Heh, wanted to ask VirMach what location (or node specifically) in Europe I should migrate my New York VPS to have most chances to stay alive... but migration is disabled
I guess I will need to pick one of the already existing idlers and this makes it much much harder decision
NY has been my favorite location so far. Stable and excellent routing.
https://billing.virmach.com/networkissuesrss.php had a change.
(removed) Current nodes facing disk-related issues:
(removed)
(removed) The following servers are being looked into together as they have similar issues related to one or more NVMe SSDs.
(removed)
(removed) * NYCB041 - Recurring issue
(removed) * TPAZ003
(removed)
(removed) Continuing to face problems:
(removed)
(removed) The following nodes have a more complicated novel issue that requires further diagnostic.
(removed)
(removed) * NYCB009 - Kernel & firmware issue
(removed) * TYOC036 - Kernel issue
(removed) * TYOC035 - Kernel issue
(removed) * SEAZ010 - Potential hardware/filesystem issue
(removed)
(added ) NYCB009 is continuing to have several issues. We are currently attempting to restore controls, but it still requires a kernel patch and firmware update for the RAID controller.
(added )
(added ) SEAZ010 is facing hardware issues in relation to the operating system disk. We're awaiting datacenter hands reseating the SATA cable.
(added )
(removed) Update: we should be contacting you today regarding your service, for the above two nodes.
(removed)
(added ) * TYOC036 - Back online
(added ) * TYOC035 - Back online
(added ) * TPAZ003 - Back online
(added ) * NYCB041 - Back online
So today™ posted weeks ago turned into we won't be contacting you at all
// just to make sure - server is set to 0.00$ billing, it's not like it was ignored or anything :P
Senior haven't told ya? I'm sorry to break it to y'all but our glorious leader ÜberchadFranz Sr. is retiring.
I am gradually taking over family biz here.
@Hakim said:
VPS from node TYOC035 is up after 2 weeks, 15 hours.
Don't worry, ma boi Soheil will take care for ya all!
I see that TPAZ003 is now back online, however my VPS instance there is not.
Main IP pings: false
Node Online: true
Service online: offline
Operating System: linux-centos-7-x86_64-minimal-latest
Service Status:Active
Registration Date:2022-12-24
@erk said: @Frankz - Was there ever a workaround or process for 'Invalid vserverid or username' ?
There was, but there no longer is, a workaround for this that I am aware of. Access to SolusVm is now restricted to going through the billing panel, so it needs to be fixed by @VirMach.
Node Online: true
To Murica? Hell no, the culture shock about guns gonna be too much for me.
@zeli said: I have a 2 core / 1700M ram / 40Gb for $15 in Amsterdam if you're interested.
That was a joke - before we would do any transfer (aka VirMach work order) I would probably be able to buy the EPYC sale and then Easter sale before that, lol. [1]
[1] Bold words here - EPYC sale before Easter sale...
why is it 2FA still broken? i had to login using backup code again
How are you defining "still"? I use it every day just fine.
3 month ago i bought vps in TYO, the 2FA works fine for few days (i logging in frequently), i also complained about this in previous thread till someone advised to temporarily uses backup code.
today i have to renew that vps, when i log in i still have to use backup code again. 2fa codes said mine was wrong (really? when it worked fine before?)
prime suspect there is private key / seed changes or broke in server-side, so i probably should deactivate it and reactivate again.. it might help if i will get the new keys.
too lazy tho, i'd rather just whine here
TYOC036 is up
, @everyone should backup data before it goes down again.
Fuck, I have nothing with 2GB of RAM.
Anyone has 2GB RAM, 2 CPU, 15+ GB disk in a Europe for a transfer? :P
Yeah, NYC looks stable AF and routing could be amazing too... but it won't help the ping from Europe (-:
Don't worry, ma boi Soheil will take care for ya too! Just hold on, he's busy with planting trees right now.
@shallow don't say that! In VirMache we trust!
Anyone with an online instance there?
"Our email system seems to have problems, I am unable to receive emails using my Outlook account."
have you considered moving?
weekend
opps wrong thread
A> @alexxgg said:
Mine is still offline. Cannot boot up as before.
Now, now .. just have to be careful where you move to. It's not like that everywhere... just most places.
only a few hops to good old Toronto
IDK did you break it again?
i dinddu nuffin'
you can disable 2fa now. thats what i did
