Managed mastodon hosting
Looking for a vps
4-8 Gb ram
2-4 cores
100gb disk space
Managed with offsite backups (just someone to do it for me and take the hassle out of it)
Can anyone help?
Thanks
Chip
  • What location
  • @NVMeNetworks said:
    What location
    Doesn't really matter... im in the UK so somewhere with good/acceptable connectivity to there
    https://www.clouvider.com/managed-hosting/
    The next in line to the throne.
  • @chip said:
    Looking for a vps
    4-8 Gb ram
    2-4 cores
    100gb disk space
    Can anyone help?
    Thanks
    Chip
    Virtual server with 2 vCore CPU, 4GB RAM, 100GB HDD, 10TB @ 2Gbps bandwidth, 100Gbps anti-DDoS protection, dual stack IPv4/IPv6 network, and various services including load balancer, IP failover, vSwitch, backup, firewall, and snapshots. Option to add additional network interface via SIIX peering port.
    €6,56/month
    What type of managing do you need?
    C1V Hosting: Low cost Italian Cloud & Data Center Solutions 🚀 | Contact us for special offers. | Our deals on Telegram
  • Hello @chip try https://panel.ihostart.com/index.php?rp=/store/ddr3-ram-vps unfortunity it s unmanaged VPS but create a cron-tab for automatically update
    Regards
    Calin
  • I was looking around before I set up my own Soapbase (Pleroma) instance and had those two saved in my bookmarks:
    Didn't try any of them though, so can't provide any more information...
    Regards
    Calin
    As a provider what did you just tell him to do?
  • @Calin said: unfortunity it s unmanaged VPS but create a cron-tab for automatically update
    wot
    Thanked by (1)AuroraZero
    €6,56/month
    I want someone to do the setup/ hand holding (day-to-day management) for me... its only going to be for me and a few friends/family (at worst)
    The problem you will run into is not the cost of the server it is the cost of the Admin to do it.
    Most management of this type of thing does not come cheap and if it does you will likely not like the outcome.
    Someone available 24/7 to do maintenance and fix broken things is a hot commodity now a days.
  • Indeed; to be honest you're probably better off looking for a dedicated mastodon hoster (I think masto.host are open again) rather than a managed VPS.
    It's something we can provide at a low fee, please DM me.
  • Another option to consider (if you're comfortable suckling at Cloudflare's teet) - https://github.com/cloudflare/wildebeest
    I've DM'd you
    Thanks
    Chip
  • I strongly recommend that you separate the VPS provider and the offsite backups to two independent entities. I would also verify the restore process before you go live. It is no fun to troubleshoot restore issues while the system is down. Just ask the FAA about NOTAM. :-(
    Thanked by (3)chip lemoncube tarasis
