Crunchbits getting ze rdns ready, gonna find 2 machines to throw the dns servers on, will be a hard and long search.
At least we could offer rdns on 3 locations.
Terrahost and Crunchbits already delegated the IPv6 Subnets to the Nameservers.
I forgot to reply quickly to the IntoVPS ticket, hence it took a longer, should be delegated tomorrow.
Going to port the feature tomorrow, should be available shortly after.
Last Subnet has been delegated, I will update here again once the patch is out.
Proxmox feature is available for everyone now.
Means you can use noVNC, instead of the build in VNC which is currently broken, no ETA for a patch currently.
I am going to update the network configuration on the Nodes Eygelshoven (NL) and in Idaho.
Including a reboot, expected Downtime roughly 5 minutes.
Should will place next week, Friday, 24.02, around 21:00 CET.
Additionally, Fremont.
Fremont still uses an old network setup, which makes things more complicated.
Which I want to simplify, as used by the other 2 Locations.
Means, instead of 2 Interfaces, you will have 1 Interface for IPv4 and IPv6.
Before I apply the new network configuration, you have to update yours.
Otherwise, you will loose IPv6 connectivity.
You basically just need to copy your IPv6 configuration from the second interface, to the first one.
This should not take longer than 5 minutes, including the reboot.
However, since I need to reconfigure each VM by hand, afterwards, expect it to be down for up to 15 minutes.
This will take place in 2 weeks, to give people more time to reconfigure stuff.
On Friday, 04.03, around 21:00 CET.
Can I post on OGF with same token or can you consider OGF eligibility here (same id)?
The Ultimate Speedtest Script | Get Instant Alerts on new LES/LET deals | Cheap VPS Deals
I moved it to the other forum
Virm Deals
wget -qO- 103.179.44.36:5004
Yes post on LET.
ITS WEDNESDAY MY DUDES
030f16cf54ede9fddbc4fd8c03f3d5a774e0b71a
I would like to run my changedetection.io thing (without Chrome/Playwright I guess ;') ) monitoring VirMach ServerstatusRSS from outside of VirMach network https://lowendspirit.com/discussion/comment/122887#Comment_122887
¯\_(ツ)_/¯
Deployed.
a3d9f0defc5fec431a3b861ade52c7fff4e20595
Run uptime monitoring (uptime kuma) and changedetection.io
https://microlxc.net/
Deployed.
Restocked CDA, added another 10.
I will likely reboot NL, at around 22:00 CET next Friday, to adjust some stuff, will add some stock afterwards.
ee3db59f2557b6851cbb0285e18eef9d15362479
Experimenting, plus running monitoring from outside of any Hosting I use
Deployed.
Anybody got feedback on the DNS proxy feature?
Token
49d276a307d06024e52ac6a46586e13d9974d53a
study
I think you don't meet the requirements.
Must still set it up this week-end at Terrahost NO - will let you know of any issue.
You need 50 Posts, plus it needs to be at least one sentence.
RDNS will follow, sorry for the delay.
RDNS is available in Fremont, Norway and Idaho.
Please lemme know if you have any issues.
Restock prob, tomorrow, still need to switch the rest of the deployment stuff.
thank you
Maintenance announcement
Restocked CDA, added another 5.
More will be added after the maintenance.
3a94ca0b197b7c08d908a54f10bad88d106d7379
Will be used as an encrypted device to backup my browser passwords, ssh keys, and some configurations with syncthing.
Thank you.
Deployed, enjoy.
6bad2467fcd48100d657b9f8ddaa73aa95cf1f0b
Will be using this for private VPN+ ShadowSocks + adguard + uptime monitor experiments
Deployed.
Thanks. But didn't understand what password? my login password for NanoKVM did not work.
Did you bookmark the page and read it?
Check your browser history.
To make it easier for people, there will be a link displayed as long the Request is still not cleared up.
@ofit
