iHostART - 5.5$/yr 50 GB HDD & 512 MB & 1 vCore & Public Torrent allowed & DMCA Ignore & 1x IPv4 NAT
11314161819
  • Great, when will you check tickets btw?
  • @Calin said: Hello yes it s possible this price , if you buy more than 8 TB + of space I can do at this price, at the moment I own a node with almost 200 TB free of space
    I only need 1TB :(
  • @Calin said:
    @arash31a said: hi @Calin site and clients area come up but node.....
    more than 4 days
    Hello I m try for fixed
    @kidoh said: 1TB HDD per 2USD/m NATVPS it's possible?
    Just curious what are the specs on this node if you don't mind
  • Hello @AuroraZero 194 TB HDD raid 5
    1x e5-2670 v2
    96 GB Ram memory
    @ccc hello i m have over 70+ tickets but i m try for replay all please leave me you email address in PM for check
    Regards,
    Calin
  • edited February 2023
    Hello everyone on this morning i m receive new 80+ DDr3 DIMM with 1600 MHz speed
    Coming soon 128/192 GB ram memory for 45-50 euros/month dedicated server <3
  • cccccc
    Won't cut in line, just confirm if tickets still being checked. Thx.
  • after the 'fix' its still unstable...
    yes
    still ontable
  • Hello @ccc depend on what type of ticket you mean , for example NAT KVM 64 are still pending other ticket we are working on them
    @cold what it s problem more exactly?You lost packets or same things? packets should not be lost
    Thanked by (2)ccc zulck
    he has no pockets!!!
    in fact he has no pants.
    yeah... a lot of outages...
  • @ehab said:
    yes
    still ontable
    more under or in btw
    Thanked by (1)ehab
  • Invoice #984 Can I get the384m ram?
  • Hello @Calin, can you check Ticket #FDT-304462?
    Thank you
  • Hi. I'm can get that 384MB extra RAM yeah? Invoice-946.pdf. Thanks.
    And please reinstall OS as requested 19 January Ticket ID: TVU-902317. Takes like 2 minutes. Cheers.
  • My server has been offline for several days
    Thanked by (1)TrendyJack
  • Helo @quartz09 and @bacangaja3 done
    @g121 what ports have?
  • only my box is working like trash or everyone else also?
  • @cold said: working like trash
    What do you mean? Can you be more specific please?
    Because I'd like to order one when my current VPS expires.
  • coldcold OG
    ping: www.google.com: Temporary failure in name resolution ... BUTmaybe this is only with NAT im not sure... maybe KVM is better
    Maybe you should try
    ping 8.8.4.4 -c 2
    If this succeeds, then the problem should lies in DNS;
    since you can connect the VPS via SSH, I believe at least the IPv4 network is fine.
    Thanked by (1)cold
    ping 8.8.4.4 -c 2
    root@debian:~# ping 8.8.4.4 -c 2
    connect: Network is unreachable
    I connect via ipv6, but I open a ticket and he will fix it soon enuff, he always does...
    @cold said: root@debian:~# ping 8.8.4.4 -c 2
    Then modify the dns to IPv6 will fix.
    /etc/resolv.conf
    nameserver 2001:4860:4860::8844
    nameserver 2606:4700:4700::1001
    Thanked by (1)cold
    /etc/resolv.conf
    thanks but i need ipv4 ;) but right now its not working so I connect via ipv6
    server is still on powersave mode... even though he said it would be changed.
    '''Server Insight                                  Hardware Information
    OS         : Debian GNU/Linux 11 (bullseye)     Model       : Intel(R) Xeon(R) CPU E5-2450L 0 @ 1.80GHz
    Location   : Romania                            Core        : 1 @ 1200.000 MHz
    Kernel     : 4.19.0                             AES-NI      : ✔ Enabled
    Uptime     : 3 days, 2 hrs, 16 mins, 11 secs    VM-x/AMD-V  : ✔ Enabled
    Virt       : openvz                             Swap        : 0.0 KiB '''
    I dont use this instance but leaving allot of preformance on the table which is why the cpu cant keep up with this oversold enviroment
  • Has he managed to get it up yet? Asking for a friend. 🤣
    🌐 Blesta.club - Blesta Modules, Plugins, Gateways and more
    💬 Join our community today and start your journey!
    Tell your friend the term house of cards comes to mind. ;)
    5091-5095
  • Done please check
    Regards,
    Calin
  • @Calin said:
    Done please check
    Regards,
    Calin
    zero inventory
