Free Alpine Linux Shell Accounts
11112131416
    @Not_Oles said:
    Hi guys! Sorry, but I just received an email from Hetrix saying that fmt ping monitor is down on IPv4 and on IPv6. Reported to @Cloudie. Will update when I know more. Thanks very much! Tom
    Hetrix says its monitors are again receiving ping responses from fmt as of eight minutes ago. :)
  • @Not_Oles said: @terrorgen Did you try it too?
    Hey Tom, just trying it and looks like you need to add me to /etc/sub{u,g}id
    Hi! Okay, added to /etc/sub*id and also to /etc/lxc/lxc-usernet. Please let me know if you need anything else. Have fun!
    Thanks! However, I can't start my LXC container. Maybe it has something to do with lxcbr0?
    edited February 2023
    Hi again @terrorgen!
    Can you please take another look at how @subenhon got his container started?
    If you did everything the same as @subenhon, are you seeing any errors? It can be helpful for seeing errors to use the "-F" a/k/a "--foreground" option to lxc-start.
    I've been busy, so, unfortunately, I haven't tried this myself yet. But I will, eventually.
    Thanks!
    Tom
  • edited February 2023
    I did, and it is stored at ~terrorgen/log if you want to take a peek.
    To save everyone's time, I think it is because of this:
    lxc-start nixos 20230220204723.613 ERROR    start - ../src/lxc/start.c:lxc_spawn:1795 - Failed to setup cgroup limits for container "nixos"
    Does the lack of systemd in Alpine contribute to this? Cause I also saw some TRACE messages related to systemd not being found.
    There are many interesting entries in those logs!
    I forgot to initialize the bridge when I last rebooted. I have to set the bridge so it starts automagically.
    Want to try starting your container again, please?
  • And it's still not working for me to get NixOS run on LXC.
    I tried downloading a standard debian and Ubuntu templates but was unsuccessful as well.
    Must be the configuration.
    It seems that the LXC containers might be working on this server! Thanks to @yoursunny for helping a lot to prepare the way! Thanks to @subenhon for blazing the trail!
    @subenhon said:
    @Not_Oles ,Here is how I create the Lxc container.
    ~ $ cat $HOME/.config/lxc/default.conf
    lxc.include = /etc/lxc/default.conf
    lxc.idmap = u 0 1022000000 65536
    lxc.idmap = g 0 1022000000 65536
    ~ $ lxc-create -n alpine -f $HOME/.config/lxc/default.conf -t download -- --dist alpine --release 3.17 --arch amd64
    Using image from local cache
    Unpacking the rootfs
    You just created an Alpinelinux 3.17 x86_64 (20230123_20:03) container.
    ~ $# change container root password and network setting frome dhcp to manual
    ~ $ lxc-attach -n alpine
    / # passwd
    Changing password for root
    New password:
    Retype password:
    passwd: password for root changed by root
    / # exit
    ~ $ # container ip config
    ~ $ echo -e "lxc.net.0.ipv4.address = 192.168.188.58/24\nlxc.net.0.ipv4.gateway = auto" >> $HOME/.local/share/lxc/alpine/config
    ~ $ echo -e "lxc.net.0.ipv6.address = 2602:fba1:999:1c00:58::/64\nlxc.net.0.ipv6.gateway = auto" >> $HOME/.local/share/lxc/alpine/config
    ~ $ #restart container
    ~ $ lxc-stop -n alpine
    ~ $ lxc-start -n alpine
    ~ $ lxc-console -n alpine
    Connected to tty 1
    Type <Ctrl+a q> to exit the console, <Ctrl+a Ctrl+a> to enter Ctrl+a itself
    Welcome to Alpine Linux 3.17
    Kernel 6.1.8-0-lts on an x86_64 (/dev/tty1)
    alpine login: root
    Password:
    Welcome to Alpine!
    The Alpine Wiki contains a large amount of how-to guides and general
    information about administrating Alpine systems.
    See <https://wiki.alpinelinux.org/>.
    You can setup the system with the command: setup-alpine
    You may change this message by editing /etc/motd.
    alpine:~# #add nameserver
    alpine:~# echo -e "nameserver 1.1.1.1\nnameserver 2001:470:20::2\n" >> /etc/resolv.conf
    alpine:~# ping -4 google.com
    PING google.com (142.251.46.238): 56 data bytes
    64 bytes from 142.251.46.238: seq=0 ttl=119 time=1.691 ms
    64 bytes from 142.251.46.238: seq=1 ttl=119 time=1.604 ms
    --- google.com ping statistics ---
    2 packets transmitted, 2 packets received, 0% packet loss
    round-trip min/avg/max = 1.604/1.647/1.691 ms
    alpine:~# ping -6 google.com
    PING google.com (2607:f8b0:4005:80b::200e): 56 data bytes
    64 bytes from 2607:f8b0:4005:80b::200e: seq=0 ttl=117 time=50.880 ms
    64 bytes from 2607:f8b0:4005:80b::200e: seq=1 ttl=117 time=1.773 ms
    There are some small differences between my procedure and @subenhon's procedure. In particular, I don't understand why @subenhon seemed to get working autoconfigured IPv4 out of the box and I perhaps didn't.
    Here is my transcript.
    # See @subenhon's post at
    # https://lowendspirit.com/discussion/comment/127589/#Comment_127589
    fmt:~/.config/lxc$ cat default.conf
    lxc.idmap = u 0 1000000000 65536
    lxc.idmap = g 0 1000000000 65536
    fmt:~/.config/lxc$ cd
    fmt:~$ lxc-create -n alpine -f $HOME/.config/lxc/default.conf -t download -- --dist alpin
    ../src/lxc/cmd/lxc_usernsexec.c: 64: opentty - Permission denied - Failed to open tty
    Downloading the image index
    Downloading the rootfs
    Downloading the metadata
    The image cache is now ready
    You just created an Alpinelinux 3.17 x86_64 (20230220_13:11) container.
    fmt:~$ lxc-ls
    alpine
    fmt:~$ lxc-attach -n alpine
    lxc-attach: alpine: ../src/lxc/attach.c: get_attach_context: 406 Connection refused - Failed to get init pid
    lxc-attach: alpine: ../src/lxc/attach.c: lxc_attach: 1470 Connection refused - Failed to get attach context
    fmt:~$ lxc-start -n alpine
    / # cd
    /bin/ash: cd: can't cd to /home/notoles: No such file or directory
    / # whoami
    root
    / # cd root
    ~ # pwd
    /root
    ~ # passwd
    New password:
    Retype password:
    ~ # echo -e "nameserver 1.1.1.1\nnameserver 2001:470:20::2\n" >> /etc/resolv.conf
    ~ # ping -4 -c 2 google.com
    ping: bad address 'google.com'
    ~ # exit
    fmt:~$ echo -e "lxc.net.0.ipv4.address = 192.168.188.10/24\nlxc.net.0.ipv4.gateway = auto
    fmt:~$ echo -e "lxc.net.0.ipv6.address = 2602:fba1:999:1c00:10::/64\nlxc.net.0.ipv6.gatew
    fmt:~$ cat -n $HOME/.local/share/lxc/alpine/config
         1  # Template used to create this container: /usr/share/lxc/templates/lxc-download
         2  # Parameters passed to the template: --dist alpine --release 3.17 --arch amd64
         3  # For additional config options, please look at lxc.container.conf(5)
         4
         5  # Uncomment the following line to support nesting containers:
         6  #lxc.include = /usr/share/lxc/config/nesting.conf
         7  # (Be aware this has security implications)
         8
         9
        10  # Distribution configuration
        11  lxc.include = /usr/share/lxc/config/common.conf
        12  lxc.include = /usr/share/lxc/config/userns.conf
        13  lxc.arch = linux64
        14
        15  # Container specific configuration
        16  lxc.include = /etc/lxc/default.conf
        17  lxc.idmap = u 0 1000000000 65536
        18  lxc.idmap = g 0 1000000000 65536
        19  lxc.rootfs.path = dir:/home/notoles/.local/share/lxc/alpine/rootfs
        20  lxc.uts.name = alpine
        21
        22  # Network configuration
        23  lxc.net.0.ipv4.address = 192.168.188.10/24
        24  lxc.net.0.ipv4.gateway = auto
        25  lxc.net.0.ipv6.address = 2602:fba1:999:1c00:10::/64
        26  lxc.net.0.ipv6.gateway = auto
    fmt:~$ lxc-stop -n alpine
    / # ping -4 -c 2 google.com
    PING google.com (142.251.32.46): 56 data bytes
    ping: sendto: Network unreachable
    / # ping -6 -c 2 google.com
    PING google.com (2607:f8b0:4005:811::200e): 56 data bytes
    64 bytes from 2607:f8b0:4005:811::200e: seq=0 ttl=119 time=1.602 ms
    64 bytes from 2607:f8b0:4005:811::200e: seq=1 ttl=119 time=1.561 ms
    round-trip min/avg/max = 1.561/1.581/1.602 ms
    / # / # ip link show
    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN qlen 1000
        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    2: eth0@if35: <BROADCAST,MULTICAST,UP,LOWER_UP,M-DOWN> mtu 1500 qdisc noqueue state UP qlen 1000
        link/ether 00:16:3e:24:60:3e brd ff:ff:ff:ff:ff:ff
    / # ip address show
        inet 127.0.0.1/8 scope host lo
        inet6 ::1/128 scope host
        inet6 2602:fba1:999:1c00:10::/64 scope global
        inet6 fe80::216:3eff:fe24:603e/64 scope link
    / # ip address add 192.168.188.10/24 dev eth0
    / # ip route add 192.168.188.1 dev eth0
    / # ip route add default via 192.168.188.1 dev eth0
    64 bytes from 142.251.46.238: seq=0 ttl=119 time=1.552 ms
    64 bytes from 142.251.46.238: seq=1 ttl=119 time=1.534 ms
    round-trip min/avg/max = 1.534/1.543/1.552 ms
    / # wget -qO- ipv4.icanhazip.com
    23.134.88.227
    / # vi ipv4-up.sh
    / # cat -n ipv4-up.sh
         1  ip address add 192.168.188.10/24 dev eth0
         2  ip route add 192.168.188.1 dev eth0
         3  ip route add default via 192.168.188.1 dev eth0
    Yes, systemd won't start in LXC container due to lack of cgroups.
    See my test report:
    https://lowendspirit.com/discussion/comment/125271/#Comment_125271
    Look at lxc.init.cmd line under "these are typed by user".
    See my test report:
    Hi @yoursunny! We were talking about setting your container quantity in /etc/lxc/lxc-usernet. Is it time to raise your quantity now? I forget how many you wanted, so can you remind me, please? Thanks!
    @terrorgen said: I tried downloading a standard debian and Ubuntu templates but was unsuccessful as well.
    Sorry to hear. I should try these as well. Do you have any info about what went wrong? Any error messages? Thanks!
  • @Not_Oles said: There are some small differences between my procedure and @subenhon's procedure. In particular, I don't understand why @subenhon seemed to get working autoconfigured IPv4 out of the box and I perhaps didn't.
    @Not_Oles I change the network type from dhcp to manual when attach to the container , maybe you missed this part.
    ~ $# change container root password and network setting from dhcp to manual
    / # passwd
    New password:
    Retype password:
    alpine:~# cat /etc/network/interfaces
    auto eth0
    iface eth0 inet manual
    hostname $(hostname)
    According to https://wiki.alpinelinux.org/wiki/LXC, cgroup can be enabled with rc-update add cgroups
    Worth a try, @Not_Oles?
    Hi again! Here are some shenanigans with Debian. :)
    fmt:~$ pwd
    /home/notoles
    fmt:~$ whoami
    notoles
    fmt:~$ lxc-create -n debian -f $HOME/.config/lxc/default.conf -t download -- --dist debia
    n --release sid --arch amd64
    You just created a Debian sid amd64 (20230220_05:24) container.
    To enable SSH, run: apt install openssh-server
    No default root or user password are set by LXC.
    fmt:~$ echo -e "lxc.net.0.ipv4.address = 192.168.188.11/24\nlxc.net.0.ipv4.gateway = auto
    > " >> $HOME/.local/share/lxc/debian/config
    fmt:~$ echo -e "lxc.net.0.ipv6.address = 2602:fba1:999:1c00:11::/64\nlxc.net.0.ipv6.gatew
    > ay = auto" >> $HOME/.local/share/lxc/debian/config
    fmt:~$ cat -n $HOME/.local/share/lxc/debian/config
         2  # Parameters passed to the template: --dist debian --release sid --arch amd64
         4
         8
         9
        14
        19  lxc.rootfs.path = dir:/home/notoles/.local/share/lxc/debian/rootfs
        20  lxc.uts.name = debian
        21
        23  lxc.net.0.ipv4.address = 192.168.188.11/24
        24  lxc.net.0.ipv4.gateway = 192.168.188.1
        25
        26  lxc.net.0.ipv6.address = 2602:fba1:999:1c00:11::/64
        27  lxc.net.0.ipv6.gateway = 2602:fba1:999:1c00:11::
    fmt:~$ lxc-start -F -n debian
    Failed to find module 'autofs4'
    Failed to mount cgroup at /sys/fs/cgroup/systemd: Operation not permitted
    [!!!!!!] Failed to mount API filesystems.
    Exiting PID 1...
    fmt:~$ # https://lowendspirit.com/discussion/comment/125271/#Comment_125271
    fmt:~/.local/share/lxc/debian$ echo lxc.init.cmd = /bin/bash >> config
    fmt:~/.local/share/lxc/debian$ cd
    fmt:~$ lxc-start -F debian
    root@debian:/# cat /etc/resolv.conf
    cat: /etc/resolv.conf: No such file or directory
    root@debian:/# ping -c 2 google.com
    ping: google.com: Temporary failure in name resolution
    root@debian:/# cd etc
    root@debian:/etc# ls -l
    total 392
    lrwxrwxrwx 1 root root      37 Feb 20 05:29 resolv.conf -> /run/systemd/resolve/stub-resolv.conf
    root@debian:/etc# rm resolv.conf
    root@debian:/etc# echo -e "nameserver 1.1.1.1\nnameserver 2001:470:20::2\n" >> /etc/resolv.conf
    root@debian:/etc# cd /root
    root@debian:/root# ping -c 2 google.com
    PING google.com(sfo03s32-in-x0e.1e100.net (2607:f8b0:4005:814::200e)) 56 data bytes
    64 bytes from sfo03s32-in-x0e.1e100.net (2607:f8b0:4005:814::200e): icmp_seq=1 ttl=117 time=66.0 ms
    64 bytes from sfo03s32-in-x0e.1e100.net (2607:f8b0:4005:814::200e): icmp_seq=2 ttl=117 time=1.82 ms
    2 packets transmitted, 2 received, 0% packet loss, time 1002ms
    rtt min/avg/max/mdev = 1.816/33.907/65.998/32.091 ms
    root@debian:/root# ping -4 -c 2 google.com
    PING  (142.251.32.46) 56(84) bytes of data.
    64 bytes from sfo03s26-in-f14.1e100.net (142.251.32.46): icmp_seq=1 ttl=119 time=1.64 ms
    64 bytes from sfo03s26-in-f14.1e100.net (142.251.32.46): icmp_seq=2 ttl=119 time=1.32 ms
    ---  ping statistics ---
    2 packets transmitted, 2 received, 0% packet loss, time 1001ms
    rtt min/avg/max/mdev = 1.318/1.478/1.638/0.160 ms
    root@debian:/root# exit
    exit
    fmt:~$ lxc-stop -n debian
    lxc-stop: debian: ../src/lxc/tools/lxc_stop.c: main: 168 debian is not running
    fmt:~$
    Hi @terrorgen!
    @terrorgen said: According to https://wiki.alpinelinux.org/wiki/LXC, cgroup can be enabled with rc-update add cgroups
    Already done, I think. Please take a look at the seond to last entry under Default runlevel.
    fmt:~$ rc-status -a
    Runlevel: nonetwork
    Runlevel: sysinit
     devfs        [  started  ]
     dmesg        [  started  ]
     mdev        [  started  ]
     hwdrivers        [  started  ]
    Runlevel: default
     vnstatd        [  started  ]
     nix-daemon        [  started  ]
     acpid        [  started  ]
     crond        [  started  ]
     sshd        [  started  ]
     cgroups        [  started  ]    <== Here!
     chronyd        [  started  ]
    Runlevel: boot
     modules        [  started  ]
     hwclock        [  started  ]
     swap        [  started  ]
     utmp-prepare                                                               [  started  ]
     sysctl        [  started  ]
     bootmisc        [  started  ]
     utmpd        [  started  ]
     seedrng        [  started  ]
     btmpd        [  started  ]
     loadkmap        [  started  ]
     wtmpd        [  started  ]
     utmp-init        [  started  ]
     hostname        [  started  ]
     syslog        [  started  ]
     networking        [  started  ]
    Runlevel: shutdown
     killprocs        [  stopped  ]
     savecache        [  stopped  ]
     mount-ro        [  stopped  ]
    Dynamic Runlevel: hotplugged
    Dynamic Runlevel: needed/wanted
     sysfs        [  started  ]
     fsck        [  started  ]
     root        [  started  ]
     localmount        [  started  ]
    Dynamic Runlevel: manual
    fmt:~$
    It looks like I can get a persistent Debian container by using tmux.
    fmt:~$ tmux
    root@debian:/#
    Inside the container, enter Ctrl-b followed by d to detach from the container and return to the host while leaving the container running.
    On the host, enter "tmux attach" to reattach to the container which is still running inside tmux.
    To stop the container from inside the container (which is inside tmux), enter "exit." To close tmux, enter "exit" again.
  • Looks like bash is PID1 in your container?
  • Btw, FMT not pingable from my end.
    @subenhon said: @Not_Oles I change the network type from dhcp to manual when attach to the container , maybe you missed this part.
    Yup. Thanks for the reminder! Much appreciated! <3
    Yeah, work in the datacenter. Downtime was not expected. But it nevertheless seems to have arrived.
    You can check
    Yeah, I think so, as a way to fix certain errors noted above which are, for easy reference, repeated here:
    Exiting PID 1...
    root@debian:/#
    Now the questions are (1) why did the errors happen, and (2) can we find a configuration that prevents them from happening?
    I typically configure "100" in lxc-usernet so it's never a limitation.
    There's really no need to place a limit here, because a user can have practically any number of containers by making creating nested containers that isn't subject to this limit.
    Exiting PID 1...
    root@debian:/#
    I got similar errors on my NixOS container about autofs and cgroup and PID1 refusing to proceed further. Looks like a systemd issue now.
  • Oh just found this from https://wiki.alpinelinux.org/wiki/LXD:
    If you plan to run systemd based Linux distributions (Debian, Ubuntu, etc.), add this to /etc/conf.d/lxc:
    systemd_container=yes
    and enable both lxc and lxd to start at boot:
     rc-update add lxc
     rc-update add lxd
     rc-update add lxcfs
    If you have problems, try to enable dbus:
    rc-update add dbus
    Reboot and lxd should be working.
    HI! The server seems to be back up, and services are restarted. If anybody has any issues, please let me know. Thanks! :)
    root@debian:/# date -u
    Tue Feb 21 22:23:21 UTC 2023
    root@debian:/# ping6 -c 2 google.com
    PING google.com(nuq04s43-in-x0e.1e100.net (2607:f8b0:4005:810::200e)) 56 data bytes
    64 bytes from nuq04s43-in-x0e.1e100.net (2607:f8b0:4005:810::200e): icmp_seq=1 ttl=119 time=59.7 ms
    64 bytes from nuq04s43-in-x0e.1e100.net (2607:f8b0:4005:810::200e): icmp_seq=2 ttl=119 time=1.76 ms
    rtt min/avg/max/mdev = 1.757/30.729/59.702/28.972 ms
    root@debian:/# ping -4 -c 2 google.com
    PING  (142.251.46.238) 56(84) bytes of data.
    64 bytes from sfo03s27-in-f14.1e100.net (142.251.46.238): icmp_seq=1 ttl=119 time=1.53 ms
    64 bytes from sfo03s27-in-f14.1e100.net (142.251.46.238): icmp_seq=2 ttl=119 time=1.61 ms
    rtt min/avg/max/mdev = 1.534/1.572/1.610/0.038 ms
    root@debian:/#
    Inside LXC Container Described Above
    root@debian:/# curl -sL yabs.sh | bash
    #                     v2022-12-29                    #
    Tue Feb 21 22:43:59 UTC 2023
    Uptime     : 0 days, 9 hours, 44 minutes
    Processor  : Intel(R) Xeon(R) CPU E5-2630L v2 @ 2.40GHz
    CPU cores  : 24 @ 1837.301 MHz
    RAM        : 62.8 GiB
    Swap       : 4.0 GiB
    Disk       : 453.3 GiB
    Distro     : Debian GNU/Linux bookworm/sid
    Kernel     : 6.1.12-0-lts
    Read       | 71.81 MB/s   (17.9k) | 119.56 MB/s   (1.8k)
    Write      | 72.00 MB/s   (18.0k) | 120.19 MB/s   (1.8k)
    Total      | 143.82 MB/s  (35.9k) | 239.75 MB/s   (3.7k)
    Read       | 119.06 MB/s    (232) | 129.29 MB/s    (126)
    Write      | 125.39 MB/s    (244) | 137.90 MB/s    (134)
    Total      | 244.46 MB/s    (476) | 267.20 MB/s    (260)
    Clouvider       | London, UK (10G)          | 854 Mbits/sec   | 210 Mbits/sec   | 143 ms
    Scaleway        | Paris, FR (10G)           | busy            | busy            | 142 ms
    NovoServe       | North Holland, NL (40G)   | 651 Mbits/sec   | 544 Mbits/sec   | 137 ms
    Uztelecom       | Tashkent, UZ (10G)        | busy            | 43.2 Mbits/sec  | 244 ms
    Clouvider       | NYC, NY, US (10G)         | 713 Mbits/sec   | 124 Mbits/sec   | 70.4 ms
    Clouvider       | Dallas, TX, US (10G)      | 627 Mbits/sec   | 633 Mbits/sec   | 41.8 ms
    Clouvider       | Los Angeles, CA, US (10G) | 785 Mbits/sec   | 645 Mbits/sec   | 26.9 ms
    Clouvider       | London, UK (10G)          | 845 Mbits/sec   | 297 Mbits/sec   | 130 ms
    Scaleway        | Paris, FR (10G)           | busy            | busy            | 141 ms
    NovoServe       | North Holland, NL (40G)   | 836 Mbits/sec   | 586 Mbits/sec   | 136 ms
    Uztelecom       | Tashkent, UZ (10G)        | 722 Mbits/sec   | 242 Mbits/sec   | 220 ms
    Clouvider       | NYC, NY, US (10G)         | 888 Mbits/sec   | 613 Mbits/sec   | 69.9 ms
    Clouvider       | Dallas, TX, US (10G)      | 920 Mbits/sec   | 795 Mbits/sec   | 41.9 ms
    Clouvider       | Los Angeles, CA, US (10G) | 933 Mbits/sec   | 902 Mbits/sec   | 11.1 ms
    Geekbench 5 Benchmark Test:
    Single Core     | 561
    Multi Core      | 7252
    Full Test       | https://browser.geekbench.com/v5/cpu/20708994
    YABS completed in 12 min 37 sec
    root@debian:/#
    On The Bare Metal Server Node
    fmt:~# curl -sL yabs.sh | bash
    #                     v2022-12-29                    #
    Tue Feb 21 23:00:46 UTC 2023
    bash: line 29: locale: command not found
    Warning: locale 'C' not detected. Test outputs may not be parsed correctly.
    Uptime     : 0 days, 10 hours, 1 minutes
    CPU cores  : 24 @ 1800.000 MHz
    RAM        : 62.8 GiB
    Swap       : 4.0 GiB
    Disk       :
    Distro     : Alpine Linux edge
    Read       | 71.90 MB/s   (17.9k) | 119.49 MB/s   (1.8k)
    Write      | 72.09 MB/s   (18.0k) | 120.12 MB/s   (1.8k)
    Total      | 143.99 MB/s  (35.9k) | 239.61 MB/s   (3.7k)
    Read       | 119.04 MB/s    (232) | 129.66 MB/s    (126)
    Write      | 125.37 MB/s    (244) | 138.29 MB/s    (135)
    Total      | 244.42 MB/s    (476) | 267.95 MB/s    (261)
    Clouvider       | London, UK (10G)          | 333 Mbits/sec   | 188 Mbits/sec   | 131.566 ms
    Scaleway        | Paris, FR (10G)           | busy            | 446 Mbits/sec   | 142.122 ms
    NovoServe       | North Holland, NL (40G)   | 231 Mbits/sec   | 554 Mbits/sec   | 136.405 ms
    Uztelecom       | Tashkent, UZ (10G)        | 698 Mbits/sec   | 149 Mbits/sec   | 220.116 ms
    Clouvider       | NYC, NY, US (10G)         | 327 Mbits/sec   | 266 Mbits/sec   | 70.053 ms
    Clouvider       | Dallas, TX, US (10G)      | busy            | 613 Mbits/sec   | 41.824 ms
    Clouvider       | Los Angeles, CA, US (10G) | 672 Mbits/sec   | 793 Mbits/sec   | 11.033 ms
    Clouvider       | London, UK (10G)          | 829 Mbits/sec   | 309 Mbits/sec   | 131.664 ms
    Scaleway        | Paris, FR (10G)           | 838 Mbits/sec   | 307 Mbits/sec   | 136.759 ms
    NovoServe       | North Holland, NL (40G)   | 837 Mbits/sec   | 585 Mbits/sec   | 136.204 ms
    Uztelecom       | Tashkent, UZ (10G)        | 644 Mbits/sec   | 276 Mbits/sec   | 219.915 ms
    Clouvider       | NYC, NY, US (10G)         | 888 Mbits/sec   | 681 Mbits/sec   | 69.913 ms
    Clouvider       | Dallas, TX, US (10G)      | 907 Mbits/sec   | 709 Mbits/sec   | 41.799 ms
    Clouvider       | Los Angeles, CA, US (10G) | 831 Mbits/sec   | 922 Mbits/sec   | 11.090 ms
    YABS completed in 7 min 35 sec
    fmt:~#
    fmt:~/Geekbench-5.4.6-Linux# ./geekbench_x86_64
    Geekbench 5.4.6 Tryout : https://www.geekbench.com/
    Running Gathering system information
    Segmentation fault
    Thanked by (1)terrorgen
  • I would also love to try one of the accounts. Thank you!!
    Hi @superyuluo!
    Welcome to LES! I hope you enjoy your time here!
    Since you have a new account, I am sure that everyone here would enjoy meeting you. Would you please introduce yourself? Please tell us
    • who and where you are,
    • about your Linux experience, and
    • what you plan to do on the server.
    Also, to give you an account, we need your ed25519 ssh public key. Would you please post your key or a link to it?
    I am looking forward to having you join us on the server!
    Best!
    Tom
    Looks like I am still not able to start my container.
     rc-update add lxc
     rc-update add lxd
     rc-update add lxcfs
    rc-update add dbus
    @Not_Oles you'll have to do this ☺️
