iHostART - 5.5$/yr 50 GB HDD & 512 MB & 1 vCore & Public Torrent allowed & DMCA Ignore & 1x IPv4 NAT
11314151719
  • my vps has been inaccessible for a few days, ports 6356-6360
  • @Calin said:
    Done please check
    Regards,
    Calin
    Hi, still unable to connect and may need to be reinstalled
  • hello,my nat vps port 6361-6365 can't connect,and 512m ram no upgrade +380m ram
    i need cheap vps year payment .
  • Hello, the service has been offline for a week
    Have recovered
  • Do you have any plan on restock? @Calin
    Has been out of stock for several days.
  • edited February 2023
    Thank you.
  • AuroraZeroAuroraZero ModeratorHosting Provider
    Thank you.
    cloudflare?
    Thanked by (1)bliss
  • i heckin' love waiting for half an hour just to install mc
    Thank you.
    Maybe @Calin 's silence equals there will be no more restock.
    So I will just walk away and seek another provider.
    @Encoders said: i heckin' love waiting for half an hour just to install mc
    Very slow disk, I've seen this before in @natvps_uk . But being cheap is more important than speed or performance.
    I wonder if there's some explanation behind this, I think apt installation are working by downloading pkg from repository then writing them into the system storage. what i don't get is, why this slowness only affect apt (well, for now), but my wget / curl download capability along with transmission can gain 10MB/s easily
  • Hello, for now we no longer plan to provide VPS-uri NAT, unfortunately maintenance to these VPS-uri is overworking and we encounter a lot of problems with them
    Thanks for all , for interest, and excuse the long response time here
    Regards,
    Calin
    Regards,
    Calin
    Are existing NAT LowEndSeedbox plans still renewable?
    Or shall I start looking for money to be able to afford the €36 next year?
    Hello , yes it s renewal
    as long as you keep the VPS with us we will offer you the same support and the same prices , i m don t have on plan for remove actualy NAT VPS
    Regards,
    Calin
    Thanked by (1)bliss
    Then disk performance is not the culprit. You need to ask Google to seek similar conditions.
    I've encountered a slow system update, which turned out to be a netplan problem, causing system freezes about 30 seconds. And the solution is simple, just remove netplan and config network with systemd-networkd.
    Thanked by (1)Encoders
    hahah I feel you. But after all of that painful slowness and 1 week provisioning time, the price is unbeatable for me to sail the seven seas. I hope we can renew this for upcoming years 😂
  • what about io speed?
  • Hello LES , becauseI like to offer people cheap prices and a decent quality I plan to offer these plans with SSD instead of HDD, yes you heard well SSD, exactly the same price and exactly the same specs just as with SSD, thing to purchase a large batch of enterprise SSDs at a low price, stay on phase
    Regards,
    Calin
  • A huge wave of customers are approaching.
    Regards,
    Calin
    Regards,
    Calin
    Can you just offer more ports per server instead ? 5 is too low. Or IPV6.
    Why?
    Looking forward to seeing new offers. Even cheap SATAs would be a good compromise.
  • Hello , it s same deal , same specifications only from HDD converted on full SSD
    Regards,
    Calin
  • I m work for add IPv6 @jmaxwell
    Thanked by (2)TrendyJack jmaxwell
  • edited March 2023
    @jmaxwell said:
    IPV6.
    These servers are advertised to have IPv6.
    Calin gave me a KVM that I can hand out IPv6 from.
    If you need IPv6:
    1. Install WireGuard on one of your UDP ports.
    2. Post the IP:port and public key in this thread.
    I will make a tunnel to your WireGuard server.
    You would get /128 only due to limitation of the KVM that I received.
    @Andrews said:
    @Calin said:
    @yoursunny said: It would not be DMCA ignored.
    Unless, you give me a free KVM NAT box?
    Then I can make tunnel there and let all the neighbors use it.
    Hello , yes it s ok , please opened ticket on website and give you
    Regards,
    Calin
    do not forget to update your TOS and mention about volunteer network traffic security inspector (before customers start asking about MITM) :D
    and if you need to draw an updated company network diagram you could start from here:
    Thanked by (2)Calin bliss
  • edited March 2023
    @yoursunny said: I will make a tunnel to your WireGuard server.
    Much appreciate it as a temporary method, thank you.
    Regards,
    Calin
    Okay, you've peaked my interest. Will you still increase the RAM?
  • OK, will you add stock any time soon ?
  • When can we expect that? Can't wait...
  • Does your panel down sir? @Calin
    http://92.84.204.2:4083/ is not accessable now
  • Hello , give you on PM IP of panel
