Free MetalVPS Intel i9-13900 Traditional Shell Account! Make Your Own VPSes!
1212224262733
  • RAM & Disk Summary:
    RAM used:  59 %
    Disk used:  91 %
    Top 20 RAM Usage:
    USER         PID %CPU %MEM    VSZ   RSS TTY      STAT START   TIME COMMAND
    shegivme  203364 69.4 12.7 10018720 8377516 ?    Sl   05:46 269:39 kvm -vnc :66,password=on -cpu host,vmx=on,-hypervisor -hda win11.img -smp 8 -m 8G -daemonize
    iamvinh+  209618  137 12.4 10272744 8162672 ?    Rl   11:38  50:43 qemu-system-x86_64 -bios /home/iamvinh123/win-vm/OVMF.fd -hda /home/iamvinh123/win-vm/os.qcow2 -pflash /home/iamvinh123/win-vm/OVMF-code.fd -pflash /home/iamvinh123/win-vm/OVMF-vars.fd -vga qxl -m 8G -cpu host,-hypervisor -smp cores=4 -usbdevice tablet --enable-kvm -daemonize -net nic,model=e1000 -net user,hostfwd=tcp::23390-:43389 -vnc 127.0.0.1:7357,password=on
    itsmepa+  207607 44.0 11.5 11001384 7597124 pts/17 Sl+ 09:59  59:36 qemu-system-x86_64 -cpu host,-hypervisor -m 8192 -smp cores=8,sockets=2 --enable-kvm -hda 11disk.qcow2 -cdrom win11.iso -net nic,model=e1000 -net user -vnc :5,password=on -monitor stdio -usbdevice tablet
    rtedpro   208600  163  9.5 7428808 6292548 pts/2 Sl+  10:47 143:46 qemu-system-x86_64 -m 6G -cpu host,-hypervisor --enable-kvm -smp cores=4 -boot d -hda vm1.img -vnc :65,password=on -monitor stdio
    dinopot+  189577  7.9  7.5 11051452 4942908 pts/15 Ssl+ May06  65:12 qemu-system-x86_64 -cpu host -m 8G -hda 10.qcow2 -cdrom 1022H2.iso -net nic -net user,hostfwd=tcp::3243-:80 -usbdevice tablet -smp 16 -vnc :96,password=on -monitor stdio --enable-kvm
    kadim19+  172671 16.1  4.9 5367400 3280528 pts/20 Sl+ May06 252:19 qemu-system-x86_64 -m 4G -cpu host --enable-kvm -smp cores=3 -boot d -hda Windwos-server-2022.qcow2 -monitor stdio -vnc :72,password=off -net nic,model=e1000 -net user,hostfwd=tcp::4389-:3399,hostfwd=tcp::2080-:80,hostfwd=tcp::27015-:27015 -machine usb=on -device usb-tablet -vga qxl
    nubuki     11502 27.7  4.0 4621632 2671012 pts/13 Sl+ Apr29 3278:56 qemu-system-x86_64 -nographic -serial mon:stdio -net user,hostfwd=tcp::2223-:23 -net nic,model=virtio -cpu host -enable-kvm -m 3G -smp 3 -hda debian.qcow2
    exajimag  207203 16.9  3.0 9511788 2015844 pts/9 Sl+  09:27  28:16 qemu-system-x86_64 -hda win8release.img -m 8G -vnc :59 -smp cores=4 -cpu host -enable-kvm -net user,hostfwd=tcp::4000-:3389 -net nic -object rng-random,id=rng0,filename=/dev/urandom -device virtio-rng-pci,rng=rng0 -monitor stdio -machine usb=on -device usb-tablet
    nubuki     11028 23.4  2.2 3219976 1456440 pts/11 Sl+ Apr29 2764:02 qemu-system-x86_64 -nographic -serial mon:stdio -net user,hostfwd=tcp::2222-:22 -net nic,model=virtio -cpu host -enable-kvm -smp 2 -m 2G -hda debian-sid-nocloud-amd64-daily.qcow2
  • edited May 2023
    @dinopotato said:
    I did it
    Windows 11 Pro 22H2 on Proxmox UEFI
    Ok since you already did it I dont need to try it since it's working so I will try something else.
    Probably I will try pterodactyl panel or OpenVPN server. But since I'm busy with my studies lately (final exam will come in around 2 weeks!!!!), maybe I will post an update in this forum in a few days.
  • edited May 2023
    @terrorgen said:
    @iamvinh123 said:
    Finally, Windows 7 on an Pentium CPU with only 66MHz
    Windows 7 on Windows 10 on Linux, why?
    I want to test old CPUs out and QEMU had issues with Windows 9x
    I also wanted to try some other things that I can't try in my PC
  • @Not_Oles said: Great that you got in and super great that sudo works!
    Please feel free to go ahead and use the server heavily. Check what the other guys are doing first. Please post here if you want to "reserve" a large amount of resources.
    Please install anything you want. If you break the server, don't worry, because breaking stuff is the best way to learn, and it's easy to reprovision the server.
    Please let me take the occasion to thank you for your always courteous, always informative, and very helpful posts.
    Thank you so much for granting me access to the server and for your kind words. I appreciate your trust in me and I will make sure to use the resources responsibly and considerately.
    I will definitely check with the others before reserving a large amount of resources and will post here if necessary.
    Regarding installing software, I will be mindful of not compromising the server's stability and security, and will seek your advice if needed.
    Once again, thank you for your support and I look forward to working on the server. 😊
  • FYI, you can check the server load and resource usage here: http://fsn.metalvps.com:8000/latest.txt
    Since this is a shared server, do "share" the resources and dont hog all to yourself. For example, if you are going off for the night, you may want to stop your "Windows VM" unless you are doing something on it. Small things like that help others who want to use the server.
    Thanked by (2)terrorgen Not_Oles
    Top RAM users:
    @SheGivMeItAgain -> 12 GB
    @ExAjiMag -> 8 GB
    @iamvinh123 -> 8 GB
    @dinopotato -> 8GB + 8GB -> 16 GB total
    @Kadim1998 -> 4GB
    @Nubuki -> 3GB + 2GB -> 5GB
    @welllam -> 2GB
    shegivme 194152 178 19.0 14493996 12499656 ? Sl 02:23 119:26 kvm -vnc :66,password=on -cpu host,vmx=on -cdrom tiny11 b1.iso?dl=0 -hda win11.img -smp 10 -m 12G -daemonize
    exajimag 125435 76.9 12.7 9750592 8380484 pts/9 Sl+ May04 3112:20 qemu-system-x86_64 -hda win10.img -m 8G -vnc :59 -smp cores=4 -cpu host -enable-kvm -net user,hostfwd=tcp::4000-:4000 -net nic -object rng-random,id=rng0,filename=/dev/urandom -device virtio-rng-pci,rng=rng0 -vga qxl -monitor stdio -machine usb=on -device usb-tablet
    iamvinh+ 191551 41.7 12.4 10211268 8139564 pts/7 Sl+ 00:59 62:43 qemu-system-x86_64 -bios /home/iamvinh123/win-vm/OVMF.fd -hda /home/iamvinh123/win-vm/os.qcow2 -pflash /home/iamvinh123/win-vm/OVMF-code.fd -pflash /home/iamvinh123/win-vm/OVMF-vars.fd -vga qxl -m 8G -cpu host,-hypervisor -smp cores=4 -usbdevice tablet --enable-kvm -monitor stdio -net nic,model=e1000 -net user,hostfwd=tcp::23390-:43389 -vnc 127.0.0.1:7357,password=on
    dinopot+ 189577 11.9 8.9 10996960 5847716 pts/15 Ssl+ May06 34:52 qemu-system-x86_64 -cpu host -m 8G -hda 10.qcow2 -cdrom 1022H2.iso -net nic -net user,hostfwd=tcp::3243-:80 -usbdevice tablet -smp 16 -vnc :96,password=on -monitor stdio --enable-kvm
    kadim19+ 172671 15.6 5.8 5385904 3813840 pts/20 Sl+ May06 162:00 qemu-system-x86_64 -m 4G -cpu host --enable-kvm -smp cores=3 -boot d -hda Windwos-server-2022.qcow2 -monitor stdio -vnc :72,password=off -net nic,model=e1000 -net user,hostfwd=tcp::4389-:3399,hostfwd=tcp::2080-:80,hostfwd=tcp::27015-:27015 -machine usb=on -device usb-tablet -vga qxl
    dinopot+ 164280 3.4 4.9 11080048 3232056 pts/5 Ssl+ May06 55:34 qemu-system-x86_64 -cpu host -m 8G -hda Ubuntu.qcow2 -cdrom Ubuntu.iso -net nic -net user,hostfwd=tcp::6969-:80 -usbdevice tablet -smp 16 -vnc :56,password=on -monitor stdio --enable-kvm
    nubuki 11502 28.6 4.3 4634996 2860400 pts/13 Sl+ Apr29 3231:21 qemu-system-x86_64 -nographic -serial mon:stdio -net user,hostfwd=tcp::2223-:23 -net nic,model=virtio -cpu host -enable-kvm -m 3G -smp 3 -hda debian.qcow2
    nubuki 11028 24.1 2.9 3255656 1951844 pts/11 Sl+ Apr29 2728:47 qemu-system-x86_64 -nographic -serial mon:stdio -net user,hostfwd=tcp::2222-:22 -net nic,model=virtio -cpu host -enable-kvm -smp 2 -m 2G -hda debian-sid-nocloud-amd64-daily.qcow2
    welllam 65608 0.1 0.9 2960892 602028 pts/12 Sl+ May01 10:55 qemu-system-x86_64 -nographic -cpu host -enable-kvm -m 2G -hda /home/welllam/debian-sid-nocloud-amd64-daily.qcow2
    As always mate, gotta let other users be able to use it.
    Hi Guys!
    In addition to the usage kindly posted above by @somik we're down to 235G disk.
    I am just about to add @H4N50. Let's assume @H4N50 wants 100G. That leaves 135G.
    We could wipe the accounts of a few of the "paused" users, but maybe it's better to wipe and reinstall the server?
    oot@fsn ~ # df -h .
    Filesystem      Size  Used Avail Use% Mounted on
    /dev/md4        3.4T  3.0T  235G  93% /
    root@fsn ~ #
    Best!
    Tom
    @H4N50 Good morning! I went ahead and made an account for you. It would be super great if we can talk some more soon. Note that, unless I missed it, you still didn't post anything about your education and experience. :( Watch out, cuz the server might be going down for a refresh soon. Not going away permanently, I hope. Please note low disk space. Kindest regards, Tom
    References:
    https://lowendspirit.com/discussion/comment/138703/#Comment_138703
    https://lowendspirit.com/discussion/comment/138717#Comment_138717
    https://lowendspirit.com/discussion/comment/138747#Comment_138747
    https://lowendspirit.com/discussion/comment/138759#Comment_138759
    https://lowendspirit.com/discussion/comment/138782#Comment_138782
    https://lowendspirit.com/discussion/comment/138800#Comment_138800
    https://lowendspirit.com/discussion/comment/138809#Comment_138809
    https://lowendspirit.com/discussion/comment/138915#Comment_138915
    root@fsn /home/h4n50 # ls -alR
    total 28
    drwx------  3 h4n50 h4n50 4096 May  7 18:34 .
    drwxr-xr-x 35 root  root  4096 May  7 18:31 ..
    -rw-r--r--  1 h4n50 h4n50  220 May  7 18:31 .bash_logout
    -rw-r--r--  1 h4n50 h4n50 3526 May  7 18:31 .bashrc
    -rw-r--r--  1 h4n50 h4n50    0 May  7 18:31 .cloud-locale-test.skip
    -rw-------  1 h4n50 h4n50   17 May  7 18:33 password
    -rw-r--r--  1 h4n50 h4n50  807 May  7 18:31 .profile
    drwx------  2 h4n50 h4n50 4096 May  7 18:34 .ssh
    ./.ssh:
    total 12
    drwx------ 3 h4n50 h4n50 4096 May  7 18:34 ..
    -rw------- 1 h4n50 h4n50   81 May  7 18:35 authorized_keys
    root@fsn /home/h4n50 # cat .ssh/authorized_keys
    ssh-ed25519 AAAAC3NzaC1lZDI1NTE5AAAAIP76M+51oxuJNjxGt1TZo8dEGXvzgtt1KQd/iLOxYkWu
    • Password access has been disabled. You need your key to log in.
    • Your password is in a mode 600 file in your home directory.
    • Your password might be needed later for sudo. But you have not yet been added to the sudo group.
    • Feel free to change your password.
    • You have been added to the kvm group.
    • If you want to make a KVM VPS it is recommended to start with slirp following this tutorial.
    • Alternatives include setting up proot as described earlier in this thread.
    • Additional node configuration might be needed for LXC and non-slirp qemu.
    • Please post your questions and progress reports and tutorials here in this thread. It benefits everyone to help answer everyone else's questions and to learn from everyone else's progress reports and tutorials. So, please post here instead of sending me PMs (PMs are okay if privacy really is necessary).
    Hello again!
    1. How should the upcoming, refreshed i9-13900 server be set up?
    2. is it too crazy to imagine that some guys might want to pay something toward the € 89 monthly cost of renting the server from Hetzner?
    Thanks for your ideas! :)
    Friendly greetings! :)
    Tom
    Hello again!
    Tom
    1 - No clue lol
    2 - It's not crazy! Some people are kinda (like you) and give away stuff so some people decide to help keep it alive!
    Also I want to forward the iGPU from the VPS to the windows 11 VM I have (KVM), any clue? Google wasn't helpful on this topic as most require the kernel to be changed which is impossible without root/restarting the server. If you know just let me know!
    References:
    total 28
    ./.ssh:
    total 12
    To login, please try something like ssh [email protected] -p 42365. Should work on IPv4 and on IPv6. Please post here in the thread to let us know whether you can get in okay. Hope you have fun on the server! :) Best wishes! Tom
  • I would like to cancel youself64 account in MetalVPS.
    Hello! The server has been rebooted into the Hetzner rescue system. Nobody can login now. Apologies! More details soon. :)
    What happened? Did it kernel panick?
    References:
    total 28
    ./.ssh:
    total 12
    Hi Tom, thanks for creating an account, I really appreciate it, I just have one question, I'm new to this, how do I connect, could you give me the connection instructions? thank you
  • @H4N50 said:
    @Not_Oles said:
    References:
    total 28
    ./.ssh:
    total 12
    Your public key will automatically be selected if your using openssh-client for others, depending on the app, you may have to Google the solution. Shouldn't be that hard.
  • @SheGivMeItAgain said:
    @H4N50 said:
    @Not_Oles said:
    References:
    total 28
    ./.ssh:
    total 12
    Apologies I misread the question:
    You can Google how to ssh into the VPS using your publickey for your specified app. E.G: Putty.
  • @Not_Oles any updates?
    Hi @youself64! Thanks for letting us know! I will remove your account. Best wishes and good luck for the future! Tom
    edited May 2023
    Guys!
    Hetzner's careful monitoring caught an outbound port scan coming from our i9-13900 server. Since we already were planning to reinstall the server, it seemed like the abuse issue could be most definitively and immediately resolved by taking the server offline. So I activated the rescue system.
    To make sure that everyone understands, it was my decision to take the server offline. Not Hetzner's. Hetzner did not interfere with our server in any way. All Hetzner did was to send me their helpful notifiction. I am really grateful to Hetzner for doing a great job, not only with monitoring, but with everything else which could be expected from a top provider! Thank you Hetzner! <3
    Please note that only the i9-13900 is offline. The i9-9900K still is up and functioning normally, as of a moment ago when I checked.
    Tom
    Thanked by (3)FrankZ Nubuki Yqua
    Hi @SheGivMeItAgain!
    Please check the update that I just posted. If you have further questions or concerns, please post them.
    However, please stop posting repeatedly on the same issue. I am slow. I need to ask you for patience and for extra time. Please wait at least 24 hours before repeatedly posting about the same issue.
    Tom
    To make sure that everyone understand, it was my decision to take the server offline. Not Hetzner's. Hetzner did not interfere with our server in any way. All Hetzner did was to send me their helpful notifiction. I am really grateful to Hetzner for doing a great job, not only with monitoring, but with everything else which could be expected from a top provider! Thank you Hetzner!
    Please note that only the i9-13900 is offline. The i9-9900K still is up and functioning normally, as of last time I checked.
    Ah, alright, any chance I could be added to that?
    edited May 2023
    Everyone please take a moment to reflect. @Not_Oles (Tom) is probably up to his arm pits in things to do at the moment (besides being clueless, and slow :wink: ). So maybe it would be a good time to refrain from unnecessarily adding to his burden.
    Note: Tom I normally refrain from commenting in your threads out of respect. I hope you will excuse this intrusion.
    Yeah that's understandable, I agree with you.
  • edited May 2023
    @Not_Oles said: Hello! The server has been rebooted into the Hetzner rescue system. Nobody can login now. Apologies! More details soon.
    People in i9 9900K still can use?
    oh nvm i dont see another message
    Thanks for your request!
    I take your request as a sign of continued confidence in MetalVPS.
    I wish I could immediately add you to the i9-9900K. However, it will be a little while before new account creation is resumed.
    Tom
    Hi @FrankZ!
    Always on the job, always considerate, always friendly! I admire you! You are an example for all of us to follow.
    I am doing fine. My personal preference is that everyone continues contributing meaningful comments to this thread. I will continue responding as time allows.
    Always best wishes and sincere thanks for your work here at LES! LES is much better off because of you!
    Respectfully,
    Tom a/k/a @Not_Oles
    Thanked by (3)Wonder_Woman FrankZ Yqua
    Tom
    Alright! I'll wait then. Also apologies for rushing you, I was in the middle doing something and it stopped and I am not sure if I lost data or anything.
    Tom
    Hope all is okay. I wish we had real time communication with everyone on the server.
    Tom
    Yeah that would be pretty cool. You could always try setup a websocket chat VIA the terminal if needed.
