Changes to NatVPS
17810121315
  • Due to an increase in DMCA takedowns from users torrenting we have moved our automated torrent detection from permissive mode to enforced mode.
    Anyone downloading torrents will be suspended automatically, this is a 3 strike rule and works as follows:
    1st offence: 24 hour suspension
    2nd offence: 1 week suspension
    3rd offence: 2 week suspension
    4th offence: Service termination
    This is active on the UK, FR, DE, KR and CA nodes. If you believe this has been triggered unfairly you may open a support ticket and we will investigate, if you open a support ticket and we find that you have in fact breached our TOS you may have your account terminated.
    Just a reminder that we take abuse seriously, we will enforce suspension and termination for any abusive activities.
    Thanked by (2)Brueggus bdl
  • Torrents still allowed in Calin location?
    Wikipedia archive torrents (open source content) still allowed everywhere?
    No hostname left!
    The automated blocking is only in place on the locations above. All torrent activity will result in suspension as we cannot programmatically determine the content. However if someone does have legitimate use for torrents that does not breach UK/EU law we can potentially whitelist them.
    All other locations do allow the use of the BitTorrent protocol although we do not condone illegal activity or breach of copyright law.
  • @sh97 said:
    Hey @natvps_uk
    Any updates on the new UK node?
    We have the node, we’re in the process of getting our own ASN to be able to do deals with /64 and /48 ranges. Just waiting on ripe - the node is ready to go once we get the address space.
  • OpenVZ with /64 isn't very useful because addresses must be individually added to the container.
    LXC with /64 is useful because LXC has real Ethernet netif and can support routed subnets.
    Will we get LXC with BGP session?
    • Each BGP session consumes ¼ credit.
    • Customer can announce up to 10 prefixes and they must be RPKI valid.
    • Up to 250 updates per hour.
    • Only available in locations that can support BGP automation.
    No hostname left!
  • The new node is openvz although we can automate the routing, we can offer bgp in this location for no additional cost.
    We will be adding a bunch of UK NAT dedis, KVM and openvz deals in the coming months which will all come with BGP.
    The dedis will start from £5 per month, KVM VPS’ from £2.50 per month.
    Thanked by (2)loay go626201
  • Bug report: I'm seeing negative values for KR bandwidth usage, like this:
    <div class='progress'>
      <div class='bar' role='progressbar' style='width: -12%; color: black;'
        aria-valuenow=-12 aria-valuemin='0' aria-valuemax='1000'
        title='Bandwidth used in Korea - Total bandwidth for the KR location, this is enforced.'
        -12G/100
      </div>
    </div>
    Instance id=9621.
    No hostname left!
    ```html
    aria-valuenow=-12 aria-valuemin='0' aria-valuemax='1000' > title='Bandwidth used in Korea - Total bandwidth for the KR location, this is enforced.' > > > -12G/100 >
    Instance id=9621.
    Thanks @yoursunny, this is a known issue and is currently on the backlog to be fixed. It’s just a reporting issue - we can access the actual bandwidth usage.
  • 🇰🇷 Seoul, Korea
    0G/50
    ok now im confused, now it shows bandwidth limit is 50 instead of 200,
    which one is correct?
    It’s 100gb per credit, if you have 0.5 credits it’s technically 50GB although we won’t suspend your VM unless it breaches 100Gb.
  • yea i meant 100gb, sorry
    maybe i failed to see the the AUP somewhere but im sure it was 100gb limit before.
    im not a heavy bandwidth user so maybe 50gb also fine
  • why can't I add ssh key using ed25519 format? is it RSA only?
  • It seems that at this time the "Enable Tun/Tap" option does not work on newly created micro-instances (all locations). Is anyone facing this issue?
    I’ll take a look
    Found the bug, it’s hotfixed now. Please let me know if you have any issues!
  • @natvps_uk that was quick, issue fixed. Thank you.
    No problem!
  • I wonder what's the necessity of "enable TUNTAP" button?
    Why not having it enabled during container creation time?
    No hostname left!
    We had considered this, the real reason is our devs just replicated the functionality from our previous panel - SolusVM.
    I might just set it to be default.
    Thanked by (1)benz
  • edited April 2023
    still no answer lol
    I just wanted to get my ssh-copy-id or login ssh using key working
    fixed this one by replacing the ssh server on my own. i don't get why it's dropbear by default, what a nonsense.
    adding ssh key in panel is just a qol thing, I whine about this because this vps salt-minion keeps dying and i have to ssh to it to restart the daemon (I give the systemd service RuntimeMaxSec=1h so now it'll always restart on it's own)
    Sorry for the slight Necro.. but
    @natvps_uk is the node ready? 😄
    Also, any offers coming soon? It's been quite sometime!
    It’s been built for a while but we’ve had a few performance issues and haven’t put it in production.
    We’ve been working on integrating the Micronode panel for other providers which has taken priority recently although we will have some deals pretty soon. Realistically it’s probably going to be another month before we do anything special.
    Thanked by (2)sh97 Calin
    i.e. iHostART
    No hostname left!
  • @yoursunny no ads on other thread please , Thanks!
    Thanked by (1)benz
  • All right, when do we get container resizing in more locations?
    I'm most interested in having this feature at Germany, which has plenty of resources.
    No hostname left!
    Any KVM updates? KVM is much better than containerization
  • RadiRadi Hosting ProviderOG
    How is it going? Can you share any license prices? Can it do PXE boot and reinstall for dedicated servers? Are you open to paid custom coding for it?
    Thanked by (1)Micronode
  • edited May 2023
    £100 setup fee for branding etc
    £20 per month per node (VMs) for businesses with NAT functionality, fully managed SaaS hosted with panel DDoS protection.
    £20 per month per rack for dedicated server provisioning (minimum one rack 48u)
    £75 one off fee for WHMCS integration
    Personal licences will be cheaper but we’re still working on this.
    Yes, it supports openvz and dedicated hardware. Raspberry Pi 4s can even be automatically provisioned and all x86 hardware that supports pxe can be provisioned.
    Currently on the x86 side we only support Debian, Ubuntu and Centos7/8 and a rescue mode for custom OS installs.
    Yes, DM me what you require.
    DM-ed.
