Changes to NatVPS
1911131415
  • I forgot my SSH password, how can I reset it?
    I tried to add SSH Public Key and reboot, but it didn't work.
    edited May 2023
    Next time, try to first test SSH Key login in another terminal window, before you disable pw auth or reboot. Some providers allow you to change rootpw in dashboard, I can't remember if that's the case for @natvps_uk , too?
  • What’s wrong with Romania node ? Servers get created but can’t connect via SSH. “Connection failed” @natvps_uk
    Why?
  • MicronodeMicronode Hosting Provider
    You will likely have to reprovision the VM with a new password. You can open a ticket for a password reset although we’re a little backlogged currently.
    I can take a look, I assume this is just on VM creation? I can SSH to my test VM.
  • @natvps_uk said: I assume this is just on VM creation?
    Mine came up apparently yesterday again after some days of downtime.
    Yes for newly created VMs on RO node. SSH issue seems to be fixed now but can’t enable TUN/TAP. When I click the button, it says enabled on the GUI but nothing happens on the VM.
    Why?
    I'll take a look into this shortly, the networking issues were resolved this morning.
    Thanked by (1)jmaxwell
    AMS Network Upgrade
    Just a quick update for the AMS instances, we have upgraded the network in this region. Previously it was on a Microwave based site to site link which in theory should have had gigabit connectivity. The reality is it got around 50mbps upload and the download was anywhere from 100mpbs to 1gbps depending on contention and the weather. Yes the weather actually affected the performance.
    This is now on a leased line although the tunneled connectivity remains the same, performance should match our FR nodes with around 1gbps down and 100mbps upload. The improvement here is the reliability, it should be vastly improved in comparison to the old setup.
    AMS instances still come with Double the RAM and disk entered at provisioning so grab them whilst they last, this location will not be restocked for some time once the node is full.
    Okay, I have submitted a ticket, please help me deal with it when you have time.
  • Hi natvps_uk ,can u check for Ticket #JHZ-955234?
    I had waited for 1+ month for the resolution.
    MY/SG & Worldwide Latency Test V3 : http://www.mywebping.com (27 February 2021 Updated)
    MY-Unifi Home SmokePing: http://smokeping.mywebping.com/smokeping/
  • edited May 2023
    @natvps_uk said:
    AMS Network Upgrade
    Network is working.
  • @natvps_uk I was unable to SSH to RO instance.
    Recreated instance, still the same.
    @jmaxwell how was the SSH issue fixed for you?
  • edited May 2023
    @hlolve said:
    @natvps_uk said:
    AMS Network Upgrade
    Network is working.
    cannot create any instance there!!
    Try now
    @ehab said:
    @hlolve said:
    @natvps_uk said:
    AMS Network Upgrade
    Network is working.
    Try now
    Thanked by (2)sh97 jmaxwell
    Try now
    @ehab said:
    @hlolve said:
    @natvps_uk said:
    AMS Network Upgrade
    Network is working.
    Try now
    works now, thanks!!
  • edited May 2023
    @natvps_uk YES
    working and got my *2 memory and *2 disk
    i <3 you :)
    hopefully you get time to answer my pm
  • Looks good now.
    Why?
  • @natvps_uk said:
    @yoursunny said: Yes, that's the instance editing feature they is coming soon™.
    This is now live for RAM only, disk will follow soon.
    Currently only enabled for UK and CA although all other nodes will follow in the coming days.
    The "coming days" has become 3 months.
    Apologies, I will get it out asap. Other tasks got in the way, which location do you want it on most? Maybe I can prioritise the rollout.
    Romania
    Why?
  • edited June 2023
    I'm currently using Limburg and Seoul.
    I'm waiting for resizing feature to roll out worldwide so that I can start using other locations as well.
  • Is IPv6 working in Limburg ? I tried to create there, but IPv6 always failed. Tried with debian and ubuntu
  • AMS node is not working
    Please check now
  • @natvps_uk said:
    Please check now
    Fixed. Thank you
  • @natvps_uk ,can you check for Ticket #JHZ-955234?
    I had waited for 2+ month for the resolution. And no one replies for the ticket...
    Thanked by (1)Micronode
    Looks like the ticket is wrongly assigned, I’ll make sure it gets actioned.
    Thanked by (1)go626201
  • Debian 12 should be available on 2023-06-10 according to this:
    https://lists.debian.org/debian-devel-announce/2023/04/msg00007.html
    How long after will it take for NatVPS LTD to offer a template of Debian 12 on the MicroNode Instances platform as well as iHostART panel?
  • @natvps_uk said:
    Please check now
    AMS is offline or node down ?
    Now is fixed
    Thanked by (1)ElonBezos
