@soj1 said:
I forgot my SSH password, how can I reset it?
I tried to add SSH Public Key and reboot, but it didn't work.
Next time, try to first test SSH Key login in another terminal window, before you disable pw auth or reboot. Some providers allow you to change rootpw in dashboard, I can't remember if that's the case for @natvps_uk , too?
You will likely have to reprovision the VM with a new password. You can open a ticket for a password reset although we’re a little backlogged currently.
@jmaxwell said:
What’s wrong with Romania node ? Servers get created but can’t connect via SSH. “Connection failed” @natvps_uk
I can take a look, I assume this is just on VM creation? I can SSH to my test VM.
Yes for newly created VMs on RO node. SSH issue seems to be fixed now but can’t enable TUN/TAP. When I click the button, it says enabled on the GUI but nothing happens on the VM.
I'll take a look into this shortly, the networking issues were resolved this morning.
Just a quick update for the AMS instances, we have upgraded the network in this region. Previously it was on a Microwave based site to site link which in theory should have had gigabit connectivity. The reality is it got around 50mbps upload and the download was anywhere from 100mpbs to 1gbps depending on contention and the weather. Yes the weather actually affected the performance.
This is now on a leased line although the tunneled connectivity remains the same, performance should match our FR nodes with around 1gbps down and 100mbps upload. The improvement here is the reliability, it should be vastly improved in comparison to the old setup.
AMS instances still come with Double the RAM and disk entered at provisioning so grab them whilst they last, this location will not be restocked for some time once the node is full.
Okay, I have submitted a ticket, please help me deal with it when you have time.
Why?
Mine came up apparently yesterday again after some days of downtime.
Why?
AMS Network Upgrade
Hi natvps_uk ,can u check for Ticket #JHZ-955234?
I had waited for 1+ month for the resolution.
MY/SG & Worldwide Latency Test V3 : http://www.mywebping.com (27 February 2021 Updated)
MY-Unifi Home SmokePing: http://smokeping.mywebping.com/smokeping/
Network is working.
@natvps_uk I was unable to SSH to RO instance.
Recreated instance, still the same.
@jmaxwell how was the SSH issue fixed for you?
cannot create any instance there!!
Try now
Try now
works now, thanks!!
@natvps_uk YES
working and got my *2 memory and *2 disk
i you
 you
hopefully you get time to answer my pm
Looks good now.
Why?
The "coming days" has become 3 months.
vps9hostname is available. affbrrApologies, I will get it out asap. Other tasks got in the way, which location do you want it on most? Maybe I can prioritise the rollout.
Romania
Why?
I'm currently using Limburg and Seoul.
I'm waiting for resizing feature to roll out worldwide so that I can start using other locations as well.
vps9hostname is available. affbrrIs IPv6 working in Limburg ? I tried to create there, but IPv6 always failed. Tried with debian and ubuntu
AMS node is not working
Please check now
Fixed. Thank you
@natvps_uk ,can you check for Ticket #JHZ-955234?
I had waited for 2+ month for the resolution. And no one replies for the ticket...
Looks like the ticket is wrongly assigned, I’ll make sure it gets actioned.
Debian 12 should be available on 2023-06-10 according to this:
https://lists.debian.org/debian-devel-announce/2023/04/msg00007.html
How long after will it take for NatVPS LTD to offer a template of Debian 12 on the MicroNode Instances platform as well as iHostART panel?
vps9hostname is available. affbrrAMS is offline or node down ?
Now is fixed
