so how to open the instance? deploy a script for monitoring it?
@frakass said: so how to open the instance? deploy a script for monitoring it?
The movie?
Never make the same mistake twice. There are so many new ones to make. It’s OK if you disagree with me. I can’t force you to be right.
Use the API to deploy, you may have luck.
At the first sight, I though you were talking about stardict, which is a fantastic open source dictionary software.
@somik said: show previous quotes @frakass said: so how to open the instance? deploy a script for monitoring it? The movie?
Stardust has Daredevil and Superman fighting each other in it.
@AC_Fan said: show previous quotes @somik said: @frakass said: so how to open the instance? deploy a script for monitoring it? The movie? Stardust has Daredevil and Superman fighting each other in it.
Can't say I have watched this movie... Maybe i'll pick it up.
@giang said: Use the API to deploy, you may have luck.
Yea use API.
Yep. I've concluded it's a waste of time even at free
@havoc said: Yep. I've concluded it's a waste of time even at free
No, they actually just work, and given you can get 2 for just 1€ its a steal.
People are talking about scaleway.com starlight learning instances, yes ?
@Neoon said: show previous quotes @havoc said: Yep. I've concluded it's a waste of time even at free No, they actually just work, and given you can get 2 for just 1€ its a steal.
@Neoon said:
Yeah not bad, but I just don't have the patience to jump through hoops like that.
Also, stuff like oracle free tier will absolutely wreck stardust. (Assuming oracle doesn't hate you & randomly deletes your acc ofc).
Who has a link to an API Scaleway guide?
https://www.scaleway.com/en/docs/compute/instances/api-cli/creating-managing-instances-with-cliv2/
The movie?
Yea use API.
