Yeah it’s unhappy after yesterdays outage. I may have to restore from backup.
It could be down for a little while longer.
Looks like it is screwed again. Can’t connect to SSH and when I try to reboot/reprovision, it loads for a while and shows cloudflare error “bad gateway”.
Funny it is exactly same issue for one of the NAT server in ihostart panel.
I believe iHostArt got the panel licensed by NatVPS.
Yes. Natvps_uk’s Romania server is provided by Calin. So I think it’s more of a Calin problem rather than Panel problem
We had 148 Minutes of downtime on the AMS node this morning. The issue turned out to be faulty RAM. After a quick memtest to confirm the module it was swapped out from parts that we had spare on site.
As for the Romania node I believe some maintenance was carried out last night by the provider. There was 193 minutes of downtime on the node although some VMs might not have came back up immediately.
Whilst we try to maintain the best uptime possible across the board we can’t guarantee this for the bonus locations. Occasionally downtime should not be unexpected.
Debian 12 is coming 🤷
<input type=radio>showed up in MicroNode, but not yet selectable.RAM and diks resizing are still waiting.
No hostname available. affbrr
natvps.micronode.uk
Cloudflare: Host Error
Fixed
uk node is down.
No downtime has been reported and I can connect to several test VMs. The load is definitely higher than expected though.
@natvps_uk maybe high cpu load is causing this, but I can't access my site nor ssh, just spinning.
Hetrixtools is showing UK down since about ~9hr ago, can confirm I can't ssh in and a reboot via MicroNode didn't help
UK is back online!
Downtime: 9 hr 55 min
Noticed at: 2023-06-28 01:07:51
it is online finally.
uk node down again?
It is, we're working on it.
Back now.
uk node is still down.
now it's up.
https://natvps.uk/ - this portal not get offer vps nat, this is fail, or all vps is end now ? thk.
You mean because you get this error ?
@Nata73 - 768mb and up UK nat VPS are available here: https://clients.natvps.uk/index.php?rp=/store/micronode-vps
Also Germany, Canada, France, Finland nat VPS and some storage nat also are available on same page
yes - this link work for me. thk.
very nice.
@natvps_uk Romania down?
Critical Error
Could not connect to the database.
https://natvps.micronode.uk/login.php
ERROR: Could not connect. Connection refused
Why?
Why?
romania and netherland down ?
both back online
