Budget is around $30-$40 a month
@Calin
Hello thanks for mention @Hertonis
If you like e5-v4 check our deals https://panel.ihostart.com/index.php?rp=/store/vps-kvm-ssd
Regards
If you're only interested in AMD based servers i can recommend liteserver.nl. Otherwise check out Calin's offering as mentioned above.
ServerFactory aff nonaff has EPYC 7702P in Dronten Netherlands. €37/month buys 8 cores, 32 GB RAM, 400 GB NVMe, 64 TB egress and unmetered ingress on 1 Gbps port. DMCA ignored for web hosting, but public torrents usage is discouraged.
HostBrr aff best VPS. We are impotent.
@Calin
Regards
We are impotent.
