@cyforex said:
my goddamn vps is down again. IP has changed but I have no ping... no access
damn it I am so mad..
vvery bad experience with you Virmach
What node are you on ?
What did you do regarding the IP change ?
What O/S are you using ?
Maybe post the output from "ip route show" to see if the default gateway is setup correctly.
Give us a little info and maybe we can get you going so you don't have to be so mad.
@Jab said:
Holy balls, VirBot AI Assistant in reply to my ticket told me to open a ticket to fix the issue.
Ticket-ception.
Should I open new ticket and blame VirBot or will @VirMach would get mad?!
If someone made an open source module then I could fix it, until then it's soontm as we'll probably take forever to make our own. Our own version in testing doesn't ever tell you to make a ticket because we made sure to tell it that.
@FrankZ said: Give us a little info and maybe we can get you going so you don't have to be so mad.
He prefers being mad all the time so he's taking the correct approach for that end result.
I'm assuming he actually also didn't read or reply to the ticket for the IP change either, no reconfigure, and then either didn't reply back to it or made a new ticket because we've definitely been monitoring those tickets very actively for people replying back and assisting them. Best to come here first to say how mad he is first.
@dgc1980 said: reinstall via the Full VPS Control Panel, there is no limit on that.
This is from Solus control panel.
How many times have you re-installed? Sounds like you might have actually reached your limit. Our policy on that is if you actually reach the upper limit in the panel, you've officially broken our I/O AUP but make a ticket explaining it correctly and it should get reset (probably not actually, you'll just get plus one re-install usually.)
@VirMach said: How many times have you re-installed? Sounds like you might have actually reached your limit. Our policy on that is if you actually reach the upper limit in the panel, you've officially broken our I/O AUP but make a ticket explaining it correctly and it should get reset (probably not actually, you'll just get plus one re-install usually.)
I will just wait till next month, no Debian template anyway.
@dgc1980 said: mount netboot.xyz and install it manaully manually.
If netboot.xyz can manage to configure the network, eventually and if the chosen ISO works. [I figured my issue wasn't the looong time it took to grab the network but the actual loading of Alma 8 & CentOS 7 ISOs, from netboot.xyz]
@VirMach said: Our policy on that is if you actually reach the upper limit in the panel, you've officially broken our I/O AUP but make a ticket explaining it correctly and it should get reset
There is no snapshot to rollback like Vultr or GoogleCloud provide,
Wha' wou'ya expec' your sorry lads do, when the Chicken went broke
Ticket-ception.
Sorry I have anger issues. no disrespect. I know some stuff is out of your control. but seriously for the past few weeks, the service been unusable.
anyways works fine now. FYI, I DID read the email.
regards
Ticket-ception.
regards
Ticket-ception.
regards
So what'd you do to fix it?
nothing the IP started pinging an hour later. however. I went into the main control panel and reconfigured the network a couple of times. (there's an option for it)
I'm not sure if that fixed the problem. but my new IP started pinging.
Huh, new node?
Ticket-ception.
Just blame VirBot for everything it is sooo much simpler.
Free Hosting at YetiNode | MicroNode | Cryptid Security | URL Shortener | LaunchVPS | ExtraVM | Host-C | In the Node, or Out of the Loop?
My VPS in FFME02 is still down
Location? I did both an Atlanta and a NY fine.
RYZE.PHX-Z001.VMS says You have reached your reinstall limit for this month
reinstall via the
, there is no limit on that.This is from Solus control panel.
mount netboot.xyz and install it manaully.
thanks, now I have Debian installed.
Yo' another new customer victim I presume?
Ontario Dildo Inspector
FYI
https://billing.virmach.com/cart.php?a=add&pid=250
Overpriced small plate chicken nevertheless
O'quite funny though, $27.5 quarterly, $120 annually,
Sincerely doubt the old fart could do math
regards
Repentance and join the flagellation club?
Hey, can you like stop quoting 78155 posts back and pinging half of the forum ^.-
Can consider hiring me if VirMach wants a Frontend Engineer for the portal...
Can I? Probably ... the question is will I? Mwhahahahahahahah.
Yo so ya could do frontend stuff too
thinking of VirmAch flush sale monitor site
Should not be a big surprise to maa
Any spoiler news of this year's black friday deals on the other side?
Any news about GCV 10th anniversary specials?
Using netboot.xyz or Debian 10 from the template?
YAAAAAAAS
yes, I used Debian 10 iso, even though you have to do some tweaking.
Yo Friday is another fine day, tell ya sorry ass a joke
What would fish say when it hits a wall?
DAM
