Most budget dedicated provider thanks
24
  • Too PREM
    Too JANK
    More than I really want to lay but there is a WOWSER storage server.
    Some reasonable budget options!
    Uninspiring
    Hmmmm, Pentium!
  • @OsirisBlack said:
    @Nekki said:
    @OsirisBlack said:
    deinserverhost - found them to be ok.
    @Amadex said:
    https://deinserverhost.de/dedicated-servers
    Too PREM. I don’t need (or want to pay for) fast Xeons and Ryzens. Thank.
    Look at their 'Dedicated Server Sonderposten'
    Intel i3 6100
    16 GB
    1 TB HDD
    1 TB HDD
    26.00€
    for example.
    Didn’t realise the list isn’t sorted by price, so I missed the cheaper stuff, thank!
  • @Nekki said:
    @localhost said:
    @Nekki said:
    @Chievo said:
    On the serious note. Terrahost?
    I'm with Terrahost at the moment, having some issues so looking to try out alternatives ahead of time in case I want to cancel/transfer ahead of it's renewal around BF.
    What's that you have with terrahost? Incase you eat to transfer out.. would love to get it
    It's the yearly special from a couple of BFs ago, i3-4130 with a 2TB drive (should have been 500GB). There's already a waiting list for the transfer, I'll put you on it - I want to move away from it but I keep having issues with potential replacements,
    Sounds good. What position will I be honored to start at?
    @Nekki said:
    @Nekki said:
    @Nekki said:
    We can give you a good dedicated server if you fight an actual wolf.
    Do I have to do it again, I can I provide video evidence of a previous wolf fight?
    Gotta be live stream on XTube.
    Who supplies the wolf?
    I do and it is a Zombie Wolf!
    Do I get any weapons?
    No weapons and have you have to wear a bacon bikini and pork chop sandals!
  • So we have a total of 18.4 quintillion blocks of 18.4 quintillion IPv6 IPs?!?
    edited July 2023
    What about some cheap Raspberry Pi Hosting then? Map some network storage/drive and be done with it. Ikoula RPi starts from 6,99€/mo iirc.
    Or maybe @DataIdeas Josh can put a 500GB Flash card in their Pi for you?
    https://rpiservers.com/
    3rd of 4th, most likely. I'll check in with the rest of the line when the time comes to shift. Last renewal was about £100/$130/year.
    Thanked by (1)localhost
    I shall rely on my flaccid sausage, then.
    Ikoula is JANK personified.
    An RPI might work. I might even be able to run it from home. In-ter-est-ing....
  • OneProvider currently have stock for Xeon E3-1220 8 GB 2× 1 TB (HDD SATA) 1 Gbps Unmetered €14.00 in Paris
    Thanked by (1)Erisa
    Depending on what you wanna do, maybe a self-hosted RPi at home will do. If you need networking use smth like Zerotier. Works liek a charm :)
    That's the sorta shiz I be diggin'.
  • edited July 2023
    @Nekki said: I still have no idea what the deal with Andy10gbit is or how it all works.
    a Leaseweb/OVH reseller for the seedbox market. No control panel. No billing platform. No tickets. Discord is the ticket system :lol:
    so if you have a problem with the server your best bet is to contact him over at Discord to solve the issue e.g Hardware replacement etc..
    but the servers and his support are prem.
    am I still at the front?
  • @Nekki said:
    So if I understand this correctly, my route to a free dedicated server is to kill a wolf with my partially erect penis?
    You don't kill the wolf.
    You let the wolf bite that thing off.
    Discord is a cancer, etc.
    Thanked by (1)SeederKun
    You are indeed.
    Thanked by (1)fluttershy
    That seems quite the price for a free dedi.
    What’s the spec?
  • edited July 2023
    Just to add to this, OneProvider are resellers. For their France servers it will either be Scaleway Dedibox (Online.net) or OVH. You can usually tell which is which because the Scaleway/Online.net ones are 1Gbps unmetered while the OVH have weird speed caps like 100Mbps/250Mbps/500Mbps.
    So if you want to avoid OVH hardware, keep an eye out.
    Thanked by (1)Nekki
    Not fussed about their hardware, just opting out of dealing with them directly.
    Thanked by (1)Erisa
  • KuroitKuroit Hosting Provider
    Got this available in West Midlands, UK:
    Intel Xeon E3-1240 v6 @ 3.70GHz
    64GB DDR4 ECC RAM
    500GB SSD
    20TB Bandwidth @ 1Gbps Uplink
    Please DM if interested!
    https://www.kuroit.com - Managed cPanel Hosting & VPS Hosting in UK
    64GB DDR4 ECC RAM
    500GB SSD
    I can’t tell if I’m interested, I don’t know the price.
    Whereabouts in the West Midlands?
    64GB DDR4 ECC RAM
    500GB SSD
    Redditch (DC: VeloxServ) to be exact. Let me know if that works, we can discuss pricing ;)
  • @Kuroit said:
    64GB DDR4 ECC RAM
    500GB SSD
    It's far more power than I need, I suspect you’ll be asking for more than I want to pay.
  • 2 available as I write this ::
    1230*, 16G, 4x2T, 1G Unmetered €36,49
    https://my.hostingby.design/index.php?rp=/store/leaseweb-nl
  • edited July 2023
    By the way there is also this. They're obviously resellers, not sure from where.
    There are a few dedis under <~15 EUR with at least 1TB + unmettered traffic
    https://www.sitehotel.de/bare-metal-france
    I had a vps from them, never had issues.
    Thanked by (4)Nekki localhost ehab someTom
    Do you know of the servers come with kvm/ ipmi? Thnx
    Sorry, no idea.
    resold oneprovider
    Thanked by (2)SeederKun Ympker
