I'm with Terrahost at the moment, having some issues so looking to try out alternatives ahead of time in case I want to cancel/transfer ahead of it's renewal around BF.
What's that you have with terrahost? Incase you eat to transfer out.. would love to get it
It's the yearly special from a couple of BFs ago, i3-4130 with a 2TB drive (should have been 500GB). There's already a waiting list for the transfer, I'll put you on it - I want to move away from it but I keep having issues with potential replacements,
Sounds good. What position will I be honored to start at?
3rd of 4th, most likely. I'll check in with the rest of the line when the time comes to shift. Last renewal was about £100/$130/year.
@Ympker said:
What about some cheap Raspberry Pi Hosting then? Map some network storage/drive and be done with it. Ikoula RPi starts from 6,99€/mo iirc.
@Nekki said: I still have no idea what the deal with Andy10gbit is or how it all works.
a Leaseweb/OVH reseller for the seedbox market. No control panel. No billing platform. No tickets. Discord is the ticket system
so if you have a problem with the server your best bet is to contact him over at Discord to solve the issue e.g Hardware replacement etc..
but the servers and his support are prem.
@emperor said:
OneProvider currently have stock for Xeon E3-1220 8 GB 2× 1 TB (HDD SATA) 1 Gbps Unmetered €14.00 in Paris
That's the sorta shiz I be diggin'.
Just to add to this, OneProvider are resellers. For their France servers it will either be Scaleway Dedibox (Online.net) or OVH. You can usually tell which is which because the Scaleway/Online.net ones are 1Gbps unmetered while the OVH have weird speed caps like 100Mbps/250Mbps/500Mbps.
So if you want to avoid OVH hardware, keep an eye out.
Not fussed about their hardware, just opting out of dealing with them directly.
By the way there is also this. They're obviously resellers, not sure from where.
There are a few dedis under <~15 EUR with at least 1TB + unmettered traffic
Too PREM
Too JANK
More than I really want to lay but there is a WOWSER storage server.
Some reasonable budget options!
Uninspiring
Hmmmm, Pentium!
Didn’t realise the list isn’t sorted by price, so I missed the cheaper stuff, thank!
No weapons and have you have to wear a bacon bikini and pork chop sandals!
https://www.turnkeyinternet.net/dedicated-servers/best-value-servers/
Or maybe @DataIdeas Josh can put a 500GB Flash card in their Pi for you?
https://rpiservers.com/
I shall rely on my flaccid sausage, then.
Exceeds my price range considerably. Thank.
Ikoula is JANK personified.
An RPI might work. I might even be able to run it from home. In-ter-est-ing....
ServerStatus , slackvpn , linux mirrors
Recommended Providers: Servarica(aff) | HostBRR(aff) | SolidVPS(aff) | RackNerd(aff) | KuroIT(aff) | AlphaVPS(aff) | HostDare(aff)
Depending on what you wanna do, maybe a self-hosted RPi at home will do. If you need networking use smth like Zerotier. Works liek a charm
am I still at the front?
You don't kill the wolf.
You let the wolf bite that thing off.
Discord is a cancer, etc.
You are indeed.
That seems quite the price for a free dedi.
What’s the spec?
Got this available in West Midlands, UK:
Intel Xeon E3-1240 v6 @ 3.70GHz
64GB DDR4 ECC RAM
500GB SSD
20TB Bandwidth @ 1Gbps Uplink
Please DM if interested!
https://www.kuroit.com - Managed cPanel Hosting & VPS Hosting in UK
I can’t tell if I’m interested, I don’t know the price.
Whereabouts in the West Midlands?
Redditch (DC: VeloxServ) to be exact. Let me know if that works, we can discuss pricing
It's far more power than I need, I suspect you’ll be asking for more than I want to pay.
2 available as I write this ::
1230*, 16G, 4x2T, 1G Unmetered €36,49
https://my.hostingby.design/index.php?rp=/store/leaseweb-nl
https://www.sitehotel.de/bare-metal-france
I had a vps from them, never had issues.
Do you know of the servers come with kvm/ ipmi? Thnx
Sorry, no idea.
resold oneprovider
