Yo deadpooled.com, ya might put refugee offer on that site
Sarcastically, if ya decided run away one day like the purple daddy did,
that domain might come handy
@abjr said: @VirMach Your ticketing system is broken. Trying to raise a ticket and all I get back is some JSON: {"success":true}
I haven't raised a ticket in a while but are you sure you're reading all the instructions on the screen 100% completely/properly? That's been an issue in the past.
Support -> Open Ticket -> Contact Us -> Select Service -> Deployment Issue -> Continue -> "If you are still having issues with your service, click here to submit a ticket." -> Click Here -> returns a page with just "{"success":true}"
No chance to type anything in or explain the issue.
Yeah, that's broken .... :-/
Try this, Support -> Open Ticket -> Contact Us -> Not Related To A Service
Carefully follow the on screen instructions from there to select your Department, Related Service, etc..... It'll at least let you generate a ticket. What happens from there I can't say.
The servers in Chicago with "QuadraNet" are facing a network outage. This is the third such outage, which we believe is caused solely by poor network management with this particular datacenter partner. We will be considering proceeding with migrations away from these servers/datacenter after networking is restored.
Seems that the Secaucus DC is having network issues again, not just VirMach, as my VMs with other providers there are also effected.
Not sure about that. dedicated.com isn't showing any issues, any my servers with hosthatch which were impacted by the previous Secaucus fire are still going strong.
Looks like you are correct as the status page for dedipath shows no network outage. https://status.dedicontrol.com/ Could it be just a coincidence that my VM at the other provider in Secaucus went down at the same time. I guess we will find out.
my LAX dedi with them just went down at the same time my NJ VPS with VirMach went down. I think it's an issue with DediPath and they just haven't updated status page.
Looks like NYJ and LAX affected (Evocative DataCenters?): DediPath, EthernetServer, VirMach - again
All of my VPS from these providers and locations unreachable..
They are offline in Evocative DC's, status page is wrong
I can confirm too. All of my services online again (from the previously mentioned providers and locations).
Looks like it was only a network outage, because all of my processes running on the VPS's and the uptimes not changed.
The "reset" button which was formerly the reboot button has been fully switched to the new actual reset button, which resets the boot order, unmounts ISO, and then attempts to reboot.
@KuYeHQ said:
Is there any new progress in the HK data center, I have prepared 25-40 dollars for it
Yo
deadpooled.com
, ya might put refugee offer on that siteSarcastically, if ya decided run away one day like the purple daddy did,
142 Euro goes directly down to the toilet
Will ya sell Tokyo Ryzen 7000 futures?
AM5 motherboard price has dropped,
besides that, Ryzen Threadripper 7000 Listings Hint at AMD's Return to HEDT
Yo Frankz, each time if there was post, ya will receive a notice right?
smartass shitposting satirist
Yes, a hundred comments, and I get a hundred notices.![:scream: :scream:](https://lowendspirit.com/plugins/emojiextender/emoji/twitter/scream.png)
What's the problem btw?
Fixed.
Poor VirMach.
NYCB022
NYCB028
SJCZ002
Operation Timed Out After 90000 Milliseconds With 0 Bytes Received
EDIT: Also down on SJCZ007, so something might be going on there in San Jose as well ?
Probably fire again, NY nodes are off again.
POLL: DO WE PANIC?
YES / NO
Some subnets related to VirMach and DediPath are not available anymore. Their status is "Low Visibility Prefixes".
https://bgp.tools/as/35913?show-low-vis#prefixes
NYC seems back up again![:) :)](https://lowendspirit.com/plugins/emojiextender/emoji/twitter/smile.png)
Everything is operational again, Thanks!![B) B)](https://lowendspirit.com/plugins/emojiextender/emoji/twitter/sunglasses.png)
Same here, my SJCZ007 is also up and working. Neither VPS was restarted, so just a network issue.
Don't panic because they have great IT workers
definitely not virmach mistake this time!
it is dung-time, let the DC burns
Yo @VirMach with all due curiosity,
wa'z your daily routine, jus' fix the broken racks, close most of the tickets and call it a day?
Is there any new progress in the HK data center, I have prepared 25-40 dollars for it![:) :)](https://lowendspirit.com/plugins/emojiextender/emoji/twitter/smile.png)
Hopefully never.
i thought mainland china has bad ping to HK, and tokyo is best overall?
