1170171173175176415
  • edited July 2023
    @VirMach said: Let me check, which one?
    Yo deadpooled.com, ya might put refugee offer on that site
    Sarcastically, if ya decided run away one day like the purple daddy did,
    that domain might come handy
    @VirMach said: €142.69
    142 Euro goes directly down to the toilet
    Will ya sell Tokyo Ryzen 7000 futures?
    AM5 motherboard price has dropped,
    besides that, Ryzen Threadripper 7000 Listings Hint at AMD's Return to HEDT
    Yo Frankz, each time if there was post, ya will receive a notice right?
    Ontario Dildo Inspector
  • @VirMach Your ticketing system is broken. Trying to raise a ticket and all I get back is some JSON: {"success":true}
    @Flying_Chinaman said: Yo Frankz, each time if there was post, ya will receive a notice right?
    Yes, a hundred comments, and I get a hundred notices. :scream:
    Thanked by (1)KuYeHQ
  • skorousskorous OGSenpai
    I haven't raised a ticket in a while but are you sure you're reading all the instructions on the screen 100% completely/properly? That's been an issue in the past.
    Support -> Open Ticket -> Contact Us -> Select Service -> Deployment Issue -> Continue -> "If you are still having issues with your service, click here to submit a ticket." -> Click Here -> returns a page with just "{"success":true}"
    No chance to type anything in or explain the issue.
    Yeah, that's broken .... :-/
    Try this, Support -> Open Ticket -> Contact Us -> Not Related To A Service
    Carefully follow the on screen instructions from there to select your Department, Related Service, etc..... It'll at least let you generate a ticket. What happens from there I can't say.
    What's the problem btw?
    Fixed.
  • JabJab Senpai
    The servers in Chicago with "QuadraNet" are facing a network outage. This is the third such outage, which we believe is caused solely by poor network management with this particular datacenter partner. We will be considering proceeding with migrations away from these servers/datacenter after networking is restored.
    Poor VirMach.
  • NYCB022
    NYCB028
    SJCZ002
    Operation Timed Out After 90000 Milliseconds With 0 Bytes Received
    Thanked by (2)ZA_capetown FrankZ
    edited July 2023
    Seems that the Secaucus DC is having network issues again, not just VirMach, as my VMs with other providers there are also effected.
    EDIT: Also down on SJCZ007, so something might be going on there in San Jose as well ?
    Not sure about that. dedicated.com isn't showing any issues, any my servers with hosthatch which were impacted by the previous Secaucus fire are still going strong.
    Thanked by (2)FrankZ BHS
    Looks like you are correct as the status page for dedipath shows no network outage. https://status.dedicontrol.com/ Could it be just a coincidence that my VM at the other provider in Secaucus went down at the same time. I guess we will find out.
    Thanked by (1)titus
    my LAX dedi with them just went down at the same time my NJ VPS with VirMach went down. I think it's an issue with DediPath and they just haven't updated status page.
  • Probably fire again, NY nodes are off again.
  • Looks like NYJ and LAX affected (Evocative DataCenters?): DediPath, EthernetServer, VirMach - again
    All of my VPS from these providers and locations unreachable..
    Thanked by (2)fluttershy FrankZ
  • AdvinAdvin Hosting Provider
    They are offline in Evocative DC's, status page is wrong
  • JabJab Senpai
    POLL: DO WE PANIC?
    YES / NO
  • Some subnets related to VirMach and DediPath are not available anymore. Their status is "Low Visibility Prefixes".
    https://bgp.tools/as/35913?show-low-vis#prefixes
    @Jab said:
    POLL: DO WE PANIC?
    YES / NO
  • NYC seems back up again :)
  • @BHS said:
    NYCB022
    NYCB028
    SJCZ002
    Everything is operational again, Thanks! B)
    edited July 2023
    Same here, my SJCZ007 is also up and working. Neither VPS was restarted, so just a network issue.
    Thanked by (1)BHS
  • I can confirm too. All of my services online again (from the previously mentioned providers and locations).
    Looks like it was only a network outage, because all of my processes running on the VPS's and the uptimes not changed.
  • @Jab said:
    POLL: DO WE PANIC?
    YES / NO
    Don't panic because they have great IT workers
    definitely not virmach mistake this time!
  • it is dung-time, let the DC burns
    Thanked by (1)ariq01
  • edited July 2023
    Yo @VirMach with all due curiosity,
    wa'z your daily routine, jus' fix the broken racks, close most of the tickets and call it a day?
  • Is there any new progress in the HK data center, I have prepared 25-40 dollars for it :)
    The "reset" button which was formerly the reboot button has been fully switched to the new actual reset button, which resets the boot order, unmounts ISO, and then attempts to reboot.
    Hopefully never.
    i thought mainland china has bad ping to HK, and tokyo is best overall?
