i5-10500T - 32GB DDR4 - 1TB NVMe - 1Gbps Unmetered - $38 Dedi // Quiet launch, read more inside...
 crunchbits
                Hosting Provider
crunchbits
                Hosting Provider
@Cloudie on the phone placing an order for 20, circa 2023
Before you get too excited, let's start off with the cons of these dedicated servers (compared to our normal enterprise offerings):
- No KVM/console access
- PXE actions are still a little buggy, so all orders require a manual staff member approval initially to make sure you're being delivered a properly deployed OS
- You're welcome to reinstall via our control panel afterwards if you want to, but it sometimes requires an abort and retry (or two)
- No redundant power supplies
- No customization, what you see is what you get
Understanding the above will be crucial for expectation setting. While we actively have some upgrade work going on behind the scenes to help with making the PXE re-deployment smoother, the ETA on that is still 5-14 days out. That being said, I'm personally excited to get some feedback on these and figure LES members will be excited to get a recurring discount on something I don't think we'll ever discount again moving forward.
The good:
* $45 $38/mo w/code: IKNOWWHATIMBUYING
* i5-10500T (6c/12t) up to 3.8GHz
* 32GB DDR4
* 1TB NVMe
* 1Gbps Unmetered
* Direct Order Link
Yabs:
root@47-DP-U26-L:~# curl -sL yabs.sh | bash
#                     v2023-04-23                    #
Fri Aug  4 06:52:06 AM UTC 2023
Uptime     : 0 days, 3 hours, 38 minutes
Processor  : Intel(R) Core(TM) i5-10500T CPU @ 2.30GHz
CPU cores  : 12 @ 2300.000 MHz
RAM        : 31.1 GiB
Swap       : 3.8 GiB
Disk       : 912.0 GiB
Kernel     : 6.1.0-10-amd64
VM Type    : NONE
ISP        : Redoubt Networks
ASN        : AS400304 REDOUBT NETWORKS
Host       : Atomic Networks LLC
Country    : United States
Read       | 793.62 MB/s (198.4k) | 1.15 GB/s    (18.0k)
Write      | 795.72 MB/s (198.9k) | 1.15 GB/s    (18.1k)
Total      | 1.58 GB/s   (397.3k) | 2.31 GB/s    (36.1k)
Read       | 1.26 GB/s     (2.4k) | 1.13 GB/s     (1.1k)
Write      | 1.32 GB/s     (2.5k) | 1.21 GB/s     (1.1k)
Total      | 2.59 GB/s     (5.0k) | 2.34 GB/s     (2.2k)
Clouvider       | London, UK (10G)          | 830 Mbits/sec   | 175 Mbits/sec   | 127 ms
Scaleway        | Paris, FR (10G)           | 837 Mbits/sec   | busy            | 143 ms
NovoServe       | North Holland, NL (40G)   | busy            | 586 Mbits/sec   | 133 ms
Uztelecom       | Tashkent, UZ (10G)        | busy            | 187 Mbits/sec   | 227 ms
Clouvider       | NYC, NY, US (10G)         | 888 Mbits/sec   | 69.5 Mbits/sec  | 62.2 ms
Clouvider       | Dallas, TX, US (10G)      | 892 Mbits/sec   | 348 Mbits/sec   | 61.4 ms
Clouvider       | Los Angeles, CA, US (10G) | 910 Mbits/sec   | 801 Mbits/sec   | 38.1 ms
Single Core     | 1508
Multi Core      | 6251
Full Test       | https://browser.geekbench.com/v6/cpu/2143471
YABS completed in 10 min 31 sec
network-speed.xyz:
---------------------------- network-speed.xyz ----------------------------
      A simple script to test network performance using speedtest-cli
 Version            : v2023.07.24
 Global Speedtest   : wget -qO- network-speed.xyz | bash
 Region Speedtest   : wget -qO- network-speed.xyz | bash -s -- -r <region>
 Basic System Info
 CPU Model          : Intel(R) Core(TM) i5-10500T CPU @ 2.30GHz
 CPU Cores          : 12 @ 2355.225 MHz
 CPU Cache          : 12288 KB
 AES-NI             : ✔ Enabled
 VM-x/AMD-V         : ✔ Enabled
 Total Disk         : 912.1 GB (1.1 GB Used)
 Total RAM          : 31.1 GB (564.2 MB Used)
 Total Swap         : 3.8 GB (0 Used)
 System uptime      : 0 days, 0 hour 17 min
 Load average       : 0.08, 0.73, 0.47
 OS                 : Debian GNU/Linux 12
 Arch               : x86_64 (64 Bit)
 Virtualization     : NONE
 Basic Network Info
 Primary Network    : IPv4
 Location (IPv4)    : Spokane, Washington, US
 Location         Latency     Loss    DL Speed       UP Speed       Server
 ISP: Sakura Network LTD
 Nearest          36.48 ms    0.0%    937.55 Mbps    932.53 Mbps    Xiber LLC - Kansas City, MO
 Kochi, IN        255.44 ms   0.0%    396.20 Mbps    348.98 Mbps    Asianet Broadband - Cochin
 Bangalore, IN    238.61 ms   0.0%    564.51 Mbps    358.53 Mbps    Bharti Airtel Ltd - Bangalore
 Chennai, IN      235.25 ms   0.0%    451.83 Mbps    376.46 Mbps    Tata Play Fiber - Chennai
 Mumbai, IN       263.39 ms   0.0%    449.91 Mbps    317.40 Mbps    i3D.net - Mumbai
 Delhi, IN        277.73 ms   0.0%    411.29 Mbps    314.31 Mbps    Tata Teleservices Ltd - New Delhi
 Seattle, US      13.26 ms    0.0%    815.04 Mbps    934.19 Mbps    DediPath - Seattle, WA
 Los Angeles, US  36.07 ms    0.0%    936.48 Mbps    916.66 Mbps    ReliableSite Hosting - Los Angeles, CA
 Dallas, US       44.79 ms    0.0%    816.31 Mbps    915.63 Mbps    Hivelocity - Dallas, TX
 Miami, US        86.55 ms    0.0%    894.51 Mbps    891.69 Mbps    AT&T - Miami, FL
 New York, US     63.81 ms    0.0%    872.82 Mbps    929.21 Mbps    Clouvider Ltd - New York, NY
 Toronto, CA      68.89 ms    0.0%    886.10 Mbps    931.79 Mbps    Rogers - Toronto, ON
 London, UK       127.63 ms   0.0%    960.70 Mbps    686.19 Mbps    VeloxServ Communications - London
 Amsterdam, NL    54.85 ms    0.0%    642.80 Mbps    549.06 Mbps    Clouvider Ltd - Amsterdam
 Paris, FR        132.89 ms   N/A     954.16 Mbps    669.07 Mbps    Axione - Paris
 Frankfurt, DE    139.32 ms   0.0%    909.81 Mbps    628.34 Mbps    23M GmbH - Frankfurt Am Main
 Warsaw, PL       161.72 ms   0.0%    559.68 Mbps    562.48 Mbps    UPC Polska - Warszawa
 Bucharest, RO    186.02 ms   0.0%    654.89 Mbps    485.27 Mbps    Vodafone Romania Fixed – Bucharest - Bucharest
 Jeddah, KSA      197.89 ms   0.0%    521.44 Mbps    455.86 Mbps    Saudi Telecom Company
 Dubai, AE        240.73 ms   0.0%    672.72 Mbps    313.99 Mbps    du - Dubai
 Fujairah, AE     267.35 ms   0.0%    875.39 Mbps    313.67 Mbps    ETISALAT-UAE - Fujairah
 Tokyo, JP        92.62 ms    N/A     732.51 Mbps    650.11 Mbps    fdcservers.net - Tokyo
 Shanghai, CU-CN  189.60 ms   0.0%    746.94 Mbps    475.84 Mbps    China Unicom 5G - ShangHai
 Nanjing, CT-CN   162.29 ms   0.0%    588.43 Mbps    408.98 Mbps    China Telecom JiangSu 5G - Nanjing
 Hong Kong, HKG   147.21 ms   N/A     590.57 Mbps    620.28 Mbps    STC - Hong Kong
 Singapore, SG    160.08 ms   0.0%    687.62 Mbps    571.82 Mbps    i3D.net - Singapore
 Jakarta, ID      211.12 ms   0.0%    407.50 Mbps    178.53 Mbps    PT. Telekomunikasi Indonesia - Jakarta
 Avg DL Speed       : 701.39 Mbps
 Avg UL Speed       : 582.85 Mbps
 Total DL Data      : 28.21 GB
 Total UL Data      : 21.47 GB
 Total Data         : 49.67 GB
 Duration           : 14 min 6 sec
 System Time        : 04/08/2023 - 03:45:26 UTC
 Total Script Runs  : 20226
Very nice offer, any VPS offers coming soon?
Will make a final decision on that with the team tomorrow--but any requests? Had something unique prepared for another LES exclusive, but I haven't decided if it is for sure yet.
Crunchbits.com
no IPv6?
Is iGPU available?
They have IPv6 available, we just have to assign them on request for the moment.
iGPU is included, this is bare metal.
Crunchbits.com
These went way too quickly. We'll restock them tomorrow.
Crunchbits.com
Any offers for the NVMe or SSD VPS?
Is it possible to request kvm temporarily?
If it's not too much - some limited stock annual deals under $20?
Haha I didn't even get the tag notification for this one. :-)
I'll buy 20, if you give me all the other goods :-D
I just have to ask... what is the relationship between @crunchbits and @Cloudie?
Seems to be a lot of PDA.
At the moment, no. We do have some portable KVMs that were likely going to be dedicated to these--but sort of weighing out the options on them.
Precisely what was discussed and prepared. Probably closer to ~$17/yr limited deals that won't go up on the website.
Strictly PDA.
Crunchbits.com
Were all of them bought up by Cloudie?
Yeah, existing customers I believe. There will be a few more this evening, as well as a LES-only treat.
Crunchbits.com
Did I miss the LES treats?
You did not. It's on pause for a day or three--forgot we had something staged already with OGF. It'll be slightly better when it goes up here anyways.
Crunchbits.com
Patience is virtue... let me wait here
if again possible to restock?
Coming today.
Don't think LES will get left out. Not only will you not get left out, but I'll be able to subtract $200 right off the top and pass it along (regarding the ogf yearly bonanza). You might even be blessed in missing out on all the shenanigans after the deal was invaded by hostloc & co
Crunchbits.com
I'm 100% in for one if/when they restock.
Curious... based on the hardware specs and the caveats, are these 1L business desktops? I've always wanted to toy with the idea of deploying them in a datacenter at some point.
Yes, these are rack mounted HP Elite Mini's with a few small customizations and a specialized software stack to allow some basic 'ipmi' functionality for the end user. I'll share some pics of how they're racked, and depending on a few things we might publicly release our 'ipmi bridge' down the road too.
Crunchbits.com
That'll be nice. We need an alternative to PiKVM.
Very interested in this! Looking forward to seeing it. Thanks!
I'd love to get my hands on these... with there was an option to sweeten the pot with annual payment or something @crunchbits
I haven't been paying much attention to LES lately, so may have missed elsewhere: what is the DC location? I don't see it here or on the order form.
Spokane, WA
At the moment it's not full 1:1 functionality, mainly because intel vpro/amt just generally sucks. At least some of the important things work but I don't think an actual console will ever be possible. Even with MeshCommander locally it usually doesn't work, or only runs a legitimate serial console that doesn't display 50% of the characters.
How sweet do you want it?
These will only be available in our Spokane, WA facility
Only a few went up today which were already locked down. We'll have another ~10-12 up tomorrow and I'll bump this thread.
Crunchbits.com
As sweet as dropping pants can be 😎
O dang. Missed the drops.. hopefully I can get one on the next bump
It's been a hot minute since I got the console part to work on Intel AMT, but I do remember that with that you need to have either a monitor or an HDMI dummy plug installed, otherwise the kvm part always shows a black screen. It seemed to work ok after that
I have no idea when this was posted and I don't care - I still don't see any photos!
ping -t @crunchbits we demand photos!
