i5-10500T - 32GB DDR4 - 1TB NVMe - 1Gbps Unmetered - $38 Dedi // Quiet launch, read more inside...
crunchbits
Hosting Provider
@Cloudie on the phone placing an order for 20, circa 2023
Before you get too excited, let's start off with the cons of these dedicated servers (compared to our normal enterprise offerings):
- No KVM/console access
- PXE actions are still a little buggy, so all orders require a manual staff member approval initially to make sure you're being delivered a properly deployed OS
- You're welcome to reinstall via our control panel afterwards if you want to, but it sometimes requires an abort and retry (or two)
- No redundant power supplies
- No customization, what you see is what you get
Understanding the above will be crucial for expectation setting. While we actively have some upgrade work going on behind the scenes to help with making the PXE re-deployment smoother, the ETA on that is still 5-14 days out. That being said, I'm personally excited to get some feedback on these and figure LES members will be excited to get a recurring discount on something I don't think we'll ever discount again moving forward.
The good:
* $45 $38/mo w/code: IKNOWWHATIMBUYING
* i5-10500T (6c/12t) up to 3.8GHz
* 32GB DDR4
* 1TB NVMe
* 1Gbps Unmetered
* Direct Order Link
Yabs:
root@47-DP-U26-L:~# curl -sL yabs.sh | bash
# Yet-Another-Bench-Script #
# v2023-04-23 #
Fri Aug 4 06:52:06 AM UTC 2023
Uptime : 0 days, 3 hours, 38 minutes
Processor : Intel(R) Core(TM) i5-10500T CPU @ 2.30GHz
CPU cores : 12 @ 2300.000 MHz
AES-NI : ✔ Enabled
RAM : 31.1 GiB
Swap : 3.8 GiB
Disk : 912.0 GiB
Kernel : 6.1.0-10-amd64
VM Type : NONE
ISP : Redoubt Networks
ASN : AS400304 REDOUBT NETWORKS
Host : Atomic Networks LLC
Country : United States
Read | 793.62 MB/s (198.4k) | 1.15 GB/s (18.0k)
Write | 795.72 MB/s (198.9k) | 1.15 GB/s (18.1k)
Total | 1.58 GB/s (397.3k) | 2.31 GB/s (36.1k)
Read | 1.26 GB/s (2.4k) | 1.13 GB/s (1.1k)
Write | 1.32 GB/s (2.5k) | 1.21 GB/s (1.1k)
Total | 2.59 GB/s (5.0k) | 2.34 GB/s (2.2k)
Clouvider | London, UK (10G) | 830 Mbits/sec | 175 Mbits/sec | 127 ms
Scaleway | Paris, FR (10G) | 837 Mbits/sec | busy | 143 ms
NovoServe | North Holland, NL (40G) | busy | 586 Mbits/sec | 133 ms
Uztelecom | Tashkent, UZ (10G) | busy | 187 Mbits/sec | 227 ms
Clouvider | NYC, NY, US (10G) | 888 Mbits/sec | 69.5 Mbits/sec | 62.2 ms
Clouvider | Dallas, TX, US (10G) | 892 Mbits/sec | 348 Mbits/sec | 61.4 ms
Clouvider | Los Angeles, CA, US (10G) | 910 Mbits/sec | 801 Mbits/sec | 38.1 ms
Test | Value
Single Core | 1508
Multi Core | 6251
Full Test | https://browser.geekbench.com/v6/cpu/2143471
YABS completed in 10 min 31 sec
network-speed.xyz:
---------------------------- network-speed.xyz ----------------------------
A simple script to test network performance using speedtest-cli
Version : v2023.07.24
Global Speedtest : wget -qO- network-speed.xyz | bash
Region Speedtest : wget -qO- network-speed.xyz | bash -s -- -r <region>
Basic System Info
CPU Model : Intel(R) Core(TM) i5-10500T CPU @ 2.30GHz
CPU Cores : 12 @ 2355.225 MHz
CPU Cache : 12288 KB
AES-NI : ✔ Enabled
Total Disk : 912.1 GB (1.1 GB Used)
Total RAM : 31.1 GB (564.2 MB Used)
Total Swap : 3.8 GB (0 Used)
System uptime : 0 days, 0 hour 17 min
Load average : 0.08, 0.73, 0.47
OS : Debian GNU/Linux 12
Arch : x86_64 (64 Bit)
Virtualization : NONE
Basic Network Info
Primary Network : IPv4
Location (IPv4) : Spokane, Washington, US
Location Latency Loss DL Speed UP Speed Server
ISP: Sakura Network LTD
Nearest 36.48 ms 0.0% 937.55 Mbps 932.53 Mbps Xiber LLC - Kansas City, MO
Kochi, IN 255.44 ms 0.0% 396.20 Mbps 348.98 Mbps Asianet Broadband - Cochin
Bangalore, IN 238.61 ms 0.0% 564.51 Mbps 358.53 Mbps Bharti Airtel Ltd - Bangalore
Chennai, IN 235.25 ms 0.0% 451.83 Mbps 376.46 Mbps Tata Play Fiber - Chennai
Mumbai, IN 263.39 ms 0.0% 449.91 Mbps 317.40 Mbps i3D.net - Mumbai
Delhi, IN 277.73 ms 0.0% 411.29 Mbps 314.31 Mbps Tata Teleservices Ltd - New Delhi
Seattle, US 13.26 ms 0.0% 815.04 Mbps 934.19 Mbps DediPath - Seattle, WA
Los Angeles, US 36.07 ms 0.0% 936.48 Mbps 916.66 Mbps ReliableSite Hosting - Los Angeles, CA
Dallas, US 44.79 ms 0.0% 816.31 Mbps 915.63 Mbps Hivelocity - Dallas, TX
Miami, US 86.55 ms 0.0% 894.51 Mbps 891.69 Mbps AT&T - Miami, FL
New York, US 63.81 ms 0.0% 872.82 Mbps 929.21 Mbps Clouvider Ltd - New York, NY
Toronto, CA 68.89 ms 0.0% 886.10 Mbps 931.79 Mbps Rogers - Toronto, ON
London, UK 127.63 ms 0.0% 960.70 Mbps 686.19 Mbps VeloxServ Communications - London
Amsterdam, NL 54.85 ms 0.0% 642.80 Mbps 549.06 Mbps Clouvider Ltd - Amsterdam
Paris, FR 132.89 ms N/A 954.16 Mbps 669.07 Mbps Axione - Paris
Frankfurt, DE 139.32 ms 0.0% 909.81 Mbps 628.34 Mbps 23M GmbH - Frankfurt Am Main
Warsaw, PL 161.72 ms 0.0% 559.68 Mbps 562.48 Mbps UPC Polska - Warszawa
Bucharest, RO 186.02 ms 0.0% 654.89 Mbps 485.27 Mbps Vodafone Romania Fixed – Bucharest - Bucharest
Jeddah, KSA 197.89 ms 0.0% 521.44 Mbps 455.86 Mbps Saudi Telecom Company
Dubai, AE 240.73 ms 0.0% 672.72 Mbps 313.99 Mbps du - Dubai
Fujairah, AE 267.35 ms 0.0% 875.39 Mbps 313.67 Mbps ETISALAT-UAE - Fujairah
Tokyo, JP 92.62 ms N/A 732.51 Mbps 650.11 Mbps fdcservers.net - Tokyo
Shanghai, CU-CN 189.60 ms 0.0% 746.94 Mbps 475.84 Mbps China Unicom 5G - ShangHai
Nanjing, CT-CN 162.29 ms 0.0% 588.43 Mbps 408.98 Mbps China Telecom JiangSu 5G - Nanjing
Hong Kong, HKG 147.21 ms N/A 590.57 Mbps 620.28 Mbps STC - Hong Kong
Singapore, SG 160.08 ms 0.0% 687.62 Mbps 571.82 Mbps i3D.net - Singapore
Jakarta, ID 211.12 ms 0.0% 407.50 Mbps 178.53 Mbps PT. Telekomunikasi Indonesia - Jakarta
Avg DL Speed : 701.39 Mbps
Avg UL Speed : 582.85 Mbps
Total DL Data : 28.21 GB
Total UL Data : 21.47 GB
Total Data : 49.67 GB
Duration : 14 min 6 sec
System Time : 04/08/2023 - 03:45:26 UTC
Total Script Runs : 20226
Very nice offer, any VPS offers coming soon?
Will make a final decision on that with the team tomorrow--but any requests? Had something unique prepared for another LES exclusive, but I haven't decided if it is for sure yet.
Crunchbits.com
no IPv6?
Is iGPU available?
They have IPv6 available, we just have to assign them on request for the moment.
iGPU is included, this is bare metal.
Crunchbits.com
These went way too quickly. We'll restock them tomorrow.
Crunchbits.com
Any offers for the NVMe or SSD VPS?
Is it possible to request kvm temporarily?
If it's not too much - some limited stock annual deals under $20?
Haha I didn't even get the tag notification for this one. :-)
I'll buy 20, if you give me all the other goods :-D
I just have to ask... what is the relationship between @crunchbits and @Cloudie?
Seems to be a lot of PDA.
At the moment, no. We do have some portable KVMs that were likely going to be dedicated to these--but sort of weighing out the options on them.
Precisely what was discussed and prepared. Probably closer to ~$17/yr limited deals that won't go up on the website.
Strictly PDA.
Crunchbits.com
Were all of them bought up by Cloudie?
Yeah, existing customers I believe. There will be a few more this evening, as well as a LES-only treat.
Crunchbits.com
Did I miss the LES treats?
You did not. It's on pause for a day or three--forgot we had something staged already with OGF. It'll be slightly better when it goes up here anyways.
Crunchbits.com
Patience is virtue... let me wait here
if again possible to restock?
Coming today.
Don't think LES will get left out. Not only will you not get left out, but I'll be able to subtract $200 right off the top and pass it along (regarding the ogf yearly bonanza). You might even be blessed in missing out on all the shenanigans after the deal was invaded by hostloc & co
Crunchbits.com
I'm 100% in for one if/when they restock.
Curious... based on the hardware specs and the caveats, are these 1L business desktops? I've always wanted to toy with the idea of deploying them in a datacenter at some point.
Yes, these are rack mounted HP Elite Mini's with a few small customizations and a specialized software stack to allow some basic 'ipmi' functionality for the end user. I'll share some pics of how they're racked, and depending on a few things we might publicly release our 'ipmi bridge' down the road too.
Crunchbits.com
That'll be nice. We need an alternative to PiKVM.
Very interested in this! Looking forward to seeing it. Thanks!
I'd love to get my hands on these... with there was an option to sweeten the pot with annual payment or something @crunchbits
I haven't been paying much attention to LES lately, so may have missed elsewhere: what is the DC location? I don't see it here or on the order form.
Spokane, WA
At the moment it's not full 1:1 functionality, mainly because intel vpro/amt just generally sucks. At least some of the important things work but I don't think an actual console will ever be possible. Even with MeshCommander locally it usually doesn't work, or only runs a legitimate serial console that doesn't display 50% of the characters.
How sweet do you want it?
These will only be available in our Spokane, WA facility
Only a few went up today which were already locked down. We'll have another ~10-12 up tomorrow and I'll bump this thread.
Crunchbits.com
As sweet as dropping pants can be 😎
O dang. Missed the drops.. hopefully I can get one on the next bump
It's been a hot minute since I got the console part to work on Intel AMT, but I do remember that with that you need to have either a monitor or an HDMI dummy plug installed, otherwise the kvm part always shows a black screen. It seemed to work ok after that
I have no idea when this was posted and I don't care - I still don't see any photos!
ping -t @crunchbits we demand photos!
