This is an update from YetiNode about moving to a new host. If you received this message that means you are a member of YetiNode.
Recently the host I have been using to host the free portion of YetiNode has gone silent. No answer to tickets and it seems the site and billing has gone down as well. This does not bode well for that host and I have decided before things go totally downhill I am moving to a different host.
The server will move from Seattle, WA to Los Angeles, CA so the ping should be minimal. I have this action planned for Saturday August 19, 2023.
The downtime should be minimal as I already have taken backups and restored them to the new server. I am just giving it a day, or so to let things settle before changing the rest.
I will keep the old server up until I am positive the new one has taken over and things are running again. Your sites and data should not be effected and things should be working normally by the end of the weekend.
I want to take this opportunity to thank you for choosing YetiNode and here is to a smooth transition.
Ok I have changed the server ips and now I await propogation for the panel. Seems to be taking a bit so not much else I can do atm.
All sites have been restored and seem to be working. Check your sites and if the they are the new IP. My tests show they are correct but some of you use cloudflare.
Yes I know it is a day early but I have the time now to futz about with it.
Edit: Ok call me a moron I fat fingered the IP now it is correct.
Please cyber safely, friend.
And you are...?
Nonono, you're supposed to say, "a/s/l?"
a/s/l/ss/ps/si/pn?
░░█░░░░▀░▐▌( ͡° ͜ʖ ͡°)▐▌░░░▀░░░▐█░░░░░░░░▀░▐▌( ͡° ͜ʖ ͡°)▐▌░░█▀
a,s,l are age, sex, location
What are ss, ps, si, and pn?
Maybe pn is pronoun?
Thanks!
ss = shoe size
ps = penis size
si = sexual identity
and pn = (you guessed it) pronouns
age
sex
location
what are the rest?
This is the notice I sent to all users.
Hello,
Temporailly suspending YetiNode free orders until this is sorted.
Wait, I could have gotten free hosting if I had just acted sooner.
Can confirm site is up
If you do not mind, please post or PM the link to your site. Thanks! 🆗
