@tetech said:
Get a VPS and install OpenVPN/wireguard/strongswan.
Nyr's script is great for setting up personal vpn. Then just create a profile for everyone who should use it (e.g. family/friends) and be done with it
I'm having my personal vpn run on a 5$/yr natvps from @natvps_uk . It's been solid so far and 10 Gbps port (or was it 1 Gbps?) is awesome
Runs on 128mb ram instance (wireguard+openvpn server), albeit ovpn was also running on 64mb ram instance
Do they have U.S. locations I am thinking about setting some up here soon.
Very happy with my instances so far I bought the Micronode Instances, rather than single NAT VPS. That way I can create/destroy vps instances as I want respective to my resource pool.
@Chievothis is the link to the resource pool product. That said I got it on sale for 5$/yr atm iirc. So you might monitor their discounts on LES, too
What's the difference between using natvps/private vpn and vpn from providers like keepsolid, ivacy since they provide lifetime vpn with servers from different countries in comparison to only one country server for natvps/private vpn?
High resources hosting in low-end pricing - ExtraVM (aff)
Don't get me wrong, Ivacy/Keepsolid lifetime etc are great and I love them. I have another use case for them, though. I use them mostly for unblocking streaming content and doing some cheap online shopping, or streaming stuff.
Self-hosted VPN is for more private stuff like online banking while abroad, whitelist ip for certain services etc
A VPS and solutions such as Wireguard can provide all the benefits. There is also proxy servers such as sing-box that can host a plethora of protocols.
Pritunl is the quickest and easiest to setup, will work on any vps really.
microtronixdc.com - Colocation, Dedicated Servers, Full-Rack options, VPS. John 3:16 - Jesus Saves!!
Massive Network Bandwidth options with Fiber throughout, up to 100Gbps connections! Always-On DDoS Mitigation for all traffic!
Seems like that's not the case right now ( https://clients.natvps.uk/index.php?rp=/store/micronode-vps ), but maybe @natvps_uk can help out?
@Chievo this is the link to the resource pool product. That said I got it on sale for 5$/yr atm iirc. So you might monitor their discounts on LES, too
You probably want to check out Gullo's hosting
Would you trust them with your data?
For private VPN, one can simply use the scripts of @Nyr from GitHub. Choose whatever you like:
I reserve the right to license all of my content under: CC BY-NC-ND. What happens on this forum should stay on this forum.
At the risk of getting a reputation I'd again mention MrVM.
Do check with the host if they allow private VPNs first. Most hosts are ok if it's only for private use.
Also, check out: https://www.pivpn.io/
You can use it on any debian/ubuntu based OS. I had been using it for a while and it worked well for a long time.
Also, this works well if you need a web UI: https://openvpn.net/vpn-software-packages/ubuntu/
