@Neoon said:
aeza 1.46€ Sweden Promo
However I only paid 114RUB = 1.11€
Seems like they limited to 100Mbit/s finally. Did you get the VPS from the 5.42. range?
To expensive, I have only one VPS that cost 5€/m which is justified.
This cannot be justified, I am sorry.
I meant the IPv4 subnet range. They have new ones in Sweden so I would like to get again the promo with their new ones (already have one in 5.42 subnet)
The network looks like garbage tough.
Jitter and Packet loss wholesale.
I wanted to Ticket them, but when I forgor I can't because its a promo package.
You can contact them on Telegram, but don't expect anything with a promo deal. I've had issues in the past with their Amsterdam one but couldn't figure it out what was happening, so I just used a VPN instead. Well, 4 months with that one and now seems stable, altough there's some network packet loss some times
Uptime of the Sweden PROMO (it's 100%, I reinstalled the O.S recently)
Uptime of the Amsterdam PROMO
I mailed them, my email got ignored.
Besides that, when I look closely at the mtr.
I can see that their network is loaded beyond repair.
The gateway has a response time from 1 to 20ms, which correlates with the latency spikes I see.
Tbf, most gateways in the hosting industry (atleast as far as I've seen) have those spikes. You can use https://check-host.net and you'll see them in most of the cases.
You need to contact them on Telegram, they will ignore other contact methods.
EDIT: How did you calculate that? I've tried multiple traceroutes to 1.1.1.1 and all of them the gateway is below 1ms (also keep in mind my SWE-PROMO is very old, from one of the first batches, so it's not limited to 100Mbit/s and it's super fast, I've got a second one a month ago IIRC and it was slow as crap)
nah, if you see the gateway latency at 20ms, shits on fire yooooo
Yeah obviously if pinging inside, but if you ping the gateway outside the network it usually has spikes on some countries. Atleast for what I've seen.
I did install my beloved https://github.com/Ne00n/wg-mesh and wanted to use this as my swedish pop.
However, wg-mesh flagged 21 of the initially 33 connections as jitter.
We talking +20ms on each of these links, its def. their network, which is fucked.
If it would be a small issue, I might see like 2-4 links flagged.
This is a TCP ping to the SSH port. There's some jittering, but overall works perfectly fine (atleast on my instance)
Also speedtest (IOPS wise is restricted to 1k so the yabs is exactly the same)
I think they got to the point of overselling, but I just find weird old clients with old instances just have the best ones hahaha, I just though once they opened sales for SWE-PROMO again that my node would be almost crashing of overselling but that's not the case (for SWE-PROMO and AMS-PROMO). They both work great, and price-performance ratio in my case is insane.
WebHorizon NVME-KVM-2GB (Singapore) IPv6-only
Crunchbits 3GB GENTLEMAN'S YEARLY VPS
Suble.io Nano
No hostname left!
I was stoned during purchase, regret.
C1V hosting
Advertised as 2C/2G/20G/250M
Delivered as 1C/1G/20G/1000M
Asked for correction, Broken.
As soon its unbroken, I will post another YAAAABS
So YABS is from the second state
good luck with that!
Roost, LU BuyVM
c1vhosting 9€/y
C1V hosting €20/m dedicated server.
C1V Hosting: Low cost Italian Cloud & Data Center Solutions 🚀 | Contact us for special offers. | Our deals on Telegram
order link?
27.70 euro per month dedicated server
DM. Low stock available
Is this with NVMe disk?
Raid 1 ssd disk
Hetzner CPX11 (2x AMD CPU, 2Gb RAM, 40 Gb NVMe). Helsinki location.
Does include AntiDDoS and a /48 IPv6.
Yea its within the /21 https://bgp.he.net/net/5.42.80.0/21
AlphaVPS 20€ /y old promo
Netcup RS 2000 Plus SAS G8 (12.8€/month)
Hazi.ro VPS Standard (customized)
I'd do a YABS but the speedtest servers aren't capable of 20G+ other than NovoServe.
Here's a speedtest.net of something we're cooking up in both Singapore and London :-)
Too high, way too high.
