Post some YABS bench here
1101102104106107120
  • @Neoon said:
    @zgato said:
    @Neoon said:
    @zgato said:
    @Neoon said:
    @zgato said:
    @Neoon said:
    @zgato said:
    @Neoon said:
    @zgato said:
    @Neoon said:
    @zgato said:
    @Neoon said:
    aeza 1.46€ Sweden Promo
    However I only paid 114RUB = 1.11€
    Seems like they limited to 100Mbit/s finally. Did you get the VPS from the 5.42. range?
    To expensive, I have only one VPS that cost 5€/m which is justified.
    This cannot be justified, I am sorry.
    I meant the IPv4 subnet range. They have new ones in Sweden so I would like to get again the promo with their new ones (already have one in 5.42 subnet)
    The network looks like garbage tough.
    Jitter and Packet loss wholesale.
    I wanted to Ticket them, but when I forgor I can't because its a promo package.
    You can contact them on Telegram, but don't expect anything with a promo deal. I've had issues in the past with their Amsterdam one but couldn't figure it out what was happening, so I just used a VPN instead. Well, 4 months with that one and now seems stable, altough there's some network packet loss some times
    Uptime of the Sweden PROMO (it's 100%, I reinstalled the O.S recently)
    Uptime of the Amsterdam PROMO
    I mailed them, my email got ignored.
    Besides that, when I look closely at the mtr.
    I can see that their network is loaded beyond repair.
    The gateway has a response time from 1 to 20ms, which correlates with the latency spikes I see.
    Tbf, most gateways in the hosting industry (atleast as far as I've seen) have those spikes. You can use https://check-host.net and you'll see them in most of the cases.
    You need to contact them on Telegram, they will ignore other contact methods.
    EDIT: How did you calculate that? I've tried multiple traceroutes to 1.1.1.1 and all of them the gateway is below 1ms (also keep in mind my SWE-PROMO is very old, from one of the first batches, so it's not limited to 100Mbit/s and it's super fast, I've got a second one a month ago IIRC and it was slow as crap)
    nah, if you see the gateway latency at 20ms, shits on fire yooooo
    Yeah obviously if pinging inside, but if you ping the gateway outside the network it usually has spikes on some countries. Atleast for what I've seen.
    I did install my beloved https://github.com/Ne00n/wg-mesh and wanted to use this as my swedish pop.
    However, wg-mesh flagged 21 of the initially 33 connections as jitter.
    We talking +20ms on each of these links, its def. their network, which is fucked.
    If it would be a small issue, I might see like 2-4 links flagged.
    This is a TCP ping to the SSH port. There's some jittering, but overall works perfectly fine (atleast on my instance)
    Too high, way too high.
    That's from my PC. That's normal ping to Sweden from Spain.
  • 1€ IONOS Frankfurt Equinix
    #                     v2023-09-06                    #
    Sun Sep 17 01:19:37 UTC 2023
    Uptime     : 0 days, 0 hours, 21 minutes
    Processor  : AMD EPYC-Milan Processor
    CPU cores  : 1 @ 1999.998 MHz
    RAM        : 878.0 MiB
    Swap       : 0.0 KiB
    Disk       : 9.8 GiB
    Kernel     : 6.1.0-9-cloud-amd64
    VM Type    : MICROSOFT
    ISP        : Strato AG
    ASN        : AS6724 Strato AG
    Host       : Strato AG
    Country    : Germany
    Read       | 40.02 MB/s   (10.0k) | 497.53 MB/s   (7.7k)
    Write      | 40.11 MB/s   (10.0k) | 500.15 MB/s   (7.8k)
    Total      | 80.13 MB/s   (20.0k) | 997.69 MB/s  (15.5k)
    Read       | 474.53 MB/s    (926) | 468.72 MB/s    (457)
    Write      | 499.75 MB/s    (976) | 499.93 MB/s    (488)
    Total      | 974.28 MB/s   (1.9k) | 968.66 MB/s    (945)
    Clouvider       | London, UK (10G)          | 287 Mbits/sec   | 453 Mbits/sec   | 14.6 ms
    Scaleway        | Paris, FR (10G)           | 1.85 Gbits/sec  | 3.93 Gbits/sec  | 10.3 ms
    NovoServe       | North Holland, NL (40G)   | busy            | busy            | 13.1 ms
    Uztelecom       | Tashkent, UZ (10G)        | 1.75 Gbits/sec  | 2.01 Gbits/sec  | 81.7 ms
    Clouvider       | NYC, NY, US (10G)         | 39.3 Mbits/sec  | 60.5 Mbits/sec  | 94.9 ms
    Clouvider       | Dallas, TX, US (10G)      | 32.6 Mbits/sec  | 64.7 Mbits/sec  | 119 ms
    Clouvider       | Los Angeles, CA, US (10G) | 26.7 Mbits/sec  | 49.6 Mbits/sec  | 148 ms
    Geekbench test failed and low memory was detected. Add at least 1GB of SWAP or use GB4 instead (higher compatibility with low memory systems).
    YABS completed in 6 min 12 sec
  • @Neoon
    [root@server ~]# curl -sL yabs.sh | bash
    #                     v2023-09-06                    #
    Sun Sep 17 03:52:26 AM CEST 2023
    Uptime     : 2 days, 1 hours, 59 minutes
    Processor  : Intel(R) Xeon(R) Gold 6230R CPU @ 2.10GHz
    CPU cores  : 4 @ 2099.999 MHz
    VM-x/AMD-V : ❌ Disabled
    RAM        : 3.5 GiB
    Swap       : 2.0 GiB
    Disk       : 118.0 GiB
    Distro     : AlmaLinux 9.2 (Turquoise Kodkod)
    Kernel     : 5.14.0-284.30.1.el9_2.x86_64
    VM Type    : VMWARE
    ISP        : IONOS SE
    ASN        : AS8560 IONOS SE
    Host       : IONOS SE
    Country    : Germany
    Read       | 256.44 MB/s  (64.1k) | 1.26 GB/s    (19.8k)
    Write      | 257.12 MB/s  (64.2k) | 1.27 GB/s    (19.9k)
    Total      | 513.56 MB/s (128.3k) | 2.54 GB/s    (39.7k)
    Read       | 1.27 GB/s     (2.4k) | 1.14 GB/s     (1.1k)
    Write      | 1.34 GB/s     (2.6k) | 1.22 GB/s     (1.1k)
    Total      | 2.61 GB/s     (5.1k) | 2.37 GB/s     (2.3k)
    Clouvider       | London, UK (10G)          | 231 Mbits/sec   | 398 Mbits/sec   | 20.5 ms
    Scaleway        | Paris, FR (10G)           | 416 Mbits/sec   | 400 Mbits/sec   | 14.4 ms
    NovoServe       | North Holland, NL (40G)   | busy            | busy            | 15.2 ms
    Uztelecom       | Tashkent, UZ (10G)        | busy            | 385 Mbits/sec   | 84.6 ms
    Clouvider       | NYC, NY, US (10G)         | 38.8 Mbits/sec  | 82.1 Mbits/sec  | 100 ms
    Clouvider       | Dallas, TX, US (10G)      | 31.8 Mbits/sec  | busy            | 124 ms
    Clouvider       | Los Angeles, CA, US (10G) | 25.7 Mbits/sec  | busy            | 153 ms
    Single Core     | 721
    Multi Core      | 1955
    Full Test       | https://browser.geekbench.com/v6/cpu/2635581
    YABS completed in 12 min 53 sec
  • @Amadex said:
    @Neoon
    > #              Yet-Another-Bench-Script              #
    > #                     v2023-09-06                    #
    > # https://github.com/masonr/yet-another-bench-script #
    > Basic System Information:
    > AES-NI     : ✔ Enabled
    > RAM        : 3.5 GiB
    > Swap       : 2.0 GiB
    > Disk       : 118.0 GiB
    > VM Type    : VMWARE
    > IPv4/IPv6  : ✔ Online / ❌ Offline
    > IPv4 Network Information:
    > ISP        : IONOS SE
    > Host       : IONOS SE
    > Location   : Frankfurt (Oder), Brandenburg (BB)
    > Country    : Germany
    > fio Disk Speed Tests (Mixed R/W 50/50):
    > Block Size | 4k            (IOPS) | 64k           (IOPS)
    > Block Size | 512k          (IOPS) | 1m            (IOPS)
    > iperf3 Network Speed Tests (IPv4):
    > Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
    > Geekbench 6 Benchmark Test:
    > Test            | Value
    > Single Core     | 721
    > Multi Core      | 1955
    what is dis
  • @Neoon dis is ionos server too
  • rskrsk Hosting Provider
    Our L2G NVMe 10Gbit plan in Spokane, WA
    #                     v2023-09-06                    #
    Thu Sep 14 15:48:28 BST 2023
    Uptime     : 0 days, 15 hours, 30 minutes
    Processor  : AMD Ryzen 9 7950X 16-Core Processor
    CPU cores  : 8 @ 4499.996 MHz
    RAM        : 7.7 GiB
    Swap       : 0.0 KiB
    Disk       : 200.0 GiB
    Distro     : Rocky Linux 9.2 (Blue Onyx)
    Kernel     : 5.14.0-284.25.1.el9_2.x86_64
    ISP        : Layer
    ASN        : Unknown
    Host       : Layer
    Country    : United Arab Emirates
    Read       | 504.91 MB/s (126.2k) | 3.02 GB/s    (47.2k)
    Write      | 506.24 MB/s (126.5k) | 3.04 GB/s    (47.5k)
    Total      | 1.01 GB/s   (252.7k) | 6.06 GB/s    (94.8k)
    Read       | 3.60 GB/s     (7.0k) | 3.89 GB/s     (3.8k)
    Write      | 3.80 GB/s     (7.4k) | 4.15 GB/s     (4.0k)
    Total      | 7.41 GB/s    (14.4k) | 8.05 GB/s     (7.8k)
    Single Core     | 2971
    Multi Core      | 13330
    Full Test       | https://browser.geekbench.com/v6/cpu/2603704
    YABS completed in 4 min 41 sec
  • HostEurope 1.20€ VPS 80% off
    I did select Europe for this one, got Strasbourg
    #                     v2023-09-06                    #
    Mon 18 Sep 2023 08:48:37 AM UTC
    Uptime     : 0 days, 0 hours, 5 minutes
    Processor  : AMD EPYC-Rome Processor
    CPU cores  : 1 @ 2349.998 MHz
    RAM        : 1.9 GiB
    Swap       : 0.0 KiB
    Disk       : 39.3 GiB
    Kernel     : 5.10.0-21-amd64
    ISP        : Host Europe GmbH
    ASN        : AS21499 Host Europe GmbH
    Host       : Host Europe GmbH
    Country    : France
    Read       | 27.99 MB/s    (6.9k) | 84.25 MB/s    (1.3k)
    Write      | 28.01 MB/s    (7.0k) | 84.69 MB/s    (1.3k)
    Total      | 56.01 MB/s   (14.0k) | 168.94 MB/s   (2.6k)
    Read       | 132.60 MB/s    (258) | 180.34 MB/s    (176)
    Write      | 139.64 MB/s    (272) | 192.35 MB/s    (187)
    Total      | 272.25 MB/s    (530) | 372.69 MB/s    (363)
    Clouvider       | London, UK (10G)          | 259 Mbits/sec   | busy            | 15.3 ms
    Scaleway        | Paris, FR (10G)           | 7.85 Gbits/sec  | busy            | 9.37 ms
    NovoServe       | North Holland, NL (40G)   | busy            | busy            | 10.6 ms
    Uztelecom       | Tashkent, UZ (10G)        | busy            | 1.96 Gbits/sec  | 95.1 ms
    Clouvider       | NYC, NY, US (10G)         | 42.6 Mbits/sec  | 143 Mbits/sec   | 86.4 ms
    Clouvider       | Dallas, TX, US (10G)      | 32.8 Mbits/sec  | 106 Mbits/sec   | 123 ms
    Clouvider       | Los Angeles, CA, US (10G) | 26.5 Mbits/sec  | 37.5 Mbits/sec  | 148 ms
    Clouvider       | London, UK (10G)          | 255 Mbits/sec   | 333 Mbits/sec   | 15.1 ms
    Scaleway        | Paris, FR (10G)           | busy            | 7.21 Gbits/sec  | 16.0 ms
    NovoServe       | North Holland, NL (40G)   | busy            | busy            | 10.5 ms
    Uztelecom       | Tashkent, UZ (10G)        | 2.29 Gbits/sec  | 1.93 Gbits/sec  | 95.0 ms
    Clouvider       | NYC, NY, US (10G)         | 45.9 Mbits/sec  | busy            | 86.2 ms
    Clouvider       | Dallas, TX, US (10G)      | 31.5 Mbits/sec  | 47.3 Mbits/sec  | 123 ms
    Clouvider       | Los Angeles, CA, US (10G) | 25.3 Mbits/sec  | 37.5 Mbits/sec  | 148 ms
    Running GB6 benchmark test... *cue elevator music*
    Single Core     | 1368
    Multi Core      | 1362
    Full Test       | https://browser.geekbench.com/v6/cpu/2651860
    YABS completed in 16 min 26 sec
    Thanked by (3)cxg loay lapua
  • HostEurope 1.20€ VPS 80% off SG
    #                     v2023-09-06                    #
    Mon 18 Sep 2023 09:15:49 AM UTC
    Uptime     : 0 days, 0 hours, 6 minutes
    RAM        : 1.9 GiB
    Swap       : 0.0 KiB
    Disk       : 39.3 GiB
    ISP        : GoDaddy.com, LLC
    ASN        : AS26496 GoDaddy.com, LLC
    Host       : Godaddy.com
    Country    : Singapore
    Read       | 24.19 MB/s    (6.0k) | 160.66 MB/s   (2.5k)
    Write      | 24.20 MB/s    (6.0k) | 161.50 MB/s   (2.5k)
    Total      | 48.39 MB/s   (12.0k) | 322.16 MB/s   (5.0k)
    Read       | 385.01 MB/s    (751) | 536.07 MB/s    (523)
    Write      | 405.47 MB/s    (791) | 571.77 MB/s    (558)
    Total      | 790.48 MB/s   (1.5k) | 1.10 GB/s     (1.0k)
    Clouvider       | London, UK (10G)          | 15.8 Mbits/sec  | 22.1 Mbits/sec  | 238 ms
    Scaleway        | Paris, FR (10G)           | 1.34 Gbits/sec  | 1.16 Gbits/sec  | 153 ms
    NovoServe       | North Holland, NL (40G)   | busy            | busy            | 244 ms
    Uztelecom       | Tashkent, UZ (10G)        | busy            | busy            | 180 ms
    Clouvider       | NYC, NY, US (10G)         | 16.7 Mbits/sec  | 25.5 Mbits/sec  | 226 ms
    Clouvider       | Dallas, TX, US (10G)      | 16.7 Mbits/sec  | 34.9 Mbits/sec  | 202 ms
    Clouvider       | Los Angeles, CA, US (10G) | 20.6 Mbits/sec  | 34.4 Mbits/sec  | 172 ms
    Clouvider       | London, UK (10G)          | 16.2 Mbits/sec  | 21.3 Mbits/sec  | 237 ms
    Scaleway        | Paris, FR (10G)           | busy            | 684 Mbits/sec   | 242 ms
    Uztelecom       | Tashkent, UZ (10G)        | 1.01 Gbits/sec  | 2.09 Mbits/sec  | 180 ms
    Clouvider       | NYC, NY, US (10G)         | 16.4 Mbits/sec  | 24.8 Mbits/sec  | 226 ms
    Clouvider       | Dallas, TX, US (10G)      | 14.6 Mbits/sec  | 38.7 Mbits/sec  | 202 ms
    Clouvider       | Los Angeles, CA, US (10G) | 15.0 Mbits/sec  | 35.8 Mbits/sec  | 172 ms
    Single Core     | 1360
    Multi Core      | 1366
    Full Test       | https://browser.geekbench.com/v6/cpu/2652089
    YABS completed in 16 min 11 sec
    Thanked by (1)loay
  • HostEurope 1.20€ VPS 80% off IN
    #                     v2023-09-06                    #
    Mon 18 Sep 2023 09:30:20 AM UTC
    RAM        : 1.9 GiB
    Swap       : 0.0 KiB
    Disk       : 39.3 GiB
    Host       : Godaddy.com
    Country    : Singapore
    Read       | 214.74 MB/s  (53.6k) | 914.98 MB/s  (14.2k)
    Write      | 215.30 MB/s  (53.8k) | 919.79 MB/s  (14.3k)
    Total      | 430.05 MB/s (107.5k) | 1.83 GB/s    (28.6k)
    Read       | 781.51 MB/s   (1.5k) | 1.08 GB/s     (1.0k)
    Write      | 823.03 MB/s   (1.6k) | 1.15 GB/s     (1.1k)
    Total      | 1.60 GB/s     (3.1k) | 2.23 GB/s     (2.1k)
    Clouvider       | London, UK (10G)          | 30.4 Mbits/sec  | 40.7 Mbits/sec  | 127 ms
    Scaleway        | Paris, FR (10G)           | 634 Mbits/sec   | busy            | 109 ms
    NovoServe       | North Holland, NL (40G)   | busy            | busy            | 133 ms
    Uztelecom       | Tashkent, UZ (10G)        | busy            | 133 Mbits/sec   | 191 ms
    Clouvider       | NYC, NY, US (10G)         | 19.7 Mbits/sec  | 22.7 Mbits/sec  | 241 ms
    Clouvider       | Dallas, TX, US (10G)      | 11.5 Mbits/sec  | 31.3 Mbits/sec  | 244 ms
    Clouvider       | Los Angeles, CA, US (10G) | 15.3 Mbits/sec  | 23.8 Mbits/sec  | 237 ms
    Clouvider       | London, UK (10G)          | 30.6 Mbits/sec  | 41.9 Mbits/sec  | 127 ms
    Scaleway        | Paris, FR (10G)           | 566 Mbits/sec   | 876 Mbits/sec   | 109 ms
    NovoServe       | North Holland, NL (40G)   | busy            | busy            | 136 ms
    Uztelecom       | Tashkent, UZ (10G)        | 397 Mbits/sec   | 792 Mbits/sec   | 191 ms
    Clouvider       | NYC, NY, US (10G)         | 15.4 Mbits/sec  | 25.2 Mbits/sec  | 241 ms
    Clouvider       | Dallas, TX, US (10G)      | 15.4 Mbits/sec  | 31.1 Mbits/sec  | 244 ms
    Clouvider       | Los Angeles, CA, US (10G) | 15.8 Mbits/sec  | 25.2 Mbits/sec  | 237 ms
    Single Core     | 1367
    Multi Core      | 1359
    Full Test       | https://browser.geekbench.com/v6/cpu/2652231
    YABS completed in 16 min 48 sec
    Thanked by (1)loay
  • edited September 2023
    Yabs after Speedypage upgrades to Ryzen 9 7900 and DDR5 ram.
    v2023-09-06
    Mon Sep 18 20:09:33 BST 2023
    Uptime : 3 days, 11 hours, 38 minutes
    Processor : AMD Ryzen 9 7900 12-Core Processor
    CPU cores : 8 @ 3699.982 MHz
    AES-NI : ✔ Enabled
    RAM : 11.6 GiB
    Swap : 5.8 GiB
    Disk : 193.8 GiB
    Distro : Ubuntu 22.04.3 LTS
    Kernel : 6.4.16-060416-generic
    VM Type : KVM
    ISP : SpeedyPage Ltd
    ASN : AS142594 SpeedyPage Ltd
    Host : SPEEDYPAGE-LTD
    Country : United Kingdom
    Read 562.40 MB/s (140.6k) 2.42 GB/s (37.8k)
    Write 563.88 MB/s (140.9k) 2.43 GB/s (38.0k)
    Total 1.12 GB/s (281.5k) 4.86 GB/s (75.9k)
    Read 2.61 GB/s (5.1k) 2.32 GB/s (2.2k)
    Write 2.75 GB/s (5.3k) 2.48 GB/s (2.4k)
    Total 5.37 GB/s (10.5k) 4.80 GB/s (4.6k)
    Provider Location (Link) Send Speed Recv Speed Ping
    Clouvider London, UK (10G) 5.71 Gbits/sec 3.40 Gbits/sec 0.587 ms
    Scaleway Paris, FR (10G) busy 3.01 Gbits/sec 18.7 ms
    NovoServe North Holland, NL (40G) busy busy 5.62 ms
    Uztelecom Tashkent, UZ (10G) 1.69 Gbits/sec 1.22 Gbits/sec 102 ms
    Clouvider NYC, NY, US (10G) 57.0 Mbits/sec 91.2 Mbits/sec 70.5 ms
    Clouvider Dallas, TX, US (10G) 32.8 Mbits/sec 64.2 Mbits/sec 118 ms
    Clouvider Los Angeles, CA, US (10G) 27.4 Mbits/sec 34.9 Mbits/sec 142 ms
    Clouvider London, UK (10G) 5.70 Gbits/sec 4.35 Gbits/sec 0.545 ms
    Scaleway Paris, FR (10G) busy busy 15.0 ms
    NovoServe North Holland, NL (40G) busy busy 5.65 ms
    Uztelecom Tashkent, UZ (10G) 1.83 Gbits/sec 897 Mbits/sec 102 ms
    Clouvider NYC, NY, US (10G) 55.7 Mbits/sec 89.5 Mbits/sec 70.6 ms
    Clouvider Dallas, TX, US (10G) 32.5 Mbits/sec 40.8 Mbits/sec 118 ms
    Clouvider Los Angeles, CA, US (10G) 26.9 Mbits/sec 37.9 Mbits/sec 141 ms
    Test | Value
    Single Core | 2575
    Multi Core | 10537
    Full Test | https://browser.geekbench.com/v6/cpu/2658384`
    Thanked by (2)carlin0 febryanvaldo
    Pretty nice considering the 6W TDP
    #                     v2023-09-06                    #
    Thu Sep 21 02:09:16 PM CEST 2023
    Processor  : Intel(R) N100
    CPU cores  : 4 @ 3212.214 MHz
    RAM        : 15.4 GiB
    Swap       : 0.0 KiB
    Disk       :
    Kernel     : 6.2.16-12-pve
    VM Type    : NONE
    ISP        : Vodafone
    ASN        : AS3209 Vodafone GmbH
    Host       : Vodafone BW GmbH
    Country    : Germany
    Read       | 36.30 MB/s    (9.0k) | 574.62 MB/s   (8.9k)
    Write      | 36.40 MB/s    (9.1k) | 577.65 MB/s   (9.0k)
    Total      | 72.71 MB/s   (18.1k) | 1.15 GB/s    (18.0k)
    Read       | 1.09 GB/s     (2.1k) | 1.08 GB/s     (1.0k)
    Write      | 1.14 GB/s     (2.2k) | 1.15 GB/s     (1.1k)
    Total      | 2.24 GB/s     (4.3k) | 2.23 GB/s     (2.1k)
    Clouvider       | London, UK (10G)          | 25.2 Mbits/sec  | 500 Mbits/sec   | 27.5 ms
    Scaleway        | Paris, FR (10G)           | 25.3 Mbits/sec  | 478 Mbits/sec   | 27.0 ms
    NovoServe       | North Holland, NL (40G)   | busy            | busy            | 23.5 ms
    Uztelecom       | Tashkent, UZ (10G)        | busy            | busy            | 198 ms
    Clouvider       | NYC, NY, US (10G)         | busy            | 212 Mbits/sec   | 93.9 ms
    Clouvider       | Dallas, TX, US (10G)      | 22.6 Mbits/sec  | 114 Mbits/sec   | 141 ms
    Clouvider       | Los Angeles, CA, US (10G) | busy            | 450 Mbits/sec   | 168 ms
    Single Core     | 1254
    Multi Core      | 3244
    Full Test       | https://browser.geekbench.com/v6/cpu/2699355
    YABS completed in 11 min 1 sec
    Thanked by (1)sh97
  • Godaddy / Hosteurope Phoenix 1.20€
    #                     v2023-09-06                    #
    Thu 21 Sep 2023 01:22:58 PM UTC
    Uptime     : 0 days, 0 hours, 43 minutes
    RAM        : 1.9 GiB
    Swap       : 0.0 KiB
    Disk       : 39.3 GiB
    ASN        : AS398101 GoDaddy.com, LLC
    Host       : GoDaddy.com, LLC
    Country    : United States
    Read       | 19.99 MB/s    (4.9k) | 149.81 MB/s   (2.3k)
    Write      | 20.00 MB/s    (5.0k) | 150.59 MB/s   (2.3k)
    Total      | 40.00 MB/s    (9.9k) | 300.40 MB/s   (4.6k)
    Read       | 431.89 MB/s    (843) | 632.65 MB/s    (617)
    Write      | 454.84 MB/s    (888) | 674.79 MB/s    (658)
    Total      | 886.74 MB/s   (1.7k) | 1.30 GB/s     (1.2k)
    Clouvider       | London, UK (10G)          | 1.23 Gbits/sec  | busy            | 131 ms
    Scaleway        | Paris, FR (10G)           | busy            | busy            | 138 ms
    NovoServe       | North Holland, NL (40G)   | busy            | busy            | 147 ms
    Uztelecom       | Tashkent, UZ (10G)        | 871 Mbits/sec   | 760 Mbits/sec   | 225 ms
    Clouvider       | NYC, NY, US (10G)         | 2.84 Gbits/sec  | 2.87 Gbits/sec  | 57.9 ms
    Clouvider       | Dallas, TX, US (10G)      | 3.53 Gbits/sec  | 6.54 Gbits/sec  | 23.3 ms
    Clouvider       | Los Angeles, CA, US (10G) | 3.95 Gbits/sec  | 9.02 Gbits/sec  | 9.92 ms
    Clouvider       | London, UK (10G)          | 1.30 Gbits/sec  | 1.33 Gbits/sec  | 130 ms
    Scaleway        | Paris, FR (10G)           | busy            | busy            | 139 ms
    NovoServe       | North Holland, NL (40G)   | busy            | busy            | 152 ms
    Uztelecom       | Tashkent, UZ (10G)        | 854 Mbits/sec   | 753 Mbits/sec   | 224 ms
    Clouvider       | NYC, NY, US (10G)         | 2.88 Gbits/sec  | 3.00 Gbits/sec  | 57.4 ms
    Clouvider       | Dallas, TX, US (10G)      | 5.69 Gbits/sec  | 1.98 Gbits/sec  | 23.3 ms
    Clouvider       | Los Angeles, CA, US (10G) | 7.99 Gbits/sec  | 3.49 Gbits/sec  | 9.51 ms
    Single Core     | 1191
    Multi Core      | 1175
    Full Test       | https://browser.geekbench.com/v6/cpu/2700340
    YABS completed in 18 min 25 sec
  • Racknerd New Year 2023
    #                     v2023-09-06                    #
    Sat Sep 23 04:49:00 PM UTC 2023
    Uptime     : 0 days, 2 hours, 52 minutes
    Processor  : Intel(R) Xeon(R) CPU E5-2680 v2 @ 2.80GHz
    CPU cores  : 1 @ 2799.998 MHz
    RAM        : 969.4 MiB
    Swap       : 1024.0 MiB
    Disk       : 23.5 GiB
    Distro     : Ubuntu 22.04.2 LTS
    Kernel     : 5.15.0-70-generic
    ISP        : ColoCrossing
    ASN        : AS36352 ColoCrossing
    Host       : ColoCrossing
    Read       | 93.80 MB/s   (23.4k) | 1.05 GB/s    (16.4k)
    Write      | 94.05 MB/s   (23.5k) | 1.05 GB/s    (16.5k)
    Total      | 187.85 MB/s  (46.9k) | 2.11 GB/s    (33.0k)
    Read       | 1.42 GB/s     (2.7k) | 1.41 GB/s     (1.3k)
    Write      | 1.50 GB/s     (2.9k) | 1.50 GB/s     (1.4k)
    Total      | 2.93 GB/s     (5.7k) | 2.91 GB/s     (2.8k)
    Clouvider       | London, UK (10G)          | 438 Mbits/sec   | 285 Mbits/sec   | 135 ms
    Scaleway        | Paris, FR (10G)           | 772 Mbits/sec   | 289 Mbits/sec   | 138 ms
    NovoServe       | North Holland, NL (40G)   | busy            | busy            | 139 ms
    Uztelecom       | Tashkent, UZ (10G)        | 561 Mbits/sec   | 229 Mbits/sec   | 234 ms
    Clouvider       | NYC, NY, US (10G)         | busy            | 283 Mbits/sec   | 64.5 ms
    Clouvider       | Dallas, TX, US (10G)      | 895 Mbits/sec   | 509 Mbits/sec   | 33.9 ms
    Clouvider       | Los Angeles, CA, US (10G) | 905 Mbits/sec   | 890 Mbits/sec   | 8.39 ms
    Single Core     | 465
    Multi Core      | 380
    Full Test       | https://browser.geekbench.com/v6/cpu/2738429
    YABS completed in 29 min 0 sec
  • hostEONS.com - Ryzen VDS - $8.99 - 2 vCore / 8 GB RAM / 100 GB NVME / 30TB / 10G Port - LES EXCL
    #                     v2023-09-06                    #
    Mon 25 Sep 2023 03:17:13 PM CEST
    Uptime     : 0 days, 0 hours, 0 minutes
    CPU cores  : 2 @ 3393.622 MHz
    RAM        : 7.8 GiB
    Swap       : 1024.0 MiB
    Disk       : 48.1 GiB
    Distro     : Ubuntu 20.04.6 LTS
    Kernel     : 5.4.0-163-generic
    ISP        : Hosteons Pte. Ltd.
    ASN        : AS142036 Hosteons Pte. Ltd.
    Host       : Hosteons Pte. Ltd
    Read       | 572.08 MB/s (143.0k) | 1.80 GB/s    (28.2k)
    Write      | 573.59 MB/s (143.3k) | 1.81 GB/s    (28.3k)
    Total      | 1.14 GB/s   (286.4k) | 3.62 GB/s    (56.6k)
    Read       | 1.82 GB/s     (3.5k) | 2.59 GB/s     (2.5k)
    Write      | 1.91 GB/s     (3.7k) | 2.76 GB/s     (2.7k)
    Total      | 3.73 GB/s     (7.3k) | 5.36 GB/s     (5.2k)
    Clouvider       | London, UK (10G)          | 1.54 Gbits/sec  | 1.58 Gbits/sec  | 115 ms
    Scaleway        | Paris, FR (10G)           | 1.53 Gbits/sec  | 1.26 Gbits/sec  | 142 ms
    NovoServe       | North Holland, NL (40G)   | busy            | busy            | 119 ms
    Uztelecom       | Tashkent, UZ (10G)        | busy            | 611 Mbits/sec   | 219 ms
    Clouvider       | NYC, NY, US (10G)         | 3.40 Gbits/sec  | 1.63 Gbits/sec  | 48.8 ms
    Clouvider       | Dallas, TX, US (10G)      | 6.61 Gbits/sec  | 6.66 Gbits/sec  | 30.8 ms
    Clouvider       | Los Angeles, CA, US (10G) | 3.16 Gbits/sec  | 7.88 Gbits/sec  | 25.4 ms
    Scaleway        | Paris, FR (10G)           | 1.05 Gbits/sec  | busy            | 123 ms
    Uztelecom       | Tashkent, UZ (10G)        | 887 Mbits/sec   | 657 Mbits/sec   | 213 ms
    Clouvider       | NYC, NY, US (10G)         | 3.25 Gbits/sec  | 3.85 Gbits/sec  | 48.7 ms
    Clouvider       | Dallas, TX, US (10G)      | 6.13 Gbits/sec  | 6.16 Gbits/sec  | 30.8 ms
    Clouvider       | Los Angeles, CA, US (10G) | 6.34 Gbits/sec  | 6.93 Gbits/sec  | 24.6 ms
    Geekbench 5 Benchmark Test:
    Single Core     | 1749
    Multi Core      | 3235
    Full Test       | https://browser.geekbench.com/v5/cpu/21761967
    Single Core     | 2223
    Multi Core      | 3912
    Full Test       | https://browser.geekbench.com/v6/cpu/2767273
    YABS completed in 13 min 54 sec
    Thanked by (1)hostEONS
    https://dttech.net - Personal Site.
  • Xeroz.Tech - Mumbai, MH - India - EUR 1.3/month
    #                     v2023-09-06                    #
    Tue Sep 26 12:38:52 PM EDT 2023
    Uptime     : 0 days, 0 hours, 17 minutes
    Processor  : Intel(R) Xeon(R) E-2386G CPU @ 3.50GHz
    CPU cores  : 2 @ 3504.000 MHz
    RAM        : 1.9 GiB
    Swap       : 0.0 KiB
    Disk       : 34.3 GiB
    Kernel     : 6.1.0-12-amd64
    ISP        : OVH SAS
    ASN        : AS16276 OVH SAS
    Host       : OVHTECH R\u0026D (INDIA) PRIVATE LIMITED
    Country    : India
    Read       | 12.93 MB/s    (3.2k) | 117.16 MB/s   (1.8k)
    Write      | 12.93 MB/s    (3.2k) | 117.78 MB/s   (1.8k)
    Total      | 25.86 MB/s    (6.4k) | 234.94 MB/s   (3.6k)
    Read       | 450.86 MB/s    (880) | 568.34 MB/s    (555)
    Write      | 474.82 MB/s    (927) | 606.19 MB/s    (591)
    Total      | 925.69 MB/s   (1.8k) | 1.17 GB/s     (1.1k)
    Single Core     | 1608
    Multi Core      | 2918
    Full Test       | https://browser.geekbench.com/v5/cpu/21767501
    YABS completed in 3 min 2 sec
    Thanked by (2)Not_Oles dosai
    > #                     v2023-09-06                    #
    > AES-NI     : ✔ Enabled
    > VM-x/AMD-V : ✔ Enabled
    > RAM        : 7.7 GiB
    > Swap       : 0.0 KiB
    > Disk       : 200.0 GiB
    > VM Type    : KVM
    > IPv6 Network Information:
    > ISP        : Layer
    > ASN        : Unknown
    > Host       : Layer
    > Location   : Dubai, Dubai (DU)
    > Test            | Value
    > Single Core     | 2971
    > Multi Core      | 13330
    nice.
    10gbit without iperf3 Network Speed Tests is senseless.
  • Linode Chennai,
    root@localhost:~# wget -qO- yabs.sh | bash -s -- -i
    #                     v2023-09-06                    #
    Wed Sep 27 03:10:28 PM UTC 2023
    Uptime     : 0 days, 0 hours, 41 minutes
    Processor  : AMD EPYC 7713 64-Core Processor
    RAM        : 961.0 MiB
    Swap       : 2.5 GiB
    Disk       : 24.0 GiB
    Kernel     : 6.1.0-10-amd64
    ISP        : Akamai Technologies, Inc.
    ASN        : AS63949 Akamai Connected Cloud
    Host       : Linode
    Country    : India
    Read       | 341.27 MB/s  (85.3k) | 4.03 GB/s    (62.9k)
    Write      | 342.17 MB/s  (85.5k) | 4.05 GB/s    (63.3k)
    Total      | 683.44 MB/s (170.8k) | 8.08 GB/s   (126.2k)
    Read       | 8.88 GB/s    (17.3k) | 9.18 GB/s     (8.9k)
    Write      | 9.35 GB/s    (18.2k) | 9.79 GB/s     (9.5k)
    Total      | 18.23 GB/s   (35.6k) | 18.97 GB/s   (18.5k)
    Single Core     | 1462
    Multi Core      | 1072
    Full Test       | https://browser.geekbench.com/v6/cpu/2799431
    YABS completed in 10 min 48 sec
    Thanked by (1)sh97
    #                     v2023-09-06                    #
    Sat Sep 30 09:45:16 AM CEST 2023
    Uptime     : 0 days, 11 hours, 44 minutes
    Processor  : AMD Ryzen 7 7700 8-Core Processor
    CPU cores  : 1 @ 3792.890 MHz
    RAM        : 3.8 GiB
    Swap       : 0.0 KiB
    Disk       : 78.7 GiB
    ISP        : Hostaris Limited
    ASN        : AS199765 Hostaris Limited
    Host       : Hostaris Limited
    Country    : Germany
    Read       | 395.01 MB/s  (98.7k) | 2.29 GB/s    (35.8k)
    Write      | 396.06 MB/s  (99.0k) | 2.30 GB/s    (36.0k)
    Total      | 791.07 MB/s (197.7k) | 4.60 GB/s    (71.9k)
    Read       | 1.92 GB/s     (3.7k) | 2.17 GB/s     (2.1k)
    Write      | 2.02 GB/s     (3.9k) | 2.32 GB/s     (2.2k)
    Total      | 3.94 GB/s     (7.7k) | 4.49 GB/s     (4.3k)
    Clouvider       | London, UK (10G)          | 900 Mbits/sec   | 905 Mbits/sec   | 15.6 ms
    Scaleway        | Paris, FR (10G)           | busy            | 804 Mbits/sec   | 17.3 ms
    NovoServe       | North Holland, NL (40G)   | 903 Mbits/sec   | 444 Mbits/sec   | 12.6 ms
    Uztelecom       | Tashkent, UZ (10G)        | busy            | busy            | 97.9 ms
    Clouvider       | NYC, NY, US (10G)         | busy            | 481 Mbits/sec   | 89.8 ms
    Clouvider       | Dallas, TX, US (10G)      | 763 Mbits/sec   | 430 Mbits/sec   | 127 ms
    Clouvider       | Los Angeles, CA, US (10G) | 674 Mbits/sec   | 360 Mbits/sec   | 165 ms
    Single Core     | 1730
    Multi Core      | 1684
    YABS completed in 14 min 40 sec
    PREVIOUS CONFIGURATION: AMD Ryzen 9 5950X 16-Core Processor
    #                     v2023-04-23                    #
    Sat 27 May 2023 10:26:35 AM CEST
    Uptime     : 6 days, 15 hours, 30 minutes
    CPU cores  : 1 @ 3393.624 MHz
    RAM        : 3.8 GiB
    Swap       : 0.0 KiB
    Disk       : 78.7 GiB
    Kernel     : 5.10.0-23-amd64
    Country    : Germany
    Read       | 310.09 MB/s  (77.5k) | 2.85 GB/s    (44.6k)
    Write      | 310.91 MB/s  (77.7k) | 2.87 GB/s    (44.8k)
    Total      | 621.00 MB/s (155.2k) | 5.72 GB/s    (89.5k)
    Read       | 3.09 GB/s     (6.0k) | 3.39 GB/s     (3.3k)
    Write      | 3.26 GB/s     (6.3k) | 3.62 GB/s     (3.5k)
    Total      | 6.36 GB/s    (12.4k) | 7.02 GB/s     (6.8k)
    Clouvider       | London, UK (10G)          | 881 Mbits/sec   | 847 Mbits/sec   | 16.7 ms
    Scaleway        | Paris, FR (10G)           | 882 Mbits/sec   | busy            | 23.4 ms
    NovoServe       | North Holland, NL (40G)   | 880 Mbits/sec   | 892 Mbits/sec   | 10.9 ms
    Uztelecom       | Tashkent, UZ (10G)        | 742 Mbits/sec   | busy            | 104 ms
    Clouvider       | NYC, NY, US (10G)         | 731 Mbits/sec   | 64.4 Mbits/sec  | 163 ms
    Clouvider       | Dallas, TX, US (10G)      | 754 Mbits/sec   | 238 Mbits/sec   | 119 ms
    Clouvider       | Los Angeles, CA, US (10G) | 648 Mbits/sec   | 223 Mbits/sec   | 149 ms
    Single Core     | 1415
    Multi Core      | 1406
    YABS completed in 10 min 51 sec
  • Virmach after migration to LAX.
    #                     v2023-09-06                    #
    Sun 01 Oct 2023 09:54:10 PM IST
    Uptime     : 0 days, 0 hours, 3 minutes
    Processor  : AMD Ryzen 9 3900X 12-Core Processor
    CPU cores  : 1 @ 3799.998 MHz
    RAM        : 1.1 GiB
    Swap       : 0.0 KiB
    Disk       : 24.3 GiB
    ISP        : Superonline Iletisim Hizmetleri A.S.
    ASN        : AS34984 Superonline Iletisim Hizmetleri A.S.
    Host       : Turkcell Iletisim Hizmetleri A.S.
    Country    : Turkey
    Read       | 200.26 MB/s  (50.0k) | 397.42 MB/s   (6.2k)
    Write      | 200.79 MB/s  (50.1k) | 399.51 MB/s   (6.2k)
    Total      | 401.06 MB/s (100.2k) | 796.94 MB/s  (12.4k)
    Read       | 623.78 MB/s   (1.2k) | 546.46 MB/s    (533)
    Write      | 656.92 MB/s   (1.2k) | 582.85 MB/s    (569)
    Total      | 1.28 GB/s     (2.5k) | 1.12 GB/s     (1.1k)
    Single Core     | 1127
    Multi Core      | 1126
    Full Test       | https://browser.geekbench.com/v5/cpu/21787582
    YABS completed in 2 min 57 sec
    HXServers
    #                     v2023-09-06                    #
    Mon Oct  2 11:38:20 AM +08 2023
    CPU cores  : 2 @ 4491.536 MHz
    RAM        : 1.9 GiB
    Swap       : 0.0 KiB
    Disk       : 29.9 GiB
    Kernel     : 6.1.0-9-amd64
    ISP        : Ipxo LLC
    ASN        : AS23470 ReliableSite.Net LLC
    Read       | 587.65 MB/s (146.9k) | 3.91 GB/s    (61.2k)
    Write      | 589.20 MB/s (147.3k) | 3.93 GB/s    (61.5k)
    Total      | 1.17 GB/s   (294.2k) | 7.85 GB/s   (122.7k)
    Read       | 3.61 GB/s     (7.0k) | 3.70 GB/s     (3.6k)
    Write      | 3.80 GB/s     (7.4k) | 3.95 GB/s     (3.8k)
    Total      | 7.42 GB/s    (14.4k) | 7.65 GB/s     (7.4k)
    Clouvider       | London, UK (10G)          | 164 Mbits/sec   | 417 Mbits/sec   | 125 ms
    Scaleway        | Paris, FR (10G)           | 231 Mbits/sec   | busy            | 142 ms
    NovoServe       | North Holland, NL (40G)   | 189 Mbits/sec   | 1.17 Gbits/sec  | 144 ms
    Uztelecom       | Tashkent, UZ (10G)        | 145 Mbits/sec   | 700 Mbits/sec   | 240 ms
    Clouvider       | NYC, NY, US (10G)         | 229 Mbits/sec   | 2.87 Gbits/sec  | 63.3 ms
    Clouvider       | Dallas, TX, US (10G)      | 358 Mbits/sec   | 4.87 Gbits/sec  | 28.8 ms
    Clouvider       | Los Angeles, CA, US (10G) | 915 Mbits/sec   | busy            | 0.375 ms
    Geekbench 4 Benchmark Test:
    Single Core     | 7378
    Multi Core      | 12777
    Full Test       | https://browser.geekbench.com/v4/cpu/16875200
    Single Core     | 1674
    Multi Core      | 3069
    Full Test       | https://browser.geekbench.com/v5/cpu/21789324
    YABS completed in 7 min 53 sec
  • A 1 CPU, 1 GB RAM, 50 Mbps Bandwidth (Netherlands) from hostvds
    #                     v2023-09-06                    #
    Mon Oct  2 16:13:17 UTC 2023
    Uptime     : 0 days, 0 hours, 2 minutes
    Processor  : Intel Core Processor (Broadwell, IBRS)
    CPU cores  : 1 @ 2199.996 MHz
    RAM        : 969.4 MiB
    Swap       : 0.0 KiB
    Disk       : 9.3 GiB
    Kernel     : 5.15.0-72-generic
    ISP        : CGI GLOBAL LIMITED
    ASN        : AS56971 CGI GLOBAL LIMITED
    Host       : CloudBackbone
    Country    : Netherlands
    Read       | 36.05 MB/s    (9.0k) | 285.86 MB/s   (4.4k)
    Write      | 36.16 MB/s    (9.0k) | 287.36 MB/s   (4.4k)
    Total      | 72.21 MB/s   (18.0k) | 573.22 MB/s   (8.9k)
    Read       | 775.87 MB/s   (1.5k) | 906.46 MB/s    (885)
    Write      | 817.09 MB/s   (1.5k) | 966.83 MB/s    (944)
    Total      | 1.59 GB/s     (3.1k) | 1.87 GB/s     (1.8k)
    Clouvider       | London, UK (10G)          | 216 Mbits/sec   | 46.9 Mbits/sec  | 9.28 ms
    Scaleway        | Paris, FR (10G)           | 194 Mbits/sec   | 46.8 Mbits/sec  | 17.2 ms
    NovoServe       | North Holland, NL (40G)   | busy            | busy            | 13.4 ms
    Uztelecom       | Tashkent, UZ (10G)        | busy            | busy            | 99.9 ms
    Clouvider       | NYC, NY, US (10G)         | 115 Mbits/sec   | 46.2 Mbits/sec  | 79.1 ms
    Clouvider       | Dallas, TX, US (10G)      | 112 Mbits/sec   | busy            | 124 ms
    Clouvider       | Los Angeles, CA, US (10G) | busy            | 45.3 Mbits/sec  | 162 ms
    YABS completed in 9 min 13 sec
  • root@102037:~# curl -sL yabs.sh | bash
    #                     v2023-09-06                    #
    Tue Oct  3 17:09:06 EEST 2023
    Processor  : 12th Gen Intel(R) Core(TM) i9-12900K
    CPU cores  : 1 @ 3187.200 MHz
    RAM        : 1.9 GiB
    Swap       : 0.0 KiB
    Disk       : 29.5 GiB
    Kernel     : 5.10.0-25-amd64
    ISP        : HOSTIKO
    ASN        : AS203394 MDCLOUD LTD
    Country    : Ukraine
    Read       | 546.12 MB/s (136.5k) | 2.45 GB/s    (38.3k)
    Write      | 547.56 MB/s (136.8k) | 2.46 GB/s    (38.5k)
    Total      | 1.09 GB/s   (273.4k) | 4.91 GB/s    (76.8k)
    Read       | 2.98 GB/s     (5.8k) | 3.26 GB/s     (3.1k)
    Write      | 3.14 GB/s     (6.1k) | 3.48 GB/s     (3.3k)
    Total      | 6.13 GB/s    (11.9k) | 6.74 GB/s     (6.5k)
    Clouvider       | London, UK (10G)          | busy            | 2.31 Gbits/sec  | 41.3 ms
    Scaleway        | Paris, FR (10G)           | busy            | busy            | 45.4 ms
    NovoServe       | North Holland, NL (40G)   | 5.61 Gbits/sec  | 2.94 Gbits/sec  | 35.0 ms
    Uztelecom       | Tashkent, UZ (10G)        | 1.62 Gbits/sec  | 1.84 Gbits/sec  | 99.4 ms
    Clouvider       | NYC, NY, US (10G)         | 1.21 Gbits/sec  | 1.33 Gbits/sec  | 115 ms
    Clouvider       | Dallas, TX, US (10G)      | 1.13 Gbits/sec  | 1.22 Gbits/sec  | 245 ms
    Clouvider       | Los Angeles, CA, US (10G) | 865 Mbits/sec   | 960 Mbits/sec   | 178 ms
    Clouvider       | London, UK (10G)          | 2.85 Gbits/sec  | 2.77 Gbits/sec  | 41.3 ms
    Scaleway        | Paris, FR (10G)           | 4.69 Gbits/sec  | 4.09 Gbits/sec  | 45.6 ms
    NovoServe       | North Holland, NL (40G)   | 5.20 Gbits/sec  | 4.05 Gbits/sec  | 35.0 ms
    Uztelecom       | Tashkent, UZ (10G)        | 1.91 Gbits/sec  | 1.73 Gbits/sec  | 99.2 ms
    Clouvider       | NYC, NY, US (10G)         | 1.33 Gbits/sec  | 1.14 Gbits/sec  | 115 ms
    Clouvider       | Dallas, TX, US (10G)      | 720 Mbits/sec   | 1.02 Gbits/sec  | 254 ms
    Clouvider       | Los Angeles, CA, US (10G) | 633 Mbits/sec   | 788 Mbits/sec   | 177 ms
    Single Core     | 2497
    Multi Core      | 2495
    YABS completed in 13 min 16 sec
    root@Debian-1201-bookworm-amd64-base ~ # curl -sL yabs.sh | bash
    #                     v2023-09-06                    #
    Thu Oct  5 06:24:30 PM CEST 2023
    Uptime     : 19 days, 8 hours, 21 minutes
    Processor  : Intel(R) Xeon(R) CPU E3-1275 v5 @ 3.60GHz
    CPU cores  : 8 @ 2979.866 MHz
    RAM        : 62.6 GiB
    Swap       : 32.0 GiB
    Disk       : 436.7 GiB
    VM Type    : NONE
    ISP        : Hetzner Online GmbH
    ASN        : AS24940 Hetzner Online GmbH
    Country    : Germany
    Read       | 379.28 MB/s  (94.8k) | 786.62 MB/s  (12.2k)
    Write      | 380.28 MB/s  (95.0k) | 790.76 MB/s  (12.3k)
    Total      | 759.56 MB/s (189.8k) | 1.57 GB/s    (24.6k)
    Read       | 901.93 MB/s   (1.7k) | 867.70 MB/s    (847)
    Write      | 949.85 MB/s   (1.8k) | 925.49 MB/s    (903)
    Total      | 1.85 GB/s     (3.6k) | 1.79 GB/s     (1.7k)
    Clouvider       | London, UK (10G)          | 921 Mbits/sec   | 906 Mbits/sec   | 19.8 ms
    Scaleway        | Paris, FR (10G)           | 925 Mbits/sec   | 930 Mbits/sec   | 21.0 ms
    NovoServe       | North Holland, NL (40G)   | 929 Mbits/sec   | 937 Mbits/sec   | 11.8 ms
    Uztelecom       | Tashkent, UZ (10G)        | 868 Mbits/sec   | 384 Mbits/sec   | 90.6 ms
    Clouvider       | NYC, NY, US (10G)         | 866 Mbits/sec   | 573 Mbits/sec   | 85.4 ms
    Clouvider       | Dallas, TX, US (10G)      | 836 Mbits/sec   | 257 Mbits/sec   | 123 ms
    Clouvider       | Los Angeles, CA, US (10G) | 813 Mbits/sec   | 211 Mbits/sec   | 149 ms
    Clouvider       | London, UK (10G)          | 911 Mbits/sec   | 913 Mbits/sec   | 19.8 ms
    Scaleway        | Paris, FR (10G)           | 912 Mbits/sec   | 904 Mbits/sec   | 24.7 ms
    NovoServe       | North Holland, NL (40G)   | 917 Mbits/sec   | 922 Mbits/sec   | 11.7 ms
    Uztelecom       | Tashkent, UZ (10G)        | 838 Mbits/sec   | 434 Mbits/sec   | 90.7 ms
    Clouvider       | NYC, NY, US (10G)         | 858 Mbits/sec   | 417 Mbits/sec   | 85.4 ms
    Clouvider       | Dallas, TX, US (10G)      | 825 Mbits/sec   | 188 Mbits/sec   | 123 ms
    Clouvider       | Los Angeles, CA, US (10G) | 797 Mbits/sec   | 186 Mbits/sec   | 149 ms
    Single Core     | 1461
    Multi Core      | 4812
    Full Test       | https://browser.geekbench.com/v6/cpu/2932930
    YABS completed in 13 min 3 sec
  • ruvps.net ("NVMe & "100Mbit/s") in Ukraine ($4.5 USD) (P.S. do not buy from them, they're scammers & will block your tickets, just want to show their shitty server)
    #                     v2023-09-06                    #
    Sat Oct  7 09:52:08 PM UTC 2023
    CPU cores  : 1 @ 2297.338 MHz
    AES-NI     : ❌ Disabled
    RAM        : 1.9 GiB
    Swap       : 0.0 KiB
    Disk       : 29.5 GiB
    ISP        : Kutumova Elena Vladimyrovna
    ASN        : AS51264 Kutumova Elena Vladimyrovna
    Host       : Kutumova Elena Vladimyrovna
    Country    : Ukraine
    Read       | 378.00 KB/s     (94) | 6.05 MB/s       (94)
    Write      | 399.00 KB/s     (99) | 6.38 MB/s       (99)
    Total      | 777.00 KB/s    (193) | 12.44 MB/s     (193)
    Read       | 11.78 MB/s      (23) | 11.49 MB/s      (11)
    Write      | 12.83 MB/s      (25) | 12.85 MB/s      (12)
    Total      | 24.62 MB/s      (48) | 24.35 MB/s      (23)
    Clouvider       | London, UK (10G)          | 57.9 Mbits/sec  | 79.7 Mbits/sec  | 41.3 ms
    Scaleway        | Paris, FR (10G)           | busy            | 78.4 Mbits/sec  | 37.7 ms
    NovoServe       | North Holland, NL (40G)   | 65.5 Mbits/sec  | 78.4 Mbits/sec  | 33.9 ms
    Uztelecom       | Tashkent, UZ (10G)        | 43.6 Mbits/sec  | 74.7 Mbits/sec  | 75.7 ms
    Clouvider       | NYC, NY, US (10G)         | 33.9 Mbits/sec  | 76.5 Mbits/sec  | 112 ms
    Clouvider       | Dallas, TX, US (10G)      | 7.89 Mbits/sec  | 68.6 Mbits/sec  | 270 ms
    Clouvider       | Los Angeles, CA, US (10G) | 18.3 Mbits/sec  | 69.8 Mbits/sec  | 179 ms
    Single Core     | 409
    Multi Core      | 406
    Full Test       | https://browser.geekbench.com/v6/cpu/2972596
    YABS completed in 35 min 42 sec
  • Got my hands on a Steam Deck finally, so naturally had to run a YABS. Got the 64 GB version and replaced the disk with a Corsair MP600 Mini
    #                     v2023-09-06                    #
    Tue Oct 10 12:39:06 PM CEST 2023
    Uptime     : 0 days, 0 hours, 39 minutes
    Processor  : AMD Custom APU 0405
    CPU cores  : 8 @ 1700.000 MHz
    RAM        : 14.5 GiB
    Swap       : 1024.0 MiB
    Disk       : 921.4 GiB
    Distro     : SteamOS
    Kernel     : 5.13.0-valve37-1-neptune
    VM Type    : NONE
    ISP        : Altibox AS
    ASN        : AS29695 Altibox AS
    Host       : Altibox
    Country    : Norway
    Read       | 587.81 MB/s (146.9k) | 1.21 GB/s    (19.0k)
    Write      | 589.36 MB/s (147.3k) | 1.22 GB/s    (19.1k)
    Total      | 1.17 GB/s   (294.2k) | 2.44 GB/s    (38.1k)
    Read       | 1.57 GB/s     (3.0k) | 1.53 GB/s     (1.4k)
    Write      | 1.66 GB/s     (3.2k) | 1.63 GB/s     (1.5k)
    Total      | 3.24 GB/s     (6.3k) | 3.16 GB/s     (3.0k)
    Clouvider       | London, UK (10G)          | 489 Mbits/sec   | 340 Mbits/sec   | 24.4 ms
    Scaleway        | Paris, FR (10G)           | busy            | busy            | 28.4 ms
    NovoServe       | North Holland, NL (40G)   | 496 Mbits/sec   | 479 Mbits/sec   | 21.1 ms
    Uztelecom       | Tashkent, UZ (10G)        | 423 Mbits/sec   | 259 Mbits/sec   | 86.8 ms
    Clouvider       | NYC, NY, US (10G)         | 458 Mbits/sec   | 293 Mbits/sec   | 89.0 ms
    Clouvider       | Dallas, TX, US (10G)      | 369 Mbits/sec   | 196 Mbits/sec   | 122 ms
    Clouvider       | Los Angeles, CA, US (10G) | 418 Mbits/sec   | 201 Mbits/sec   | 146 ms
    Clouvider       | London, UK (10G)          | 471 Mbits/sec   | 349 Mbits/sec   | 24.6 ms
    Scaleway        | Paris, FR (10G)           | busy            | busy            | 31.8 ms
    NovoServe       | North Holland, NL (40G)   | 484 Mbits/sec   | 492 Mbits/sec   | 21.1 ms
    Uztelecom       | Tashkent, UZ (10G)        | 410 Mbits/sec   | 188 Mbits/sec   | 91.1 ms
    Clouvider       | NYC, NY, US (10G)         | 342 Mbits/sec   | 184 Mbits/sec   | 90.8 ms
    Clouvider       | Dallas, TX, US (10G)      | 243 Mbits/sec   | 219 Mbits/sec   | 145 ms
    Clouvider       | Los Angeles, CA, US (10G) | 255 Mbits/sec   | 194 Mbits/sec   | 173 ms
    Single Core     | 1120
    Multi Core      | 4145
    Full Test       | https://browser.geekbench.com/v6/cpu/3009824
    YABS completed in 13 min 41 sec
  • Love these cheap builds :)
    сре, 11 окт 19:12:36 CEST 2023
    Uptime     : 0 days, 0 hours, 49 minutes
    Processor  : AMD Ryzen 5 1600 Six-Core Processor
    CPU cores  : 12 @ 1479.880 MHz
    RAM        : 15.5 GiB
    Swap       : 7.6 GiB
    Disk       : 447.8 GiB
    Distro     : Manjaro Linux
    Kernel     : 6.1.55-1-MANJARO
    VM Type    : NONE
    ISP        : Telekabel-Bitola
    ASN        : AS41557 Drustvo za telekomunikaciski uslugi TELEKABEL DOOEL Stip
    Host       : NEOTEL DOO export-import Skopje
    Country    : North Macedonia
    Read       | 106.13 MB/s  (26.5k) | 176.71 MB/s   (2.7k)
    Write      | 106.41 MB/s  (26.6k) | 177.64 MB/s   (2.7k)
    Total      | 212.55 MB/s  (53.1k) | 354.36 MB/s   (5.5k)
    Read       | 147.72 MB/s    (288) | 224.95 MB/s    (219)
    Write      | 155.57 MB/s    (303) | 239.93 MB/s    (234)
    Total      | 303.29 MB/s    (591) | 464.89 MB/s    (453)
    Clouvider       | London, UK (10G)          | 96.1 Mbits/sec  | 90.6 Mbits/sec  | 50.7 ms
    Scaleway        | Paris, FR (10G)           | busy            | 93.3 Mbits/sec  | 62.7 ms
    NovoServe       | North Holland, NL (40G)   | 86.0 Mbits/sec  | 94.4 Mbits/sec  | 43.7 ms
    Uztelecom       | Tashkent, UZ (10G)        | 97.3 Mbits/sec  | 70.8 Mbits/sec  | 122 ms
    Clouvider       | NYC, NY, US (10G)         | 93.2 Mbits/sec  | 70.6 Mbits/sec  | 128 ms
    Clouvider       | Dallas, TX, US (10G)      | 80.8 Mbits/sec  | 53.9 Mbits/sec  | 276 ms
    Clouvider       | Los Angeles, CA, US (10G) | 89.3 Mbits/sec  | 62.0 Mbits/sec  | 184 ms
    Single Core     | 1228
    Multi Core      | 5551
    Full Test       | https://browser.geekbench.com/v6/cpu/3029184
    YABS completed in 10 min 57 sec
  • Hivelocity NYC
    #                     v2023-09-06                    #
    Wed Oct 11 19:36:58 UTC 2023
    Uptime     : 0 days, 0 hours, 32 minutes
    CPU cores  : 1 @ 2799.996 MHz
    RAM        : 1.9 GiB
    Swap       : 0.0 KiB
    Disk       : 49.2 GiB
    Kernel     : 6.1.0-13-amd64
    ISP        : HIVELOCITY, Inc.
    ASN        : AS29802 HIVELOCITY, Inc.
    Host       : HIVELOCITY, Inc.
    Read       | 240.76 MB/s  (60.1k) | 355.29 MB/s   (5.5k)
    Write      | 241.39 MB/s  (60.3k) | 357.16 MB/s   (5.5k)
    Total      | 482.15 MB/s (120.5k) | 712.46 MB/s  (11.1k)
    Read       | 491.54 MB/s    (960) | 522.14 MB/s    (509)
    Write      | 517.66 MB/s   (1.0k) | 556.91 MB/s    (543)
    Total      | 1.00 GB/s     (1.9k) | 1.07 GB/s     (1.0k)
    Clouvider       | London, UK (10G)          | 613 Mbits/sec   | 220 Mbits/sec   | 67.5 ms
    Scaleway        | Paris, FR (10G)           | busy            | 730 Mbits/sec   | 80.9 ms
    NovoServe       | North Holland, NL (40G)   | 1.07 Gbits/sec  | 876 Mbits/sec   | 78.6 ms
    Uztelecom       | Tashkent, UZ (10G)        | 984 Mbits/sec   | 419 Mbits/sec   | 179 ms
    Clouvider       | NYC, NY, US (10G)         | 1.12 Gbits/sec  | 980 Mbits/sec   | 2.65 ms
    Clouvider       | Dallas, TX, US (10G)      | 346 Mbits/sec   | 260 Mbits/sec   | 41.7 ms
    Clouvider       | Los Angeles, CA, US (10G) | 1.07 Gbits/sec  | 676 Mbits/sec   | 61.5 ms
    Clouvider       | London, UK (10G)          | 1.01 Gbits/sec  | 925 Mbits/sec   | 67.3 ms
    Scaleway        | Paris, FR (10G)           | busy            | busy            | 78.6 ms
    NovoServe       | North Holland, NL (40G)   | 1.06 Gbits/sec  | 848 Mbits/sec   | 78.7 ms
    Uztelecom       | Tashkent, UZ (10G)        | 933 Mbits/sec   | 167 Mbits/sec   | 179 ms
    Clouvider       | NYC, NY, US (10G)         | 1.12 Gbits/sec  | 966 Mbits/sec   | 2.55 ms
    Clouvider       | Dallas, TX, US (10G)      | 1.02 Gbits/sec  | 890 Mbits/sec   | 41.7 ms
    Clouvider       | Los Angeles, CA, US (10G) | 1.01 Gbits/sec  | 904 Mbits/sec   | 61.3 ms
    Single Core     | 1310
    Multi Core      | 1313
    Full Test       | https://browser.geekbench.com/v6/cpu/3030828
  • RadiRadi Hosting ProviderOG
    drServer's Intel Xeon E-2136 dedicated server
    #                     v2023-09-06                    #
    Fri 13 Oct 2023 10:39:10 PM MSK
    Uptime     : 0 days, 0 hours, 20 minutes
    Processor  : Intel(R) Xeon(R) E-2136 CPU @ 3.30GHz
    CPU cores  : 12 @ 3203.751 MHz
    RAM        : 15.5 GiB
    Swap       : 976.0 MiB
    Disk       : 438.1 GiB
    Distro     : Debian GNU/Linux 10 (buster)
    Kernel     : 4.19.0-25-amd64
    VM Type    : NONE
    ISP        : drServer International
    ASN        : AS396881 drServer.net
    Host       : FranTech Solutions
    Read       | 94.81 MB/s   (23.7k) | 169.37 MB/s   (2.6k)
    Write      | 95.06 MB/s   (23.7k) | 170.26 MB/s   (2.6k)
    Total      | 189.88 MB/s  (47.4k) | 339.64 MB/s   (5.3k)
    Read       | 198.39 MB/s    (387) | 210.05 MB/s    (205)
    Write      | 208.93 MB/s    (408) | 224.04 MB/s    (218)
    Total      | 407.33 MB/s    (795) | 434.10 MB/s    (423)
    Clouvider       | London, UK (10G)          | 30.4 Mbits/sec  | 91.3 Mbits/sec  | 102 ms
    Scaleway        | Paris, FR (10G)           | 90.3 Mbits/sec  | busy            | 112 ms
    NovoServe       | North Holland, NL (40G)   | 90.4 Mbits/sec  | 88.5 Mbits/sec  | 113 ms
    Uztelecom       | Tashkent, UZ (10G)        | 85.7 Mbits/sec  | 74.1 Mbits/sec  | 207 ms
    Clouvider       | NYC, NY, US (10G)         | 93.1 Mbits/sec  | 93.6 Mbits/sec  | 34.9 ms
    Clouvider       | Dallas, TX, US (10G)      | 94.1 Mbits/sec  | 94.0 Mbits/sec  | 1.07 ms
    Clouvider       | Los Angeles, CA, US (10G) | 93.3 Mbits/sec  | 93.7 Mbits/sec  | 29.5 ms
    Single Core     | 1749
    Multi Core      | 5805
    Full Test       | https://browser.geekbench.com/v6/cpu/3063927
    YABS completed in 10 min 4 sec
  • New home server:
    • Intel Core i5-13500
    • Asus Pro WS W680M-ACE SE motherboard
    • 64GB DDR5 ECC RAM
    • 2 x 2TB Solidigm P44 Pro SSDs (similar to SK Hynix Platinum P41) in ZFS mirror
    • 2 x 20TB Seagate Exos X20 hard drives in ZFS mirror
    • Fractal Design Node 804 case
    • 10Gbps internet connection via TRENDnet 10Gbps PCIe Ethernet card, Mikrotik CRS312-4C+8XG-RM switch, TP-Link ER8411 router, AdTran 822v ONT. IPv6 not enabled yet because apparently my router doesn't actually have an IPv6 firewall yet ¯\_(ツ)_/¯
    • Running Unraid which is based on Slackware
    All CPU power saving settings are on to conserve power, which may affect the GB6 test result a little bit.
    #                     v2023-09-06                    #
    Fri Oct 13 15:15:18 PDT 2023
    Uptime     : 36 days, 4 hours, 34 minutes
    Processor  : 13th Gen Intel(R) Core(TM) i5-13500
    CPU cores  : 20 @ 2500.000 MHz
    RAM        : 62.4 GiB
    Swap       : 0.0 KiB
    Disk       : 60.3 GiB
    Distro     : Slackware 15.0 x86_64 (post 15.0 -current)
    Kernel     : 6.1.38-Unraid
    VM Type    :
    ISP        : Sonic Telecom LLC
    ASN        : AS46375 Sonic Telecom LLC
    Host       : Sonic.net, Inc.
    tail: cannot open '2' for reading: No such file or directory
    Read       | 520.99 MB/s (130.2k) | 3.78 GB/s    (59.2k)
    Write      | 522.36 MB/s (130.5k) | 3.80 GB/s    (59.5k)
    Total      | 1.04 GB/s   (260.8k) | 7.59 GB/s   (118.7k)
    Read       | 5.23 GB/s    (10.2k) | 5.81 GB/s     (5.6k)
    Write      | 5.51 GB/s    (10.7k) | 6.20 GB/s     (6.0k)
    Total      | 10.75 GB/s   (21.0k) | 12.01 GB/s   (11.7k)
    Clouvider       | London, UK (10G)          | busy            | 1.59 Gbits/sec  | 141 ms
    Scaleway        | Paris, FR (10G)           | 2.62 Gbits/sec  | busy            | 143 ms
    NovoServe       | North Holland, NL (40G)   | 1.20 Gbits/sec  | 1.26 Gbits/sec  | 146 ms
    Uztelecom       | Tashkent, UZ (10G)        | 1.81 Gbits/sec  | busy            | 231 ms
    Clouvider       | NYC, NY, US (10G)         | 2.64 Gbits/sec  | 3.24 Gbits/sec  | 72.4 ms
    Clouvider       | Dallas, TX, US (10G)      | 945 Mbits/sec   | 1.43 Gbits/sec  | 154 ms
    Clouvider       | Los Angeles, CA, US (10G) | 3.51 Gbits/sec  | 8.04 Gbits/sec  | 12.2 ms
    Single Core     | 2485
    Multi Core      | 12662
    Full Test       | https://browser.geekbench.com/v6/cpu/3065449
    YABS completed in 8 min 44 sec
    Thanked by (4)Mason sh97 loay aryanraj
  • c1vhosting €15/year - 2C/2G/900GB/500M
    #                     v2023-09-06                    #
    Sat 14 Oct 2023 11:34:14 AM PDT
    Uptime     : 0 days, 0 hours, 31 minutes
    CPU cores  : 2 @ 2599.996 MHz
    RAM        : 1.9 GiB
    Swap       : 975.0 MiB
    Disk       : 883.9 GiB
    Kernel     : 5.10.0-26-amd64
    ISP        : Cinzia Tocci trading as C1V
    ASN        : AS212271 Cinzia Tocci trading as C1V
    Host       : C1V di Cinzia Tocci
    Country    : Italy
    Read       | 48.63 MB/s   (12.1k) | 716.56 MB/s  (11.1k)
    Write      | 48.71 MB/s   (12.1k) | 720.33 MB/s  (11.2k)
    Total      | 97.34 MB/s   (24.3k) | 1.43 GB/s    (22.4k)
    Read       | 1.68 GB/s     (3.2k) | 1.93 GB/s     (1.8k)
    Write      | 1.77 GB/s     (3.4k) | 2.05 GB/s     (2.0k)
    Total      | 3.46 GB/s     (6.7k) | 3.99 GB/s     (3.8k)
    Clouvider       | London, UK (10G)          | 394 Mbits/sec   | 397 Mbits/sec   | 32.1 ms
    Scaleway        | Paris, FR (10G)           | busy            | 397 Mbits/sec   | 26.0 ms
    NovoServe       | North Holland, NL (40G)   | 399 Mbits/sec   | 393 Mbits/sec   | 34.6 ms
    Uztelecom       | Tashkent, UZ (10G)        | 202 Mbits/sec   | busy            | 114 ms
    Clouvider       | NYC, NY, US (10G)         | busy            | 378 Mbits/sec   | 104 ms
    Clouvider       | Dallas, TX, US (10G)      | 27.6 Mbits/sec  | 237 Mbits/sec   | 249 ms
    Clouvider       | Los Angeles, CA, US (10G) | busy            | 364 Mbits/sec   | 157 ms
    Single Core     | 645
    Multi Core      | 1127
    Full Test       | https://browser.geekbench.com/v6/cpu/3081605
    YABS completed in 17 min 42 sec
    Thanked by (1)c1vhosting
