@mikewazar said: @Calin You're either ignoring my support ticket or you are too busy with volume. Please at least respond on a matter going on from 8 September
Hello I'm not ignore you ticket , I'm re-checked right now , coming soon make you invoice for storage VPS , because for now I prefer not to take clients' money in advance for this type of VPS, only after it will be finished building our storage cluster
@Encoders said: hey @Calin any plan adding debian bookworm in the reinstall panel?
Hello , very sorry but most probality no
Regards,
Calin
Please fullfill my request in ticket #WBE-435236
I decided to not deal with your service anymore, and i do not want to keep my client area account. there are just too many problem.
Your available OS are too cripled, systemd-resolved doesn't work out of the box which causes /etc/resolv.conf to fail just like I mentioned in ticket #NRE-084178
Default dropbear ssh is a bit iffy, especially when you didn't configure it to accept ssh keys be default, in fresh install.
/sbin isn't included in $PATH by default, and it's funny since the default user is root on fresh install. Do you even test your OS before adding it into the install panel?
I think you should provide both OS that install like other VPS Provider, if you want slim version, separate them.
I can't even access your panel properly too https://i.ibb.co/9qKK7rD/image.png. yes this is includes your client area too with frequent error like this
other than this I'm also disappointed you just told me to fuck off into the new micronode panel after that migration, you didn't tell me beforehand in email, just giving a new login for new panel without moving my data at all.
I think it's time to move on, after idling more than 6 month and I'm about to use it just to found out it's not usable for me.
I don't like the default OS template either, but thankfully it's at least possible to update from Debian 10 to 12 manually.
Uptime is great, 98.577% from the deployment on 29th April, 2023, to be precise. There are 1 or 2 downtime weekly ranging from minutes to quarters.
Yes, the network is somewhat terrible, 20 Mbps at most, while 7 Mbps is the average, not to mention the IPv6 access is never delivered next week;
Control panel is fine (micronode.uk).
Overall I rate iHostArt "above average" for both cheap price, fine uptime, and courteous, quick (within a week) reply.
Maybe you want to consider big companies for stable service, timely reply or just wait until Black Friday for cheap specials.
Before that, it's might be helpful for you to learn some Unix-like 101.
Might want to reserve judgement on that. I'm fairly certain he's got those skills. He's just annoyed that he has to employ them on such fundamental pieces.
Vps been down for 2 Months now!!!
Tickets gets answered in around 5 days, but with no solution.
Dont know what is happening here, but i think the end is near...
Hello @yoursunny now work?
Regards
No, still timeout upon reboot button.
Cloudflare Ray ID: 7f7899670cc73961
HostBrr aff best VPS.
check PM
what server is that bro?
Hello @Sneaky_Squid it;s our discord server , join on the party! https://discord.com/invite/mG3Pv76rmB
Regards
oh thanks already joined
its amazing @Calin is still alive
he is a vps monster
can build a spaceship to.
keep on strong and horny .... you will get there and then sell and live in a bigger house with more cars
Calin and iHostART never died!
Free giveaway?
Sultan Muda - Amazon Store
#GAW-306989
Regards,
Calin
why not?
Thank you
Regards,
Calin
#WBE-435236
#NRE-084178
/sbin
isn't included in$PATH
by default, and it's funny since the default user is root on fresh install. Do you even test your OS before adding it into the install panel?other than this I'm also disappointed you just told me to fuck off into the new micronode panel after that migration, you didn't tell me beforehand in email, just giving a new login for new panel without moving my data at all.
I can confirm what you've encountered, but some technical problems can be solved by users on their own:
sudo systemd disable --now systemd-networkd && sudo rm /etc/resolv.conf -f && sudo bash -c 'cat << EOF > /etc/resolv.conf
nameserver 1.0.0.1
nameserver 8.8.4.4
nameserver 74.82.42.42
EOF'
Replace dropbear with widely used openssh;
MicroLXC is lovable.
How about randomly choosing a happy customer in this thread?
nat vps down for serval hours
From discord
The Ultimate Speedtest Script | Get Instant Alerts on new LES/LET deals | Cheap VPS Deals
looks same before, cpu is X5660, upload network speed is less 2Mbps
Hello we don t finish migration , migration take long so we migrate slow all things , we have to migrate 27+ TB of files
Regards
so, when is the next migrate plan?
N ext wiik, I guess?
no reply to tickets in a week my lad.
JPO-572128
My nat has been offline for a few days, and Ticket has not replied yet
Is it gone for good this time?
