A private VPN service ? How to do it ?
A private VPN service ? How to do it ? Which is your recommendation?
Thanked by (1)jureve
  • Get a VPS and install OpenVPN/wireguard/strongswan.
    Thanked by (2)Chievo Ympker
    edited August 2023
    Nyr's script is great for setting up personal vpn. Then just create a profile for everyone who should use it (e.g. family/friends) and be done with it :)
    I'm having my personal vpn run on a 5$/yr natvps from @natvps_uk . It's been solid so far and 10 Gbps port (or was it 1 Gbps?) is awesome :)
    Runs on 128mb ram instance (wireguard+openvpn server), albeit ovpn was also running on 64mb ram instance :tongue:
    Thanked by (2)Chievo KidRock
    Do they have U.S. locations I am thinking about setting some up here soon.
    edited August 2023
    Seems like that's not the case right now ( https://clients.natvps.uk/index.php?rp=/store/micronode-vps ), but maybe @natvps_uk can help out?
    Very happy with my instances so far :) I bought the Micronode Instances, rather than single NAT VPS. That way I can create/destroy vps instances as I want respective to my resource pool.
    @Chievo this is the link to the resource pool product. That said I got it on sale for 5$/yr atm iirc. So you might monitor their discounts on LES, too :)
    Thanked by (1)Chievo
    You probably want to check out Gullo's hosting
    Thanked by (1)AuroraZero
    What's the difference between using natvps/private vpn and vpn from providers like keepsolid, ivacy since they provide lifetime vpn with servers from different countries in comparison to only one country server for natvps/private vpn?
    High resources hosting in low-end pricing - ExtraVM (aff)
    Would you trust them with your data?
  • For private VPN, one can simply use the scripts of @Nyr from GitHub. Choose whatever you like:
    I reserve the right to license all of my content under: CC BY-NC-ND. What happens on this forum should stay on this forum.
    Don't get me wrong, Ivacy/Keepsolid lifetime etc are great and I love them. I have another use case for them, though. I use them mostly for unblocking streaming content and doing some cheap online shopping, or streaming stuff.
    Self-hosted VPN is for more private stuff like online banking while abroad, whitelist ip for certain services etc :)
  • skorousskorous OGSenpai
    At the risk of getting a reputation I'd again mention MrVM.
    Thanked by (2)FrankZ mikho
  • Do check with the host if they allow private VPNs first. Most hosts are ok if it's only for private use.
    Also, check out: https://www.pivpn.io/
    You can use it on any debian/ubuntu based OS. I had been using it for a while and it worked well for a long time.
    Also, this works well if you need a web UI: https://openvpn.net/vpn-software-packages/ubuntu/
    Thanked by (2)FrankZ Chievo
  • A VPS and solutions such as Wireguard can provide all the benefits. There is also proxy servers such as sing-box that can host a plethora of protocols.
  • jfreak53jfreak53 Hosting Provider
    Pritunl is the quickest and easiest to setup, will work on any vps really.
    microtronixdc.com - Colocation, Dedicated Servers, Full-Rack options, VPS. John 3:16 - Jesus Saves!!
    Massive Network Bandwidth options with Fiber throughout, up to 100Gbps connections! Always-On DDoS Mitigation for all traffic!
