server-factory.com | Test of a New NL Location | Help us test and win a VPS!
Hi!
We are testing a New NL Location in Eygelshoven, The Netherlands
We would like to ask the community to help us test!
Limitations of the Test:
- 24 Hour Trial
- One Trial VPS per Client
- IPv6 Only, Mail Ports blocked
- Debian 12 only
Specs:
NL-AMD EPYC™ XXS IPv6 ONLY VPS 24 HOUR TRIAL
TRIAL: 24 HOURS
IPv6 ONLY: NO IPv4
DATA CENTER: SKYLINK DATA CENTER, EYGELSHOVEN, THE NETHERLANDS
VIRTUALIZATION: KVM
NESTED VIRTUALIZATION: ENABLED
CPU: AMD EPYC™ 7702P
BASE CLOCK: 2.00 GHZ
BOOST CLOCK: UP TO 3.35 GHZ
CORES: 1 (25 % LIMIT)
RAM: 2 GiB DDR4 3200 MHZ ECC
STORAGE: 25 GiB NVME PCIe 4.0 SSD (RAID 10)
UPLINK: 1 GBIT
TRAFFIC (INCOMING + OUTGOING): 100 GiB FOR 24 HOURS
IPV6 SUBNET: /64 (ROUTED TOWARDS ::1 IPv6 ADDRESS OF THE SUBNET)
(For this location the IPv6 Subnet is added to the IP Filter of the VPS automatically.)
FEATURE: 1 SNAPSHOT
FEATURE: UPLOAD OWN ISO
FEATURE: RDNS MANAGEMENT
FEATURE: MAIL PORTS BLOCKED
Price
FREE!
You want to win one of our AMD EPYC™ S VPS in Eygelshoven, The Netherlands for 12 months?
Specs: 2 Cores, 8 GiB RAM, 100 GiB NVME SSD, 1 IPv4 Address, /64 IPv6 Subnet, 1 GBIT Uplink, 16 TiB Traffic per month
Just order the Trial VPS and give us some feedback regarding performance/network/client area/etc via comment here.
Winner will be announced on 22.10.2023 15:00 CEST.
VPS for winner will be deployed as soon as the new NL location is production ready (expected Mid November 2023).
Thanks everyone
Kind regards,
mxmla
thank you
woo!
youtube to wav ogg mp3
congrats.
using raid10 instead of ZFS now?
Network test. Maybe has a issue.
Cann't ping NL IPV6 Only service from Sweden IPV6 Service. No reponse.
But it's ok from other NL Service.
Disk test
Congrats on your new NL location!
Got some feedback for y'all:
Obligatory YABS (without GB6, can't run as it's IPv6 and normal GB only uploads data and doesn't print)
HostBill as Control Panel is just super nice (though everyone is vouching for VirtFusion, including myself
), I have no bad feedback for it really (though graphs could be smaller but meh)
Snapshots work perfectly fine
Upload ISO doesn't work at all, fails every time, either via IPv4 or IPv6.
rDNS works perfectly fine, instantly got the PTR record set.
Overall performance is great.
One last thing, the email sent to the client regarding server's setup shouldn't be sent again on reinstallation of OS. Perhaps a different/more explanatory email could be sent?
Congratulations!
Nice panel with access to looking glass - very useful, because you don't have to ask about it on tickets. I hope you will not abandon like most Knowledgebase hosting and add some tutorials for laymen there.
As for uptime you might want to consider a solution from InStatus - it has a much nicer UI along with the ability to set up notifications at the time of failure for clients / yourself.
Regarding the server:
The server is very fast... I have never seen such performance before (I have several servers in other companies that have much better CPU, RAM).
Nothing to whine about... performance is really great.... I hope you will maintain this level with higher node load, then I will consider switching to you myself!
All the best and good luck with your new location!
Thank you
It is ZFS RAID 10 as always
No plans to change that, performance is great and ZFS never let us down.
@Flaymes Thank you for your tests! We will investigate the networking in the upcoming week and will update this Thread as soon as this is solved
@zgato Thanks for your feedback! Could you check the ISO Download feature again please? I adjusted a few Settings and it should work now. We will consider changing the Rebuild E-Mail, thank you!
@Spectrum Thanks for your feedback! We will check out Instatus for sure! At the moment we are very happy with Uptime Kuma but Client Notifications are a huge plus
server-factory.com
Uploading & mounting ISO works flawlessly now. One thing you may consider checking is a weird error whilst using a Debian 11 ISO image (and perhaps happens with others too), whilst installing using GUI interface instead of legacy install
I tried to order one, but can't login into the CP: account closed. But I also can't create a new one, as an account with the email already exists.
Glad ISO is working now
I will check what is going on with the mentioned error. As far as I remember this is a known Debian 11 bug, I will update you
Please send me your E-Mail Address via DM and I will check
server-factory.com
Makes me wish I had the time to break it, er I mean test it.
It also appears I need to order a new keyboard for my laptop.
@mxmla do I use port 22 for ssh?
Congrats on the new location!
Performance is as good as usual. Network is stable and fast, latency to my ISP is lower than Sweden location.
Installed Ubuntu via ISO and working fine
Windows also worked. Of course, I don't think to use it regularly.
https://i.imgur.com/12vRKAB.png
Account registration and activation of service went through pretty smoothly. Overall, the VM feels pretty responsive.
Port 22 is the officially documented port for ssh, yes.
Yes, Port 22 for SSH. (Thanks @skorous )
server-factory.com
Not enough time for in depth test but idling
was stable.
Just used it for some docker ipv6 testing with low load and I can't complain about the VPS.
Minor improvements for the panel:
On sign up the alignment of input fields felt wrong, first name and last name on a line break - same for password and repeat password inputs.
And in
Security
section, theMulti-factor auth
looks like a tabbed view but the tab is gone when selecting it and can't return toAllowed IP Access
from it. (openSecurity
section again works of course)Thanks for sponsoring a free VPS and good luck with sales.
Cloudstorage Filen.io Aff - filelu Aff
Free Uptime Monitoring HetrixTools Aff
Test ready, will check it
Trusted Partner - www.webi.co.in
WOW
Feeling very tired, let's call it a day.
Couple of things I noticed: the control panel sidebar 'flashes' in and out during login between the username/password page and the 2FA page, then again once login is complete.
The order form contains this option: I have read and accepted that I tested the connection towards the network beforehand with the Looking Glass at https://lg.nl.server-factory.com
This shall be edited to point to a looking glass at Eygelshoven location.
I have confirmed that routed IPv6 is working properly.
When this product exits trial status, it will be eligible for Routed IPv6 Hall of Fame.
vps9
hostname is available. affbrr2、Performance Testing:
3、Netflix and other streaming media tests:
4、CPU performance test:
5、Memory performance test:
6、Disk performance test
Disk write performance:
Hard drive read performance:
Advantages:
High-Speed Network Connection: The server exhibits extremely high upload and download speeds in network speed tests at multiple locations, especially at European test nodes. This is a significant advantage for applications that require substantial data transfers.
Powerful CPU Performance: The AMD EPYC 7702P 64-Core Processor provides robust processing capabilities. Even though only one core is allocated, its performance is still remarkably outstanding.
Rapid Disk I/O: The disk read and write speeds are exceptionally fast, particularly in mixed read/write tests, showcasing the powerful performance of NVMe SSDs.
Sufficient RAM: 2GB of DDR4 RAM should be enough for most basic tasks.
Stable Operating Environment: Debian GNU/Linux 12 provides a stable and widely supported operating system environment.
IPv6 Support: The server supports IPv6, which is essential for the future development of networks.
Disadvantages:
IPv6 Only in This Test: Some services and applications that only support IPv4 could not be thoroughly tested in this instance. Further testing opportunities could be explored in the future.
Limited CPU Cores and RAM: While the CPU performance is strong, having only one core and 2GB of RAM could potentially limit the server's performance in handling multitasking or memory-intensive applications. Of course, upgrades and configuration optimizations can be made later based on individual needs.
Limited Access to Streaming Media Services: As the current test only supports IPv6, the results for streaming media services show that the server is unable to access several streaming media services. This could be due to network configuration or other issues.
In summary, this server excels in network speed, CPU performance, and disk I/O, making it highly suitable for applications that require fast network connections and robust processing capabilities.
VPS Discounts and Reviews | Hosting Provider Directory & Check out the latest VPS offers and reviews to help you choose the best VPS service.
ChatGPT?
Ready to test one
Sorry for the delay!
Thanks to everyone who helped us test our new NL location so far
@tototo is the winner, please register here: https://my.server-factory.com/signup/ and let me know your E-Mail Address via private message within the next 24 hours. Provisioning is expected within the next 7 days.
server-factory.com
congrats @tototo
hey maxi, where is your 11.11 offer?
NL-AMD EPYC™ XXS IPv6 ONLY VPS 24 HOUR TRIAL is back in stock with more OS Templates
We are searching for a few people with public ASN and Subnets to test our BGP Session setup.
Reward: Free NL-AMD EPYC™ XXS VPS for 1 year. Specs: https://my.server-factory.com/cart/nl-amd-epyc-vps/
PM please
server-factory.com
@yoursunny PING
Congratulations @tototo !!
