server-factory.com | Test of a New NL Location | Help us test and win a VPS!
Hi!
We are testing a New NL Location in Eygelshoven, The Netherlands
We would like to ask the community to help us test!
Limitations of the Test:
  • 24 Hour Trial
  • One Trial VPS per Client
  • IPv6 Only, Mail Ports blocked
  • Debian 12 only
Specs:
NL-AMD EPYC™ XXS IPv6 ONLY VPS 24 HOUR TRIAL
TRIAL: 24 HOURS
IPv6 ONLY: NO IPv4
DATA CENTER: SKYLINK DATA CENTER, EYGELSHOVEN, THE NETHERLANDS
VIRTUALIZATION: KVM
NESTED VIRTUALIZATION: ENABLED
CPU: AMD EPYC™ 7702P
BASE CLOCK: 2.00 GHZ
BOOST CLOCK: UP TO 3.35 GHZ
CORES: 1 (25 % LIMIT)
RAM: 2 GiB DDR4 3200 MHZ ECC
STORAGE: 25 GiB NVME PCIe 4.0 SSD (RAID 10)
UPLINK: 1 GBIT
TRAFFIC (INCOMING + OUTGOING): 100 GiB FOR 24 HOURS
IPV6 SUBNET: /64 (ROUTED TOWARDS ::1 IPv6 ADDRESS OF THE SUBNET)
(For this location the IPv6 Subnet is added to the IP Filter of the VPS automatically.)
FEATURE: 1 SNAPSHOT
FEATURE: UPLOAD OWN ISO
FEATURE: RDNS MANAGEMENT
FEATURE: MAIL PORTS BLOCKED
Price
FREE!
Order here!
You want to win one of our AMD EPYC™ S VPS in Eygelshoven, The Netherlands for 12 months?
Specs: 2 Cores, 8 GiB RAM, 100 GiB NVME SSD, 1 IPv4 Address, /64 IPv6 Subnet, 1 GBIT Uplink, 16 TiB Traffic per month
Just order the Trial VPS and give us some feedback regarding performance/network/client area/etc via comment here.
Winner will be announced on 22.10.2023 15:00 CEST.
VPS for winner will be deployed as soon as the new NL location is production ready (expected Mid November 2023).
Thanks everyone
Kind regards,
mxmla
Thanked by (3)Ganonk iKirby Spectrum
  • thank you <3
    Thanked by (1)mxmla
    congrats.
    using raid10 instead of ZFS now?
    Thanked by (1)mxmla
  • Network test. Maybe has a issue.
    Cann't ping NL IPV6 Only service from Sweden IPV6 Service. No reponse.
    root@swedenvps01:~# ping -6 2a07:e042:1:60::1
    PING 2a07:e042:1:60::1(2a07:e042:1:60::1) 56 data bytes
    root@swedenvps01:~# telnet 2a07:e042:1:60::1 80
    Trying 2a07:e042:1:60::1...
    telnet: Unable to connect to remote host: Connection timed out
    But it's ok from other NL Service.
    root@nl01sfvps:~# wget http://[2a07:e042:1:60::1]/download/test -O /dev/null
    --2023-10-13 02:44:08--  http://[2a07:e042:1:60::1]/download/test
    Connecting to [2a07:e042:1:60::1]:80... connected.
    HTTP request sent, awaiting response... 200 OK
    Length: 1048576000 (1000M) [application/octet-stream]
    Saving to: ‘/dev/null’
    /dev/null                                   21%[=================>        ] 213.03M   106MB/s
    Disk test
    root@sfnl2:/mnt/nfs_data/downloads# time dd if=/dev/zero of=/tmp/test bs=8k count=1000000
    1000000+0 records in
    1000000+0 records out
    8192000000 bytes (8.2 GB, 7.6 GiB) copied, 8.52337 s, 961 MB/s
    real    0m8.525s
    user    0m0.124s
    sys 0m5.995s
    root@sfnl2:/mnt/nfs_data/downloads# time dd if=/tmp/test of=/dev/null bs=8k
    8192000000 bytes (8.2 GB, 7.6 GiB) copied, 8.86395 s, 924 MB/s
    real    0m8.866s
    user    0m0.134s
    sys 0m4.372s
    root@sfnl2:/mnt/nfs_data/downloads# time dd if=/tmp/test of=/var/test bs=64k
    125000+0 records in
    125000+0 records out
    8192000000 bytes (8.2 GB, 7.6 GiB) copied, 14.5451 s, 563 MB/s
    real    0m14.547s
    user    0m0.036s
    sys 0m9.299s
  • edited October 2023
    Congrats on your new NL location!
    Got some feedback for y'all:
    Obligatory YABS (without GB6, can't run as it's IPv6 and normal GB only uploads data and doesn't print)
    #                     v2023-09-06                    #
    Fri Oct 13 01:55:51 AM CEST 2023
    Uptime     : 0 days, 0 hours, 4 minutes
    Processor  : AMD EPYC 7702P 64-Core Processor
    CPU cores  : 1 @ 1999.999 MHz
    RAM        : 1.9 GiB
    Swap       : 0.0 KiB
    Disk       : 24.5 GiB
    Kernel     : 6.1.0-13-amd64
    IPv4/IPv6  : ❌ Offline / ✔ Online
    Read       | 252.09 MB/s  (63.0k) | 2.97 GB/s    (46.4k)
    Write      | 252.75 MB/s  (63.1k) | 2.98 GB/s    (46.6k)
    Total      | 504.85 MB/s (126.2k) | 5.95 GB/s    (93.0k)
    Read       | 5.18 GB/s    (10.1k) | 6.56 GB/s     (6.4k)
    Write      | 5.46 GB/s    (10.6k) | 7.00 GB/s     (6.8k)
    Total      | 10.64 GB/s   (20.7k) | 13.57 GB/s   (13.2k)
    Clouvider       | London, UK (10G)          | 1.00 Gbits/sec  | 985 Mbits/sec   | 12.4 ms
    Scaleway        | Paris, FR (10G)           | 1.01 Gbits/sec  | 985 Mbits/sec   | 13.2 ms
    NovoServe       | North Holland, NL (40G)   | 1.01 Gbits/sec  | 979 Mbits/sec   | 13.1 ms
    Uztelecom       | Tashkent, UZ (10G)        | 475 Mbits/sec   | 791 Mbits/sec   | 99.8 ms
    Clouvider       | NYC, NY, US (10G)         | 497 Mbits/sec   | 937 Mbits/sec   | 85.8 ms
    Clouvider       | Dallas, TX, US (10G)      | 410 Mbits/sec   | 700 Mbits/sec   | 125 ms
    Clouvider       | Los Angeles, CA, US (10G) | 335 Mbits/sec   | 743 Mbits/sec   | 145 ms
    HostBill as Control Panel is just super nice (though everyone is vouching for VirtFusion, including myself ;)), I have no bad feedback for it really (though graphs could be smaller but meh)
    Snapshots work perfectly fine
    Upload ISO doesn't work at all, fails every time, either via IPv4 or IPv6.
    rDNS works perfectly fine, instantly got the PTR record set.
    Overall performance is great.
    One last thing, the email sent to the client regarding server's setup shouldn't be sent again on reinstallation of OS. Perhaps a different/more explanatory email could be sent?
    Thanked by (1)mxmla
  • Congratulations!
    Nice panel with access to looking glass - very useful, because you don't have to ask about it on tickets. I hope you will not abandon like most Knowledgebase hosting and add some tutorials for laymen there.
    As for uptime you might want to consider a solution from InStatus - it has a much nicer UI along with the ability to set up notifications at the time of failure for clients / yourself. :)
    Regarding the server:
    The server is very fast... I have never seen such performance before (I have several servers in other companies that have much better CPU, RAM).
    • Very good network - access to 1G/1G with low ping,
    • very fast disks:
    Block size 4k (IOPS) 64k (IOPS).
    Read 250.94 MB/s (62.7k) 2.77 GB/s (43.3k).
    Write 251.60 MB/s (62.9k) 2.78 GB/s (43.5k).
    Total 502.55 MB/s (125.6 thousand) 5.56 GB/s (86.9 thousand).
    Block size 512 thousand (IOPS) 1 million (IOPS).
    Read 4.21 GB/s (8.2k) 4.16 GB/s (4.0k).
    Write 4.43 GB/s (8.6 thousand) 4.44 GB/s (4.3 thousand).
    Total 8.64 GB/s (16.8 thousand) 8.61 GB/s (8.4 thousand).
    Nothing to whine about... performance is really great.... I hope you will maintain this level with higher node load, then I will consider switching to you myself!
    All the best and good luck with your new location! :D
    @cybertech said:
    congrats.
    Thank you :) It is ZFS RAID 10 as always ;) No plans to change that, performance is great and ZFS never let us down.
    @Flaymes Thank you for your tests! We will investigate the networking in the upcoming week and will update this Thread as soon as this is solved ;)
    @zgato Thanks for your feedback! Could you check the ISO Download feature again please? I adjusted a few Settings and it should work now. We will consider changing the Rebuild E-Mail, thank you!
    @Spectrum Thanks for your feedback! We will check out Instatus for sure! At the moment we are very happy with Uptime Kuma but Client Notifications are a huge plus :)
    Thanked by (2)cybertech Spectrum
    Uploading & mounting ISO works flawlessly now. One thing you may consider checking is a weird error whilst using a Debian 11 ISO image (and perhaps happens with others too), whilst installing using GUI interface instead of legacy install
    Thanked by (1)mxmla
  • I tried to order one, but can't login into the CP: account closed. But I also can't create a new one, as an account with the email already exists.
    Thanked by (1)mxmla
    Thanks for your feedback :) Glad ISO is working now ;)
    I will check what is going on with the mentioned error. As far as I remember this is a known Debian 11 bug, I will update you ;)
    Please send me your E-Mail Address via DM and I will check ;)
  • AuroraZeroAuroraZero Retired
    edited October 2023
    Makes me wish I had the time to break it, er I mean test it. :p It also appears I need to order a new keyboard for my laptop. :'(
    Thanked by (2)FrankZ mxmla
  • @mxmla do I use port 22 for ssh?
    Thanked by (1)mxmla
  • Congrats on the new location!
    Performance is as good as usual. Network is stable and fast, latency to my ISP is lower than Sweden location.
    Thanked by (1)mxmla
    Installed Ubuntu via ISO and working fine B)
    root@ubuntu:~# curl yabs.sh -sL | bash -s -- -ig
    #                     v2023-09-06                    #
    Sat Oct 14 06:22:51 UTC 2023
    RAM        : 1.9 GiB
    Swap       : 2.0 GiB
    Disk       : 24.4 GiB
    Distro     : Ubuntu 23.10
    Kernel     : 6.5.0-9-generic
    Read       | 256.25 MB/s  (64.0k) | 2.67 GB/s    (41.7k)
    Write      | 256.93 MB/s  (64.2k) | 2.68 GB/s    (41.9k)
    Total      | 513.18 MB/s (128.2k) | 5.35 GB/s    (83.6k)
    Read       | 5.56 GB/s    (10.8k) | 4.90 GB/s     (4.7k)
    Write      | 5.86 GB/s    (11.4k) | 5.22 GB/s     (5.1k)
    Total      | 11.42 GB/s   (22.3k) | 10.13 GB/s    (9.8k)
    YABS completed in 15 sec
    Windows also worked. Of course, I don't think to use it regularly.
    https://i.imgur.com/12vRKAB.png
    Thanked by (1)mxmla
  • Account registration and activation of service went through pretty smoothly. Overall, the VM feels pretty responsive.
    #                     v2023-09-06                    #
    Sat Oct 14 02:02:17 PM CEST 2023
    Uptime     : 0 days, 0 hours, 2 minutes
    RAM        : 1.9 GiB
    Swap       : 0.0 KiB
    Disk       : 24.5 GiB
    Read       | 257.26 MB/s  (64.3k) | 3.30 GB/s    (51.7k)
    Write      | 257.94 MB/s  (64.4k) | 3.32 GB/s    (51.9k)
    Total      | 515.20 MB/s (128.8k) | 6.63 GB/s   (103.6k)
    Read       | 5.43 GB/s    (10.6k) | 5.54 GB/s     (5.4k)
    Write      | 5.72 GB/s    (11.1k) | 5.91 GB/s     (5.7k)
    Total      | 11.15 GB/s   (21.7k) | 11.45 GB/s   (11.1k)
    Clouvider       | London, UK (10G)          | 995 Mbits/sec   | 985 Mbits/sec   | 12.3 ms
    Scaleway        | Paris, FR (10G)           | 994 Mbits/sec   | 983 Mbits/sec   | 13.6 ms
    NovoServe       | North Holland, NL (40G)   | 1.00 Gbits/sec  | busy            | 13.2 ms
    Uztelecom       | Tashkent, UZ (10G)        | busy            | 513 Mbits/sec   | 100 ms
    Clouvider       | NYC, NY, US (10G)         | 620 Mbits/sec   | 925 Mbits/sec   | 85.7 ms
    Clouvider       | Dallas, TX, US (10G)      | 374 Mbits/sec   | busy            | 125 ms
    Clouvider       | Los Angeles, CA, US (10G) | 345 Mbits/sec   | busy            | 148 ms
    Geekbench releases can only be downloaded over IPv4. FTP the Geekbench files and run manually.
    YABS completed in 2 min 58 sec
    Thanked by (1)mxmla
    Port 22 is the officially documented port for ssh, yes.
    Thanked by (1)Jab
    Yes, Port 22 for SSH. (Thanks @skorous )
  • Not enough time for in depth test but idling :smile: was stable.
    Just used it for some docker ipv6 testing with low load and I can't complain about the VPS.
    Minor improvements for the panel:
    On sign up the alignment of input fields felt wrong, first name and last name on a line break - same for password and repeat password inputs.
    And in Security section, the Multi-factor auth looks like a tabbed view but the tab is gone when selecting it and can't return to Allowed IP Access from it. (open Security section again works of course)
    Thanks for sponsoring a free VPS and good luck with sales.
    Thanked by (1)mxmla
    Cloudstorage Filen.io Aff - filelu Aff
    Free Uptime Monitoring HetrixTools Aff
  • Test ready, will check it
    Thanked by (1)mxmla
    Trusted Partner - www.webi.co.in
  • WOW
    Feeling very tired, let's call it a day.
  • JBBJBB OG
    edited October 2023
    Couple of things I noticed: the control panel sidebar 'flashes' in and out during login between the username/password page and the 2FA page, then again once login is complete.
  • The order form contains this option: I have read and accepted that I tested the connection towards the network beforehand with the Looking Glass at https://lg.nl.server-factory.com
    This shall be edited to point to a looking glass at Eygelshoven location.
    I have confirmed that routed IPv6 is working properly.
    When this product exits trial status, it will be eligible for Routed IPv6 Hall of Fame.
    No hostname available. affbrr
    1. This should be a common problem with Debian 11/12. New machines do not have the wget and curl command lines installed, so they need to be installed manually!
    2、Performance Testing:
    #                     v2023-09-06                    #
    Thu Oct 26 08:13:18 AM CEST 2023
    Uptime     : 0 days, 1 hours, 0 minutes
    RAM        : 1.9 GiB
    Swap       : 0.0 KiB
    Disk       : 24.5 GiB
    Read       | 259.36 MB/s  (64.8k) | 3.29 GB/s    (51.5k)
    Write      | 260.05 MB/s  (65.0k) | 3.31 GB/s    (51.8k)
    Total      | 519.41 MB/s (129.8k) | 6.61 GB/s   (103.3k)
    Read       | 6.50 GB/s    (12.7k) | 5.84 GB/s     (5.7k)
    Write      | 6.85 GB/s    (13.3k) | 6.23 GB/s     (6.0k)
    Total      | 13.35 GB/s   (26.0k) | 12.08 GB/s   (11.8k)
    Clouvider       | London, UK (10G)          | 980 Mbits/sec   | 641 Mbits/sec   | 16.6 ms
    Scaleway        | Paris, FR (10G)           | 995 Mbits/sec   | 952 Mbits/sec   | 13.5 ms
    NovoServe       | North Holland, NL (40G)   | 996 Mbits/sec   | 911 Mbits/sec   | 16.7 ms
    Uztelecom       | Tashkent, UZ (10G)        | 435 Mbits/sec   | 422 Mbits/sec   | 102 ms
    Clouvider       | NYC, NY, US (10G)         | 529 Mbits/sec   | 227 Mbits/sec   | 91.1 ms
    Clouvider       | Dallas, TX, US (10G)      | 430 Mbits/sec   | 294 Mbits/sec   | 128 ms
    Clouvider       | Los Angeles, CA, US (10G) | 351 Mbits/sec   | 247 Mbits/sec   | 153 ms
    YABS completed in 3 min 8 sec
    3、Netflix and other streaming media tests:
     HBO Now:                               Failed (Network Connection)
     Bahamut Anime:                         Failed (Network Connection)
     Abema.TV:                              Failed (Network Connection)
     Princess Connect Re:Dive Japan:        Failed (Network Connection)
     BBC:                                   Failed (Network Connection)
     BiliBili China Mainland Only:          Failed (Network Connection)
     BiliBili HongKong/Macau/Taiwan:        Failed (Network Connection)
     Bilibili Taiwan Only:                  Failed (Network Connection)
     Netflix:                               Only Homemade
     YouTube Region:                        DE
     DisneyPlus:                            No
    4、CPU performance test:
    sysbench 1.0.20 (using system LuaJIT 2.1.0-beta3)
    Running the test with following options:
    Number of threads: 1
    Initializing random number generator from current time
    Prime numbers limit: 20000
    Initializing worker threads...
    Threads started!
    CPU speed:
        events per second:   618.02
    General statistics:
        total time:                          10.0004s
        total number of events:              6181
    Latency (ms):
             min:                                    1.57
             avg:                                    1.62
             max:                                    1.85
             95th percentile:                        1.70
             sum:                                 9999.11
    Threads fairness:
        events (avg/stddev):           6181.0000/0.00
        execution time (avg/stddev):   9.9991/0.00
    5、Memory performance test:
    Running memory speed test with the following options:
      block size: 1KiB
      total size: 102400MiB
      operation: write
      scope: global
    Threads started!
    Total operations: 55685934 (5568062.86 per second)
    54380.79 MiB transferred (5437.56 MiB/sec)
    General statistics:
        total time:                          10.0000s
        total number of events:              55685934
    Latency (ms):
             min:                                    0.00
             avg:                                    0.00
             max:                                    0.15
             95th percentile:                        0.00
             sum:                                 4183.85
    Threads fairness:
        events (avg/stddev):           55685934.0000/0.00
        execution time (avg/stddev):   4.1839/0.00
    6、Disk performance test
    Disk write performance:
    1+0 records in
    1+0 records out
    1073741824 bytes (1.1 GB, 1.0 GiB) copied, 1.48149 s, 725 MB/s
    Hard drive read performance:
    /dev/sda:
     Timing cached reads:   15994 MB in  2.00 seconds = 8008.00 MB/sec
     Timing buffered disk reads: 2372 MB in  3.00 seconds = 790.37 MB/sec
    Advantages:
    High-Speed Network Connection: The server exhibits extremely high upload and download speeds in network speed tests at multiple locations, especially at European test nodes. This is a significant advantage for applications that require substantial data transfers.
    Powerful CPU Performance: The AMD EPYC 7702P 64-Core Processor provides robust processing capabilities. Even though only one core is allocated, its performance is still remarkably outstanding.
    Rapid Disk I/O: The disk read and write speeds are exceptionally fast, particularly in mixed read/write tests, showcasing the powerful performance of NVMe SSDs.
    Sufficient RAM: 2GB of DDR4 RAM should be enough for most basic tasks.
    Stable Operating Environment: Debian GNU/Linux 12 provides a stable and widely supported operating system environment.
    IPv6 Support: The server supports IPv6, which is essential for the future development of networks.
    Disadvantages:
    IPv6 Only in This Test: Some services and applications that only support IPv4 could not be thoroughly tested in this instance. Further testing opportunities could be explored in the future.
    Limited CPU Cores and RAM: While the CPU performance is strong, having only one core and 2GB of RAM could potentially limit the server's performance in handling multitasking or memory-intensive applications. Of course, upgrades and configuration optimizations can be made later based on individual needs.
    Limited Access to Streaming Media Services: As the current test only supports IPv6, the results for streaming media services show that the server is unable to access several streaming media services. This could be due to network configuration or other issues.
    In summary, this server excels in network speed, CPU performance, and disk I/O, making it highly suitable for applications that require fast network connections and robust processing capabilities.
    VPS Discounts and Reviews | Hosting Provider Directory & Check out the latest VPS offers and reviews to help you choose the best VPS service.
    ChatGPT?
    Thanked by (2)yoursunny terrorgen
  • Ready to test one
  • edited November 2023
    Sorry for the delay!
    Thanks to everyone who helped us test our new NL location so far :)
    @tototo is the winner, please register here: https://my.server-factory.com/signup/ and let me know your E-Mail Address via private message within the next 24 hours. Provisioning is expected within the next 7 days.
    Thanked by (3)ehab Ganonk tototo
    @tototo is the winner, please register here: https://my.server-factory.com/signup/ and let me know your E-Mail Address via private message with the next 24 hours. Provisioning is expected within the next 7 days.
    congrats @tototo :)
    hey maxi, where is your 11.11 offer?
    Thanked by (1)tototo
  • NL-AMD EPYC™ XXS IPv6 ONLY VPS 24 HOUR TRIAL is back in stock with more OS Templates :)
    We are searching for a few people with public ASN and Subnets to test our BGP Session setup.
    Reward: Free NL-AMD EPYC™ XXS VPS for 1 year. Specs: https://my.server-factory.com/cart/nl-amd-epyc-vps/
    PM please ;)
    Thanked by (1)ehab
  • @mxmla said: We are searching for a few people with public ASN and Subnets to test our BGP Session setup.
    @yoursunny PING
    Congratulations @tototo !!
    Thanked by (3)Wonder_Woman mxmla tototo
