Looking for a cost-effective dedicated server with a budget of US$20 per month
The configuration is as follows:
At least 4 cores and 8 threads
At least 16GB RAM
At least 500GB SSD or 240GB nvme
At least 30TB traffic, 1Gbps network speed
(I only use 3TB of traffic in a month at most, but the site is growing rapidly and I want to use this server for a long time)
If possible, I would like the configuration to be as high as possible. Although this is a bit wishful thinking, I still want to give it a try.
ColoCrossing black friday 19$
TrackWith - Free Privacy Focused Analytics
Did you mean: ColonCoughing
I don't think you will get any Dedi for $20 but as mentioned above you can try CC BF sale if they still running offer.
In that budget range, I'd look at a VDS. HostEONS sale right now would run around $21/mo for 4 vcore 16gb ram 200gb nvme VDS on a 10gb connection, decent transfer. It'll easily replace an older dedicated server, if you manage to find a dedi for under $20/mo it's going to be significantly less power than that.
I have this in the Netherlands, outside yo
For approx $30/mo. Could reduce it a little if you can commit for 6 months at least.
Hong Kong, United Kingdom, The Netherlands, Lithuania, Switzerland VPS / Dedicated Servers - DDoS Protected, 1 / 10 Gbit Unmetered, NAT and more
