BGP routes not installed into Linux kernel routing table
Hello LESbians who are proficient in BGP,
I am observing that my BIRD is not exporting any routes to the kernel.
Looks like it is receiving routes from the upstream alright:
~ terrorgen@awesomebox
❯ sudo birdc s p a upstream
BIRD 2.14 ready.
Name Proto Table State Since Info
upstream BGP --- up 00:18:11.949 Established
BGP state: Established
Neighbor address: 2001:db8:0:2::1
Neighbor AS: 65000
Local AS: 65001
Neighbor ID: 1.2.3.4
Local capabilities
Multiprotocol
AF announced: ipv6
Route refresh
Graceful restart
Restart time: 120
AF supported: ipv6
AF preserved:
4-octet AS numbers
Enhanced refresh
Long-lived graceful restart
Neighbor capabilities
Multiprotocol
AF announced: ipv6
Route refresh
Graceful restart
4-octet AS numbers
Session: external multihop AS4
Source address: 2001:db8:3::30
Hold timer: 75.387/90
Keepalive timer: 21.792/30
Channel ipv6
State: UP
Table: master6
Preference: 100
Input filter: (unnamed)
Output filter: (unnamed)
Routes: 195136 imported, 4 exported, 195134 preferred
Route change stats: received rejected filtered ignored accepted
Import updates: 517095 0 0 0 517095
Import withdraws: 70578 0 --- 0 70578
Export updates: 517100 517093 3 --- 4
Export withdraws: 70578 --- --- --- 0
BGP Next hop: 2001:db8:3::30
IGP IPv6 table: master6
But upon inspecting the individual routes, many of them are marked "!". According to the manual, that means "failure to install to kernel".
~ terrorgen@awesomebox 7s
❯ sudo birdc s r table master6
BIRD 2.14 ready.
Table master6:
::/0 unicast [upstream 10:44:46.318 from 2001:db8:0:2::1] ! (100/?) [AS65000i]
via 2001:db8:3::1 on enp3s0
2620:129:2000::/42 unicast [upstream 10:44:48.950 from 2001:db8:0:2::1] ! (100/?) [AS27016i]
2804:505c::/32 unicast [upstream 10:44:49.979 from 2001:db8:0:2::1] ! (100/?) [AS268384i]
2804:385c:a200::/40 unicast [upstream 10:44:49.960 from 2001:db8:0:2::1] ! (100/?) [AS262687i]
2804:d84:f000::/36 unicast [upstream 10:44:49.333 from 2001:db8:0:2::1] ! (100/?) [AS28171i]
2a04:26c0::/29 unicast [upstream 10:44:50.916 from 2001:db8:0:2::1] ! (100/?) [AS60532i]
2804:5a64::/34 unicast [upstream 10:44:50.720 from 2001:db8:0:2::1] ! (100/?) [AS268770i]
2804:5d3c:c000::/34 unicast [upstream 10:44:50.014 from 2001:db8:0:2::1] ! (100/?) [AS268959i]
2001:44b8:4040::/48 unicast [upstream 10:44:46.961 from 2001:db8:0:2::1] * (100/?) [AS7545i]
2803:bc40:8155::/48 unicast [upstream 10:44:49.180 from 2001:db8:0:2::1] ! (100/?) [AS52468i]
240a:aded::/32 unicast [upstream 10:44:48.046 from 2001:db8:0:2::1] * (100/?) [AS146215i]
2402:3a80:19ec::/46 unicast [upstream 10:44:47.367 from 2001:db8:0:2::1] * (100/?) [AS38266i]
2a00:1d58:f812::/48 unicast [upstream 10:44:50.213 from 2001:db8:0:2::1] ! (100/?) [AS47524?]
2620:12f:f000::/44 unicast [upstream 10:44:49.021 from 2001:db8:0:2::1] ! (100/?) [AS43?]
2800:bf0:2206::/48 unicast [upstream 10:44:48.906 from 2001:db8:0:2::1] ! (100/?) [AS52257i]
2001:4430:c20e::/47 unicast [upstream 10:44:46.931 from 2001:db8:0:2::1] * (100/?) [AS17853i]
Looking at systemd-journald
this is the message being generated (restarted BIRD just to get the full message):
~ terrorgen@awesomebox 11s
❯ sudo systemctl restart bird2; sudo journalctl -fu bird2
Dec 04 10:50:36 awesomebox bird[773]: Shutdown completed
Dec 04 10:50:36 awesomebox systemd[1]: bird2.service: Deactivated successfully.
Dec 04 10:50:36 awesomebox systemd[1]: Stopped BIRD Internet Routing Daemon.
Dec 04 10:50:36 awesomebox systemd[1]: bird2.service: Consumed 10.171s CPU time, received 8.5M IP traffic, sent 17.9M IP traffic.
Dec 04 10:50:36 awesomebox systemd[1]: Starting BIRD Internet Routing Daemon...
Dec 04 10:50:36 awesomebox systemd[1]: Started BIRD Internet Routing Daemon.
Dec 04 10:50:36 awesomebox bird[1047]: Started
Dec 04 10:50:38 awesomebox bird[1047]: Netlink: File exists
Dec 04 10:50:38 awesomebox bird[1047]: Kernel dropped some netlink messages, will resync on next scan.
Dec 04 10:50:39 awesomebox bird[1047]: Kernel dropped some netlink messages, will resync on next scan.
(multiple identical messages)
Dec 04 10:50:41 awesomebox bird[1047]: Netlink: No route to host
Dec 04 10:50:41 awesomebox bird[1047]: ...
Dec 04 10:50:42 awesomebox bird[1047]: Netlink: No route to host
Dec 04 10:50:42 awesomebox bird[1047]: ...
Dec 04 10:50:43 awesomebox bird[1047]: Netlink: No route to host
Dec 04 10:50:43 awesomebox bird[1047]: ...
Dec 04 10:50:44 awesomebox bird[1047]: Netlink: No route to host
Dec 04 10:50:44 awesomebox bird[1047]: ...
Dec 04 10:50:45 awesomebox bird[1047]: Netlink: No route to host
Dec 04 10:50:45 awesomebox bird[1047]: ...
Dec 04 10:50:46 awesomebox bird[1047]: Netlink: No route to host
Dec 04 10:50:46 awesomebox bird[1047]: ...
Dec 04 10:50:47 awesomebox bird[1047]: Netlink: No route to host
Dec 04 10:50:47 awesomebox bird[1047]: ...
Wonder if you have any pointers?
Note: 2001:db8:3::30
is my VPS address, upstream is using multihop. Immediate nexthop router is 2001:db8:3::1
and BGP router is at 2001:db8:0:2::1
How does the kernel section of your bird.conf look?
quite boiler plate...
bird has multiple tables, you have to explicitly tell it to do that.
I am not an expert in bird though.
Maybe @FHR can help.
there is a default master4 and master6 table. If you don't specify the table in the config the default tables are used.
That being said, this is not the first nor the only BGP session I have. All sessions are written with the snippet above and there isn't a problem.
Is this actually a valid route installed in the kernel (aka visible in
ip -6 r
)?2001:db8:3::1 on enp3s0
If netlink is complaining about no route to host while trying to install a route it sort of points towards that not being the case; i.e. Bird is trying to insert a route that is not resolveable by the kernel.SkylonHost.com High Bandwidth European Cloud KVM | AS202297
that is the statically configured default route:
default via 2001:db8:3::1 dev enp3s0 proto static metric 1024 pref medium
Pls share your entire bird config
C1V hosting: Italy's Leading Data Center | Unbeatable VPS, Dedicated Servers, and Colocation | Cutting-Edge Facilities in Pomezia | Where Your Success Takes Center Stage.
🚀 VPN for €5/year 🚀 | Follow us on Telegram
protocol kernel {
ipv6 {
import all;
export all; };
Why?
It is potentially dangerous to just import and export all. Plus, it doesn't make any difference to the problem anyways.
kernel export all isn't that dangerous. Anyway, I guess this article will help you: https://blog.fhrnet.eu/2018/08/15/bird-unreachable-routes-on-multihop-bgp-sessions/
Thanks but unfortunately, that doesn't describe my problem though. I can reach the multi hop router fine.
What did you determine with this? Find a resolution?
Somehow I have to set the next hop router's address to "onlink" for the routes to install, which is weird. The next hop router is reachable anyways without setting this.
Lmfao wth man?
IKR?
How did that even work?
Might need someone who truly understands the Linux kernel network stack to explain it to us.
What I am saying is it should not have even partially worked.
Someone here should know I hope because it may not even be replacable.
Oh, yes, very true. Why does the kernel choose to accept some prefixes and deny some other, when their nexthops are the same?
No idea man and I have not heard of one acting that strange before. Is it a stock kernel?
