BGP routes not installed into Linux kernel routing table
Hello LESbians who are proficient in BGP,
I am observing that my BIRD is not exporting any routes to the kernel.
Looks like it is receiving routes from the upstream alright:
~ terrorgen@awesomebox
❯ sudo birdc s p a upstream
BIRD 2.14 ready.
Name       Proto      Table      State  Since         Info
upstream BGP        ---        up     00:18:11.949  Established
  BGP state:          Established
    Neighbor address: 2001:db8:0:2::1
    Neighbor AS:      65000
    Local AS:         65001
    Neighbor ID:      1.2.3.4
    Local capabilities
      Multiprotocol
        AF announced: ipv6
      Route refresh
      Graceful restart
        Restart time: 120
        AF supported: ipv6
        AF preserved:
      4-octet AS numbers
      Enhanced refresh
      Long-lived graceful restart
    Neighbor capabilities
      Multiprotocol
        AF announced: ipv6
      Route refresh
      Graceful restart
      4-octet AS numbers
    Session:          external multihop AS4
    Source address:   2001:db8:3::30
    Hold timer:       75.387/90
    Keepalive timer:  21.792/30
  Channel ipv6
    State:          UP
    Table:          master6
    Preference:     100
    Input filter:   (unnamed)
    Output filter:  (unnamed)
    Routes:         195136 imported, 4 exported, 195134 preferred
    Route change stats:     received   rejected   filtered    ignored   accepted
      Import updates:         517095          0          0          0     517095
      Import withdraws:        70578          0        ---          0      70578
      Export updates:         517100     517093          3        ---          4
      Export withdraws:        70578        ---        ---        ---          0
    BGP Next hop:   2001:db8:3::30
    IGP IPv6 table: master6
But upon inspecting the individual routes, many of them are marked "!". According to the manual, that means "failure to install to kernel".
~ terrorgen@awesomebox 7s
❯ sudo birdc s r table master6
BIRD 2.14 ready.
Table master6:
::/0                 unicast [upstream 10:44:46.318 from 2001:db8:0:2::1] ! (100/?) [AS65000i]
        via 2001:db8:3::1 on enp3s0
2620:129:2000::/42   unicast [upstream 10:44:48.950 from 2001:db8:0:2::1] ! (100/?) [AS27016i]
2804:505c::/32       unicast [upstream 10:44:49.979 from 2001:db8:0:2::1] ! (100/?) [AS268384i]
2804:385c:a200::/40  unicast [upstream 10:44:49.960 from 2001:db8:0:2::1] ! (100/?) [AS262687i]
2804:d84:f000::/36   unicast [upstream 10:44:49.333 from 2001:db8:0:2::1] ! (100/?) [AS28171i]
2a04:26c0::/29       unicast [upstream 10:44:50.916 from 2001:db8:0:2::1] ! (100/?) [AS60532i]
2804:5a64::/34       unicast [upstream 10:44:50.720 from 2001:db8:0:2::1] ! (100/?) [AS268770i]
2804:5d3c:c000::/34  unicast [upstream 10:44:50.014 from 2001:db8:0:2::1] ! (100/?) [AS268959i]
2001:44b8:4040::/48  unicast [upstream 10:44:46.961 from 2001:db8:0:2::1] * (100/?) [AS7545i]
2803:bc40:8155::/48  unicast [upstream 10:44:49.180 from 2001:db8:0:2::1] ! (100/?) [AS52468i]
240a:aded::/32       unicast [upstream 10:44:48.046 from 2001:db8:0:2::1] * (100/?) [AS146215i]
2402:3a80:19ec::/46  unicast [upstream 10:44:47.367 from 2001:db8:0:2::1] * (100/?) [AS38266i]
2a00:1d58:f812::/48  unicast [upstream 10:44:50.213 from 2001:db8:0:2::1] ! (100/?) [AS47524?]
2620:12f:f000::/44   unicast [upstream 10:44:49.021 from 2001:db8:0:2::1] ! (100/?) [AS43?]
2800:bf0:2206::/48   unicast [upstream 10:44:48.906 from 2001:db8:0:2::1] ! (100/?) [AS52257i]
2001:4430:c20e::/47  unicast [upstream 10:44:46.931 from 2001:db8:0:2::1] * (100/?) [AS17853i]
Looking at systemd-journald this is the message being generated (restarted BIRD just to get the full message):
~ terrorgen@awesomebox 11s
❯ sudo systemctl restart bird2; sudo journalctl -fu bird2
Dec 04 10:50:36 awesomebox bird[773]: Shutdown completed
Dec 04 10:50:36 awesomebox systemd[1]: bird2.service: Deactivated successfully.
Dec 04 10:50:36 awesomebox systemd[1]: Stopped BIRD Internet Routing Daemon.
Dec 04 10:50:36 awesomebox systemd[1]: bird2.service: Consumed 10.171s CPU time, received 8.5M IP traffic, sent 17.9M IP traffic.
Dec 04 10:50:36 awesomebox systemd[1]: Starting BIRD Internet Routing Daemon...
Dec 04 10:50:36 awesomebox systemd[1]: Started BIRD Internet Routing Daemon.
Dec 04 10:50:36 awesomebox bird[1047]: Started
Dec 04 10:50:38 awesomebox bird[1047]: Netlink: File exists
Dec 04 10:50:38 awesomebox bird[1047]: Kernel dropped some netlink messages, will resync on next scan.
Dec 04 10:50:39 awesomebox bird[1047]: Kernel dropped some netlink messages, will resync on next scan.
(multiple identical messages)
Dec 04 10:50:41 awesomebox bird[1047]: Netlink: No route to host
Dec 04 10:50:41 awesomebox bird[1047]: ...
Dec 04 10:50:42 awesomebox bird[1047]: Netlink: No route to host
Dec 04 10:50:42 awesomebox bird[1047]: ...
Dec 04 10:50:43 awesomebox bird[1047]: Netlink: No route to host
Dec 04 10:50:43 awesomebox bird[1047]: ...
Dec 04 10:50:44 awesomebox bird[1047]: Netlink: No route to host
Dec 04 10:50:44 awesomebox bird[1047]: ...
Dec 04 10:50:45 awesomebox bird[1047]: Netlink: No route to host
Dec 04 10:50:45 awesomebox bird[1047]: ...
Dec 04 10:50:46 awesomebox bird[1047]: Netlink: No route to host
Dec 04 10:50:46 awesomebox bird[1047]: ...
Dec 04 10:50:47 awesomebox bird[1047]: Netlink: No route to host
Dec 04 10:50:47 awesomebox bird[1047]: ...
Wonder if you have any pointers?
Note: 2001:db8:3::30 is my VPS address, upstream is using multihop. Immediate nexthop router is 2001:db8:3::1 and BGP router is at 2001:db8:0:2::1.
