Free Shadowsocks - Openvpn - Ipsec IKEv2
Hello All,
I would like to offer a free VPN for personal use on 2 different locations that i am running on VPS.
The VPS on Yearly subscription but i always run it or replace it as soon as the provider becomes unreliable.
You can find Openvpn, Shadowsocks URL & IPsec IKEv2 information on this link
[redacted at OP's request]
We will be adding Wireguard soon as we are currently testing it.
how much do you sell the data for
All of my VMs: https://nodecheck.net/s/otusibrc/
We don't keep data nor check it, i do run it as for hope not for profit, i am not looking to gain income.
Even the apps i provide for other locations from the app store and play store pearly cover the store subscription fee.
If you not confident using it, simple it's not for you.
https://0a0.uk
@mad_4u
Can you write some more about how you set this up - eg, how you negotiate with providers to run a low-cost VPN in terms of handling abuse reports; and what sort of tricks are needed to keep bandwidth manageable..
I usually check with the provider if they allow using VPN on their network and mostly they allow accept using tor exit where i am not using tor.
In terms of BW i just use what is allocated to me when i see that my consumption are about %80 of my allowance, i switch the VPS to other provider or same provider but with available allocations of bandwidth were i don't overuse the BW, also i confirm with the provider their procedure after using the allocated BW some will disable the network port others will reduce the network speed for those who charge for the overage i just don't use them.
I never had issue with Bandwidth usage before as i never offered this for free but who knows things can change.
https://0a0.uk
Thanks a lot.
You didn't think about abuse.
Yes indeed, this could bring the service down instantly.
https://0a0.uk
/thread at OP's request
