May I Borrow your IPv4?
This article is originally published on yoursunny.com blog https://yoursunny.com/t/2023/borrow-ipv4/
With the rise of IPv4 costs, IPv6-only servers are becoming more popular in low end hosting world.
In one occasion, I acquired an IPv6-only server, but wanted to have IPv4 on it.
Somewhere else, I have a dual-stack IPv4+IPv6 server, idling away.
Can I "borrow" the IPv4 of that dual-stack server, to use on the IPv6-only server?
I tried several methods, and found a way to make this work.
Situation / Assumption / Requirement
In this case, both servers have KVM virtualization and are running Debian 12 operating system.
Server A is a dual-stack server, with IPv4 address 192.0.2.158
and IPv6 address 2001:db8:aefc::2
Server B is an IPv6-only server, with IPv6 address 2001:db8:eec0::2
At server A, both IPv4 and IPv6 service are delivered on the same network interface.
My goal is to somehow "move" the IPv4 address from server A to server B.
In particular, I want all IPv4 traffic to the 192.0.2.158
destination address to reach server B, and allow server B to send any IPv4 traffic with 192.0.2.158
source address.
This shall include all TCP and UDP ports, as well as other IPv4 traffic such as ICMP ping.
A "port forwarding" solution would be insufficient, as it cannot deliver non-TCP/UDP traffic.
Tunnel + Ethernet Bridge (does not work)
The first idea came to my mind is creating an Ethernet bridge:
# server A
ip link add br4 type bridge
ip addr flush dev eth0
ip link set eth0 master br4
ip addr add 2001:db8:aefc::2/64 dev br4
ip route add default via 2001:db8:aefc::1
ip link add tnl4 type ip6gre remote 2001:db8:eec0::2 local 2001:db8:aefc::2 hoplimit 64
ip link set tnl4 up master br4
# server B
ip link add tnl4 type ip6gre remote 2001:db8:aefc::2 local 2001:db8:eec0::2 hoplimit 64
ip link set tnl4 up
ip addr add 192.0.2.158/24 dev tnl4
ip route add default via 192.0.2.1
These commands would achieve the following:
- Establish an ip6gre tunnel between server A and server B.
- Add the
192.0.2.158
IPv4 address on server B's tunnel interface. - Create an Ethernet bridge on server A that includes both the
eth0
"real" network interface and the tunnel interface.
Theoretically, incoming ARP requests for the 192.0.2.158
IPv4 address would travel over the ip6gre tunnel to server B, server B would respond to those ARP requests, and then IPv4 traffic could flow normally.
However, this method does not work, because:
Most hosting providers have MAC address filtering in place.
The hypervisor does not allow server A to send packets with a source MAC address that differs from the assigned MAC address of itseth0
"real" network interface.When server B responds to the ARP requests for the
192.0.2.158
IPv4 address, the source MAC address would be the MAC address of server B's ip6gre tunnel interface.
These packets would be dropped by the hypervisor of server A's hosting provider.
I tried changing the MAC address of server B's ip6gre tunnel interface to be same as server A's eth0
, but this does not work either.
Effectively, there are two network interfaces with duplicate MAC address in the br4
bridge, confusing the Linux bridge driver.
Tunnel + IPv4 Routing (it works)
The second idea is configuring IPv4 routing, but without any address in server A.
According to ip-route(8) manpage, the next hop of a route could specify a device name without an address:
NH := [ encap ENCAP ] [ via [ FAMILY ] ADDRESS ] [ dev STRING ] [ weight NUMBER ] NHFLAGS
Therefore, I could make a tunnel and route the IPv4 address over the tunnel interface:
# server A
echo 1 >/proc/sys/net/ipv4/ip_forward
ip addr del 192.0.2.158/24 dev eth0
ip link set tnl4 up
ip route add default via 192.0.2.1 dev eth0 onlink
ip route add 192.0.2.158/32 dev tnl4
echo 1 >/proc/sys/net/ipv4/conf/all/proxy_arp
# server B
ip link set tnl4 up
ip addr add 192.0.2.158/32 dev tnl4
ip route add default dev tnl4
- Delete the
192.0.2.158
IPv4 address from server A, and add it on server B's tunnel interface. - Make server A forward IPv4 traffic with destination address
192.0.2.158
over the tunnel interface, and route all other IPv4 traffic over theeth0
"real" network interface. - Make server A respond to ARP requests for the
192.0.2.158
IPv4 address. - Make server B send all IPv4 traffic over the tunnel interface.
This method worked.
Traceroute and tcpdump suggest that the traffic is indeed being passed to server B.
Traceroute Reports
I tested this procedure between Crunchbits "server A" in Spokane WA and Limitless Hosting "server B" in Chicago IL, with 50ms RTT in between over IPv6.
Before tunnel setup, from outside to our IPv4 address:
sunny@clientC:~$ mtr -wnz -c4 192.0.2.158
Start: 2023-09-09T22:19:32+0000
HOST: vps4 Loss% Snt Last Avg Best Wrst StDev
1. AS??? 10.0.0.73 0.0% 4 9.3 13.0 9.3 18.7 4.0
2. AS201106 172.83.154.5 0.0% 4 1.3 2.2 1.0 4.5 1.6
3. AS??? ??? 100.0 4 0.0 0.0 0.0 0.0 0.0
4. AS400304 23.147.152.15 0.0% 4 24.3 55.7 24.3 130.8 50.2
5. AS400304 192.0.2.158 0.0% 4 13.7 13.7 13.6 13.7 0.1
After tunnel setup, from outside to our IPv4 address:
Start: 2023-09-09T22:22:38+0000
1. AS??? 10.0.0.73 0.0% 4 4.8 12.8 2.5 36.4 15.9
2. AS201106 172.83.154.5 0.0% 4 0.3 0.3 0.2 0.3 0.0
4. AS400304 23.147.152.15 0.0% 4 19.5 31.7 17.4 67.7 24.1
5. AS??? ??? 100.0 4 0.0 0.0 0.0 0.0 0.0
6. AS400304 192.0.2.158 0.0% 4 63.0 63.1 63.0 63.2 0.1
Notice that the RTT of the last hop increased by 50ms, which corresponds to the IPv6 RTT between server A and server B.
There is also a mysterious "hop 5" that we cannot see the IPv4 address, because server A no longer possesses a globally reachable IPv4 address.
Before tunnel setup, from server A to an outside IPv4 destination:
sunny@serverA:~$ mtr -wnz -c4 1.1.1.1
Start: 2023-09-09T22:25:33+0000
HOST: vps6 Loss% Snt Last Avg Best Wrst StDev
1. AS400304 104.36.84.1 0.0% 4 18.5 49.1 13.2 151.5 68.3
2. AS400304 23.147.152.14 0.0% 4 0.4 0.7 0.4 1.3 0.4
3. AS??? 206.81.81.10 0.0% 4 12.0 12.5 12.0 12.9 0.4
4. AS13335 172.71.144.3 0.0% 4 12.2 13.2 11.8 16.0 1.9
5. AS13335 1.1.1.1 0.0% 4 11.7 11.7 11.7 11.8 0.1
After tunnel setup, from server B to an outside IPv4 destination:
sunny@serverB:~$ mtr -wnz -c4 1.1.1.1
Start: 2023-09-09T18:23:43-0400
HOST: box4 Loss% Snt Last Avg Best Wrst StDev
1. AS??? 192.0.0.8 0.0% 4 49.8 51.1 49.6 55.1 2.7
2. AS400304 104.36.84.1 0.0% 4 72.7 67.9 59.6 73.7 6.6
3. AS400304 23.147.152.14 0.0% 4 49.9 50.1 49.9 50.6 0.3
4. AS??? 206.81.81.10 0.0% 4 61.6 63.4 61.6 68.3 3.3
5. AS13335 172.71.144.3 0.0% 4 61.5 61.9 61.5 62.4 0.4
6. AS13335 1.1.1.1 0.0% 4 61.3 61.2 61.1 61.4 0.1
Likewise, we can see the RTT of the last hop increased by 50ms, which corresponds to the IPv6 RTT between server A and server B.
There is an additional "hop 1", which has an IPv4 address that is technically globally routable but does not belong to us.
Speedtest Reports
I also tested TCP and UDP speeds over the same environment.
Before tunnel setup, from server A to a private iperf3 server over IPv4:
- TCP upload: 290 Mbps
- TCP download: 362 Mbps
- UDP upload: 783 Mbps
- UDP download: 686 Mbps
After tunnel setup, from server B to a private iperf3 server over IPv4:
- TCP upload: 46.6 Mbps
- TCP download: 30.9 Mbps
- UDP upload: 407 Mbps
- UDP download: 304 Mbps
From server B to server A, over IPv6:
- TCP upload: 375 Mbps
- TCP download: 263 Mbps
- UDP upload: 317 Mbps
- UDP download: 590 Mbps
We can see that there's considerable speed reduction in TCP traffic.
There are three possible reasons:
- Both plain IPv4 flow and tunneled IPv4 flow are competing for bandwidth at server A.
- Server A must re-fragment the TCP segments, because the tunnel interface has a smaller MTU than the
eth0
"real" interface. - TCP offload features including Large Receive Offload (LRO) and TCP Segmentation Offload (TSO) provided by the virtio network interface driver are ineffective on the tunnel interface of both servers, which means the kernel and
iperf3
application must handle more packets.
Conclusion
This article explores the method of moving an IPv4 address from a dual-stack KVM server to an IPv6-only KVM server.
A successful way to achieve this goal is establishing an ip6gre tunnel and configuring IPv4 routing.
It then compares the traceroute and iperf3 results before and after tunnel setup.
vps9
hostname is available. affbrr
Interesting read.
What do you think about using dual-stack server as a proxy, such that in IPv6-only server we establish a tun proxy client that exposes the IPv4 of the other server?
wow
this article should be a paid article.
i would love to test it and will do because its cool and good to know
@Mason any chance @yoursunny can get $40 for this article ?
TUN is a kernel feature that creates a L3 network interface that is connected to an application.
The application can surely act as a VPN client and "expose the IPv4".
This is how most userspace L3 VPN clients, including BoringTUN, works.
I choose the GRE tunnel because I don't need encryption so that this overhead can be eliminated.
vps9
hostname is available. affbrrThis ain't an LES exclusive article.
It's a repost from yoursunny.com blog.
I can't sell articles because it causes tax complications.
If @ehab likes my articles, go buy my service transfers: A B.
vps9
hostname is available. affbrrIt's an easy method.
By the way, we are considering whether to provide NAT64 VPS. What do you think?
C1V Hosting: Low cost Italian Cloud & Data Center Solutions 🚀 | Contact us for special offers. | Our deals on Telegram
This is a great write-up and was easy to understand. Networking is fascinating to me, even though is not one of my strong skills. Would it be possible to route multiple IPs to the second server, such as a /29 block? Would it be possible to have tunnels to multiple servers with different IPs?
It's certainly possible.
Just change the routed prefix.
Just repeat the procedure to create multiple tunnel interfaces and routes.
The unique feature of this article is how to move away the single IPv4 on server A.
I think most people who tunnels IPv4 would still leave one IPv4 on server A.
vps9
hostname is available. affbrrMaybe some form of IPv6 VPN would be a solution too. I never tried it though.
@yoursunny great article
In an older article (https://yoursunny.com/t/2020/EUserv-IPv4/) you used vxlan to do the tunneling.
Would you suggest ip6gre over vxlan for such cases?
Good stuff 👍
i can buy you coffee, those vms are of no use to me.
iirc tailscale can do this by default:
https://tailscale.com/kb/1103/exit-nodes
The benefit of IP6GRE is having less header overhead.
IP6GRE header structure: outer IPv6 - GRE - inner IPv4.
If outer MTU is 1500 octets, inner MTU would be 1456 octets.
VXLAN header structure: outer IPv6 - outer UDP - VXLAN - inner Ethernet - inner IPv4.
If outer MTU is 1500 octets, inner MTU would be 1430 octets.
WireGuard header structure: outer IPv6 - outer UDP - WireGuard - inner IPv4.
If outer MTU is 1500 octets, inner MTU would be 1420 octets.
Use visual packet size calculator to calculate inner MTU.
The inner IPv4 header would take a part of inner MTU.
When I wrote the EUserv-IPv4 article, I haven't heard about IP6GRE tunnel protocol, so I went for VXLAN that I'm most familiar with.
vps9
hostname is available. affbrrGood article!
One thing you forgot is TCP MSS clamping. This can be set up with an iptables rule. Otherwise, TCP sessions will freeze if the peer has non-functional PMTUD.
I don't believe TCP MSS clamping is necessary.
In either direction, if the packet size exceeds tunnel MTU, the tunnel driver will perform IPv4 fragmentation as needed.
vps9
hostname is available. affbrrAs part of attempting PMTUD, the peer will send packets with DF set. The tunnel driver shouldn't fragment those. If PMTUD fails (ie: overly aggressive ICMP filtering on the peer's side, outside your control), the peer will just keep sending oversized packets with DF set and they'll get dropped on the floor.
