10PM to 2AM was the timeslot I think but maybe they'll delay it again because now it says "Problem" and "check back January 27th"
@foitin said: For restaurante, corny ramen chain like Ichiran? Probably the least disliked food.
If there's a problem and it happened twice in a row and you dont speak Japanese. You're unlike fucked and never getting it unless you have someone sort it out.
and you forgot this more important part Tokyo IPv6 I assume most if not all first batch Ryzen preorders dont have any functional IPv6 atm.
One of my VPS's on TYOC007 went offline a couple hours ago while the other is working fine, but since the node is under maintenance and locked down, I can't get to the control panel and I don't know what's going on.
If the maintenance is over on Tokyo can you please turn them on?
Unrelated to previous maintenance. Node broke its own controls on purpose (automatic to prevent missing disks) and it's likely related to your VPS going offline. It's on my list to review and co-worker likely locked it off until I see what's going on. I'm almost done traveling so it will be fixed this afternoon and I do apologize if they didn't post a network status update.
No acknowledgement on their https://billing.virmach.com/serverstatus.php page yet, so who knows what's up right now. I have systems with other providers in the same DC, though, that are online so I'd guess this is routing-related.
I did take a wire cutter but I forgot my hammer and regretted it greatly.
Tokyo IPv6
I assume most if not all first batch Ryzen preorders dont have any functional IPv6 atm.The one in Frankfurt.
https://microlxc.net/
Yes, Frankfurt and NL are both xtom.
My 5950X VPS is still awesome! Both GB5 and GB6 rock.
@VirMach Is maintenance over in Tokyo?
Yeah, I have the same problem.
I like this new you!
I still waiting for the refund about double charge...
MY/SG & Worldwide Latency Test V3 : http://www.mywebping.com (27 February 2021 Updated)
MY-Unifi Home SmokePing: http://smokeping.mywebping.com/smokeping/
TYOC002S marked resolved in network status? but no reboot?
IPv6 still not available for first batch Tokyo preorder
tokyo has been up 6 days. is the work fully completed?
Looks like some of the nodes in Tokyo are still locked.
That's his neu ALT.
any updates about tokyo?
@VirMach TYOC026 has been migrating for four days, how much longer is needed?
@Virmach This is unusual: all three four of my NYC servers are timing out.
It looks like all of their NY operations are out... https://status.virm.ac/
-Dan
Came here to check up on NYC. Mine are also down.
Does seem that way; vanished into the ether.
DALZ005 in virmach had been offlined.
Mine's down too, but IDK how to check the node.
Still no update on VirMach status page about NYC.
Looks to be billing related, hope everything is ok
All the servers seem to be back online.
why do you think it's billing related? speculation?
Ok mine is working now
that's record breaking fix!
