1278279281283284362
    Walking?
    The terrain in western Alaska is rough.
    We'd recommend a sailboat.
    It's faster than walking, without increasing carbon footprint.
    Screwdriver?
    We'd recommend a wirecutter and a hammer.
    It's more effective in ensuring the servers stay offline for as long as possible.
    I did take a wire cutter but I forgot my hammer and regretted it greatly.
    Thanked by (2)yoursunny burntascii
  • @VirMach said:
    10PM to 2AM was the timeslot I think :# but maybe they'll delay it again because now it says "Problem" and "check back January 27th"
    If there's a problem and it happened twice in a row and you dont speak Japanese. You're unlike fucked and never getting it unless you have someone sort it out.
    and you forgot this more important part Tokyo IPv6 I assume most if not all first batch Ryzen preorders dont have any functional IPv6 atm.
  • @fluttershy said:
    NL is xtom
    The one in Frankfurt.
    Yes, Frankfurt and NL are both xtom.
  • My 5950X VPS is still awesome! Both GB5 and GB6 rock.
    Spoiler
    #                     v2024-01-01                    #
    Mon Jan 29 09:50:15 EST 2024
    Uptime     : 62 days, 14 hours, 13 minutes
    CPU cores  : 4 @ 3393.624 MHz
    RAM        : 3.6 GiB
    Swap       : 0.0 KiB
    Disk       : 127.7 GiB
    Distro     : AlmaLinux 8.7 (Stone Smilodon)
    Kernel     : 4.18.0-425.13.1.el8_7.x86_64
    ISP        : RoyaleHosting BV
    ASN        : AS212477 RoyaleHosting BV
    Host       : Virtual Machine Solutions LLC
    Country    : United States
    Geekbench 5 Benchmark Test:
    Single Core     | 1486
    Multi Core      | 4910
    Full Test       | https://browser.geekbench.com/v5/cpu/22182113
    Single Core     | 1940
    Multi Core      | 5789
    Full Test       | https://browser.geekbench.com/v6/cpu/4649708
    YABS completed in 7 min 22 sec
  • @VirMach Is maintenance over in Tokyo?
    One of my VPS's on TYOC007 went offline a couple hours ago while the other is working fine, but since the node is under maintenance and locked down, I can't get to the control panel and I don't know what's going on.
    If the maintenance is over on Tokyo can you please turn them on?
    Yeah, I have the same problem.
  • @kheng86 said:
    What about those VPS that got stucked in AMSD031T36? Lol
    Thanked by (2)kheng86 someTom
    Unrelated to previous maintenance. Node broke its own controls on purpose (automatic to prevent missing disks) and it's likely related to your VPS going offline. It's on my list to review and co-worker likely locked it off until I see what's going on. I'm almost done traveling so it will be fixed this afternoon and I do apologize if they didn't post a network status update.
    Thanked by (2)tulipyun DanSummer
    I like this new you! =)
    Thanked by (1)AlwaysSkint
  • I still waiting for the refund about double charge... :'(
    MY/SG & Worldwide Latency Test V3 : http://www.mywebping.com (27 February 2021 Updated)
    MY-Unifi Home SmokePing: http://smokeping.mywebping.com/smokeping/
  • TYOC002S marked resolved in network status? but no reboot?
    IPv6 still not available for first batch Tokyo preorder :/
    tokyo has been up 6 days. is the work fully completed?
  • Looks like some of the nodes in Tokyo are still locked.
    That's his neu ALT.
  • any updates about tokyo?
  • edited February 2024
    @VirMach TYOC026 has been migrating for four days, how much longer is needed?
    @Virmach This is unusual: all three four of my NYC servers are timing out. :'(
    It looks like all of their NY operations are out... https://status.virm.ac/
    No acknowledgement on their https://billing.virmach.com/serverstatus.php page yet, so who knows what's up right now. I have systems with other providers in the same DC, though, that are online so I'd guess this is routing-related.
    -Dan
  • Came here to check up on NYC. Mine are also down.
  • @loyaltyforge_dan said: I'd guess this is routing-related
    Does seem that way; vanished into the ether.
  • DALZ005 in virmach had been offlined.
  • Mine's down too, but IDK how to check the node.
  • Still no update on VirMach status page about NYC.
  • Looks to be billing related, hope everything is ok
  • All the servers seem to be back online.
    Thanked by (2)fluttershy AlwaysSkint
    why do you think it's billing related? speculation?
  • Ok mine is working now
    that's record breaking fix!
