Comprehensive Speedtest Script | network-speed.xyz | Share your bench
17891113
  • Crunchbits VDS, $42.75 first year then $171
    ---------------------------- network-speed.xyz ----------------------------
          A simple script to test network performance using speedtest-cli
     Version            : v2023.12.01
     Global Speedtest   : wget -qO- network-speed.xyz | bash
     Region Speedtest   : wget -qO- network-speed.xyz | bash -s -- -r <region>
     Basic System Info
     CPU Model          : Intel Xeon Processor (Skylake, IBRS)
     CPU Cores          : 8 @ 2194.842 MHz
     CPU Cache          : 16384 KB
     AES-NI             : ✔ Enabled
     VM-x/AMD-V         : ✔ Enabled
     Total Disk         : 991.9 GB (12.5 GB Used)
     Total RAM          : 19.5 GB (964.1 MB Used)
     System uptime      : 0 days, 0 hour 43 min
     Load average       : 0.64, 2.75, 2.58
     OS                 : Debian GNU/Linux 12
     Arch               : x86_64 (64 Bit)
     Kernel             : 6.1.0-13-amd64
     Virtualization     : KVM
     TCP Control        :
     Basic Network Info
     Primary Network    : IPv4
     IPv6 Access        : ✔ Online
     IPv4 Access        : ✔ Online
     ISP                : Redoubt Networks
     ASN                : AS400304 Redoubt Networks
     Host               : Crunchbits LLC
     Location         Latency     Loss    DL Speed       UP Speed       Server
     ISP: Redoubt-net
     Nearest          0.31 ms     0.0%    2238.22 Mbps   2491.27 Mbps   Crunchbits - Spokane, WA
     Kochi, IN        258.78 ms   0.0%    745.17 Mbps    264.46 Mbps    Asianet Broadband - Cochin
     Bangalore, IN    237.31 ms   0.0%    1545.51 Mbps   287.44 Mbps    Bharti Airtel Ltd - Bangalore
     Chennai, IN      273.88 ms   N/A     1602.43 Mbps   292.15 Mbps    Jio - Chennai
     Mumbai, IN       257.66 ms   0.0%    36.56 Mbps     283.01 Mbps    i3D.net - Mumbai
     Delhi, IN        327.59 ms   0.0%    687.59 Mbps    225.23 Mbps    Tata Play Fiber - New Delhi
     Seattle, US      11.81 ms    N/A     2163.65 Mbps   2501.72 Mbps   Comcast - Seattle, WA
     Los Angeles, US  36.88 ms    0.0%    2154.79 Mbps   2189.64 Mbps   ReliableSite Hosting - Los Angeles, CA
     Dallas, US       74.54 ms    0.0%    2198.41 Mbps   1115.93 Mbps   Hivelocity - Dallas, TX
     Miami, US        139.17 ms   7.0%    1544.53 Mbps   638.60 Mbps    AT&T - Miami, FL
     New York, US     87.56 ms    0.0%    2318.67 Mbps   940.02 Mbps    GSL Networks - New York, NY
     Toronto, CA      76.49 ms    0.0%    1598.54 Mbps   1056.64 Mbps   Rogers - Toronto, ON
     London, UK       127.59 ms   0.0%    2146.15 Mbps   646.93 Mbps    VeloxServ Communications - London
     Amsterdam, NL    135.09 ms   0.0%    2118.86 Mbps   609.47 Mbps    31173 Services AB - Amsterdam
     Paris, FR        138.85 ms   N/A     2159.12 Mbps   596.47 Mbps    Axione - Paris
     Frankfurt, DE    149.88 ms   0.0%    2000.19 Mbps   479.06 Mbps    23M GmbH - Frankfurt am Main
     Warsaw, PL       150.46 ms   0.0%    2048.91 Mbps   543.71 Mbps    Play - Warszawa
     Bucharest, RO    187.11 ms   0.0%    1495.72 Mbps   419.68 Mbps    Vodafone Romania Fixed – Bucharest - Bucharest
     Moscow, RU       190.99 ms   0.7%    1859.24 Mbps   249.20 Mbps    MegaFon - Moscow
     Jeddah, SA       205.76 ms   0.0%    1971.59 Mbps   392.62 Mbps    Saudi Telecom Company
     Dubai, AE        254.39 ms   0.0%    1135.69 Mbps   270.78 Mbps    du - Dubai
     Fujairah, AE     262.93 ms   0.0%    1774.57 Mbps   298.43 Mbps    ETISALAT-UAE - Fujairah
     Tehran, IR       220.90 ms   N/A     1176.20 Mbps   318.89 Mbps    Asiatech - Tehran
     Cairo, EG        195.92 ms   0.0%    1469.17 Mbps   402.95 Mbps    Vodafone Egypt - Cairo
     Tokyo, JP        137.18 ms   N/A     1856.77 Mbps   587.55 Mbps    fdcservers.net - Tokyo
     Shanghai, CU-CN  185.33 ms   6.0%    948.19 Mbps    294.62 Mbps    China Unicom 5G - Shanghai
     Nanjing, CT-CN   169.43 ms   0.0%    646.72 Mbps    12.86 Mbps     China Telecom JiangSu 5G - Nanjing
     Hong Kong, CN    174.99 ms   N/A     1176.79 Mbps   467.40 Mbps    STC - Hong Kong
     Singapore, SG    186.80 ms   0.0%    2062.28 Mbps   432.67 Mbps    i3D.net - Singapore
     Jakarta, ID      229.37 ms   0.0%    1034.94 Mbps   330.07 Mbps    PT. Telekomunikasi Indonesia - Jakarta
     Avg DL Speed       : 1597.17 Mbps
     Avg UL Speed       : 654.66 Mbps
     Total DL Data      : 66.04 GB
     Total UL Data      : 27.33 GB
     Total Data         : 93.37 GB
     Duration           : 15 min 47 sec
     System Time        : 03/12/2023 - 08:58:48 PST
     Total Script Runs  : 28899
     Result             : https://result.network-speed.xyz/r/1701622039_X76RM1_GLOBAL.txt
  • IONOS 1€/month recurring
     Basic System Info
     CPU Cores          : 1 @ 2099.998 MHz
     CPU Cache          : 4096 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 9.8 GB (919.1 MB Used)
     Total RAM          : 943.2 MB (115.7 MB Used)
     System uptime      : 0 days, 0 hour 6 min
     Load average       : 0.62, 0.35, 0.17
     OS                 : Debian GNU/Linux 11
     Kernel             : 5.10.0-26-cloud-amd64
     Virtualization     : MICROSOFT
     TCP Control        : cubic
     Basic Network Info
     IPv6 Access        : ❌ Offline
     ISP                : Strato AG
     ASN                : AS6724 Strato AG
     Host               : Strato AG
     Speedtest.net (Region: EUROPE)
     ISP: Strato
     Nearest          14.34 ms    0.0%    1789.25 Mbps   1835.94 Mbps   Schlueter Onlinedienste - Ruethen
     London, UK       27.62 ms    0.0%    1418.21 Mbps   1824.39 Mbps   M247 Ltd - London
     Manchester, UK   29.66 ms    N/A     1809.63 Mbps   1795.52 Mbps   Vodafone UK - Manchester
     Dublin, IE       35.83 ms    0.0%    1008.66 Mbps   1712.59 Mbps   Three Ireland - Dublin
     Amsterdam, NL    21.29 ms    0.0%    1007.89 Mbps   1879.42 Mbps   Melbicom - Amsterdam
     Eygelshoen, NL   24.57 ms    0.0%    1270.47 Mbps   1179.95 Mbps   SkyLink Data Center BV - Eygelshoven
     Paris, FR        21.36 ms    0.0%    892.98 Mbps    1900.74 Mbps   ORANGE - Paris
     Marseille, FR    34.52 ms    0.0%    1029.93 Mbps   1779.65 Mbps   GSL Networks - Marseille
     Madrid, ES       73.40 ms    0.0%    792.50 Mbps    1529.57 Mbps   Orange - Jazztel - Madrid
     Barcelona, ES    41.91 ms    0.0%    613.01 Mbps    1722.27 Mbps   Adamo - Barcelona
     Lisbon, PT       53.01 ms    0.0%    1427.07 Mbps   1606.15 Mbps   Edgoo Networks - Lisbon
     Rome, IT         45.15 ms    0.0%    1248.69 Mbps   1747.89 Mbps   TIM SpA - Rome
     Milan, IT        20.39 ms    0.0%    1848.15 Mbps   1769.45 Mbps   Fastweb SpA - Milan
     Zurich, CH       18.94 ms    0.0%    1803.08 Mbps   1848.16 Mbps   Sunrise Communication AG - Zurich
     Frankfurt, DE    11.21 ms    0.0%    1549.28 Mbps   1869.54 Mbps   23M GmbH - Frankfurt am Main
     Berlin, DE       0.97 ms     N/A     2000.97 Mbps   1196.94 Mbps   Misaka Network, Inc. - Berlin
     Vienna, AT       22.31 ms    0.0%    1490.01 Mbps   1743.10 Mbps   A1 Telekom Austria AG - Vienna
     Budapest, HU     28.93 ms    0.0%    1789.68 Mbps   1842.51 Mbps   ATW Internet Kft. - Budapest
     Gdansk, PL       151.33 ms   0.0%    919.81 Mbps    179.32 Mbps    T-Mobile Polska S.A. - Gdańsk
     Warsaw, PL       29.59 ms    0.0%    1140.42 Mbps   1525.61 Mbps   Orange Polska S.A. - Warsaw
     Lviv, UA         28.39 ms    0.0%    832.20 Mbps    1818.06 Mbps   Kyivstar - Lviv
     Kyiv, UA         21.17 ms    0.0%    1774.21 Mbps   1781.98 Mbps   o3 - Kyiv
     Minsk, BY        24.86 ms    0.0%    878.07 Mbps    1587.62 Mbps   A1 - Minsk
     Bucharest, RO    39.03 ms    0.0%    2022.62 Mbps   1806.38 Mbps   Orange Romania Communications - Bucharest
     Iasi, RO         49.56 ms    0.0%    911.65 Mbps    1436.23 Mbps   Digi
     Helsinki, FI     31.83 ms    0.0%    1686.26 Mbps   1815.61 Mbps   Elisa Oyj - Helsinki
     Stockholm, SE    45.05 ms    0.0%    1336.59 Mbps   1583.11 Mbps   i3D.net - Stockholm
     Oslo, NO         41.58 ms    0.0%    1496.99 Mbps   1695.16 Mbps   Speedtest.net - Oslo
     Moscow, RU       54.11 ms    0.0%    1027.75 Mbps   1348.99 Mbps   Rostelecom - Moscow
     Petersburg, RU   FAILED
     Istanbul, TR     51.40 ms    0.0%    1448.44 Mbps   1016.41 Mbps   Turkcell - Istanbul
     Tbilisi, GE      71.83 ms    0.0%    1611.42 Mbps   1163.38 Mbps   Silknet JSC - Tbilisi
     Avg DL Speed       : 1350.84 Mbps
     Avg UL Speed       : 1598.12 Mbps
     Total DL Data      : 52.90 GB
     Total UL Data      : 69.99 GB
     Total Data         : 122.88 GB
     Duration           : 13 min 54 sec
  • Natvps 256MB SGP,
     Basic System Info
     CPU Model          : AMD EPYC 7443P 24-Core Processor
     CPU Cores          : 1 @ 1425.000 MHz
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 3.9 GB (1.9 GB Used)
     Total RAM          : 256.0 MB (69.5 MB Used)
     Total Swap         : 128.0 MB (18.0 MB Used)
     System uptime      : 0 days, 0 hour 17 min
     Load average       : 0.03, 0.18, 0.22
     Kernel             : 6.1.0
     Virtualization     : OPENVZ
     TCP Control        :
     Basic Network Info
     Primary Network    : IPv6
     ISP                : WebHorizon Internet Services
     ASN                : AS149020 WebHorizon Internet Services
     Host               : WebHorizon
     Speedtest.net (Region: INDIA | भारत)
     ISP: WebHorizon Internet Services
     Nearest          0.31 ms     0.0%    4651.44 Mbps   799.37 Mbps    PT FirstMedia - Singapore
     Mumbai, MH       53.28 ms    N/A     811.82 Mbps    590.36 Mbps    Jio - Mumbai
     Mumbai, MH       51.00 ms    0.0%    2482.60 Mbps   831.43 Mbps    Airtel Broadband - Mumbai
     Pune, MH         156.60 ms   0.0%    508.58 Mbps    298.91 Mbps    Tata Play Fiber - Pune
     Hyderabad, AP/TL 176.02 ms   N/A     560.30 Mbps    338.65 Mbps    Airtel Broadband - Hyderabad
     Bangalore, KA    159.65 ms   0.0%    747.86 Mbps    373.45 Mbps    Bharti Airtel Ltd - Bangalore
     Bangalore, KA    42.12 ms    0.0%    715.88 Mbps    609.49 Mbps    ACT FIBERNET - Bangalore
     Mangalore, KA    46.05 ms    0.7%    739.31 Mbps    634.93 Mbps    BBNL - Mangalore
     Chennai, TN      33.30 ms    N/A     912.89 Mbps    601.42 Mbps    Jio - Chennai
     Coimbatore, TN   164.09 ms   0.0%    656.24 Mbps    381.01 Mbps    Airtel Broadband - Coimbatore
     Madurai, TN      297.08 ms   0.0%    2518.75 Mbps   28.18 Mbps     Vi India - Madurai
     Kochi, KL        45.36 ms    N/A     864.06 Mbps    615.75 Mbps    Jio - Kochi
     Kochi, KL        43.52 ms    0.0%    764.38 Mbps    437.56 Mbps    Asianet Broadband - Cochin
     Trivandrum, KL   104.20 ms   0.0%    638.59 Mbps    462.47 Mbps    Keralavision Broadband - Trivandrum
     Kolkata, WB      94.22 ms    0.0%    569.56 Mbps    379.18 Mbps    Alliance Broadband Services Pvt Ltd - Kolkata
     Delhi, DL        175.44 ms   0.0%    3797.16 Mbps   489.53 Mbps    Extreme IX - New Delhi
     Gurgaon, HR      76.89 ms    0.0%    2091.06 Mbps   820.95 Mbps    Powernet - Gurgaon
     Patna, BH        FAILED
     Avg DL Speed       : 1413.56 Mbps
     Avg UL Speed       : 511.33 Mbps
     Total DL Data      : 28.30 GB
     Total UL Data      : 12.63 GB
     Total Data         : 40.92 GB
     Duration           : 8 min 21 sec
     System Time        : 26/12/2023 - 08:15:20 GMT
     Total Script Runs  : 30392
    Thanked by (1)sh97
  • https://inleed.com/virtual-server - VPS Starter €8 / per month ex. vat
    yabs: https://lowendspirit.com/discussion/comment/166230/#Comment_166230
     Version            : v2023.12.28
     Basic System Info
     CPU Model          : QEMU Virtual CPU version 2.5+
     CPU Cores          : 1 @ 2199.996 MHz
     AES-NI             : ❌ Disabled
     VM-x/AMD-V         : ❌ Disabled
     Total Disk         : 49.1 GB (1.4 GB Used)
     Total RAM          : 3.8 GB (68.3 MB Used)
     System uptime      : 0 days, 2 hour 9 min
     Load average       : 0.00, 0.00, 0.00
     Kernel             : 5.10.0-26-amd64
     TCP Control        : cubic
     Basic Network Info
     ISP                : Yelles AB
     ASN                : AS206170 Yelles AB
     Host               : Inleed AB
     Location (IPv4)    : Stockholm, Stockholm, SE
     ISP: Yelles AB
     Nearest          0.44 ms     0.0%    8232.00 Mbps   9028.83 Mbps   84 Grams AB - Stockholm
     London, UK       FAILED
     Manchester, UK   34.55 ms    N/A     4704.04 Mbps   2024.41 Mbps   Vodafone UK - Manchester
     Dublin, IE       FAILED
     Amsterdam, NL    FAILED
     Eygelshoen, NL   27.89 ms    0.0%    6426.25 Mbps   1193.88 Mbps   SkyLink Data Center BV - Eygelshoven
     Paris, FR        29.24 ms    0.0%    6442.21 Mbps   3038.86 Mbps   ORANGE - Paris
     Marseille, FR    39.12 ms    0.0%    6740.95 Mbps   1633.39 Mbps   GSL Networks - Marseille
     Madrid, ES       FAILED
     Barcelona, ES    FAILED
     Lisbon, PT       FAILED
     Rome, IT         FAILED
     Milan, IT        FAILED
     Zurich, CH       FAILED
     Frankfurt, DE    FAILED
     Berlin, DE       FAILED
     Vienna, AT       FAILED
     Budapest, HU     FAILED
     Gdansk, PL       FAILED
     Warsaw, PL       FAILED
     Lviv, UA         FAILED
     Kyiv, UA         FAILED
     Minsk, BY        FAILED
     Bucharest, RO    FAILED
     Iasi, RO         FAILED
     Helsinki, FI     FAILED
     Stockholm, SE    FAILED
     Oslo, NO         7.76 ms     0.0%    44.04 Mbps     110.60 Mbps    Speedtest.net - Oslo
     Moscow, RU       FAILED
     Istanbul, TR     59.65 ms    0.0%    5833.11 Mbps   1760.16 Mbps   Turkcell - Istanbul
     Tbilisi, GE      FAILED
     Avg DL Speed       : 5488.93 Mbps
     Avg UL Speed       : 2684.31 Mbps
     Total DL Data      : 44.98 GB
     Total UL Data      : 27.30 GB
     Total Data         : 72.27 GB
     Duration           : 8 min 34 sec
     System Time        : 30/12/2023 - 09:45:57 EST
     Total Script Runs  : 32654
  • ---------------------------- network-speed.xyz ----------------------------
     Basic System Info
     CPU Model          : AMD Ryzen 7 7700 8-Core Processor
     CPU Cores          : 1 @ 3792.860 MHz
     CPU Cache          : 1024 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 78.7 GB (6.9 GB Used)
     Total RAM          : 3.8 GB (396.4 MB Used)
     System uptime      : 0 days, 0 hour 2 min
     Kernel             : 6.1.0-17-amd64
     TCP Control        : cubic
     Basic Network Info
     ISP                : Hostaris Limited
     ASN                : AS199765 Hostaris Limited
     Host               : Hostaris Limited
     ISP: Hostaris Limited
     Nearest          5.28 ms     0.0%    886.64 Mbps    885.20 Mbps    wirsNET - Frankfurt
     London, UK       16.88 ms    0.0%    829.46 Mbps    888.10 Mbps    M247 Ltd - London
     Manchester, UK   24.39 ms    N/A     832.77 Mbps    880.60 Mbps    Vodafone UK - Manchester
     Dublin, IE       30.83 ms    0.5%    898.30 Mbps    872.92 Mbps    Three Ireland - Dublin
     Amsterdam, NL    11.83 ms    0.0%    886.24 Mbps    889.34 Mbps    Melbicom - Amsterdam
     Eygelshoen, NL   14.71 ms    0.0%    867.97 Mbps    889.20 Mbps    SkyLink Data Center BV - Eygelshoven
     Paris, FR        15.43 ms    0.0%    911.54 Mbps    898.61 Mbps    ORANGE - Paris
     Marseille, FR    20.96 ms    0.0%    902.87 Mbps    879.51 Mbps    GSL Networks - Marseille
     Madrid, ES       33.35 ms    0.0%    906.74 Mbps    866.39 Mbps    Orange - Jazztel - Madrid
     Barcelona, ES    32.59 ms    0.0%    868.63 Mbps    838.07 Mbps    Adamo - Barcelona
     Lisbon, PT       43.10 ms    0.0%    815.70 Mbps    844.27 Mbps    Edgoo Networks - Lisbon
     Rome, IT         27.24 ms    0.0%    916.48 Mbps    884.25 Mbps    TIM SpA - Rome
     Milan, IT        14.91 ms    0.0%    905.14 Mbps    892.71 Mbps    Fastweb SpA - Milan
     Zurich, CH       11.75 ms    0.0%    893.25 Mbps    878.59 Mbps    Sunrise Communication AG - Zurich
     Frankfurt, DE    5.82 ms     0.0%    893.22 Mbps    877.69 Mbps    23M GmbH - Frankfurt am Main
     Berlin, DE       14.81 ms    N/A     765.61 Mbps    663.27 Mbps    Misaka Network, Inc. - Berlin
     Vienna, AT       18.58 ms    0.0%    885.20 Mbps    879.35 Mbps    A1 Telekom Austria AG - Vienna
     Budapest, HU     20.75 ms    0.0%    803.76 Mbps    868.74 Mbps    ATW Internet Kft. - Budapest
     Gdansk, PL       24.56 ms    0.0%    765.17 Mbps    881.65 Mbps    T-Mobile Polska S.A. - Gdańsk
     Warsaw, PL       32.01 ms    0.0%    842.58 Mbps    881.78 Mbps    Orange Polska S.A. - Warsaw
     Lviv, UA         30.91 ms    0.0%    854.82 Mbps    872.88 Mbps    Kyivstar - Lviv
     Kyiv, UA         30.22 ms    0.0%    848.97 Mbps    645.96 Mbps    o3 - Kyiv
     Minsk, BY        42.52 ms    0.0%    927.27 Mbps    798.51 Mbps    A1 - Minsk
     Bucharest, RO    32.38 ms    0.0%    906.90 Mbps    883.26 Mbps    Orange Romania Communications - Bucharest
     Iasi, RO         42.25 ms    0.0%    685.07 Mbps    806.49 Mbps    Digi
     Helsinki, FI     34.47 ms    0.0%    808.68 Mbps    876.07 Mbps    Elisa Oyj - Helsinki
     Stockholm, SE    36.30 ms    0.0%    846.95 Mbps    873.23 Mbps    i3D.net - Stockholm
     Oslo, NO         31.20 ms    0.0%    884.65 Mbps    882.43 Mbps    Speedtest.net - Oslo
     Moscow, RU       38.13 ms    0.0%    838.38 Mbps    865.18 Mbps    Rostelecom - Moscow
     Petersburg, RU   36.22 ms    0.0%    924.96 Mbps    878.40 Mbps    MegaFon - Saint Petersburg
     Istanbul, TR     40.66 ms    0.0%    914.84 Mbps    881.24 Mbps    Turkcell - Istanbul
     Tbilisi, GE      63.67 ms    0.0%    816.81 Mbps    814.02 Mbps    Silknet JSC - Tbilisi
     Avg DL Speed       : 860.49 Mbps
     Avg UL Speed       : 856.81 Mbps
     Total DL Data      : 32.77 GB
     Total UL Data      : 32.00 GB
     Total Data         : 64.77 GB
     Duration           : 14 min 33 sec
     System Time        : 02/01/2024 - 16:50:54 CET
     Total Script Runs  : 33023
  • edited January 2
    deleted
  • Webhorizon - NATVPS.net
    HK
     Basic System Info
     CPU Model          : AMD EPYC 7513 32-Core Processor
     CPU Cores          : 1 @ 1297.561 MHz
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 3.9 GB (884.8 MB Used)
     Total RAM          : 256.0 MB (35.6 MB Used)
     System uptime      : 21 days, 21 hour 6 min
     Load average       : 0.09, 0.10, 0.13
     Kernel             : 6.1.0
     TCP Control        :
     Basic Network Info
     ISP                : HostHatch
     ASN                : AS63473 HostHatch, LLC
     Host               : HostHatch, LLC
     Location           : Tseung Kwan O, Sai Kung District-NSK, Hong Kong
     Location (IPv4)    : Hong Kong, Central and Western, HK
     Speedtest.net (Region: ASIA)
     ISP: HostHatch LLC
     Nearest          0.30 ms     N/A     7383.65 Mbps   8452.36 Mbps   GSL Networks - Hong Kong
     Tokyo, JP        55.18 ms    0.0%    1129.56 Mbps   690.31 Mbps    Rakuten Mobile, Inc - Tokyo
     Tapei, TW        20.56 ms    N/A     6524.34 Mbps   634.78 Mbps    Chunghwa Mobile - Taipei
     China Telecom    FAILED
     China Unicom     410.86 ms   7.6%    8.71 Mbps      0.75 Mbps      China Unicom 5G - Shanghai
     China Mobile     236.81 ms           1928.04 Mbps   FAILED         China Mobile Henan 5G - Zhengzhou
     Hong Kong, CN    0.42 ms     0.0%    1469.68 Mbps   863.10 Mbps    i3D.net - Hong Kong
     Ho Chi Minh, VN  36.04 ms    0.0%    1251.88 Mbps   1194.80 Mbps   CMC Telecom - Ho Chi Minh
     Hanoi, VN        40.82 ms    0.0%    5070.99 Mbps   952.44 Mbps    FPT Telecom - Hanoi
     Bangkok, TH      48.77 ms    0.0%    1368.82 Mbps   911.42 Mbps    3BB - Bangkok
     Manila, PH       21.28 ms    N/A     7514.49 Mbps   1838.82 Mbps   PLDT - Manila
     Singapore, SG    37.42 ms    0.0%    2097.97 Mbps   955.58 Mbps    MyRepublic Singapore - Singapore
     Singapore, SG    37.73 ms    N/A     4093.64 Mbps   1082.70 Mbps   StarHub Ltd - Singapore
     Jakarta, ID      FAILED
     Surabaya, ID     71.45 ms    N/A     8351.06 Mbps   777.10 Mbps    PT. Indonesia Comnets Plus - Surabaya
     Kuala Lum, MY    43.66 ms    0.0%    2696.62 Mbps   1042.91 Mbps   Telekom Malaysia Berhad - Kuala Lumpur
     Mumbai, IN       95.01 ms    0.0%    1111.41 Mbps   737.48 Mbps    i3D.net - Mumbai
     Chennai, IN      205.64 ms   N/A     1003.53 Mbps   300.72 Mbps    Jio - Chennai
     Bangalore, IN    245.06 ms   0.0%    875.87 Mbps    375.57 Mbps    Bharti Airtel Ltd - Bangalore
     Karachi, PK      213.12 ms   0.3%    1830.95 Mbps   141.47 Mbps    JAZZ - Karachi
     Lahore, PK       125.72 ms   N/A     4133.84 Mbps   370.61 Mbps    Telenor Pakistan - Lahore
     Kathmandu, NP    118.44 ms   0.0%    1122.51 Mbps   529.86 Mbps    Ncell Axiata Ltd - Kathmandu
     Colombo, SL      227.87 ms   N/A     2098.03 Mbps   155.94 Mbps    Airtel Lanka - Colombo
     Dhaka, BD        83.89 ms    N/A     4225.16 Mbps   635.51 Mbps    Grameenphone Ltd - Dhaka
     Novosibirsk, RU  261.52 ms   0.0%    1039.59 Mbps   436.54 Mbps    MegaFon - Novosibirsk
     Almaty, KZ       71.61 ms    0.0%    4480.40 Mbps   782.68 Mbps    Kazakhtelecom - Almaty
     Tehran, IR       346.73 ms   0.0%    2354.43 Mbps   258.88 Mbps    Irancell - Tehran
     Dubai, AE        104.53 ms   0.0%    4730.46 Mbps   318.22 Mbps    ETISALAT-UAE - Dubai
     Jeddah, SA       244.44 ms   0.0%    3146.26 Mbps   281.65 Mbps    Mobily - Jeddah
     Istanbul, TR     271.45 ms   0.0%    972.69 Mbps    141.59 Mbps    Turkcell - Istanbul
     Avg DL Speed       : 3000.52 Mbps
     Avg UL Speed       : 887.99 Mbps
     Total DL Data      : 110.91 GB
     Total UL Data      : 37.48 GB
     Total Data         : 148.39 GB
     Duration           : 14 min 22 sec
     System Time        : 02/01/2024 - 05:45:30 EST
     Total Script Runs  : 32999
     Result             : https://result.network-speed.xyz/r/1704191379_2P9X9C_ASIA.txt
    SG
     Basic System Info
     CPU Model          : AMD EPYC 7B13 64-Core Processor
     CPU Cores          : 1 @ 1122.890 MHz
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 3.9 GB (950.2 MB Used)
     Total RAM          : 256.0 MB (16.9 MB Used)
     Total Swap         : 128.0 MB (13.0 MB Used)
     System uptime      : 37 days, 1 hour 50 min
     Load average       : 0.11, 0.13, 0.14
     Kernel             : 6.1.0
     TCP Control        :
     Basic Network Info
     Host               : WebHorizon
     Nearest          0.31 ms     0.0%    5094.43 Mbps   993.07 Mbps    PT FirstMedia - Singapore
     Tokyo, JP        82.39 ms    0.0%    1103.78 Mbps   534.49 Mbps    Rakuten Mobile, Inc - Tokyo
     Tapei, TW        51.80 ms    N/A     4438.03 Mbps   414.07 Mbps    Chunghwa Mobile - Taipei
     China Unicom     FAILED
     China Mobile     FAILED
     Hong Kong, CN    36.60 ms    0.0%    1160.52 Mbps   673.08 Mbps    i3D.net - Hong Kong
     Ho Chi Minh, VN  68.33 ms    0.0%    1142.39 Mbps   611.57 Mbps    CMC Telecom - Ho Chi Minh
     Hanoi, VN        40.86 ms    0.0%    3967.65 Mbps   998.28 Mbps    FPT Telecom - Hanoi
     Bangkok, TH      24.63 ms    0.0%    1333.95 Mbps   802.53 Mbps    3BB - Bangkok
     Manila, PH       83.36 ms    N/A     3609.71 Mbps   18.85 Mbps     PLDT - Manila
     Singapore, SG    0.98 ms     0.0%    4934.08 Mbps   991.49 Mbps    MyRepublic Singapore - Singapore
     Singapore, SG    1.93 ms     N/A     5311.84 Mbps   987.39 Mbps    StarHub Ltd - Singapore
     Jakarta, ID      FAILED
     Surabaya, ID     24.64 ms    N/A     3666.54 Mbps   1026.13 Mbps   PT. Indonesia Comnets Plus - Surabaya
     Kuala Lum, MY    12.28 ms    0.0%    3390.94 Mbps   1067.44 Mbps   Telekom Malaysia Berhad - Kuala Lumpur
     Mumbai, IN       61.70 ms    0.0%    1210.13 Mbps   693.66 Mbps    i3D.net - Mumbai
     Chennai, IN      36.13 ms    N/A     1196.18 Mbps   806.71 Mbps    Jio - Chennai
     Bangalore, IN    157.25 ms   0.0%    925.41 Mbps    404.35 Mbps    Bharti Airtel Ltd - Bangalore
     Karachi, PK      77.14 ms    0.0%    2128.43 Mbps   628.79 Mbps    JAZZ - Karachi
     Lahore, PK       93.87 ms    N/A     4084.58 Mbps   500.83 Mbps    Telenor Pakistan - Lahore
     Kathmandu, NP    207.36 ms   0.0%    948.01 Mbps    479.38 Mbps    Ncell Axiata Ltd - Kathmandu
     Colombo, SL      48.89 ms    N/A     2365.53 Mbps   936.96 Mbps    Airtel Lanka - Colombo
     Dhaka, BD        45.40 ms    N/A     2546.11 Mbps   1022.19 Mbps   Grameenphone Ltd - Dhaka
     Novosibirsk, RU  226.69 ms   0.0%    946.69 Mbps    321.18 Mbps    MegaFon - Novosibirsk
     Almaty, KZ       109.15 ms   0.0%    2968.16 Mbps   769.08 Mbps    Kazakhtelecom - Almaty
     Tehran, IR       269.73 ms   0.0%    2178.43 Mbps   326.46 Mbps    Irancell - Tehran
     Dubai, AE        76.67 ms    N/A     5882.42 Mbps   256.09 Mbps    ETISALAT-UAE - Dubai
     Jeddah, SA       210.30 ms   0.0%    3263.26 Mbps   430.67 Mbps    Mobily - Jeddah
     Istanbul, TR     194.80 ms   0.0%    841.73 Mbps    125.55 Mbps    Turkcell - Istanbul
     Avg DL Speed       : 2716.88 Mbps
     Avg UL Speed       : 646.94 Mbps
     Total DL Data      : 98.80 GB
     Total UL Data      : 24.52 GB
     Total Data         : 123.32 GB
     Duration           : 13 min 6 sec
     System Time        : 02/01/2024 - 16:31:04 IST
     Total Script Runs  : 33001
     Result             : https://result.network-speed.xyz/r/1704192313_CWWN5Q_ASIA.txt
    Thanked by (1)Abdullah
  • Updated to v2024.01.26
    • Updated broken servers
    • Add more locations to India test
    • Updated speedtest-cli to latest version, 1.2.0
    If anyone finds any issues while running (as I updated the CLI version), let me know.
    KhanWebHost NAT India
     Version            : v2024.01.26
     Basic System Info
     CPU Model          : Intel(R) Xeon(R) CPU E5-2620 v3 @ 2.40GHz
     CPU Cores          : 1 @ 2394.454 MHz
     CPU Cache          : 15360 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 3.8 GB (2.5 GB Used)
     Total RAM          : 224.6 MB (65.7 MB Used)
     Total Swap         : 1024.0 MB (2.8 MB Used)
     System uptime      : 34 days, 6 hour 37 min
     Load average       : 0.39, 0.29, 0.24
     OS                 : Debian GNU/Linux 10
     Kernel             : 5.10.0-0.deb10.26-rt-amd64
     TCP Control        : cubic
     Basic Network Info
     ISP                : NETWORK-LEAPSWITCH
     ASN                : AS132335 LeapSwitch Networks Pvt Ltd
     Host               : LeapSwitch Networks Pvt Ltd
     ISP: LeapSwitch Networks Pvt
     Nearest          0.83 ms     0.0%    869.20 Mbps    903.33 Mbps    Excitel - Mumbai
     Mumbai, MH       2.46 ms     N/A     456.93 Mbps    485.14 Mbps    Jio - Mumbai
     Mumbai, MH       2.76 ms     0.0%    447.78 Mbps    485.16 Mbps    Airtel Broadband - Mumbai
     Pune, MH         4.54 ms     0.0%    23.22 Mbps     481.88 Mbps    Tata Play Fiber - Pune
     Hyderabad, AP/TL 17.46 ms    N/A     2.01 Mbps      446.60 Mbps    Airtel Broadband - Hyderabad
     Bangalore, KA    18.96 ms    0.0%    442.78 Mbps    445.53 Mbps    Bharti Airtel Ltd - Bangalore
     Bangalore, KA    22.72 ms    0.0%    456.17 Mbps    446.87 Mbps    ACT FIBERNET - Bangalore
     Mangalore, KA    24.97 ms    0.0%    453.59 Mbps    332.46 Mbps    BBNL - Mangalore
     Chennai, TN      27.41 ms    N/A     440.86 Mbps    436.50 Mbps    Jio - Chennai
     Coimbatore, TN   47.48 ms    0.0%    442.94 Mbps    299.90 Mbps    Airtel Broadband - Coimbatore
     Madurai, TN      139.80 ms   0.0%    709.88 Mbps    206.29 Mbps    Vi India - Madurai
     Kochi, KL        33.30 ms    N/A     443.16 Mbps    441.20 Mbps    Jio - Kochi
     Kochi, KL        40.66 ms    0.0%    434.65 Mbps    249.03 Mbps    Asianet Broadband - Cochin
     Trivandrum, KL   FAILED
     Kolkata, WB      33.15 ms    0.0%    447.21 Mbps    448.82 Mbps    Alliance Broadband Services Pvt Ltd - Kolkata
     Ahmedabad, GJ    18.89 ms    0.0%    447.94 Mbps    460.97 Mbps    GTPL Broadband Pvt Ltd - Ahmedabad
     Jaipur, RJ       47.34 ms    0.0%    825.32 Mbps    442.47 Mbps    RailTel Corporation of India Ltd - Jaipur
     Lucknow, UP      32.57 ms    0.9%    882.02 Mbps    40.25 Mbps     Excitel - Lucknow
     Delhi, DL        28.94 ms    0.0%    864.60 Mbps    533.06 Mbps    Extreme IX - New Delhi
     Gurgaon, HR      22.36 ms    0.0%    858.33 Mbps    530.08 Mbps    Powernet - Gurgaon
     Patna, BH        300.70 ms   N/A     0.46 Mbps      69.45 Mbps     Vi India - Patna
     Avg DL Speed       : 497.45 Mbps
     Avg UL Speed       : 409.25 Mbps
     Total DL Data      : 13.14 GB
     Total UL Data      : 8.36 GB
     Total Data         : 21.49 GB
     Duration           : 7 min 58 sec
     System Time        : 25/01/2024 - 12:26:58 EST
     Total Script Runs  : 34679
     Result             : https://result.network-speed.xyz/r/1706202464_7AWUPE_INDIA.txt
    Racknerd France
     Basic System Info
     CPU Model          : Intel(R) Xeon(R) CPU E5-2630 v4 @ 2.20GHz
     CPU Cores          : 2 @ 2199.996 MHz
     AES-NI             : ✔ Enabled
     Total Disk         : 26.5 GB (4.1 GB Used)
     Total RAM          : 1.9 GB (723.4 MB Used)
     Total Swap         : 1024.0 MB (189.0 MB Used)
     System uptime      : 14 days, 14 hour 34 min
     Load average       : 0.07, 0.13, 0.12
     TCP Control        : cubic
     Basic Network Info
     ISP                : velia.net Internetdienste GmbH
     ASN                : AS29066 velia.net Internetdienste GmbH
     Host               : RackNerd, LLC
     Location (IPv4)    : Köln, North Rhine-Westphalia, DE
     ISP: velia.net Internetdienste
     Nearest          7.19 ms     0.0%    93.34 Mbps     80.48 Mbps     Frachtwerk GmbH - Karlsruhe
     Kochi, IN        187.26 ms   0.0%    446.22 Mbps    462.46 Mbps    Asianet Broadband - Cochin
     Bangalore, IN    133.11 ms   0.0%    622.57 Mbps    488.86 Mbps    Bharti Airtel Ltd - Bangalore
     Chennai, IN      135.70 ms   N/A     490.73 Mbps    618.87 Mbps    Jio - Chennai
     Mumbai, IN       168.43 ms   0.0%    492.10 Mbps    318.57 Mbps    i3D.net - Mumbai
     Delhi, IN        176.69 ms   0.0%    549.04 Mbps    407.53 Mbps    Tata Play Fiber - New Delhi
     Seattle, US      155.22 ms   N/A     559.18 Mbps    545.52 Mbps    Comcast - Seattle, WA
     Los Angeles, US  142.35 ms   0.0%    827.66 Mbps    601.58 Mbps    ReliableSite Hosting - Los Angeles, CA
     Dallas, US       117.16 ms   0.0%    665.22 Mbps    733.66 Mbps    Hivelocity - Dallas, TX
     Miami, US        116.20 ms   0.0%    745.89 Mbps    445.94 Mbps    AT&T - Miami, FL
     New York, US     80.31 ms    0.0%    954.53 Mbps    600.05 Mbps    GSL Networks - New York, NY
     Toronto, CA      93.37 ms    0.0%    864.55 Mbps    824.59 Mbps    Rogers - Toronto, ON
     Mexico City, MX  195.28 ms   N/A     480.64 Mbps    473.77 Mbps    INFINITUM - Mexico City
     London, UK       21.29 ms    0.0%    924.43 Mbps    918.23 Mbps    VeloxServ Communications - London
     Amsterdam, NL    11.09 ms    0.0%    906.78 Mbps    836.11 Mbps    31173 Services AB - Amsterdam
     Paris, FR        13.05 ms    N/A     912.94 Mbps    841.21 Mbps    Axione - Paris
     Frankfurt, DE    4.01 ms     0.0%    925.42 Mbps    916.78 Mbps    23M GmbH - Frankfurt am Main
     Warsaw, PL       27.67 ms    0.0%    934.56 Mbps    913.74 Mbps    Play - Warszawa
     Bucharest, RO    39.56 ms    0.0%    900.29 Mbps    829.92 Mbps    Vodafone Romania Fixed – Bucharest - Bucharest
     Moscow, RU       44.18 ms    0.0%    919.50 Mbps    913.66 Mbps    MegaFon - Moscow
     Jeddah, SA       83.70 ms    0.0%    951.76 Mbps    817.97 Mbps    Saudi Telecom Company
     Dubai, AE        132.59 ms   0.0%    930.14 Mbps    386.27 Mbps    du - Dubai
     Fujairah, AE     118.71 ms   0.0%    924.67 Mbps    626.37 Mbps    ETISALAT-UAE - Fujairah
     Istanbul, TR     51.31 ms    0.0%    930.26 Mbps    928.35 Mbps    Turkcell - Istanbul
     Tehran, IR       88.01 ms    0.0%    877.87 Mbps    633.25 Mbps    Asiatech - Tehran
     Tokyo, JP        278.74 ms   N/A     618.62 Mbps    224.28 Mbps    fdcservers.net - Tokyo
     Shanghai, CU-CN  233.49 ms   0.0%    466.72 Mbps    241.60 Mbps    China Unicom 5G - Shanghai
     Nanjing, CT-CN   FAILED
     Hong Kong, CN    246.84 ms   N/A     415.33 Mbps    301.85 Mbps    STC - Hong Kong
     Singapore, SG    150.49 ms   0.0%    420.35 Mbps    576.08 Mbps    i3D.net - Singapore
     Jakarta, ID      180.27 ms   0.0%    568.19 Mbps    195.00 Mbps    PT. Telekomunikasi Indonesia - Jakarta
     Avg DL Speed       : 710.65 Mbps
     Avg UL Speed       : 590.09 Mbps
     Total DL Data      : 30.29 GB
     Total UL Data      : 22.25 GB
     Total Data         : 52.55 GB
     Duration           : 14 min 28 sec
     System Time        : 25/01/2024 - 23:05:50 IST
     Total Script Runs  : 34680
     Result             : https://result.network-speed.xyz/r/1706202995_K72O2F_GLOBAL.txt
  • 70RUB = 0.71€ UAE VPS from JustHost
     Version            : v2024.02.05
     Basic System Info
     CPU Model          : Intel(R) Xeon(R) CPU E5-2697 v4 @ 2.30GHz
     CPU Cores          : 1 @ 2299.998 MHz
     AES-NI             : ✔ Enabled
     Total Disk         : 5.8 GB (1.5 GB Used)
     Total RAM          : 473.3 MB (58.7 MB Used)
     System uptime      : 0 days, 0 hour 11 min
     Load average       : 0.13, 0.36, 0.27
     Kernel             : 5.10.0-20-amd64
     TCP Control        : cubic
     Basic Network Info
     ISP                : BFB ONE FZ-LLC
     ASN                : AS59878 BFB ONE FZ-LLC
     Host               : BFB ONE FZ-LLC
     Location (IPv4)    : Al Fujairah City, Fujairah, AE
     ISP: Baxet Group Inc.
     Nearest          0.41 ms     0.0%    10.03 Mbps     10.30 Mbps     Melbicom - Fujairah
     Kochi, IN        97.09 ms    0.0%    9.87 Mbps      10.52 Mbps     Asianet Broadband - Cochin
     Bangalore, IN    73.47 ms    0.0%    9.88 Mbps      10.29 Mbps     Bharti Airtel Ltd - Bangalore
     Chennai, IN      76.40 ms    N/A     9.86 Mbps      10.35 Mbps     Jio - Chennai
     Mumbai, IN       260.95 ms   0.0%    9.88 Mbps      10.47 Mbps     i3D.net - Mumbai
     Delhi, IN        158.90 ms   0.0%    10.02 Mbps     10.59 Mbps     Tata Play Fiber - New Delhi
     Seattle, US      245.16 ms   N/A     9.89 Mbps      10.53 Mbps     Comcast - Seattle, WA
     Los Angeles, US  244.84 ms   0.0%    9.89 Mbps      10.66 Mbps     ReliableSite Hosting - Los Angeles, CA
     Dallas, US       306.26 ms   0.0%    8.60 Mbps      10.49 Mbps     Hivelocity - Dallas, TX
     Miami, US        224.55 ms   0.0%    10.03 Mbps     10.56 Mbps     AT&T - Miami, FL
     New York, US     237.21 ms   0.0%    9.91 Mbps      10.79 Mbps     GSL Networks - New York, NY
     Toronto, CA      326.84 ms   0.0%    9.87 Mbps      11.16 Mbps     Rogers - Toronto, ON
     Mexico City, MX  301.79 ms   N/A     9.89 Mbps      10.94 Mbps     INFINITUM - Mexico City
     London, UK       243.31 ms   0.0%    9.81 Mbps      10.21 Mbps     VeloxServ Communications - London
     Amsterdam, NL    122.03 ms   0.0%    10.03 Mbps     10.42 Mbps     31173 Services AB - Amsterdam
     Paris, FR        107.01 ms   N/A     10.00 Mbps     10.38 Mbps     Axione - Paris
     Frankfurt, DE    258.74 ms   0.0%    9.85 Mbps      3.41 Mbps      Clouvider Ltd - Frankfurt am Main
     Warsaw, PL       254.89 ms   0.5%    9.77 Mbps      4.10 Mbps      Play - Warszawa
     Bucharest, RO    140.70 ms   0.0%    10.00 Mbps     10.53 Mbps     Vodafone Romania Fixed – Bucharest - Bucharest
     Moscow, RU       332.00 ms   0.0%    9.35 Mbps      10.79 Mbps     MegaFon - Moscow
     Jeddah, SA       38.52 ms    0.0%    9.99 Mbps      10.33 Mbps     Saudi Telecom Company
     Dubai, AE        8.10 ms     0.0%    9.96 Mbps      10.19 Mbps     du - Dubai
     Fujairah, AE     0.43 ms     0.0%    10.01 Mbps     10.28 Mbps     ETISALAT-UAE - Fujairah
     Istanbul, TR     187.29 ms   0.0%    7.65 Mbps      10.60 Mbps     Turkcell - Istanbul
     Tehran, IR       351.87 ms   0.0%    10.04 Mbps     10.76 Mbps     Asiatech - Tehran
     Tokyo, JP        348.79 ms   N/A     8.93 Mbps      10.45 Mbps     fdcservers.net - Tokyo
     Shanghai, CU-CN  257.28 ms   0.0%    10.02 Mbps     12.20 Mbps     China Unicom 5G - Shanghai
     Nanjing, CT-CN   264.53 ms   38.7%   10.02 Mbps     8.65 Mbps      China Telecom JiangSu 5G - Nanjing
     Hong Kong, CN    109.69 ms   N/A     10.01 Mbps     10.49 Mbps     STC - Hong Kong
     Singapore, SG    77.81 ms    0.0%    9.84 Mbps      10.29 Mbps     i3D.net - Singapore
     Jakarta, ID      FAILED - IP has been rate limited. Try again after 1 hour.
     Avg DL Speed       : 9.76 Mbps
     Avg UL Speed       : 10.06 Mbps
     Total DL Data      : 0.34 GB
     Total UL Data      : 0.43 GB
     Total Data         : 0.77 GB
     Duration           : 14 min 25 sec
     System Time        : 10/02/2024 - 01:36:43 MSK
     Total Script Runs  : 35608
     Result             : https://result.network-speed.xyz/r/1707516916_II9CKN_GLOBAL.txt
    Thanked by (1)lapua
     Basic System Info
     AES-NI             : ✔ Enabled
     Total RAM          : 473.3 MB (63.2 MB Used)
     System uptime      : 0 days, 1 hour 48 min
     OS                 : Debian GNU/Linux 1170RUB = 0.71€ UAE VPS from JustHost
     Speedtest.net (Region: MIDDLE EAST | الشرق الأوسط)
     Nearest          0.36 ms     0.0%    9.96 Mbps      10.14 Mbps     Melbicom - Fujairah
     Abu Dhabi, AE    8.45 ms     0.0%    9.99 Mbps      10.19 Mbps     du - Abu Dhabi
     Dubai, AE        3.75 ms     0.0%    9.80 Mbps      10.03 Mbps     i3D.net - Dubai
     Fujairah, AE     0.42 ms     0.0%    10.02 Mbps     10.31 Mbps     ETISALAT-UAE - Fujairah
     Muscat, OM       254.02 ms   0.0%    10.12 Mbps     10.48 Mbps     OmanTel - Muscat
     Seeb, OM         79.97 ms    0.0%    9.71 Mbps      10.26 Mbps     Ooredoo Oman - Seeb
     Sanaa, YE        169.14 ms   0.0%    9.86 Mbps      10.52 Mbps     Yemen Net - Sanaa
     Doha, QA         9.53 ms     0.0%    9.97 Mbps      10.21 Mbps     Ooredoo Qatar - Doha
     Rayan, QA        15.08 ms    0.0%    9.99 Mbps      10.22 Mbps     Vodafone Qatar PQSC - Rayan
     Manama, BH       15.62 ms    0.0%    10.04 Mbps     10.35 Mbps     ZainBH - Manama
     Rifa, BH         41.65 ms    0.0%    9.56 Mbps      10.31 Mbps     stc Bahrain - Riffa
     Kuwait, KW       20.19 ms    0.0%    9.85 Mbps      10.17 Mbps     Zain Kuwait - Kuwait City
     Kuwait, KW       25.31 ms    N/A     9.87 Mbps      10.19 Mbps     Ooredoo Kuwait - Kuwait City
     Riyadh, SA       FAILED
     Dammam, SA       66.39 ms    0.0%    9.97 Mbps      10.37 Mbps     Saudi Telecom Company
     Jeddah, SA       116.68 ms   0.0%    12.17 Mbps     6.19 Mbps      Zain KSA - Jeddah
     Jeddah, SA       38.05 ms    0.0%    9.96 Mbps      10.30 Mbps     Saudi Telecom Company
     Tehran, IR       281.38 ms   0.0%    9.98 Mbps      10.72 Mbps     Irancell - Tehran
     Baghdad, IQ      105.86 ms   0.0%    9.97 Mbps      10.59 Mbps     Al-Jazeera Telecom - Baghdad
     Beirut, LB       134.31 ms   0.0%    10.10 Mbps     10.60 Mbps     Ogero - Beirut
     Nicosia, CY      77.61 ms    N/A     9.96 Mbps      10.37 Mbps     Cyprus Telecommunications Authority - Nicosia
     Tel Aviv, IL     163.05 ms   0.5%    9.98 Mbps      4.38 Mbps      Bezeq - Tel Aviv
     Amman, JO        41.18 ms    0.0%    10.00 Mbps     10.31 Mbps     Zain Jordan - Amman
     Cairo, EG        189.37 ms   0.0%    9.86 Mbps      11.05 Mbps     Etisalat Misr - Cairo
     Cairo, EG        162.99 ms   0.0%    9.98 Mbps      10.57 Mbps     Vodafone Egypt - Cairo
     Istanbul, TR     FAILED
     Avg DL Speed       : 10.03 Mbps
     Avg UL Speed       : 9.95 Mbps
     Total DL Data      : 0.21 GB
     Total UL Data      : 0.34 GB
     Total Data         : 0.55 GB
     Duration           : 10 min 19 sec
     System Time        : 10/02/2024 - 03:09:21 MSK
     Total Script Runs  : 35611
     Result             : https://result.network-speed.xyz/r/1707522474_SJF38A_MIDDLE-EAST.txt
    Thanked by (1)sh97
    How did you pay in RUB with that conversion? For me it's always 1.09€
    you have to go via justhost.ru the links on LET won't let you pay in RUB.
    It gets converted to EUR/USD for me :( (so around 1.09€)
    Only way to pay with RUB is using Russian payment methods
  • NeoonNeoon OG
    edited February 10
    If you are able to pay in RUB, you only pay 0.71€ but in RUB right, otherwise he charges you more.
  • PrepaidHost
     Basic System Info
     CPU Model          : AMD EPYC 7443 24-Core Processor
     CPU Cores          : 6 @ 2849.998 MHz
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 28.8 GB (4.1 GB Used)
     Total RAM          : 25.4 GB (17.2 GB Used)
     System uptime      : 2 days, 16 hour 10 min
     Load average       : 0.16, 0.67, 0.41
     TCP Control        : cubic
     Basic Network Info
     ISP                : Oliver Horscht is trading as \
     ASN                : AS44486 Oliver Horscht is trading as \
     Host               : Prepaidhost
     ISP: SYNLINQ
     Nearest          3.96 ms     0.0%    1394.07 Mbps   1453.37 Mbps   Stadtwerke Soest GmbH - Soest
     London, UK       17.07 ms    0.0%    41.53 Mbps     663.53 Mbps    M247 Ltd - London
     Manchester, UK   FAILED
     Dublin, IE       FAILED
     Amsterdam, NL    6.75 ms     0.0%    1414.69 Mbps   1455.75 Mbps   Melbicom - Amsterdam
     Eygelshoen, NL   10.84 ms    0.0%    1379.43 Mbps   1301.52 Mbps   SkyLink Data Center BV - Eygelshoven
     Paris, FR        10.81 ms    0.0%    1429.74 Mbps   1281.54 Mbps   ORANGE - Paris
     Marseille, FR    FAILED
     Madrid, ES       28.85 ms    0.0%    1399.37 Mbps   687.45 Mbps    Orange - Jazztel - Madrid
     Lisbon, PT       38.51 ms    0.0%    1400.11 Mbps   486.57 Mbps    Edgoo Networks - Lisbon
     Rome, IT         FAILED
     Milan, IT        FAILED
     Zurich, CH       FAILED
     Berlin, DE       11.51 ms    0.0%    1410.71 Mbps   706.44 Mbps    Misaka Network, Inc. - Berlin
     Vienna, AT       FAILED
     Budapest, HU     14.12 ms    0.0%    1415.58 Mbps   694.22 Mbps    ATW Internet Kft. - Budapest
     Gdansk, PL       FAILED
     Warsaw, PL       FAILED
     Lviv, UA         FAILED
     Kyiv, UA         FAILED
     Minsk, BY        22.59 ms    0.0%    1420.77 Mbps   705.32 Mbps    A1 - Minsk
     Iasi, RO         42.01 ms    0.0%    1413.90 Mbps   378.09 Mbps    Digi
     Helsinki, FI     29.67 ms    0.0%    1390.64 Mbps   584.56 Mbps    Elisa Oyj - Helsinki
     Stockholm, SE    29.05 ms    0.0%    1401.93 Mbps   486.04 Mbps    i3D.net - Stockholm
     Oslo, NO         FAILED
     Moscow, RU       43.53 ms    0.0%    1413.01 Mbps   519.77 Mbps    Rostelecom - Moscow
     Petersburg, RU   32.60 ms    0.0%    1417.16 Mbps   524.38 Mbps    MegaFon - Saint Petersburg
     Istanbul, TR     41.17 ms    0.0%    1421.42 Mbps   412.13 Mbps    Turkcell - Istanbul
     Tbilisi, GE      FAILED
     Avg DL Speed       : 1322.75 Mbps
     Avg UL Speed       : 771.29 Mbps
     Total DL Data      : 24.96 GB
     Total UL Data      : 13.38 GB
     Total Data         : 38.35 GB
     Duration           : 8 min 1 sec
     System Time        : 10/02/2024 - 14:02:49 CET
     Total Script Runs  : 35636
     Result             : https://result.network-speed.xyz/r/1707568875_986NDN_EU.txt
  • MicroLXC Pakistan
     Version            : v2024.02.14
     Basic System Info
     CPU Model          : Common KVM processor
     CPU Cores          : 2 @ 2299.998 MHz
     AES-NI             : ❌ Disabled
     Total Disk         :  ( Used)
     Total RAM          : 122.1 MB (27.1 MB Used)
     System uptime      : 14 days, 19 hour 22 min
     Load average       : 0.06, 0.14, 1.12
     Kernel             : 5.15.0-92-generic
     Virtualization     : LXC
     TCP Control        : cubic
     Basic Network Info
     ISP                : Virtury
     ASN                : AS150315 Virtury Cloud Pakistan
     ISP: Virtury Cloud
     Nearest          1.18 ms     0.0%    19.66 Mbps     100.52 Mbps    Nayatel - Islamabad
     Tokyo, JP        361.47 ms   0.0%    94.62 Mbps     58.24 Mbps     Rakuten Mobile, Inc - Tokyo
     Tapei, TW        376.68 ms   N/A     101.35 Mbps    76.34 Mbps     Chunghwa Mobile - Taipei
     China Unicom     456.50 ms   0.0%    96.18 Mbps     51.93 Mbps     China Unicom 5G - Shanghai
     China Mobile     FAILED
     Hong Kong, CN    131.95 ms   0.0%    101.90 Mbps    92.69 Mbps     i3D.net - Hong Kong
     Ho Chi Minh, VN  115.52 ms   0.0%    100.18 Mbps    98.22 Mbps     CMC Telecom - Ho Chi Minh
     Hanoi, VN        224.17 ms   0.0%    102.40 Mbps    98.26 Mbps     FPT Telecom - Hanoi
     Bangkok, TH      119.42 ms   0.0%    97.97 Mbps     96.41 Mbps     3BB - Bangkok
     Manila, PH       127.83 ms   N/A     97.78 Mbps     93.03 Mbps     PLDT - Manila
     Singapore, SG    95.78 ms    0.0%    97.99 Mbps     97.34 Mbps     MyRepublic Singapore - Singapore
     Singapore, SG    100.55 ms   N/A     97.43 Mbps     98.66 Mbps     StarHub Ltd - Singapore
     Jakarta, ID      130.02 ms   0.0%    101.89 Mbps    98.37 Mbps     PT Indosat Tbk - Jakarta
     Surabaya, ID     119.30 ms   N/A     99.12 Mbps     96.81 Mbps     PT. Indonesia Comnets Plus - Surabaya
     Kuala Lum, MY    214.22 ms   10.3%   99.04 Mbps     73.74 Mbps     Telekom Malaysia Berhad - Kuala Lumpur
     Mumbai, IN       227.77 ms   0.0%    98.02 Mbps     82.58 Mbps     i3D.net - Mumbai
     Chennai, IN      129.05 ms   N/A     99.51 Mbps     96.11 Mbps     Jio - Chennai
     Bangalore, IN    132.19 ms   0.0%    101.66 Mbps    70.08 Mbps     Bharti Airtel Ltd - Bangalore
     Karachi, PK      19.62 ms    0.0%    97.91 Mbps     71.54 Mbps     JAZZ - Karachi
     Islamabad, PK    40.51 ms    0.0%    97.79 Mbps     98.76 Mbps     Ufone - Islamabad
     Kathmandu, NP    178.84 ms   0.0%    100.73 Mbps    92.54 Mbps     Ncell Axiata Ltd - Kathmandu
     Colombo, SL      133.69 ms   N/A     97.71 Mbps     89.82 Mbps     Airtel Lanka - Colombo
     Dhaka, BD        140.34 ms   N/A     97.60 Mbps     96.92 Mbps     Grameenphone Ltd - Dhaka
     Novosibirsk, RU  215.61 ms   0.0%    100.79 Mbps    81.72 Mbps     MegaFon - Novosibirsk
     Almaty, KZ       228.90 ms   0.0%    102.56 Mbps    87.67 Mbps     Kazakhtelecom - Almaty
     Tehran, IR       174.26 ms   0.0%    96.49 Mbps     96.31 Mbps     Irancell - Tehran
     Dubai, AE        36.79 ms    N/A     97.81 Mbps     17.16 Mbps     ETISALAT-UAE - Dubai
     Jeddah, SA       168.70 ms   0.0%    101.50 Mbps    90.06 Mbps     Mobily - Jeddah
     Istanbul, TR     177.91 ms   0.0%    102.58 Mbps    93.73 Mbps     Vodafone TR - Istanbul
     Avg DL Speed       : 96.43 Mbps
     Avg UL Speed       : 85.56 Mbps
     Total DL Data      : 4.12 GB
     Total UL Data      : 3.17 GB
     Total Data         : 7.29 GB
     Duration           : 14 min 34 sec
     System Time        : 14/02/2024 - 13:46:38 UTC
     Total Script Runs  : 35840
     Result             : https://result.network-speed.xyz/r/1707917070_Y1OZWT_ASIA.txt
  • @sh97 I think the cores are wrong, should be 1 not 2.
    The only location that has 2 cores is Norway.
  • 9€/y C1V
     Basic System Info
     CPU Cores          : 2 @ 2399.996 MHz
     AES-NI             : ✔ Enabled
     Total Disk         : 6.7 GB (3.0 GB Used)
     Total RAM          : 1.9 GB (245.5 MB Used)
     Total Swap         : 975.0 MB (0 Used)
     System uptime      : 47 days, 2 hour 2 min
     Load average       : 0.08, 0.03, 0.00
     Kernel             : 6.1.0-11-amd64
     TCP Control        : cubic
     Basic Network Info
     ISP                : Cinzia Tocci trading as C1V
     ASN                : AS212271 Cinzia Tocci trading as C1V
     Host               : C1V Hosting
     Location (IPv4)    : Pomezia, Lazio, IT
     ISP: C1V
     Nearest          7.52 ms     0.0%    247.27 Mbps    257.56 Mbps    Connesi s.p.a. - Foligno
     London, UK       43.32 ms    0.0%    247.99 Mbps    236.33 Mbps    M247 Ltd - London
     Manchester, UK   41.52 ms    N/A     247.45 Mbps    236.68 Mbps    Vodafone UK - Manchester
     Dublin, IE       45.71 ms    0.0%    253.73 Mbps    240.75 Mbps    Three Ireland - Dublin
     Amsterdam, NL    34.08 ms    N/A     246.65 Mbps    80.60 Mbps     Melbicom - Amsterdam
     Eygelshoen, NL   34.90 ms    0.0%    244.34 Mbps    240.17 Mbps    SkyLink Data Center BV - Eygelshoven
     Paris, FR        30.55 ms    0.0%    252.15 Mbps    241.32 Mbps    ORANGE - Paris
     Marseille, FR    31.84 ms    0.0%    245.00 Mbps    4.87 Mbps      GSL Networks - Marseille
     Madrid, ES       41.25 ms    0.0%    251.57 Mbps    201.50 Mbps    Orange - Jazztel - Madrid
     Barcelona, ES    20.46 ms    0.0%    247.64 Mbps    248.52 Mbps    Adamo - Barcelona
     Lisbon, PT       42.45 ms    0.0%    247.82 Mbps    231.53 Mbps    Edgoo Networks - Lisbon
     Rome, IT         44.67 ms    0.0%    260.11 Mbps    239.01 Mbps    TIM SpA - Rome
     Milan, IT        FAILED
     Zurich, CH       32.60 ms    0.0%    247.39 Mbps    234.89 Mbps    Sunrise Communication AG - Zurich
     Frankfurt, DE    32.33 ms    3.1%    246.61 Mbps    8.95 Mbps      Deutsche Telekom - Frankfurt am Main
     Berlin, DE       38.16 ms    0.0%    244.80 Mbps    38.02 Mbps     Misaka Network, Inc. - Berlin
     Vienna, AT       44.24 ms    0.0%    248.62 Mbps    227.28 Mbps    A1 Telekom Austria AG - Vienna
     Budapest, HU     42.56 ms    0.0%    242.75 Mbps    240.51 Mbps    ATW Internet Kft. - Budapest
     Gdansk, PL       53.92 ms    0.9%    246.89 Mbps    8.94 Mbps      T-Mobile Polska S.A. - Gdańsk
     Warsaw, PL       54.27 ms    0.0%    250.26 Mbps    225.29 Mbps    Orange Polska S.A. - Warsaw
     Lviv, UA         57.87 ms    0.0%    244.93 Mbps    201.13 Mbps    Kyivstar - Lviv
     Kyiv, UA         FAILED
     Minsk, BY        48.88 ms    0.0%    254.50 Mbps    232.88 Mbps    A1 - Minsk
     Bucharest, RO    66.22 ms    0.0%    255.47 Mbps    191.19 Mbps    Orange Romania Communications - Bucharest
     Iasi, RO         59.97 ms    0.0%    246.60 Mbps    143.85 Mbps    Digi
     Helsinki, FI     55.86 ms    0.0%    244.85 Mbps    201.43 Mbps    Elisa Oyj - Helsinki
     Stockholm, SE    49.51 ms    0.0%    246.59 Mbps    234.34 Mbps    i3D.net - Stockholm
     Oslo, NO         FAILED
     Moscow, RU       62.08 ms    0.0%    248.89 Mbps    232.49 Mbps    Rostelecom - Moscow
     Petersburg, RU   54.21 ms    0.0%    254.99 Mbps    232.42 Mbps    MegaFon - Saint Petersburg
     Istanbul, TR     FAILED
     Tbilisi, GE      94.73 ms    0.0%    248.14 Mbps    181.00 Mbps    Silknet JSC - Tbilisi
     Avg DL Speed       : 248.71 Mbps
     Avg UL Speed       : 189.05 Mbps
     Total DL Data      : 9.23 GB
     Total UL Data      : 6.45 GB
     Total Data         : 15.67 GB
     Duration           : 12 min 53 sec
     System Time        : 14/02/2024 - 14:41:09 EST
     Total Script Runs  : 35857
     Result             : https://result.network-speed.xyz/r/1707938360_9U1M2B_EU.txt
    Yea, this bug was reported by @febryanvaldo too. Happens very rarely, maybe I'll just use the method which YABS uses to fetch proc info.
    Thanked by (1)febryanvaldo
  • I had some time today, and I noticed a lot of talks about statistics for YABS on OGF, so I was curious if I could do something for network-speed.
    I moved away from FroCDN to share network test results maybe a few weeks before it was shut down to an in-house tech hosted on a Crunchbits Server.
    Below are some stats from the shared (captured) results. 90% code was from GPT as I was lazy, so there might be some inaccuracies.
    Number of tests in each month
    2023-09: 1152
    2023-10: 1104
    2023-11: 1672
    2023-12: 3269
    2024-01: 1343
    2024-02: 742
    Top Regions for Test
    GLOBAL.txt: 6315
    EU.txt: 853
    NA.txt: 776
    CHINA.txt: 422
    ASIA.txt: 417
    INDONESIA.txt: 205
    IRAN.txt: 139
    INDIA.txt: 114
    SA.txt: 95
    MIDDLE-EAST.txt: 58
    AU.txt: 36
    AFRICA.txt: 14
    Top Networks
    AS25846 Cloudnium LLC: 1747 times
    Unknown: 430 times
    AS35916 MULTACOM CORPORATION: 420 times
    AS63473 HostHatch, LLC: 208 times
    AS400304 Redoubt Networks: 205 times
    AS36352 ColoCrossing: 199 times
    AS16276 OVH SAS: 173 times
    AS24940 Hetzner Online GmbH: 149 times
    AS31898 Oracle Corporation: 140 times
    AS9050 ORANGE ROMANIA COMMUNICATION S.A: 137 times
    AS26042 FiberState, LLC: 128 times
    AS210630 IncogNET LLC: 124 times
    Top Locations
    Toronto, Ontario-ON, Canada: 1752 times
    Los Angeles, California-CA, United States: 750 times
    Frankfurt am Main, Hesse-HE, Germany: 283 times
    London, England-ENG, United Kingdom: 266 times
    Amsterdam, North Holland-NH, Netherlands: 206 times
    Liberty Lake, Washington-WA, United States: 173 times
    Tokyo, Tokyo-13, Japan: 170 times
    Singapore, North West-03, Singapore: 160 times
    Helsinki, Uusimaa-18, Finland: 137 times
    Amsterdam, North Holland-NH, The Netherlands: 132 times
    Chicago, Illinois-IL, United States: 130 times
     Version            : v2024.03.07
     Basic System Info
     CPU Model          : Intel(R) Core(TM) i5-8500T CPU @ 2.10GHz
     CPU Cores          : 1 @ 2112.002 MHz
     AES-NI             : ✔ Enabled
     Total Disk         : 9.0 GB (1.2 GB Used)
     Total RAM          : 452.6 MB (135.1 MB Used)
     System uptime      : 0 days, 0 hour 8 min
     Kernel             : 6.1.0-18-amd64
     TCP Control        : cubic
     Basic Network Info
     ISP                : Magna Capax Finland Oy
     ASN                : AS203003 Magna Capax Finland Oy
     Host               : Pulsed-Media
     ISP: Magna Capax Finland Oy
     Nearest          0.91 ms     0.0%    190.84 Mbps    197.87 Mbps    Valoo - Helsinki
     Tokyo, JP        265.80 ms   0.0%    194.72 Mbps    99.95 Mbps     Rakuten Mobile, Inc - Tokyo
     Tapei, TW        311.01 ms   N/A     191.25 Mbps    78.54 Mbps     Chunghwa Mobile - Taipei
     China Telecom    261.35 ms   2.3%    184.25 Mbps    7.87 Mbps      China Telecom JiangSu 5G - Nanjing
     China Unicom     336.91 ms   0.0%    192.43 Mbps    102.96 Mbps    China Unicom 5G - Shanghai
     China Mobile     FAILED
     Hong Kong, CN    137.18 ms   0.0%    193.46 Mbps    119.04 Mbps    i3D.net - Hong Kong
     Ho Chi Minh, VN  FAILED
     Hanoi, VN        239.02 ms   0.0%    167.36 Mbps    80.40 Mbps     FPT Telecom - Hanoi
     Bangkok, TH      208.19 ms   0.0%    195.06 Mbps    104.93 Mbps    3BB - Bangkok
     Manila, PH       282.31 ms   N/A     194.88 Mbps    106.82 Mbps    PLDT - Manila
     Singapore, SG    179.12 ms   0.0%    194.81 Mbps    104.02 Mbps    MyRepublic Singapore - Singapore
     Singapore, SG    177.30 ms   N/A     189.26 Mbps    99.17 Mbps     StarHub Ltd - Singapore
     Jakarta, ID      190.99 ms   0.0%    197.33 Mbps    110.68 Mbps    PT Indosat Tbk - Jakarta
     Surabaya, ID     206.61 ms   N/A     195.40 Mbps    95.27 Mbps     PT. Indonesia Comnets Plus - Surabaya
     Kuala Lum, MY    200.69 ms   0.0%    196.46 Mbps    151.76 Mbps    Telekom Malaysia Berhad - Kuala Lumpur
     Mumbai, IN       154.20 ms   0.0%    193.12 Mbps    150.30 Mbps    i3D.net - Mumbai
     Chennai, IN      172.42 ms   N/A     193.83 Mbps    122.17 Mbps    Jio - Chennai
     Bangalore, IN    175.38 ms   0.0%    193.99 Mbps    142.70 Mbps    Bharti Airtel Ltd - Bangalore
     Karachi, PK      154.96 ms   0.0%    168.32 Mbps    34.89 Mbps     JAZZ - Karachi
     Islamabad, PK    228.37 ms   0.0%    194.13 Mbps    94.77 Mbps     Ufone - Islamabad
     Kathmandu, NP    196.23 ms   0.0%    194.17 Mbps    103.31 Mbps    Ncell Axiata Ltd - Kathmandu
     Colombo, SL      166.37 ms   N/A     197.42 Mbps    121.38 Mbps    Airtel Lanka - Colombo
     Dhaka, BD        227.43 ms   N/A     191.44 Mbps    83.90 Mbps     Grameenphone Ltd - Dhaka
     Novosibirsk, RU  84.40 ms    0.0%    197.48 Mbps    189.56 Mbps    MegaFon - Novosibirsk
     Almaty, KZ       110.90 ms   0.0%    191.11 Mbps    172.68 Mbps    Kazakhtelecom - Almaty
     Tehran, IR       116.17 ms   0.0%    192.54 Mbps    147.33 Mbps    Irancell - Tehran
     Dubai, AE        140.82 ms   N/A     199.66 Mbps    147.79 Mbps    ETISALAT-UAE - Dubai
     Jeddah, SA       118.19 ms   0.0%    199.31 Mbps    127.76 Mbps    Mobily - Jeddah
     Istanbul, TR     68.40 ms    0.0%    192.08 Mbps    185.04 Mbps    Vodafone TR - Istanbul
     Avg DL Speed       : 192.00 Mbps
     Avg UL Speed       : 117.25 Mbps
     Total DL Data      : 8.21 GB
     Total UL Data      : 4.15 GB
     Total Data         : 12.36 GB
     Duration           : 14 min 23 sec
     System Time        : 07/03/2024 - 23:04:29 UTC
     Total Script Runs  : 37308
     Result             : https://result.network-speed.xyz/r/1709851144_GMJ9E0_ASIA.txt
  • Aeza HK
     Basic System Info
     CPU Model          : AMD Ryzen 9 7950X3D 16-Core Processor
     CPU Cores          : 2 @ 4192.080 MHz
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 59.0 GB (1.5 GB Used)
     Total RAM          : 3.8 GB (277.0 MB Used)
     Total Swap         : 512.0 MB (0 Used)
     Load average       : 0.00, 0.08, 0.05
     TCP Control        : bbr
     Basic Network Info
     ISP                : Aeza International LTD
     ASN                : AS210644 AEZA INTERNATIONAL LTD
     Host               : Aeza International LTD
     ISP: Aeza International
     Nearest          0.27 ms     N/A     8165.43 Mbps   8101.12 Mbps   fdcservers.net - Hong Kong
     Tokyo, JP        51.43 ms    0.0%    7965.56 Mbps   1544.89 Mbps   Rakuten Mobile, Inc - Tokyo
     Tapei, TW        56.14 ms    N/A     5696.23 Mbps   1457.01 Mbps   Chunghwa Mobile - Taipei
     China Telecom    205.01 ms   5.5%    6.16 Mbps      197.92 Mbps    China Telecom JiangSu 5G - Nanjing
     China Unicom     94.30 ms    14.0%   3365.51 Mbps   234.57 Mbps    China Unicom 5G - Shanghai
     China Mobile     FAILED
     Hong Kong, CN    0.28 ms     0.0%    8717.96 Mbps   8704.66 Mbps   i3D.net - Hong Kong
     Hanoi, VN        20.70 ms    0.0%    8858.82 Mbps   3959.44 Mbps   FPT Telecom - Hanoi
     Bangkok, TH      58.34 ms    0.0%    5572.92 Mbps   1516.20 Mbps   3BB - Bangkok
     Manila, PH       28.60 ms    N/A     8757.11 Mbps   2210.16 Mbps   PLDT - Manila
     Singapore, SG    40.36 ms    0.0%    8773.04 Mbps   2102.35 Mbps   MyRepublic Singapore - Singapore
     Singapore, SG    43.89 ms    N/A     8165.63 Mbps   2019.16 Mbps   StarHub Ltd - Singapore
     Jakarta, ID      51.08 ms    0.0%    8065.11 Mbps   1341.71 Mbps   PT Indosat Tbk - Jakarta
     Surabaya, ID     56.77 ms    N/A     7289.26 Mbps   1252.58 Mbps   PT. Indonesia Comnets Plus - Surabaya
     Kuala Lum, MY    FAILED
     Mumbai, IN       94.92 ms    0.0%    4271.67 Mbps   883.37 Mbps    i3D.net - Mumbai
     Chennai, IN      80.26 ms    N/A     2663.81 Mbps   854.20 Mbps    Jio - Chennai
     Bangalore, IN    76.74 ms    0.0%    8.60 Mbps      985.87 Mbps    Bharti Airtel Ltd - Bangalore
     Karachi, PK      282.52 ms   0.0%    418.61 Mbps    176.04 Mbps    JAZZ - Karachi
     Islamabad, PK    146.03 ms   0.0%    2021.86 Mbps   535.12 Mbps    Ufone - Islamabad
     Kathmandu, NP    107.02 ms   0.0%    3211.68 Mbps   720.40 Mbps    Ncell Axiata Ltd - Kathmandu
     Colombo, SL      116.16 ms   N/A     2751.37 Mbps   665.19 Mbps    Airtel Lanka - Colombo
     Dhaka, BD        88.14 ms    N/A     3973.71 Mbps   940.74 Mbps    Grameenphone Ltd - Dhaka
     Novosibirsk, RU  296.04 ms   0.0%    158.51 Mbps    197.05 Mbps    MegaFon - Novosibirsk
     Almaty, KZ       69.63 ms    0.0%    2877.62 Mbps   1190.46 Mbps   Kazakhtelecom - Almaty
     Tehran, IR       349.39 ms   0.0%    10.61 Mbps     132.55 Mbps    Irancell - Tehran
     Dubai, AE        104.52 ms   N/A     3842.83 Mbps   385.90 Mbps    ETISALAT-UAE - Dubai
     Jeddah, SA       264.66 ms   3.4%    6.24 Mbps      212.60 Mbps    Mobily - Jeddah
     Istanbul, TR     274.37 ms   0.0%    1384.64 Mbps   278.79 Mbps    Vodafone TR - Istanbul
     Avg DL Speed       : 4333.41 Mbps
     Avg UL Speed       : 1585.19 Mbps
     Total DL Data      : 166.68 GB
     Total UL Data      : 39.02 GB
     Total Data         : 205.70 GB
     Duration           : 14 min 21 sec
     System Time        : 09/03/2024 - 13:24:21 MSK
     Total Script Runs  : 37394
     Result             : https://result.network-speed.xyz/r/1709979767_3FHFW3_ASIA.txt
  • Hi,
    I don't know why most of the download speed is fast, but the upload speed is slow.
    The Avg DL Speed may be several times than Avg DL Data.
    my blog: https://tang.lu
  • Bakker-IT 9.99EUR/yr
     Basic System Info
     AES-NI             : ✔ Enabled
     Total Disk         : 39.3 GB (1012.6 MB Used)
     Total RAM          : 1.9 GB (212.6 MB Used)
     System uptime      : 0 days, 4 hour 3 min
     Load average       : 0.31, 1.21, 1.00
     TCP Control        : cubic
     Basic Network Info
     ISP                : The Mastermind Holding B.V.
     ASN                : AS44103 The Mastermind Holding B.V.
     Host               : The Mastermind Holding B.V
     Location (IPv4)    : Amstelveen, North Holland, NL
     ISP: The Mastermind Holding
     Nearest          2.47 ms     0.0%    5836.47 Mbps   8298.33 Mbps   RETN - Amsterdam
     Kochi, IN        164.61 ms   2.0%    1249.86 Mbps   526.19 Mbps    Asianet Broadband - Cochin
     Bangalore, IN    148.60 ms   5.4%    1161.65 Mbps   609.47 Mbps    Bharti Airtel Ltd - Bangalore
     Chennai, IN      295.68 ms   N/A     1432.73 Mbps   312.58 Mbps    Jio - Chennai
     Mumbai, IN       140.68 ms   4.5%    1810.20 Mbps   477.24 Mbps    i3D.net - Mumbai
     Delhi, IN        142.91 ms   5.2%    430.83 Mbps    469.94 Mbps    Tata Play Fiber - New Delhi
     Seattle, US      136.55 ms   N/A     1391.07 Mbps   630.43 Mbps    Comcast - Seattle, WA
     Los Angeles, US  157.14 ms   3.4%    703.15 Mbps    267.10 Mbps    ReliableSite Hosting - Los Angeles, CA
     Dallas, US       108.47 ms   1.0%    782.46 Mbps    451.41 Mbps    Hivelocity - Dallas, TX
     Miami, US        113.61 ms   N/A     1492.16 Mbps   492.99 Mbps    Dish Wireless - Miami, FL
     New York, US     74.19 ms    2.7%    3691.06 Mbps   1380.10 Mbps   GSL Networks - New York, NY
     Toronto, CA      88.96 ms    4.9%    1841.55 Mbps   1018.24 Mbps   Rogers - Toronto, ON
     Mexico City, MX  248.05 ms   N/A     134.52 Mbps    301.26 Mbps    INFINITUM - Mexico City
     London, UK       8.22 ms     5.4%    4443.84 Mbps   4247.24 Mbps   VeloxServ Communications - London
     Amsterdam, NL    2.58 ms     2.8%    3721.51 Mbps   4547.45 Mbps   31173 Services AB - Amsterdam
     Paris, FR        11.85 ms    N/A     3376.34 Mbps   4470.59 Mbps   Axione - Paris
     Frankfurt, DE    8.39 ms     2.0%    3779.75 Mbps   4103.32 Mbps   Clouvider Ltd - Frankfurt am Main
     Warsaw, PL       19.25 ms    6.2%    4055.37 Mbps   2491.22 Mbps   Play - Warszawa
     Bucharest, RO    36.81 ms    4.0%    1987.03 Mbps   1034.22 Mbps   Vodafone Romania Fixed – Bucharest - Bucharest
     Moscow, RU       37.30 ms    1.9%    4314.88 Mbps   1152.82 Mbps   MegaFon - Moscow
     Jeddah, SA       74.69 ms    2.8%    2912.36 Mbps   1333.37 Mbps   Saudi Telecom Company
     Dubai, AE        135.16 ms   0.0%    2750.28 Mbps   895.45 Mbps    du - Dubai
     Fujairah, AE     117.57 ms   0.0%    2911.05 Mbps   896.57 Mbps    ETISALAT-UAE - Fujairah
     Istanbul, TR     56.99 ms    4.7%    2566.80 Mbps   1743.04 Mbps   Turkcell - Istanbul
     Tehran, IR       88.10 ms    1.9%    2550.47 Mbps   673.44 Mbps    Asiatech - Tehran
     Tokyo, JP        270.85 ms   N/A     1561.19 Mbps   401.21 Mbps    fdcservers.net - Tokyo
     Shanghai, CU-CN  176.86 ms   0.0%    680.96 Mbps    459.96 Mbps    China Unicom 5G - Shanghai
     Hong Kong, CN    199.64 ms   N/A     2952.18 Mbps   312.14 Mbps    STC - Hong Kong
     Singapore, SG    159.53 ms   3.0%    971.90 Mbps    499.39 Mbps    i3D.net - Singapore
     Jakarta, ID      175.26 ms   3.0%    1139.43 Mbps   278.82 Mbps    PT. Telekomunikasi Indonesia - Jakarta
     Avg DL Speed       : 2287.77 Mbps
     Avg UL Speed       : 1492.51 Mbps
     Total DL Data      : 87.21 GB
     Total UL Data      : 68.24 GB
     Total Data         : 155.45 GB
     Duration           : 15 min 9 sec
     System Time        : 14/03/2024 - 04:28:36 UTC
     Total Script Runs  : 37756
     Result             : https://result.network-speed.xyz/r/1710390380_ATYYUG_GLOBAL.txt
    @tanglu said:
    Hi,
    Hi @tanglu! I hear that, when buying internet connectivity, the cost frequently is calculated based only on the upload speed. Fast upload is more expensive. Slower upload is less expensive. Besides more expensive connectivity, faster upload requires more capable, newer, and more expensive equipment. The expensive connectivity and expensive equipment required for fast upload explain why, on the Low End, we frequently see faster download than upload. Others here know a lot more about this than I do. But nobody else was answering your question, so I decided to try. Best wishes! Tom
  • Hi @tanglu! I hear that, when buying internet connectivity, the cost frequently is calculated based only on the upload speed. Fast upload is more expensive. Slower upload is less expensive. Besides more expensive connectivity, faster upload requires more capable, newer, and more expensive equipment. The expensive connectivity and expensive equipment required for fast upload explain why, on the Low End, we frequently see faster download than upload. Others here know a lot more about this than I do. But nobody else was answering your question, so I decided to try. Best wishes! Tom
    I don't agree with you said, I think it's maybe BGP issue
    For example this hetzner network test , on hetzner's German network: https://result.network-speed.xyz/r/1710469112_3KZZVY_GLOBAL.txt
    their upload speed can up to 7Gbps in NL , but the upload speed only 500Mbps in the US and Asia!
    I see the packet loss rate is almost 0, I'm not sure why the upload speed isn't fast for US, and other VPS providers such as aws OVH are same.Though they have connected many Tier1 ISP
  • Just Hosting UAE
     Version            : v2024.03.15
     Basic System Info
     AES-NI             : ✔ Enabled
     Total Disk         : 5.8 GB (2.4 GB Used)
     Total RAM          : 473.3 MB (59.3 MB Used)
     Total Swap         : 1024.0 MB (12.7 MB Used)
     System uptime      : 2 days, 10 hour 11 min
     TCP Control        : cubic
     Basic Network Info
     Nearest          0.71 ms     0.0%    197.76 Mbps    203.83 Mbps    Melbicom - Fujairah
     Tokyo, JP        157.74 ms   0.0%    206.58 Mbps    6.76 Mbps      Rakuten Mobile, Inc - Tokyo
     Tapei, TW        143.88 ms   N/A     202.44 Mbps    163.24 Mbps    Chunghwa Mobile - Taipei
     China Unicom     232.44 ms   0.0%    198.96 Mbps    117.42 Mbps    China Unicom 5G - Shanghai
     China Mobile     138.23 ms   0.0%    198.31 Mbps    158.96 Mbps    China Mobile Zhejiang 5G - Hangzhou
     Hong Kong, CN    109.99 ms   0.0%    199.50 Mbps    160.35 Mbps    i3D.net - Hong Kong
     Ho Chi Minh, VN  103.93 ms   0.0%    196.10 Mbps    170.26 Mbps    VNPT-NET - Ho Chi Minh
     Hanoi, VN        120.41 ms   0.0%    183.66 Mbps    144.32 Mbps    FPT Telecom - Hanoi
     Bangkok, TH      113.82 ms   0.0%    196.57 Mbps    196.66 Mbps    3BB - Bangkok
     Manila, PH       116.47 ms   N/A     194.34 Mbps    164.41 Mbps    PLDT - Manila
     Singapore, SG    73.47 ms    0.0%    197.74 Mbps    194.77 Mbps    MyRepublic Singapore - Singapore
     Singapore, SG    74.02 ms    N/A     198.23 Mbps    193.27 Mbps    StarHub Ltd - Singapore
     Jakarta, ID      186.38 ms   0.0%    196.76 Mbps    108.50 Mbps    PT Indosat Tbk - Jakarta
     Surabaya, ID     99.21 ms    N/A     198.24 Mbps    172.09 Mbps    PT. Indonesia Comnets Plus - Surabaya
     Kuala Lum, MY    233.79 ms   0.0%    198.69 Mbps    132.85 Mbps    Telekom Malaysia Berhad - Kuala Lumpur
     Mumbai, IN       33.10 ms    0.0%    196.35 Mbps    201.53 Mbps    i3D.net - Mumbai
     Chennai, IN      78.01 ms    N/A     196.29 Mbps    191.31 Mbps    Jio - Chennai
     Bangalore, IN    62.48 ms    0.0%    197.65 Mbps    205.51 Mbps    Bharti Airtel Ltd - Bangalore
     Karachi, PK      324.78 ms   0.0%    191.97 Mbps    8.79 Mbps      JAZZ - Karachi
     Islamabad, PK    100.77 ms   0.0%    202.51 Mbps    161.97 Mbps    Ufone - Islamabad
     Kathmandu, NP    125.69 ms   0.0%    198.56 Mbps    142.00 Mbps    Ncell Axiata Ltd - Kathmandu
     Colombo, SL      142.24 ms   N/A     202.23 Mbps    156.90 Mbps    Airtel Lanka - Colombo
     Dhaka, BD        118.14 ms   N/A     197.94 Mbps    177.54 Mbps    Grameenphone Ltd - Dhaka
     Novosibirsk, RU  381.33 ms   0.0%    203.16 Mbps    105.14 Mbps    MegaFon - Novosibirsk
     Almaty, KZ       286.64 ms   0.0%    194.40 Mbps    112.88 Mbps    Kazakhtelecom - Almaty
     Tehran, IR       287.51 ms   0.0%    199.02 Mbps    113.51 Mbps    Irancell - Tehran
     Dubai, AE        3.21 ms     N/A     197.58 Mbps    59.38 Mbps     ETISALAT-UAE - Dubai
     Jeddah, SA       119.27 ms   0.0%    209.84 Mbps    173.41 Mbps    Mobily - Jeddah
     Istanbul, TR     186.80 ms   0.0%    206.81 Mbps    120.90 Mbps    Vodafone TR - Istanbul
     Avg DL Speed       : 198.56 Mbps
     Avg UL Speed       : 145.46 Mbps
     Total DL Data      : 8.47 GB
     Total UL Data      : 5.46 GB
     Total Data         : 13.93 GB
     Duration           : 14 min 50 sec
     System Time        : 22/03/2024 - 08:34:21 MSK
     Total Script Runs  : 39016
     Result             : https://result.network-speed.xyz/r/1711085455_N0BMMN_ASIA.txt
  • IntoVPS Cluj
     Basic System Info
     CPU Cores          : 2 @ 2099.998 MHz
     AES-NI             : ✔ Enabled
     Total Disk         : 19.6 GB (1.7 GB Used)
     Total RAM          : 1.9 GB (247.3 MB Used)
     System uptime      : 0 days, 0 hour 48 min
     Load average       : 0.01, 0.45, 0.52
     Kernel             : 6.1.0-9-amd64
     TCP Control        : cubic
     Basic Network Info
     ISP                : Hosterion SRL
     ASN                : AS43927 HOSTERION SRL
     Host               : Hosterion SRL
     ISP: Hosterion
     Nearest          8.64 ms     0.0%    934.74 Mbps    655.29 Mbps    Nu-Ip.Ro - Ramnicu Valcea
     Kochi, IN        194.16 ms   0.0%    1910.97 Mbps   443.30 Mbps    Asianet Broadband - Cochin
     Bangalore, IN    161.77 ms   0.0%    1917.35 Mbps   518.99 Mbps    Bharti Airtel Ltd - Bangalore
     Chennai, IN      255.18 ms   N/A     1951.34 Mbps   1.05 Mbps      Jio - Chennai
     Mumbai, IN       157.25 ms   0.0%    1745.72 Mbps   564.10 Mbps    i3D.net - Mumbai
     Delhi, IN        182.38 ms   0.0%    1113.14 Mbps   347.84 Mbps    Tata Play Fiber - New Delhi
     Seattle, US      175.99 ms   N/A     1639.67 Mbps   467.43 Mbps    Comcast - Seattle, WA
     Los Angeles, US  160.57 ms   0.0%    1913.21 Mbps   448.29 Mbps    ReliableSite Hosting - Los Angeles, CA
     Dallas, US       134.82 ms   0.0%    1530.11 Mbps   633.16 Mbps    Hivelocity - Dallas, TX
     Miami, US        134.72 ms   N/A     1916.50 Mbps   512.61 Mbps    Dish Wireless - Miami, FL
     New York, US     100.29 ms   0.0%    1249.73 Mbps   668.57 Mbps    GSL Networks - New York, NY
     Toronto, CA      112.76 ms   0.0%    1832.05 Mbps   696.77 Mbps    Rogers - Toronto, ON
     Mexico City, MX  175.04 ms   N/A     1904.21 Mbps   520.23 Mbps    INFINITUM - Mexico City
     London, UK       33.48 ms    0.0%    1836.36 Mbps   574.03 Mbps    VeloxServ Communications - London
     Amsterdam, NL    30.61 ms    0.0%    1266.72 Mbps   692.56 Mbps    31173 Services AB - Amsterdam
     Paris, FR        36.74 ms    N/A     1771.69 Mbps   695.58 Mbps    Axione - Paris
     Frankfurt, DE    21.45 ms    0.0%    1743.27 Mbps   707.44 Mbps    Clouvider Ltd - Frankfurt am Main
     Warsaw, PL       38.10 ms    0.0%    1816.16 Mbps   694.76 Mbps    Play - Warszawa
     Bucharest, RO    6.10 ms     0.0%    1818.89 Mbps   594.33 Mbps    Vodafone Romania Fixed – Bucharest - Bucharest
     Moscow, RU       73.19 ms    0.0%    1845.78 Mbps   704.13 Mbps    MegaFon - Moscow
     Jeddah, SA       91.69 ms    0.0%    1264.41 Mbps   749.97 Mbps    Saudi Telecom Company
     Dubai, AE        149.36 ms   0.0%    1438.33 Mbps   638.22 Mbps    du - Dubai
     Fujairah, AE     141.73 ms   0.0%    1266.78 Mbps   696.76 Mbps    ETISALAT-UAE - Fujairah
     Istanbul, TR     51.19 ms    0.0%    1774.57 Mbps   652.76 Mbps    Turkcell - Istanbul
     Tehran, IR       109.10 ms   0.0%    1741.25 Mbps   687.20 Mbps    Asiatech - Tehran
     Tokyo, JP        277.07 ms   N/A     8.99 Mbps      1.80 Mbps      fdcservers.net - Tokyo
     Shanghai, CU-CN  318.67 ms   11.0%   1826.98 Mbps   271.47 Mbps    China Unicom 5G - Shanghai
     Nanjing, CT-CN   226.92 ms   32.0%   404.40 Mbps    1.34 Mbps      China Telecom JiangSu 5G - Nanjing
     Hong Kong, CN    184.32 ms   N/A     1982.02 Mbps   479.81 Mbps    STC - Hong Kong
     Singapore, SG    496.01 ms   18.7%   1892.18 Mbps   0.55 Mbps      i3D.net - Singapore
     Jakarta, ID      FAILED
     Avg DL Speed       : 1575.26 Mbps
     Avg UL Speed       : 510.68 Mbps
     Total DL Data      : 65.38 GB
     Total UL Data      : 24.69 GB
     Total Data         : 90.07 GB
     Duration           : 15 min 37 sec
     System Time        : 22/03/2024 - 09:12:24 UTC
     Total Script Runs  : 39026
     Result             : https://result.network-speed.xyz/r/1711098536_0376ZJ_GLOBAL.txt
    IntoVPS Bucharest
     Basic System Info
     CPU Model          : AMD EPYC-Rome Processor
     CPU Cores          : 2 @ 2999.998 MHz
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     Total RAM          : 1.9 GB (211.3 MB Used)
     System uptime      : 0 days, 0 hour 20 min
     Load average       : 0.07, 0.48, 0.39
     TCP Control        : cubic
     Basic Network Info
     ISP                : Hosterion SRL
     Location (IPv4)    : Bucharest, București, RO
     ISP: Hosterion
     Nearest          0.56 ms     0.0%    5414.60 Mbps   7347.11 Mbps   INFINITY NETWORK - Bucharest
     Kochi, IN        201.09 ms   0.0%    2462.33 Mbps   443.35 Mbps    Asianet Broadband - Cochin
     Bangalore, IN    181.17 ms   0.0%    2790.56 Mbps   259.33 Mbps    Bharti Airtel Ltd - Bangalore
     Chennai, IN      209.34 ms   N/A     2460.93 Mbps   472.21 Mbps    Jio - Chennai
     Mumbai, IN       199.11 ms   0.0%    2331.80 Mbps   403.46 Mbps    i3D.net - Mumbai
     Delhi, IN        176.65 ms   0.0%    3037.52 Mbps   437.92 Mbps    Tata Play Fiber - New Delhi
     Seattle, US      182.41 ms   N/A     2551.02 Mbps   496.56 Mbps    Comcast - Seattle, WA
     Los Angeles, US  177.63 ms   0.0%    2999.42 Mbps   342.44 Mbps    ReliableSite Hosting - Los Angeles, CA
     Dallas, US       149.86 ms   0.0%    2243.26 Mbps   394.35 Mbps    Hivelocity - Dallas, TX
     Miami, US        145.24 ms   N/A     2235.90 Mbps   546.67 Mbps    Dish Wireless - Miami, FL
     New York, US     110.33 ms   0.0%    3511.54 Mbps   651.14 Mbps    GSL Networks - New York, NY
     Toronto, CA      121.73 ms   0.0%    2637.30 Mbps   750.88 Mbps    Rogers - Toronto, ON
     Mexico City, MX  173.99 ms   N/A     2456.21 Mbps   536.98 Mbps    INFINITUM - Mexico City
     London, UK       42.04 ms    0.0%    5287.10 Mbps   1074.09 Mbps   VeloxServ Communications - London
     Amsterdam, NL    31.46 ms    0.0%    4548.46 Mbps   1980.69 Mbps   31173 Services AB - Amsterdam
     Paris, FR        37.86 ms    N/A     4629.14 Mbps   1283.77 Mbps   Axione - Paris
     Frankfurt, DE    28.21 ms    0.0%    3347.53 Mbps   2942.27 Mbps   Clouvider Ltd - Frankfurt am Main
     Warsaw, PL       42.08 ms    0.0%    4987.94 Mbps   2002.19 Mbps   Play - Warszawa
     Bucharest, RO    1.10 ms     0.0%    7758.08 Mbps   7362.67 Mbps   Vodafone Romania Fixed – Bucharest - Bucharest
     Moscow, RU       73.56 ms    0.0%    5649.89 Mbps   1298.36 Mbps   MegaFon - Moscow
     Jeddah, SA       98.95 ms    0.0%    3711.02 Mbps   1031.02 Mbps   Saudi Telecom Company
     Dubai, AE        293.06 ms   0.0%    2741.92 Mbps   298.00 Mbps    du - Dubai
     Fujairah, AE     221.14 ms   0.0%    2895.67 Mbps   393.04 Mbps    ETISALAT-UAE - Fujairah
     Istanbul, TR     66.93 ms    0.0%    2926.18 Mbps   576.05 Mbps    Turkcell - Istanbul
     Tehran, IR       122.99 ms   0.0%    2885.86 Mbps   574.02 Mbps    Asiatech - Tehran
     Tokyo, JP        267.11 ms   N/A     2883.13 Mbps   1.52 Mbps      fdcservers.net - Tokyo
     Shanghai, CU-CN  258.04 ms   0.0%    1303.84 Mbps   385.86 Mbps    China Unicom 5G - Shanghai
     Nanjing, CT-CN   260.62 ms   77.9%   87.64 Mbps     1.04 Mbps      China Telecom JiangSu 5G - Nanjing
     Hong Kong, CN    193.74 ms   N/A     2612.47 Mbps   452.05 Mbps    STC - Hong Kong
     Singapore, SG    177.27 ms   0.0%    2352.37 Mbps   499.89 Mbps    i3D.net - Singapore
     Jakarta, ID      FAILED
     Avg DL Speed       : 3258.02 Mbps
     Avg UL Speed       : 1174.64 Mbps
     Total DL Data      : 139.51 GB
     Total UL Data      : 39.82 GB
     Total Data         : 179.34 GB
     Duration           : 15 min 20 sec
     System Time        : 22/03/2024 - 09:13:12 UTC
     Total Script Runs  : 39027
     Result             : https://result.network-speed.xyz/r/1711098583_YZXBM8_GLOBAL.txt
    Thanked by (1)sh97
  • host-c Storage, Oradea RO
     Basic Network Info
     ISP                : Andrei Tiberiu Holt
     ASN                : AS211462 Andrei Tiberiu Holt
     Host               : Andrei Tiberiu Holt
     ISP: Andrei Tiberiu Holt
     Nearest          7.21 ms     0.0%    855.38 Mbps    952.67 Mbps    BOCU.ro - Brasov
     London, UK       32.96 ms    0.0%    990.52 Mbps    808.13 Mbps    M247 Ltd - London
     Manchester, UK   35.28 ms    N/A     989.83 Mbps    628.67 Mbps    Vodafone UK - Manchester
     Dublin, IE       44.52 ms    0.0%    1025.36 Mbps   563.69 Mbps    Three Ireland - Dublin
     Amsterdam, NL    32.98 ms    0.0%    981.86 Mbps    705.00 Mbps    Melbicom - Amsterdam
     Eygelshoen, NL   39.44 ms    0.0%    976.95 Mbps    728.04 Mbps    SkyLink Data Center BV - Eygelshoven
     Paris, FR        30.47 ms    N/A     722.86 Mbps    219.01 Mbps    ORANGE FRANCE - Paris
     Marseille, FR    31.70 ms    0.0%    1017.81 Mbps   653.89 Mbps    GSL Networks - Marseille
     Madrid, ES       45.15 ms    0.0%    1006.16 Mbps   562.19 Mbps    Orange - Madrid
     Barcelona, ES    55.24 ms    0.0%    991.70 Mbps    561.52 Mbps    Adamo - Barcelona
     Lisbon, PT       58.92 ms    0.0%    977.91 Mbps    475.16 Mbps    Edgoo Networks - Lisbon
     Rome, IT         46.58 ms    0.0%    1015.49 Mbps   595.30 Mbps    TIM SpA - Rome
     Milan, IT        25.12 ms    0.0%    236.38 Mbps    689.68 Mbps    Fastweb SpA - Milan
     Zurich, CH       27.02 ms    0.5%    987.40 Mbps    669.60 Mbps    Sunrise Communication AG - Zurich
     Frankfurt, DE    21.42 ms    0.0%    992.89 Mbps    706.71 Mbps    Deutsche Telekom - Frankfurt am Main
     Berlin, DE       25.58 ms    0.0%    963.72 Mbps    135.23 Mbps    Misaka Network, Inc. - Berlin
     Vienna, AT       39.86 ms    0.0%    987.34 Mbps    723.82 Mbps    A1 Telekom Austria AG - Vienna
     Budapest, HU     29.75 ms    0.0%    973.63 Mbps    636.43 Mbps    ATW Internet Kft. - Budapest
     Gdansk, PL       47.06 ms    0.0%    853.70 Mbps    554.96 Mbps    T-Mobile Polska S.A. - Gdańsk
     Warsaw, PL       44.98 ms    0.0%    990.56 Mbps    753.46 Mbps    Orange Polska S.A. - Warsaw
     Lviv, UA         58.47 ms    0.0%    996.88 Mbps    566.34 Mbps    Kyivstar - Lviv
     Kyiv, UA         28.22 ms    0.0%    987.46 Mbps    799.55 Mbps    O3 - Kyiv
     Minsk, BY        50.76 ms    0.0%    985.96 Mbps    416.42 Mbps    A1 - Minsk
     Bucharest, RO    41.86 ms    0.0%    983.40 Mbps    858.65 Mbps    Orange Romania SA - Bucuresti
     Timisoara, RO    3.41 ms     0.0%    979.23 Mbps    1033.30 Mbps   Digi
     Helsinki, FI     36.79 ms    0.0%    977.83 Mbps    569.73 Mbps    Elisa Oyj - Helsinki
     Stockholm, SE    54.99 ms    0.0%    985.71 Mbps    446.64 Mbps    i3D.net - Stockholm
     Oslo, NO         52.78 ms    0.0%    997.20 Mbps    583.25 Mbps    Speedtest.net - Oslo
     Moscow, RU       54.34 ms    0.0%    996.29 Mbps    452.88 Mbps    MTS - Moscow
     Petersburg, RU   49.13 ms    0.0%    1010.02 Mbps   592.82 Mbps    MegaFon - Saint Petersburg
     Istanbul, TR     62.05 ms    0.0%    986.80 Mbps    399.32 Mbps    Turkcell - Istanbul
     Tbilisi, GE      77.95 ms    0.0%    985.30 Mbps    408.79 Mbps    Silknet JSC - Tbilisi
     Avg DL Speed       : 950.30 Mbps
     Avg UL Speed       : 607.83 Mbps
     Total DL Data      : 40.68 GB
     Total UL Data      : 24.24 GB
     Total Data         : 64.92 GB
     Duration           : 13 min 27 sec
     System Time        : 29/03/2024 - 10:20:03 UTC
     Total Script Runs  : 39441
    Thanked by (1)host_c
  • edited April 1
    lapua@xxxFFM:~# curl -sL network-speed.xyz | bash -s -- -r eu
    bash: line 1: error: command not found
    @sh97
    @crunchbits
