Static Routed /48 to OpenWRT under CGNAT via WireGuard
Just like the title suggests. I want a static routed v6 /48 to my home router via WireGuard.
Here are a few things I have thought:
1. Adding a static route as routing v6 to router wireguard v6
2. Just doing a NAT though I really don't want to do that.
Idea is to make something like Route48.
All of my VMs: https://nodecheck.net/s/otusibrc/
Talk to @Cloudie before you attempt this endeavor
Since you have ASN, it's easy.
HostBrr aff best VPS.
We are impotent.
Do I add the IP to the wg0 dev or my ens3 dev?
Neither side needs any address on the WireGuard interface or WAN interface.
You would need one address from your prefix on the LAN interface of the home router.
You can assign other addresses within the subnet to your LAN devices.
We are impotent.
This is the way
Can I just then follow my guide on running Wireguard on OpenWRT (which I wrote for R48)
Apparently not, ugh.
Managed to kill/OOM my Vultr, ugh.
