@jgo24 said: For your information I don't know latin. Why do you think brother that i know latin?
You wrote "N.B."
@jgo24 said: N.B.: And also reactivate my MetalVPS account when you think it's best for me.
[N.B. means "Note well."](https://en.wikipedia.org/wiki/Nota_bene#:~:text=Nota bene (%2F%CB%88no%CA%8A,appeared%20in%20English%20writing%20c.) I have seeen "N.B." in English, but only rarely in today's English. As mentioned in the linked Wikipedia article, "N.B." is derived from Latin. So I imagined that you might have studied some Latin. Like I did, bro!
It's our regular practice (using N.B) in English. I meant in my country. I know it's derived from latin. But we use it as it's an original english 😁😁
Yes. Same in American English. People use N.B. as American English just like you said. Thanks!
@babywhale said: It looks like it has something to do with iperf3, i did a little research and found that people have gotten this type of error before...
Oh yes! Only now do I remember that Mason might have said something about yabs using a "Holy Build Box" iperf3 when iperf3 wasn't installed. Maybe if we install the system's expected iperf3 and the yabs will run fine. I will check this out when I get a chance, maybe tomorrow.
@subenhon If you get a chance, maybe you might try installing iperf3 inside your VPS and running yabs again?
Also, do you want a bashvm VPS in addition to the VPS you already have? I'd be delighgted to make another VPS for you! Long term, you can keep whichever VPS you like best, or keep both if you want. But, if you are happy with the VPS you have, that's just fine keep it the way it is.
Hello again! I installed the expected apt iperf3 package in my test VM and re-ran yabs. Yabs ran okay this time! No segfaults. Yaaay! Disk I/O still shows a little more virtualization penalty than I like. Why? How to fix? Network speeds seem a little slower, but it's the busy time of day. Thanks to @babywhale for giving me a great hint about the segfault! Also for wonderful bashvm! Thanks to @crunchbits for wonderful Crunchy!
root@vm1-crunchy:~# curl -sL yabs.sh | bash
# Yet-Another-Bench-Script #
# v2024-01-01 #
Mon Feb 26 04:53:18 UTC 2024
Uptime : 0 days, 1 hours, 54 minutes
Processor : Intel(R) Xeon(R) CPU E3-1245 v5 @ 3.50GHz
CPU cores : 2 @ 3503.982 MHz
AES-NI : ✔ Enabled
RAM : 1.9 GiB
Swap : 0.0 KiB
Disk : 19.6 GiB
Kernel : 6.1.0-18-amd64
VM Type : KVM
ISP : Redoubt Networks
ASN : AS400304 Redoubt Networks
Host : Crunchbits LLC
Country : United States
Read | 191.82 MB/s (47.9k) | 2.10 GB/s (32.8k)
Write | 192.33 MB/s (48.0k) | 2.11 GB/s (32.9k)
Total | 384.16 MB/s (96.0k) | 4.21 GB/s (65.7k)
Read | 3.14 GB/s (6.1k) | 3.77 GB/s (3.6k)
Write | 3.31 GB/s (6.4k) | 4.02 GB/s (3.9k)
Total | 6.46 GB/s (12.6k) | 7.79 GB/s (7.6k)
Clouvider | London, UK (10G) | 707 Mbits/sec | 217 Mbits/sec | 135 ms
Scaleway | Paris, FR (10G) | 766 Mbits/sec | 573 Mbits/sec | 142 ms
NovoServe | North Holland, NL (40G) | 792 Mbits/sec | 594 Mbits/sec | 139 ms
Uztelecom | Tashkent, UZ (10G) | 549 Mbits/sec | 167 Mbits/sec | 225 ms
Clouvider | NYC, NY, US (10G) | 133 Mbits/sec | 342 Mbits/sec | 70.6 ms
Clouvider | Dallas, TX, US (10G) | 843 Mbits/sec | 303 Mbits/sec | 74.6 ms
Clouvider | Los Angeles, CA, US (10G) | 913 Mbits/sec | 720 Mbits/sec | 41.2 ms
Clouvider | London, UK (10G) | 755 Mbits/sec | 194 Mbits/sec | 135 ms
Scaleway | Paris, FR (10G) | busy | 557 Mbits/sec | 142 ms
NovoServe | North Holland, NL (40G) | 692 Mbits/sec | 584 Mbits/sec | 139 ms
Uztelecom | Tashkent, UZ (10G) | busy | busy | 378 ms
Clouvider | NYC, NY, US (10G) | 867 Mbits/sec | 217 Mbits/sec | 70.6 ms
Clouvider | Dallas, TX, US (10G) | 845 Mbits/sec | 356 Mbits/sec | 74.6 ms
Clouvider | Los Angeles, CA, US (10G) | 904 Mbits/sec | 609 Mbits/sec | 41.3 ms
Test | Value
Single Core | 1437
Multi Core | 2522
Full Test | https://browser.geekbench.com/v6/cpu/5072870
YABS completed in 15 min 3 sec
root@vm1-crunchy:~#
@babywhale's bashvm, has been working great on a couple of MetalVPS test servers over at Redacted. One test server has been running Debian 12 and the other test server has been running Ubuntu 22.04 LTS.
Today bashvm was installed here on Crunchy! Now bashvm VMs are available here on Crunchy in addition to VMs hand made with direct calls to Qemu.
@babywhale's bashvm provides a bash shell scripted menu interface to libvirt. Even a clueless™ guy can call bash bashvm.sh and then enter 1 and then 10 to automatically create a Debian KVM VPS with 2 cores, 2 GB RAM, and 20 GB disk. The automatic bashvm VMs get ssh port forwarded plus 20 additional IPv4 ports. They also get an IPv6/128.
bashvm has additional options for creating KVM VMs manually from an ISO, increasing the resources of a VM, etc.
Since bashvm is accessed via ssh into the Node, (1) bashvm doesn't require much overhead, and (2) bashvm may be less susceptible to external attack than VPS creation tools which require, for example, a web server and PHP.
Thanks to @babywhale for working so hard on bashvm! And for making bashvm Open Source under the MIT license!
After installing native fio on both our Crunchy Node and the test VM, Node 4k IOPS seems down from about 146k to 124k. Test VM 4k IOPS seems down slightly from 95.4k to 90.3k.
@Not_Oles said If you get a chance, maybe you might try installing iperf3 inside your VPS and running yabs again?
After installed iperf3,here is the result of yabs.
According to the result, the VPS you created has better performance.
Intresting! I must missing something when I configurate the VPS.
The bashvm is really wonderful!
It is very happy to have a bashvm VPS in addition,Thanks! @Not_Oles
# v2024-01-01 #
Mon 26 Feb 2024 01:03:37 AM CST
Uptime : 0 days, 3 hours, 51 minutes
Processor : QEMU Virtual CPU version 2.5+
CPU cores : 4 @ 3503.982 MHz
AES-NI : â Disabled
VM-x/AMD-V : â Disabled
RAM : 3.8 GiB
Swap : 2.0 GiB
Disk : 97.9 GiB
Distro : Ubuntu 20.04.6 LTS
Kernel : 5.15.0-97-generic
VM Type : KVM
IPv4/IPv6 : â Online / â Online
Host : Atomic Networks LLC
Preparing system for disk tests...
[0KGenerating fio test file...
[0KRunning fio random mixed R+W disk test with 4k block size...
[0KRunning fio random mixed R+W disk test with 64k block size...
[0KRunning fio random mixed R+W disk test with 512k block size...
[0KRunning fio random mixed R+W disk test with 1m block size...
[0Kfio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda5):
Read | 7.65 MB/s (1.9k) | 91.39 MB/s (1.4k)
Write | 7.68 MB/s (1.9k) | 91.87 MB/s (1.4k)
Total | 15.33 MB/s (3.8k) | 183.27 MB/s (2.8k)
Read | 388.52 MB/s (758) | 315.64 MB/s (308)
Write | 409.17 MB/s (799) | 336.66 MB/s (328)
Total | 797.69 MB/s (1.5k) | 652.30 MB/s (636)
Performing IPv4 iperf3 send test to Clouvider (Attempt #1 of 3)...
[0KPerforming IPv4 iperf3 recv test from Clouvider (Attempt #1 of 3)...
[0KPerforming IPv4 iperf3 recv test from Clouvider (Attempt #2 of 3)...
[0KPerforming IPv4 iperf3 recv test from Clouvider (Attempt #3 of 3)...
[0KClouvider | London, UK (10G) | 837 Mbits/sec | 221 Mbits/sec | 129 ms
Performing IPv4 iperf3 send test to Scaleway (Attempt #1 of 3)...
[0KPerforming IPv4 iperf3 send test to Scaleway (Attempt #2 of 3)...
[0KPerforming IPv4 iperf3 send test to Scaleway (Attempt #3 of 3)...
[0KPerforming IPv4 iperf3 recv test from Scaleway (Attempt #1 of 3)...
[0KScaleway | Paris, FR (10G) | 827 Mbits/sec | 563 Mbits/sec | 142 ms
Performing IPv4 iperf3 send test to NovoServe (Attempt #1 of 3)...
[0KPerforming IPv4 iperf3 recv test from NovoServe (Attempt #1 of 3)...
[0KNovoServe | North Holland, NL (40G) | 835 Mbits/sec | 580 Mbits/sec | 134 ms
Performing IPv4 iperf3 send test to Uztelecom (Attempt #1 of 3)...
[0KPerforming IPv4 iperf3 send test to Uztelecom (Attempt #2 of 3)...
[0KPerforming IPv4 iperf3 recv test from Uztelecom (Attempt #1 of 3)...
[0KUztelecom | Tashkent, UZ (10G) | 729 Mbits/sec | 144 Mbits/sec | 245 ms
[0KPerforming IPv4 iperf3 send test to Clouvider (Attempt #2 of 3)...
[0KPerforming IPv4 iperf3 send test to Clouvider (Attempt #3 of 3)...
[0KClouvider | NYC, NY, US (10G) | 896 Mbits/sec | 297 Mbits/sec | 63.3 ms
[0KClouvider | Dallas, TX, US (10G) | 896 Mbits/sec | 399 Mbits/sec | 60.4 ms
[0KClouvider | Los Angeles, CA, US (10G) | 914 Mbits/sec | 603 Mbits/sec | 41.3 ms
Performing IPv6 iperf3 send test to Clouvider (Attempt #1 of 3)...
[0KPerforming IPv6 iperf3 recv test from Clouvider (Attempt #1 of 3)...
[0KClouvider | London, UK (10G) | 820 Mbits/sec | 224 Mbits/sec | 128 ms
Performing IPv6 iperf3 send test to Scaleway (Attempt #1 of 3)...
[0KPerforming IPv6 iperf3 recv test from Scaleway (Attempt #1 of 3)...
[0KPerforming IPv6 iperf3 recv test from Scaleway (Attempt #2 of 3)...
[0KScaleway | Paris, FR (10G) | 814 Mbits/sec | 554 Mbits/sec | --
Performing IPv6 iperf3 send test to NovoServe (Attempt #1 of 3)...
[0KPerforming IPv6 iperf3 recv test from NovoServe (Attempt #1 of 3)...
[0KNovoServe | North Holland, NL (40G) | 826 Mbits/sec | 559 Mbits/sec | 134 ms
Performing IPv6 iperf3 send test to Uztelecom (Attempt #1 of 3)...
[0KPerforming IPv6 iperf3 send test to Uztelecom (Attempt #2 of 3)...
[0KPerforming IPv6 iperf3 send test to Uztelecom (Attempt #3 of 3)...
[0KPerforming IPv6 iperf3 recv test from Uztelecom (Attempt #1 of 3)...
[0KUztelecom | Tashkent, UZ (10G) | busy | 888 Kbits/sec | 245 ms
[0KClouvider | NYC, NY, US (10G) | 877 Mbits/sec | 211 Mbits/sec | 62.8 ms
[0KClouvider | Dallas, TX, US (10G) | 881 Mbits/sec | 407 Mbits/sec | 60.1 ms
[0KClouvider | Los Angeles, CA, US (10G) | 905 Mbits/sec | 783 Mbits/sec | 41.0 ms
Running GB6 benchmark test... *cue elevator music*
[0KGeekbench 6 Benchmark Test:
Test | Value
Single Core | 823
Multi Core | 2449
Full Test | https://browser.geekbench.com/v6/cpu/5073918
YABS completed in 17 min 54 sec
Thanks for installing iperf3 and for running the yabs!
I did not see anything missing in your VM configuration. I think you did a great job!
Yesterday's new VPS with better performance was made with bashvm. bashvm used virsh to talk to libvirt. libvirt then talked with qemu in a very complicated way.
The VPS previously made was done directly with qemu in a way that is wonderfully simple. Here is an old example of the beautiful simplicity:
Faster with -enable-kvm but still works well enough for many purposes even without KVM.
Launch the VM inside tmux if you want to be able to leave with the VPS still running. . . . Ctrl-b, d to detatch from the tmux session. Ctrl-b, x to leave and kill the tmux session. tmux attach to get back into a running session.
No default password for root VM user. Just enter "root" for the user and then press enter for the password.
You can do all kinds of things, such as change the memory, number of cores, add a second disk, increase disk size, add IPv6, sshd, port forwarding, etc.
I am sure there are many benefits from a more complicated libvirt based approach, such as faster performance, nice HTML interface, etc. Maybe some genius could do a bash script menu thing, where all someone would need to do is press 1 and then 10.
A few minutes ago, on Crunchy:
Debian GNU/Linux trixie/sid localhost ttyS0
localhost login: root
Linux localhost 6.6.15-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.6.15-2 (2024-02-04) x86_64
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
root@localhost:~# date -u
Tue Feb 27 01:53:34 UTC 2024
root@localhost:~#
You of course see that the checkmark ✔ is rendered as "â" on whatever system you are using to connect to your VM. I am guessing that your local system might not be using a UTF-8 character encoding which your VPS might be expecting.
Another alternative might be to change the encoding on your VPS so that the VPS encoding matches whatever you are using to connect.
There also are extra lines in the yabs output which you are posting. Those extra lines also might be fixed if you can get the character encodings to match in your viewer and in your VPS.
@subenhon I made you a Debian VPS. Sent login info by PM. We can make another VPS, a bigger one, or one with a different OS. You can try making one yourself, of course. Have fun!
# Make second VPS for @subenhon
root@crunchy:~/bashvm# date
Tue Feb 27 02:43:21 AM UTC 2024
root@crunchy:~/bashvm# bash bashvm.sh
========================== Main Menu ==========================
1. Virtual Machines 2. Storage Pools 3. Networks
4. Snapshots 5. Edit Properties 6. Firewall Settings
7. Port Forwarding 8. System Monitor q. Exit
Enter your choice: 1
==================== Manage Virtual Machine ====================
s. Show all virtual machines 1. Show more details of a VM
2. Start a VM 3. Reboot a VM
4. Shutdown a VM (graceful) 5. Shutdown a VM (force)
6. Enable autostart of a VM 7. Disable autostart of a VM
8. Create a new / existing VM 9. Undefine a VM
10.Create a new VM (Automated) 11.Console into a VM
12.Change resources of a VM q. Back to main menu
Enter your choice: 10
This will create a debian12 VM with (2 vcores, 2GB ram, 20GB disk)
Press Enter to confirm this is what you want or q to exit
Enter the hostname of the new VM: vm2-crunchy
Enter the username for the new VM: XXXX
Enter the password for the new VM: Redacted
Starting download of debian 12 cloud image...
File debian-12-generic-amd64.qcow2 already there. Canceling re-download...
Starting install...
Allocating 'vm2-crunchy.qcow2' | 0 B 00:00:00 ...
Creating domain... | 0 B 00:00:00
Domain creation completed.
Setting DHCP reservation...
Updated network default persistent config and live state
Setting Port Forwarding...
Restarting vm...
Waiting for vm2-crunchy to shutdown...
Domain 'vm2-crunchy' started
========== Info for vm2-crunchy ==========
IPv4: 192.168.XXX.XXX
SSH port: XXXXX
Ports: XXXXX to XXXXX
Username: XXXX
Password: XXXXXXXXXXXXXXXX
Info for vm2-crunchy has been saved to redacted.txt
You may need to restart libvirtd, networking and the vm for the changes to take effect
Enter your choice: 11
Enter the VM name to console into: vm2-crunchy
Connected to domain 'vm2-crunchy'
Escape character is ^] (Ctrl + ])
vm2-crunchy login: XXXX
Password:
Linux vm2-crunchy 6.1.0-18-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.76-1 (2024-02-01) x86_64
XXXX@vm2-crunchy:~$ date -u
Tue Feb 27 02:48:30 UTC 2024
XXXX@vm2-crunchy:~$ curl icanhazip.com
Redacted::XXXX
XXXX@vm2-crunchy:~$ curl -4 icanhazip.com
XXX.XXX.XXX.XXX
XXXX@vm2-crunchy:~$
ssh into the VM works as soon as the authorized keys are added.
@Not_Oles said: You of course see that the checkmark ✔ is rendered as "â" on whatever system you are using to connect to your VM. I am guessing that your local system might not be using a UTF-8 character encoding which your VPS might be expecting.
The VM can be started by an unprivileged user (no sudo needed) with this command (but, please shutdown the VM and leave the VM off while resizing on the Node):
root@localhost:~# df -h .
Filesystem Size Used Avail Use% Mounted on
/dev/sda1 1.9G 913M 827M 53% /
root@localhost:~# growpart /dev/sda 1 # growpart needs a space between a and 1.
CHANGED: partition=1 start=262144 old: size=3930112 end=4192255 new: size=209453023 end=209715166
root@localhost:~# df -h . # Disk size does not change until after the reboot shown below.
root@localhost:~#
So I was wondering just how horribly horrible a yabs would look on an unprivileged user's non-KVM and Qemu default slirp networking VPS. Turns out to be very interesting, doesn't it? File I/O is slow, Geekbench 6 is . . . uh! . . . the lowest I've seen, but network connectivity seems reasonably okay, but slower.
I couldn't believe how long it took to run the yabs! I bumped the memory up from 1G to 2G, because, initially, when the Geekbench didn't complete, and didn't complete, and didn't complete, I just assumed that the system had frozen. But, the yabs eventually completed.
Here's the command used to start the VM in which the yabs was run:
root@localhost:~# ip -6 a s
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 state UNKNOWN qlen 1000
inet6 ::1/128 scope host noprefixroute
2: ens3: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 state UP qlen 1000
inet6 fec0::5054:ff:fe12:3456/64 scope site dynamic mngtmpaddr noprefixroute
valid_lft 86107sec preferred_lft 14107sec
inet6 fe80::5054:ff:fe12:3456/64 scope link proto kernel_ll
root@localhost:~# curl -6 icanhazip.com
Redacted (IPv6 Node address)
root@localhost:~#
Next thing to try might be rerunning the yabs with 1G RAM, be more patient, and see if it completes. Then activating KVM and seeing what difference that makes. We could also change from the "emulated" -hda to a faster "virtualized" disk.
root@localhost:~# # yabs in slirp non-KVM VM on Crunchy
Tue Feb 27 21:15:53 UTC 2024
root@localhost:~# curl -sL yabs.sh | bash
# v2024-01-01 #
Tue Feb 27 21:16:05 UTC 2024
qemu-system-x86_64: Slirp: external icmpv6 not supported yet
Uptime : 0 days, 0 hours, 44 minutes
CPU cores : 1 @ 3503.937 MHz
AES-NI : ❌ Disabled
RAM : 1.9 GiB
Swap : 0.0 KiB
Disk : 98.4 GiB
Distro : Debian GNU/Linux trixie/sid
Kernel : 6.6.15-amd64
VM Type : QEMU
Read | 7.04 MB/s (1.7k) | 94.81 MB/s (1.4k)
Write | 7.07 MB/s (1.7k) | 95.31 MB/s (1.4k)
Total | 14.12 MB/s (3.5k) | 190.12 MB/s (2.9k)
Read | 496.20 MB/s (969) | 392.94 MB/s (383)
Write | 522.57 MB/s (1.0k) | 419.11 MB/s (409)
Total | 1.01 GB/s (1.9k) | 812.06 MB/s (792)
Clouvider | London, UK (10G) | 526 Mbits/sec | 294 Mbits/sec | 152 ms
Scaleway | Paris, FR (10G) | busy | busy | 161 ms
NovoServe | North Holland, NL (40G) | 531 Mbits/sec | 524 Mbits/sec | 150 ms
Uztelecom | Tashkent, UZ (10G) | 548 Mbits/sec | 145 Mbits/sec | 252 ms
Clouvider | NYC, NY, US (10G) | 603 Mbits/sec | 269 Mbits/sec | 76.5 ms
Clouvider | Dallas, TX, US (10G) | 614 Mbits/sec | 277 Mbits/sec | 65.6 ms
Clouvider | Los Angeles, CA, US (10G) | 682 Mbits/sec | 668 Mbits/sec | 37.9 ms
Clouvider | London, UK (10G) | 389 Mbits/sec | 248 Mbits/sec | 151 ms
Scaleway | Paris, FR (10G) | busy | busy | --
NovoServe | North Holland, NL (40G) | 466 Mbits/sec | 532 Mbits/sec | 150 ms
Uztelecom | Tashkent, UZ (10G) | 456 Mbits/sec | 148 Mbits/sec | 252 ms
Clouvider | NYC, NY, US (10G) | 490 Mbits/sec | 306 Mbits/sec | 76.9 ms
Clouvider | Dallas, TX, US (10G) | 379 Mbits/sec | 339 Mbits/sec | 65.6 ms
Clouvider | Los Angeles, CA, US (10G) | 465 Mbits/sec | 568 Mbits/sec | 38.0 ms
Test | Value
Single Core | 41
Multi Core | 41
Full Test | https://browser.geekbench.com/v6/cpu/5097912
YABS completed in 380 min 11 sec
root@localhost:~#
bashvm works via libvirt. Libvirt is a virtualization API that provides an interface to qemu. Trying bashvm got me interested in looking a little more into the interaction between libvirt and qemu. Conveniently, the libvirt wiki has a page correlating qemu command line options with libvirt XML configuration elements.
How do the libvirt and the qemu development communities co-ordinate? Are there developers who work on both libvirt and on qemu? Do we have anyone here at LES who is invloved with either or both libvirt and qemu development?
Maybe I can learn a little of the answers to my questions by checking the libvirt and qemu source repositories and mailing list and irc archives. But if some kind and knowledgeable person here could please comment, I would be grateful. Thank you!
@subenhon When you have time, please let me know how it's going with your new, second VPS that was made with bashvm. Have you had a chance to try it?
Also, how is it going with your original VPS that you made yourself?
I have continued testing bashvm. Maybe I could make several more bashvm VPSes on Crunchy. If I did make more Crunchy VPSes, maybe some awesome LESbians might want them. I could make them a little bigger, say 4 vcores, 4 GB RAM, 400 or more GB disk. I could make them either Debian or Ubuntu. It's certainly okay to keep both your VPSes as they are now, but would you like to trade either your original or your new VPS for a new, bigger bashvm VPS? If yes, do you want Debian or Ubuntu?
Thanks @subenhon! Thanks to @crunchbits for wonderful Crunchy! And thanks to any awesome LESbians who might want to try a MetalVPS VPS on Crunchy.
@subenhon Yes, you have a good life because you are interested in many good things. I am glad to hear! Thanks for posting. I look forward to hearing more when the time is right!
In other news, I have continued testing bashvm. I have two Debian and two NetBSD VMs running on one of my Redacted test servers. These VMs were made with bashvm. I look forward to making more VMs on Crunchy! Thanks @crunchbits!
The MetalVPS test NAT VPSes at Redacted continue working well! Thanks @babywhale for wonderful bashvm, which was used to make the test NAT VPSes.
I have the idea to make available four 2 core, 4 GB ECC RAM, 1000GB SSD RAID 10, MetalVPS bashvm Debian 12 NAT IPv4 plus IPv6 VPSes on Crunchy!
To get additional identity information, and thereby discourage abuse, I might charge $1.01 for each VPS, paid once, for the entire remaining period until November. A new Offer thread might be needed, since this thread is in the Free Offers category.
Lots of sites seem to say that the Paypal minimum charge is $0.01. But, on paypal.com itself, the only minimum number I found in a quick search was $1.01. If you happen to have a link on paypal.com where it says a minimum that is lower than $1.01, please post the link.
All Crunchy offers in this thread are hereby withdrawn. Of course, @subenhon is more than welcome to continue using his free Crunchy VPSes.
Today, it's peaceful, sunny, not too cold, and not too hot here in the Sonoran Desert. Breezy. Blue sky. ¡Perfecto! Hope everyone at LES also enjoys a wonderful weekend!
Thanks @crunchbits for wonderful Crunchy! Thanks, wonderful LES!
Isn't paypal fee based on the currency and transaction mode? For personal transfer, if no currency is involved, there is no transaction fee. Moreover personal transfers also are protected against chargebacks as the money goes from their account to yours (i could be wrong here). So it's better for you if the user "sends" you the money and not "pay" you.
Thanks! I could be wrong, but I think my MetalVPS account is a business account, not a personal account. Free transfers to business accounts went away a year or so ago? Something like that?
@babywhale
Here's a bit more from
dmesg.If you want on the server, let me know, and I will drop your key in there.
Thanks!
 Thanks!
Get a free VPS! - freevps.org
bashvm - CLI VM Manager - bashvm.com
Great catch @babywhale!
thats good you solved it
Yeah, but, really, I don't think I would have got it if you hadn't commented about research showing other people got the same error.
Introduction to bashvm
bash bashvm.shand then enter 1 and then 10 to automatically create a Debian KVM VPS with 2 cores, 2 GB RAM, and 20 GB disk. The automatic bashvm VMs get ssh port forwarded plus 20 additional IPv4 ports. They also get an IPv6/128.bashvm has additional options for creating KVM VMs manually from an ISO, increasing the resources of a VM, etc.
Effect of installing native fio
@Not_Oles
Here is the actual, complicated command for the new vm1-crunchy that was made yesterday. You can see that libvirt is talking with qemu:
libvirt+ 9139 2.5 3.3 6735256 2212652 ? Sl Feb26 33:05 /usr/bin/qemu-system-x86_64 -name guest=vm1-crunchy,debug-threads=on -S -object {"qom-type":"secret","id":"masterKey0","format":"raw","file":"/var/lib/libvirt/qemu/domain-2-vm1-crunchy/master-key.aes"} -machine pc-q35-6.2,usb=off,vmport=off,dump-guest-core=off,memory-backend=pc.ram -accel kvm -cpu host,migratable=on -m 2048 -object {"qom-type":"memory-backend-ram","id":"pc.ram","size":2147483648} -overcommit mem-lock=off -smp 2,sockets=2,cores=1,threads=1 -uuid 82a54a42-8427-468d-8261-adc82142c560 -no-user-config -nodefaults -chardev socket,id=charmonitor,fd=33,server=on,wait=off -mon chardev=charmonitor,id=monitor,mode=control -rtc base=utc,driftfix=slew -global kvm-pit.lost_tick_policy=delay -no-hpet -no-shutdown -global ICH9-LPC.disable_s3=1 -global ICH9-LPC.disable_s4=1 -boot strict=on -device pcie-root-port,port=16,chassis=1,id=pci.1,bus=pcie.0,multifunction=on,addr=0x2 -device pcie-root-port,port=17,chassis=2,id=pci.2,bus=pcie.0,addr=0x2.0x1 -device pcie-root-port,port=18,chassis=3,id=pci.3,bus=pcie.0,addr=0x2.0x2 -device pcie-root-port,port=19,chassis=4,id=pci.4,bus=pcie.0,addr=0x2.0x3 -device pcie-root-port,port=20,chassis=5,id=pci.5,bus=pcie.0,addr=0x2.0x4 -device pcie-root-port,port=21,chassis=6,id=pci.6,bus=pcie.0,addr=0x2.0x5 -device pcie-root-port,port=22,chassis=7,id=pci.7,bus=pcie.0,addr=0x2.0x6 -device pcie-root-port,port=23,chassis=8,id=pci.8,bus=pcie.0,addr=0x2.0x7 -device pcie-root-port,port=24,chassis=9,id=pci.9,bus=pcie.0,multifunction=on,addr=0x3 -device pcie-root-port,port=25,chassis=10,id=pci.10,bus=pcie.0,addr=0x3.0x1 -device pcie-root-port,port=26,chassis=11,id=pci.11,bus=pcie.0,addr=0x3.0x2 -device pcie-root-port,port=27,chassis=12,id=pci.12,bus=pcie.0,addr=0x3.0x3 -device pcie-root-port,port=28,chassis=13,id=pci.13,bus=pcie.0,addr=0x3.0x4 -device pcie-root-port,port=29,chassis=14,id=pci.14,bus=pcie.0,addr=0x3.0x5 -device qemu-xhci,p2=15,p3=15,id=usb,bus=pci.2,addr=0x0 -device virtio-serial-pci,id=virtio-serial0,bus=pci.3,addr=0x0 -blockdev {"driver":"file","filename":"/var/lib/libvirt/images/debian-12-generic-amd64.qcow2","node-name":"libvirt-3-storage","auto-read-only":true,"discard":"unmap"} -blockdev {"node-name":"libvirt-3-format","read-only":true,"discard":"unmap","driver":"qcow2","file":"libvirt-3-storage","backing":null} -blockdev {"driver":"file","filename":"/var/lib/libvirt/images/vm1-crunchy.qcow2","node-name":"libvirt-2-storage","auto-read-only":true,"discard":"unmap"} -blockdev {"node-name":"libvirt-2-format","read-only":false,"discard":"unmap","driver":"qcow2","file":"libvirt-2-storage","backing":"libvirt-3-format"} -device virtio-blk-pci,bus=pci.4,addr=0x0,drive=libvirt-2-format,id=virtio-disk0,bootindex=1 -device ide-cd,bus=ide.0,id=sata0-0-0 -netdev tap,fd=34,id=hostnet0,vhost=on,vhostfd=36 -device virtio-net-pci,netdev=hostnet0,id=net0,mac=52:54:00:50:fa:0b,bus=pci.1,addr=0x0 -chardev pty,id=charserial0 -device isa-serial,chardev=charserial0,id=serial0 -chardev socket,id=charchannel0,fd=32,server=on,wait=off -device virtserialport,bus=virtio-serial0.0,nr=1,chardev=charchannel0,id=channel0,name=org.qemu.guest_agent.0 -chardev spicevmc,id=charchannel1,name=vdagent -device virtserialport,bus=virtio-serial0.0,nr=2,chardev=charchannel1,id=channel1,name=com.redhat.spice.0 -device usb-tablet,id=input0,bus=usb.0,port=1 -audiodev {"id":"audio1","driver":"spice"} -spice port=5900,addr=127.0.0.1,disable-ticketing=on,image-compression=off,seamless-migration=on -device qxl-vga,id=video0,ram_size=67108864,vram_size=67108864,vram64_size_mb=0,vgamem_mb=16,max_outputs=1,bus=pcie.0,addr=0x1 -device ich9-intel-hda,id=sound0,bus=pcie.0,addr=0x1b -device hda-duplex,id=sound0-codec0,bus=sound0.0,cad=0,audiodev=audio1 -chardev spicevmc,id=charredir0,name=usbredir -device usb-redir,chardev=charredir0,id=redir0,bus=usb.0,port=2 -chardev spicevmc,id=charredir1,name=usbredir -device usb-redir,chardev=charredir1,id=redir1,bus=usb.0,port=3 -device virtio-balloon-pci,id=balloon0,bus=pci.5,addr=0x0 -object {"qom-type":"rng-random","id":"objrng0","filename":"/dev/urandom"} -device virtio-rng-pci,rng=objrng0,id=rng0,bus=pci.6,addr=0x0 -sandbox on,obsolete=deny,elevateprivileges=deny,spawn=deny,resourcecontrol=deny -msg timestamp=onAgreed! Thanks again to @babywhale for making bashvm! Thanks also to @crunchbits for wonderful Crunchy!
Excellent! I will try making you another VM. Debian or something else?
-cpu host \
-enable-kvm \
-m 8192 \
-drive file=debian-10.10.qcow2 \
-cdrom debian-10.10.0-amd64-netinst.iso \
-net nic -net user,hostfwd=tcp::8080-:8080,hostfwd=tcp::42397-:42397 \
-vnc 127.0.0.1:0 \
-boot d
wow thats super simple :O i wonder what features are available when doing it like this compared to the XML format.
@babywhale
wget https://cloud.debian.org/images/cloud/sid/daily/latest/debian-sid-nocloud-amd64-daily.qcow2qemu-system-x86_64 -nographic -m 1G -hda ./debian-sid-nocloud-amd64-daily.qcow2Faster with
-enable-kvmbut still works well enough for many purposes even without KVM.Launch the VM inside
tmuxif you want to be able to leave with the VPS still running. . . . Ctrl-b, d to detatch from thetmuxsession. Ctrl-b, x to leave and kill thetmuxsession.tmux attachto get back into a running session.No default password for root VM user. Just enter "root" for the user and then press enter for the password.
@subenhon
Please compare the following lines, one from the yabs you posted, and a similar line from the yabs I posted:
Hope this helps!
Here's how easy it is to make a VPS with bashvm!
Thanks to @babywhale for bashvm! Thanks to @crunchbits for Crunchy!
Thanks!
I will try it later.
Resizing A Debian Sid Nocloud Image
As mentioned above, the image can be installed by using this simple command:
45699 pts/4 Sl+ 406:24 qemu-system-x86_64 -nographic -m 2G -hda ./debian-sid-nocloud-amd64-daily.qcow2It also interesting that IPv6 worked despite the error about IPv6 not being supported by slirp, yet.
And, unlike the bashvm VMs, no AES-NI.
-hdato a faster "virtualized" disk.Thanks to @crunchbits for wonderful Crunchy!
@Not_Oles i think i should be given a chance to taste the slice of MetalVPS 🤗🤗
THANKS BROTHER
https://wiki.libvirt.org/QEMUSwitchToLibvirt.html
Decided to glance at a little of the libvirt and the qemu code.
Currently i am busy with other things.
When I have free time, I will test it out.
Thanks for the bashvm VPS
The bashvm seems easy to use, i will try it too!
Transition from Free Offers in this Thread
Good morning!
Tom
Link: https://www.paypal.com/sg/webapps/mpp/paypal-fees
