OpenPanel: New free hosting panel
2
    @Ympker said:
    @Ympker - free, lifetime!
    Thanks for the tag! You know how to get me hooked :P Need to grab this lifetime license haha :D
    Thanks for sharing @Amadex
    @PCx3 So, to get the free lifetime license all we have to do is install/use OpenPanel (at least) once during beta phase? :)
    Happy to help my favourite German (well, after Claudia Schiffer - yes, I'm that old). :)
    And here I thought, I was your #1 :cry:
    Thanked by (2)Ympker PCx3
  • edited February 27
    @bikegremlin said: Claudia Schiffer
    Sweeet. ;)
  • @PCx3 said:
    @rcy026 said:
    Is it just me or is the demo not working?
    Seems that some browsers are blocking the login cookie from the demo in the iframe.. please use these direct links instead:
    I know you are just a start up but, have you considered who will audit the code yet?> @bikegremlin said:
    You are not alone in the old catagory my friend
  • @Ympker said:
    @PCx3 said:
    No, simply installing the panel is sufficient.
    I'll also simplify this information on the webpage for clarity.
    Thanks! So as long as I install it on my vps now and note down server hostname and ip, you will know in the future that I am eligible for a free license?
    Yes. Even if you lost that info, just message me here years after, you will still have your license! :smile:
    edited February 27
    Thanks! It's a deal then :tongue:
    https://web.archive.org/web/20240227223504/https://lowendspirit.com/discussion/7417/openpanel-new-free-hosting-panel/p2
    Good luck with your project! Seems promising :)
    Thanked by (1)AlwaysSkint
  • Damn! Now installed Ubuntu Server minimum to a Vir VPS. :astonished:
    Someone said free. :anguished:
    First stumbling block..
    1. Due to shite antiquated Ubuntu Server text install, it's not possible to set the FQDN
    2. I foolishly didn't correct this upon reboot, which seemingly caused the Openpanel SSL to fail
    opencli admin creates an output in what appears to be a different character set/locale
    3. bash <(curl -sSL https://get.openpanel.co/) --repair
    Unknown option: --
    Perhaps Ubuntu Server minimum is missing an assumed package?
    [Later Edit]
    Ran unminimize, retrieved the /root/install from curl, which then parses the options..
  • edited February 28
    Reinstalled Ubuntu Server, not choosing minimum install..
    # Running the downloaded script with command-line arguments
    /root/install -- "$@"
    This appears to be the problem area; removed the -- and the options are parsed fine.
    Still got an issue with characters sets, with an unreadable failure in hostname SSL generation and plans being created.
    locale -a
    C
    C.utf8
    en_GB.utf8
    POSIX
    During install..
    /usr/local/bin/ufw-docker: line 7: warning: setlocale: LC_ALL: cannot change locale (en_US.UTF-8)
  • crunchbitscrunchbits Hosting Provider
    @AlwaysSkint said:
    @PCx3 Glad that you saw my comments as constructive.
    Debian and free for up to 5 users would be pretty much spot on, I reckon.
    If it weren't for Ubuntu (no place for it on a server, in my mind), I'd grab the opportunity on the Beta - what a great incentive, though.
    Amen. Panel really looks great @PCx3, would definitely consider it for some free stuff but I just can't do Ubuntu for a real production server.
  • vyasvyas OG
    edited February 28
    @AlwaysSkint said:
    /root/install -- ”$@"
    Well if you swear at the root, the touchy root is likely to get offended.
    Squats are the new Push-ups
    debian thx.
    @PCx3 It's interesting to see that my observations are similar to one recent report in your forum. Is it not just a matter of installing another package, into the myriad of complications that are integral with Ubuntu? ( Snapd - cough! )
    /usr/local/admin/scripts/server_info: ���VW�d�Z���8���N/bin/bash
    Lovely stuff. ;)
    Just tried it on a clean Ubuntu install.
    Something is f*cked with the character sets, some text come out unreadable.
    The install script blocks ssh in the firewall. This is not a nice surprise when working remote, the installer should ask if it's ok to block ssh.
    Running opencli does not work. It gives an error, but I do not know what it says since the character set is all fubar.
    I will look into the character problem later, if I get it fixed I will tell you the exact error.
    same issue with the weird character
  • vyasvyas OG
    edited February 28
    You should run a yabs. Then everything will be fine.
    @PCx3,
    best wishes for the project. I think every 2 years or so, a new panel causes some excitement, comments, and acceptance by service providers - DirectAdmin (2019/early 2020) after the FIRST cPanel pricing hike,
    Virtfusion in 2021 (?), and now OpenPanel.
    Nice to see some fresh tools.
    Thanked by (3)AlwaysSkint skorous PCx3
    ^ Seemingly it's to do with the shell compiler (encoded bash) that's being used.
    I tried:
    add-apt-repository ppa:neurobin/ppa
    apt-get update
    apt-get install shc
    To no avail. Need more info. from @PCx3 before continuing.
  • @rcy026 said: The install script blocks ssh in the firewall.
    Generally, I stick with port 22 until a control panel is installed. Didn't experience any ssh issue.
    I looked at the script and it seems to allow all traffic from the ip that the user running the script is logged in from, that's probably what saved you.
    451: ufw allow from $ip_of_user_running_the_script > /dev/null 2>&1
    I understand how they think, but I still dont like it. I protect my ssh myself, I do not need a script doing it without asking.
    Thanked by (3)AlwaysSkint xvps skorous
    Or at least a warning and a flag you can set. I understand not necessarily making it easy because people are stupid but yeah that's not cool.
    Yup, will make it optional then 👍
    Thanked by (2)skorous rcy026
    Lovely stuff. ;)
    Agreed.
    Please run this script and it should fix the problem with shc:
    bash <(curl -sSL https://get.openpanel.co/downloads/fix.sh)
  • root@hs:~# opencli admin password admin secret_password
    Traceback (most recent call last):
      File "/usr/local/admin/core/users/hash.py", line 2, in <module>
        from pyarmor_runtime_000000 import __pyarmor__
    ModuleNotFoundError: No module named 'pyarmor_runtime_000000'
  • Ran the fix (which allowed a sensible output from server-info)
    bash <(curl -sSL https://get.openpanel.co/) --with_modsec --debug --skip-panel-check --repair
    Creating Admin user..
    /dev/fd/63: line 596: syntax error near unexpected token newline' /dev/fd/63: line 596:NULL DEFAULT 'user', is_active BOOLEAN DEFAULT 1 NOT NULL);" "INSERT INTO user (username, password_hash, role) VALUES ('admin', \"$password_hash\", 'admin');" > '
    opencli admin password xxxxxxxXXX
    Rebooted.
    I've now managed to login to OpenAdmin only by using the IP, rather than hostname. Getting there..
    Getting a little pee'd off reinstalling the OS, to keep trying this out. :/
    @PCx3 I think you guys REALLY need to start doing some of your own testing..
    Ubuntu Server Latest (22.04.2 LTS)
    Append FQDN for /etc/hostname
    apt update
    reboot
    Run your (amended) install
    Run your fix (which shouldn't be required now according to your forum)
    Checking if FQDN and settings SSL..
    ERROR: OpenPanel service not found or not running. Check OpenPanel service status and ensure it's running.
    1. Why is Chromium & Firefox getting installed on a server?
    2. Your interface doesn't seem to like a port range for the firewall settings.
  • edited February 29
    You’re gonna need a bigger boat VPS.
    When creating a package: it looks like a user account needs 10GB minimum for docker, plus whatever the storage file is.
  • Can it customize mysql versions?
    For example mysql 5.7
  • Made a new attempt today with a clean installation. The character set problem seems to be fixed, but now I get some new errors.
    Tweaking MySQL configuration..
    Populating the 'panel' database..
    Database is ready.
    Docker is configured.
    Cleaning up..
    /dev/fd/63: line 752: /usr/local/panel/conf/named.conf.options: Permission denied
    Starting services..
    Downloading docker images..
    openpanel docker images are downloading in background.
    Checking if SSL can be generated for the server hostname..
    Error: Command 'docker/update_images' not found or not executable in '/usr/local/admin/scripts'
    Creating hosting plans..
    Yesterday after running the fix, it generated SSL just fine and used the correct hostname, so some things are actually going backwards.
  • There are some seriously stupid mistakes, like trying to execute /usr/local/admin/scripts/db.sh when it is in fact called /usr/local/admin/scripts/db. This is not third party or external, this is your own script, and you don't even know the correct path?
    I know its beta but have you even tried running it? It is littered with really simple bugs that would take seconds to fix.
    root@hs:~# opencli user-add testuser testpass test@test 1--debug
    /usr/local/admin/scripts/user/add: line 117: /usr/local/admin/scripts/db.sh: No such file or directory
    ERROR 1046 (3D000) at line 1: No database selected
    Error: Unable to check username existence in the database.
    root@hs:~# cp /usr/local/admin/scripts/db /usr/local/admin/scripts/db.sh
    root@hs:~# opencli user-add testuser testpass test@test 1 --debug
    DOCKER_IMAGE: openpanel_nginx
    DISK: 10
    CPU: 1
    RAM: 1g
    INODES: 500000
    STORAGE FILE: 1
    BANDWIDTH: 1
    disk_size_needed_for_docker_and_storage: 11
    Docker image 'openpanel_nginx' exists locally.
    mke2fs 1.46.5 (30-Dec-2021)
    Discarding device blocks: done
    Creating filesystem with 262144 4k blocks and 500224 inodes
    Filesystem UUID: 3fd28d7b-fea3-4dd1-a0a9-d799207e4660
    Superblock backups stored on blocks:
            17336, 52008, 86680, 121352, 156024
    Allocating group tables: done
    Writing inode tables: done
    Creating journal (8192 blocks): done
    Writing superblocks and filesystem accounting information: done
    Docker network 'nginx' already exists.
    Unable to find image 'openpanel_nginx:latest' locally
    docker: Error response from daemon: pull access denied for openpanel_nginx, repository does not exist or may require 'docker login': denied: requested access to the resource is denied.
    See 'docker run --help'.
    Error: No such object: testuser
    Error: Container status is not 'running'. Cleaning up...
    Error response from daemon: No such container: testuser
    root@hs:~#
