1TB €12,20/yr STORAGE KVM - IPv6VM.Com
IPv6VM.Com Special Deal
IPv6VM.Com is excited to present our latest offer:
IPv6VM.com is the new brand of affordable IPv6-only VPS. We at IPv6VM provide you with the best solutions while keeping the offers at the lowest price to make them accessible to everyone.
1TB HDD IPV6VM.Com SPECIAL DEAL
  • Price: €12.20/year (VAT included)
  • Specs:
    • CPU: 1 vCore (1000 CPU units, 40% Core allocation)
    • RAM: 1GB DDR4 ECC
    • Storage: 1TB HDD SAS (No Raid, 100MB/s read&write, 70 iop/s)
    • Bandwidth: 1TB @ 100Mbps monthly traffic usage
    • Connectivity: 1 IPv6 address
Order Now
You can upgrade all these specifics:
CPU vCores, RAM, Storage Capacity, IPv4 addresses, IPv6 addresses, Monthly bandwidth and Port speed.
Useful Links
C1V Hosting: Low cost Italian Cloud & Data Center Solutions 🚀 | Contact us for special offers. | Our deals on Telegram
  • If you experience any problems during the ordering process, please don't hesitate to reach out to us directly via DM or email us at [email protected]. Note that this contact is specifically for ordering issues and not for service-related assistance. Thank you.
  • Is it really no raid (one disk per server) or is it YOLORAID (multiple disks per server)?
    No hostname available. affbrr
    I didn’t know about Yoloraid.
    It’s one single disk.
  • vyasvyas OGSenpai
    Push-Up RAID. You push your luck, which for the price is okay I guess !
    Thanked by (2)yoursunny c1vhosting
  • Why taxing non-Italian non-European resident? I choose Indonesia yet VAT still 22%.
  • 1 ip address means a /128?
    Hello dear,
    thanks for your question.
    We are applying VAT to all Individual Customers.
    Yes
  • Can multiple VPS be combined for larger storage (combining partitions) or higher resiliency (backup from one to another)? Is it one piece of metal or spread over multiple servers?
    Hello dear!
    Sure thing. Please contact me to arrange this custom setup.
    Regarding your request, currently it is a offer for POM4 node => the one that yesterday was upgraded from 10Gbps Uplink to 40Gbps :)
    Thanked by (1)wankel
    oh my that is most unfortunate.
  • On OGF they also took away his provider tag
    F. Battiato ---
    Which one is the actual OGF?
    Over at LET they say LES is the OGF.
    Here people say LET is the OGF x)
    I am confused.
  • Both, actually. It's "other green forum."
  • edited March 2024
    FWIW, my VPS with c1vhosting has an uptime of more than 2 months now. I mean, sure, the performance is nothing to shout about, but I feel that I am getting a decent service for the amount that I paid for.
    Only, in our case it's "Original Greener F***m"
  • no IPv4 NAT ports?
  • @c1vhosting What's the bandwidth tolerance after the 1TB mark, how low does it get limited to?
  • TheDPTheDP OGSenpai
    @tzy170150585 said:
    400 people voted in lowendtalk, and 56.03% of them still agreed to ban you from selling. You have been revoked as a provider label by LET. Because your server performance is very poor, you lied
    This isn’t LET and I do understand your frustration, but with you being this “aggressive”, especially with your threats and barrage of comments, don’t usually end well if you continue being like this.
    If you want to share your experience, compose and post your review where it should be posted.
  • @brian said:
    no IPv4 NAT ports?
    No - it is IPv6-only.
    The VPS gets stopped until next billing cycle (unless you contact us to upgrade bandwidth)
  • @c1vhosting said:
    @brian said:
    no IPv4 NAT ports?
    Oh! Are there any plans to implement REALLY limited networking, like, capped at 1Mbps until the end of the month?
  • @yucchun said:
    @c1vhosting said:
    @brian said:
    no IPv4 NAT ports?
    We can work on a customised plan for you. Please contact me to arrange it
  • edited March 2024
    Sorry to bother, but I just noticed that several temporary IPv6 addresses were assigned to my IPv6-only VPS.
    Since my VPS was suspended once for "IPv6 abuse" which actually means only 1 IPv6 address can be used despite a /48 prefix is given.
    I'm sure IPv6 address is statically set up:
    /etc/systemd/network/20-wired.network
    [Match]
    Name=eth0
    [Address]
    Address=2a05:xxxx:3::6xx/48
    [Route]
    Gateway=2a05:xxxx:3::1
    And IPv6 Privacy Extensions has been disabled:
    /etc/sysctl.d/99-sysctl.conf
    net.ipv6.conf.eth0.use_tempaddr=0
    net.ipv6.conf.all.use_tempaddr=0
    What can I or @c1vhosting do to remove the additional IPv6 addresses ?
    I don't want to be accused of "IP abuse" again or have the VPS suspended.
    Thank you.
    [Match]
    Name=eth0
    [Address]
    [Route]
    Thank you.
    Disable autoconf
    Thanked by (1)bliss
  • edited March 2024
    @c1vhosting said: Disable autoconf
    Thanks for replying. It works.
    Here are my configurations which might be helpful to someone else.
    net.ipv6.conf.eth0.autoconf=0
    net.ipv6.conf.eth0.accept_ra=0
    net.ipv6.conf.all.autoconf=0
    net.ipv6.conf.all.accept_ra=0
    net.ipv6.conf.default.use_tempaddr=0
    At first the above setting had no effect and there were still temporary IPv6 addresses assigned.
    Then I found out that systemd-networkd prioritizes its own configuration:
    [Match]
    Name=eth0
    [Network]
    IPv6AcceptRA=false
    IPv6PrivacyExtensions=false
    Address=2a05:xxx:3::xx/48
    Gateway=2a05:xxx:3::1
    Thanked by (2)c1vhosting wankel
  • I've bought this VPS few days ago, since Saturdays morning (GMT) it doesn't work (I can't start it up, when I click start->confirm i got information saying "The virtual machine has been booted successfully", but status is still stopped and I cant use noVNC or SSH into it), I've send a ticket and get response at 4 pm saying "Hello, please check again in minutes." but nothing changed and I still can't use it (Sunday 12pm).
  • I really want to buy it, but, Your ipv6 address cannot be used for external access
    And the panel supports too few linux systems
    i need cheap vps year payment .
  • My VPS is working now, support wasn't working because of Easter.
    You can use it, another device that you are going to connect to this vps must support IPv6. I'm using this VPS just as storage connected via smb share to other VPS.
    Ciao,
    I see you have read we weren't working because of Easter days.
    Thanks for your help.
