1789101113»
  • @Shot² said:
    No luck for us poor sods from the early days :'(
    You can always ask to get your disk space increased.
    Mostly depends on storage space available on the Node.
  • BIGGER DICKS ON REQUEST!
    // I had no idea what to comment, just wanted to say I logged in so the system shows me as active, still running this ChangeDetection.io for VirMach billing status tickets. Tanks Neoon!
    Thanked by (1)Neoon
  • This feature is now available, plus some stock has been cleaned up.
    Thanked by (2)FrankZ Wonder_Woman
  • Maintenance Announcement
    On Friday the 24th this Week, roughly 20:00 UTC, I plan to carry out a maintenance to upgrade the current software stack that NanoKVM.net is running on.
    I don't expect more than a few minutes of downtime, however, I shall announce a 30 minute window.
    Done
    Thanked by (3)flips balloon Ganonk
  • edited December 2023
    a3647d2a0788a2a31f7dc0016ad6293af9ca6c7e
    I plan to run jupyter notebook on the vps. I was using Google Colab in the past, but now I need to use PARI to do some number computing and Colab doesn't support it :#
    Thank you!
    Thank you!
    Deployed.
    Thanked by (1)dwight
    Can we adjust spec for the deployed vps?
  • NeoonNeoon OG
    Depends, what and which Node.
  • Logged in just now and got this message:
    Error!
    Unable to fetch Proxmox data, try to log out and log in again.
    Error!
    Have you tried logging in again?
    Sometimes timeouts happen, I see no issue here.
  • I did several times and also before I posted this. Still there.
    Please say that next time, I did assume you only logged in once.
    I did reset your proxmox account, try again.
  • Looks good now. Thanks.
  • NeoonNeoon OG
    edited March 14
    Announcement, Announcement
    As I just have been informed a day ago, that the current Node in Eygelshoven will be discontinued in a few weeks.
    Due to increasing costs, however, there will likely be a more power efficient replacement.
    More details will be announced later.
    Thanked by (2)ElonBezos host_c
    We get a new dedi next week, once its setup, people can request to get a VM on the new Node.
    So they should have enough time to migrate their stuff in-between the old and new node.
    I will post here once the new Node is up.
    KTS24 is discontinuing their old blade systems, hence the migration.
  • NeoonNeoon OG
    edited March 19
    If you have an existing KVM in Eygelshoven, you can send me a DM to get a new VM on the new Node.
    The early your ask, the more time you will have to migrate.
    If you don't send me a DM, I will send you a DM, however it would be nice if you do it from your side, less work for me.
    Thanked by (1)bliss
  • Token:
    9cebfa235fb1886b25e33f3cce2871912da55c78
    My plan is to use the VPS as a temp hosting for future self-hosted apps that I want to have in my home server, I don't have that home server yet so I want to start with a VPS to test and see how things work and be able to break stuff without any risk. My first idea was to host some mealie or similar and once that works fine and I have my own server, move the stuff to my server.
    Thanks so much.
  • @albermonte said:
    Token:
    Thanks so much.
    You have to read the Requirements.
  • Hi,
    Token: 5937fc8619b5648fd6b49e089284566812a16893
    Purpose: For znc, eggdrop and other bots.
  • Nice to see someone giving away vpses to lowendspirit members! I would also take one but i don't meet the requirements yet.
