microLXC Public Test
1131416181922
    edited January 2024
    @ElonBezos said:
    @Neoon said:
    Looks more like a issue related to SSH for some reason.
    i'll look further in to this
    Tokyo no idea, we got 2 Nodes, you have to be more precise.
    it said tyo only, the other tyo equinix seems fine for me
    anyway unable to ssh is not a big deal for me since i can access them from the portal
    Well, seems to be the same issue, SSH not listening.
    Not a forwarding issue or anything, since the rules are in place and IPv6 returns the same result.
    However, I can't replicate that, so no idea yet.
    Will do a quick reboot on Singapore and Groningen on Friday, at around 21:00 UTC.
    More Stock should be available afterwards.
    Thanked by (2)carlin0 SwordfishBE
  • 594c-620d-842c-7996
    Thanked by (1)Brueggus
    Islamabad is now available, Native IPv6 however only a /70 and depending on version and distro, manual configuration might be required.
    Thanks to https://virtury.com
    Currently 3 Packages are available.
    • 1x Core (25%), 64MB, 1.3GB ZFS, 100GB @ 100Mbit
    • 1x Core (50%), 128MB, 2.0GB ZFS, 200GB @ 100Mbit
    • 1x Core (50%), 256MB, 2.5GB ZFS, 200GB @ 100Mbit
  • May I apply for a tiny R0 VPS?
    edited February 2024
    RO gets migrated from E5 to Xeon Gold in 1 hour ish. Thanks @host_c / https://www.host-c.com/
    NL is next on the list, but no ETA, gonna be EYPC though.
    Was that 64MB?
    Looks like an issue due to low memory and a combination of what OS you choose to install.
    Debian/Devuan has issues with 64MB, so I disabled it again.
    It doesn't work reliable enough.
  • Are you aware of IPv6 issues in PK? Seems like their subnet disappeared from the DFZ: https://bgp.tools/prefix/2001:df2:d40::/48
    I wasn't, didn't check my email box, yet.
    Will Ticket him later, at some point we should have a /48 Prefix ready in PK, no ETA though, waiting since 1 week for him to announce it.
    Thanks to @host_c for providing the Prefix, since I don't have my own allocation or ASN yet.
    Thanked by (1)host_c
    @Neoon said: allocation or ASN yet.
    I think we can help with that, PM me when you are interested.
    PS: I did send you something via PM by the way :)
    They replied but no fix yet.
    The Prefix used in PK is back on the routing table, however no reply yet.
    Helsinki is now available, No IPv6 however, plan was running a wg tunnel back to Norway, however routing was not feasible.
    Right now its without IPv6 and probably will stay this way, local brokers are available though.
    Thanks to https://pulsedmedia.com
    Currently 4 Packages are available.
    • 1x Core (100%), 512MB, 10GB ZFS Raid 1, 1TB @ 200Mbit
    • 1x Core (100%), 512MB, 50GB ZFS Raid 1, 1TB @ 200Mbit, Limited to 5
    • 1x Core (100%), 1024MB, 25GB ZFS Raid 1, 1TB @ 200Mbit
    • 1x Core (100%), 1024MB, 50GB ZFS Raid 1, 1TB @ 200Mbit, Limited to 5
    This Location will be KVM only for now, since this is our first machine with Debian, I don't have a live kernel patching solution yet so no LXC, expect a reboot though every now and then, will be announced here.
    Because we don't have smoler packages available, the is currently a 50% discount off the memory usage, so if you get the 512MB package it will be calculated as 256MB and so on until the Node is about half full.
    edited March 2024
    Maintenance announcement for New Zealand.
    Expect about 60 minutes downtime at Wednesday the 14th of March at 12:30AM NZDT / 11:30AM GMT
    Due to scheduled hardware upgrades.
    Restocked Helsinki.
    Thanked by (1)Ganonk
    Maintenance Announcement
    I have to carry out some changes on the backend, this will make the backend unavailable for roughly 1 hour or less.
    Running machines are not affected, however no tasks or deployments can be done.
    Should be done next week, Friday, 15th of March, at around 20:00 GMT.
    Thanked by (1)carlin0
    edited March 2024
    Got SPICE working.
    You should be able to install any OS with netboot.xyz on KVM.
    Spice is now available along with an option under Settings to boot from ISO (netboot.xyz).
    That will set the boot priority up and mount the ISO.
    I added empty KVM's too (BYOOS), so we can offer 256MB KVM's again.
    Debian 12 isn't going to boot or run on these, some other operating systems might run though.
    The 256MB KVM Package is only available in Finland right now, if there is any use, I can add it to Norway and Dronten too.
    Thanked by (2)bliss ElonBezos
    I added a 384MB KVM too on Helsinki.
    Since 256MB seems to barely work with netboot.xyz to get any installer up.
    I will add more iso's and an option to switch iso's later.
    edited March 2024
    /48 IPv6 for PK is on the way, should be available in the next few days.
    Took a bit longer than expected.
    Thanks again to @host_c / https://www.host-c.com
    No ETA for Tokyo though.
    The containers on Tokyo have been restarted today accidentally, I needed to replace a certificate however I did a restart instead of a reload, hence the reboot.
    Thanked by (3)host_c ElonBezos Ganonk
  • nice to see Helsinki
    i gotta read how to apply for this first.
    <3 to Neoon
    Thanked by (2)Neoon host_c
  • edited March 2024
    if u still have room:
    3077-1c51-1101-2aa1
    3077-1c51-1101-2aa1
    Always.
    Finland currently has network issues, I had to reboot the node.
    Out of Stock for now.
    As soon as I know more, I will post it here.
    The issue has been found, a switch gone bad.
    Its gonna be replaced next week, if it gets unstable again, earlier.
    Stock has been enabled again.
    Thanked by (2)host_c bliss
    Switch has been replaced.
    Thanked by (3)carlin0 wankel ElonBezos
    @Neoon said: Switch has been replaced.
    yeeeeee!
    Restocked Finland.
    openSUSE image has been removed, since the official Imageserver does not build it any longer.
    If you have an openSUSE container, you can still use it, however you can't create any new ones.
    Testing the nixOS image currently, since officially its not supported by LXD, but seems to work well.
    Should be added soon, hopefully.
