Neeed VPS in EU: 2C / 2G / 10GiB SSD / 800GiB HDD
On the lookout for a tiny beefy VPS, with hybrid storage.
Not in a hurry (can wait till ~May 15th).
Desirableed specs at least:
- KVM/VMw, no OVZ/LXD
- 2 vCPU w/ AES-NI
- 2 GB RAM
- 10+ GiB SSD (20 GiB preferred) for an OS that kicks ars
- 800~1000 GiB of spinning rust... with tolerable io please
- 1 TiB at 100+ mbps per month (200mbps preferred)
- no hard cutoff once bw exceeded (even 1mbps will do)
- native IPv6 + some IPv4 connectivity (NAT's fine)
- low delay (<25ms) to Paris' ping6.online.net, so likely in FR NL DE GB IT.
Budget 3€/month, annual payment ok. Can go a bit higher if extra perfs/perks.
Something along the lines of Servarica's Opossum2 plan... but in the Old World ![]()
Usage will be rather modest - nothing shady nor noisy: backend for some light web hosting/mirroring + infrequent cold data encrypted backup.
If you can wait it out
https://lowendspirit.com/discussion/7559/host-c-5tb-storage-deal-12-5-usd-quarter#latest
Thanks - had noticed your sweet offer... but a bit too far (>30ms) and above budget.
(BTW the IPv6 of your lookingglass seems down.)
maybe you can finde something here: https://login.layer7.net/index.php?rp=/store/storage-server-par1
Thanks for the tip. A bit too much/pricey ("trop beaucoup" ©) for my needs, but close
I've checked hostbrr's "hybrid" line also - close but no cigar.
Budget is a bit low.
Maybe try waiting for the upcoming HostBrr sale, @Labze mentioned on LET he'll be releasing hybrid storage then
Fixed, "too much firewall will kill you"
https://ping6.ping.pe/2a0d:8140:0:4::2
Yep, I'm playing MrCheapo here, in the hope that some special/custom offers or extraordinary suggestions pop up.
I take Servarica as reference (hell, $36/yr for 2C/2G/1T is neat) but I have to admit it was a bit on the low side performance-wise, that's why I'll also consider more expensive offers if still a good bargain.
I see.
If that's the case, best bang for buck remains host C.
EUR 3 * 12 = EUR 36/yr
For ~9 EUR extra, you get 4TB additional storage and a decent, not oversold CPU. Has 20GB NVMe boot too.
Maybe after the RDS peering issues are solved, you'll have a better latency, I'm waiting for that fix too, ping is not the best to Asia.
Hello!
PING ping6.online.net(2001:bc8:0:1::49 (2001:bc8:0:1::49)) 56 data bytes
64 bytes from 2001:bc8:0:1::49 (2001:bc8:0:1::49): icmp_seq=1 ttl=55 time=23.4 ms
64 bytes from 2001:bc8:0:1::49 (2001:bc8:0:1::49): icmp_seq=2 ttl=55 time=23.3 ms
64 bytes from 2001:bc8:0:1::49 (2001:bc8:0:1::49): icmp_seq=3 ttl=55 time=23.3 ms
64 bytes from 2001:bc8:0:1::49 (2001:bc8:0:1::49): icmp_seq=4 ttl=55 time=23.3 ms
^C
--- ping6.online.net ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3000ms
rtt min/avg/max/mdev = 23.283/23.330/23.420/0.053 ms
So, this is our best plan for you. Please note that we will suspend (stop) your VPS until next month if you overuse your bandwidth, so I entered one TB more than your request.
2 vCore CPU, 4GB DDR4 ECC RAM, 20GB SSD NVMe PCIe, 1TB HDD SAS (single disk, limit at 100MB/s r/w and 100 iops), 2TB @ 200Mbps monthly traffic usage, 1 IPv4 address, 1 IPv6 address
We can do this at €20/year VAT incl. or €3/month VAT incl.
C1V Hosting: Low cost Italian Cloud & Data Center Solutions 🚀 | Contact us for special offers. | Our deals on Telegram
I have storage vps with @host_c and it is excellent in performance and stability. The proper ticketing system is extremely helpful to get support in time.
I personally avoid providers who do not have proper ticket based online support. Also check the cancellation policy as well before signing up
Yep, I'm wary of summerhosts and other too-good-to-be-true "funny" hosts (a recipe for LowEndlessDramas on the sister LowEndTrash forum, wink wink). They harvest gazilions of customers - including tons of noisy neighbours - thanks to cheap powerful plans shining in benchmarks... then after a few weeks quality goes to deep sh*t (iops, latency, bankruptcy, "of course it was all raid0", whatever...).
As for @host_c, save for the fact they're newcomers and out-of-stock right now (and weird statements such as no DNS, XFS, qemu-guest-agent etc.), it looks tempting indeed, and definitely in my budget. Especially now that I can see that their IPv6 is roughly ~25ms only from here.
I have been @host_c customer since Dec 2023, and recently upgraded my storage VPS.
Compare these two GB6 scores from two providers
same cpu and both "claim" with 2 vCores
Avoid providers who won’t share GB6 score from their “busy node”
Went for a neat offer at @Labze's HostBrr - and it appears to kick a$$ so far
/thread
