1-Month Free trial VPS (with requirements)
LowHostingLowHosting Hosting Provider
edited April 2024 in Free Offers and Stuff
Hello everyone,
I'll get straight to the point, I want to give free trials of a VPS plan for 1 month, but I also want to prevent duplicate or fake accounts, so there will be requirements to qualify for a free VPS, below are the requirements:
  • Have at least 30 non-spammy posts.
  • Have an account with a registration date older than one month.
  • Have received at least 40 "Thanked" responses.
For now, I will set a limit of 40 free trials, if a lot of people like the idea I will extend it further.
This is the VPS plan:
2 Core (Ryzen 9 5950X)
RAM 4 Gb
60 Gb NVMe
300 Mbps*
Advanced Anti-DDoS
Germany**
Bandwidth Unlimited***
IPv6 Included
Standard price: €8/mo
After the trial, you can renew it at a discounted price (-20%) by opening a ticket.
*Can be increased up to 1Gbps by opening a ticket if needed.
**The order can be processed in 2 locations, both are in Germany and with minimal ping variation between them (<2ms).
***As long as it does not result in abuse.
Additional info:
Looking Glass: https://lg.lowhosting.com/
Anti-DDoS info: https://lowhosting.com/antiddos
If you need a custom or not listed OS, please open a ticket including the ISO link and we'll mount it for you.
You may receive an IP address that does not have updated GeoDB/DB-IP data, be patient even if you see incorrect values, unfortunately, it takes months to correct them for new prefixes.
To request the trial, please use the following link and PM (DM) us with your Reference Number or Order Number:
https://lowhosting.com/?lesfreetrial
Please select "Free Trial Request" as the payment method during the order.
Please note that we reserve the right not to accept to provide the trial in cases where our anti-fraud system detects something strange, such as using a VPN or other factors.
The review can last up to 12 hours in some cases.
I hope you like the idea, I'm available to answer questions if you have any.
LowHosting.com - LowHosting.org
  • edited March 2024
    skip
  • @LowHosting said: Have received at least 40 "Thanked" responses.
    I'm missed this
    Thanked by (2)LowHosting Mumbly
    I'm missed this
    Damn that's a high bar! Good luck :)
    Thanked by (2)LowHosting warih
  • Thanks for the fast setup :)
    Thanked by (1)LowHosting
  • edited March 2024
    I am just 3 posts short huh
  • JabJab Senpai
    @w12138 said:
    skip
    @alethic said:
    skip
    Go skip yourself.
    Thanked by (2)LowHosting terrorgen
  • LowHostingLowHosting Hosting Provider
    Posts mean comments, you are eligible.
    Since I can no longer edit the thread, I'll write it here, if you meet the minimum requirements on the OGF but not here, you can send me the Reference Number/Order Number via PM on the other forum.
  • what i would like to see is 1 year free gift raffle with same specs.
    In that case, it couldn't be called "Trial"
    I will make your dream come real if you can tell me who the person in your propic is
    its yours truly.
    i had better moments thou.
  • edited April 2024
    I have a small VPS at LowHosting (1 Ryzen 5950X vCore, 2GB memory), active for 4 months or so by now. No issues whatsoever since the day it was activated and performance is good. You can't say no to a free trial! (but I actually don't need it! don't give it to me!!!)
    @ehab said:
    its yours truly.
    I'm unsure about the answer, but you got the VM, but not with the 5950X CPU, you will see when you test it, PM me your email or Support PIN.
  • nice offer. windows possible @LowHosting
    but price after 1st month to high @ehab
    maybe he can x2 RAM more RAM for us :)
  • JabJab Senpai
    Ooooooo... 7950X, jelly.
  • @ehab said:
    Thank you @LowHosting
    i got my free kvm :) so kind of you,.
    i will install some db since disk io is high
    hey @lapua look at the yab
    Single Core     | 2818
    Multi Core      | 5098
    Full Test       | https://browser.geekbench.com/v6/cpu/5819018
    YABS completed in 15 min 59 sec
    This is a VPS with powerful computing power.
    Congrats, @ehab.
    Thanked by (2)LowHosting ehab
    If any of you have suggestions on templates/ISOs that you would like to see added, please let me know.
    Windows Server 2022 Standard 180 day trial
    Thanked by (1)ehab
  • @LowHosting
     Basic System Info
     CPU Model          : AMD Ryzen 9 7950X 16-Core Processor
     CPU Cores          : 2 @ 4192.104 MHz
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     VM-x/AMD-V         : ✔ Enabled
     Total Disk         : 58.7 GB (3.0 GB Used)
     Total RAM          : 3.8 GB (116.5 MB Used)
     Total Swap         : 256.0 MB (0 Used)
     System uptime      : 0 days, 1 hour 58 min
     Load average       : 0.00, 0.00, 0.00
     OS                 : Ubuntu 22.04.4 LTS
     Arch               : x86_64 (64 Bit)
     Kernel             : 5.15.0-102-generic
     Virtualization     : KVM
     TCP Control        : cubic
     Basic Network Info
     Primary Network    : IPv6
     IPv6 Access        : ✔ Online
     IPv4 Access        : ✔ Online
     ISP                : Lowhosting services of Davide Gennari
     ASN                : AS212508 Lowhosting services of Davide Gennari
     Host               : LowHosting Services
     Speedtest.net (Region: EUROPE)
     Location         Latency     Loss    DL Speed       UP Speed       Server
     ISP: Lowhosting services of Davide Gennari
     Nearest          5.76 ms     N/A     920.26 Mbps    921.23 Mbps    SYNLINQ - Frankfurt am Main
     London, UK       23.78 ms    0.0%    935.51 Mbps    780.98 Mbps    M247 Ltd - London
     Manchester, UK   25.58 ms    N/A     934.01 Mbps    909.83 Mbps    Vodafone UK - Manchester
     Dublin, IE       32.90 ms    0.0%    945.76 Mbps    911.15 Mbps    Three Ireland - Dublin
     Amsterdam, NL    12.08 ms    0.0%    918.60 Mbps    915.06 Mbps    Melbicom - Amsterdam
     Eygelshoen, NL   25.28 ms    0.0%    921.25 Mbps    903.67 Mbps    SkyLink Data Center BV - Eygelshoven
     Paris, FR        14.78 ms    N/A     920.70 Mbps    820.82 Mbps    ORANGE FRANCE - Paris
     Marseille, FR    27.29 ms    0.0%    941.36 Mbps    917.56 Mbps    GSL Networks - Marseille
     Madrid, ES       33.83 ms    0.0%    929.31 Mbps    647.06 Mbps    Orange - Madrid
     Barcelona, ES    33.10 ms    0.0%    936.13 Mbps    879.70 Mbps    Adamo - Barcelona
     Lisbon, PT       45.15 ms    0.0%    921.18 Mbps    590.04 Mbps    Edgoo Networks - Lisbon
     Rome, IT         25.68 ms    0.0%    952.45 Mbps    922.23 Mbps    TIM SpA - Rome
     Milan, IT        15.65 ms    0.0%    325.49 Mbps    937.21 Mbps    Fastweb SpA - Milan
     Zurich, CH       14.70 ms    0.0%    467.92 Mbps    595.39 Mbps    Sunrise Communication AG - Zurich
     Frankfurt, DE    6.51 ms     0.0%    934.85 Mbps    933.87 Mbps    Deutsche Telekom - Frankfurt am Main
     Berlin, DE       17.00 ms    N/A     901.93 Mbps    623.02 Mbps    Misaka Network, Inc. - Berlin
     Vienna, AT       19.11 ms    0.0%    933.46 Mbps    871.84 Mbps    A1 Telekom Austria AG - Vienna
     Budapest, HU     19.46 ms    0.0%    371.71 Mbps    666.80 Mbps    ATW Internet Kft. - Budapest
     Gdansk, PL       25.34 ms    0.0%    897.76 Mbps    919.38 Mbps    T-Mobile Polska S.A. - Gdańsk
     Warsaw, PL       24.45 ms    0.0%    934.41 Mbps    842.60 Mbps    Orange Polska S.A. - Warsaw
     Lviv, UA         34.67 ms    0.0%    931.35 Mbps    737.14 Mbps    Kyivstar - Lviv
     Kyiv, UA         34.13 ms    0.0%    935.37 Mbps    122.81 Mbps    O3 - Kyiv
     Bucharest, RO    33.20 ms    0.5%    937.02 Mbps    194.47 Mbps    Orange Romania SA - Bucuresti
     Timisoara, RO    32.62 ms    0.0%    803.82 Mbps    726.73 Mbps    Digi
     Helsinki, FI     34.85 ms    0.0%    924.58 Mbps    769.48 Mbps    Elisa Oyj - Helsinki
     Stockholm, SE    33.47 ms    0.0%    920.26 Mbps    865.63 Mbps    i3D.net - Stockholm
     Oslo, NO         27.47 ms    0.0%    925.55 Mbps    621.14 Mbps    Telia Norge AS - Oslo
     Moscow, RU       38.84 ms    0.0%    929.27 Mbps    745.32 Mbps    MTS - Moscow
     Petersburg, RU   38.10 ms    0.0%    931.62 Mbps    881.74 Mbps    MegaFon - Saint Petersburg
     Istanbul, TR     45.62 ms    0.0%    934.95 Mbps    837.59 Mbps    Turkcell - Istanbul
     Tbilisi, GE      68.56 ms    1.2%    902.71 Mbps    608.96 Mbps    Silknet JSC - Tbilisi
     Avg DL Speed       : 871.64 Mbps
     Avg UL Speed       : 761.95 Mbps
     Total DL Data      : 33.12 GB
     Total UL Data      : 27.79 GB
     Total Data         : 60.91 GB
    There is already an ISO of this OS.
  • hey LowHosting
    don't take too much and make LES exclusive offers soon.
  • @LowHosting
    Uptime     : 0 days, 2 hours, 33 minutes
    Processor  : AMD Ryzen 9 7950X 16-Core Processor
    CPU cores  : 2 @ 4192.104 MHz
    RAM        : 3.8 GiB
    Swap       : 256.0 MiB
    Disk       : 58.7 GiB
    Distro     : Ubuntu 22.04.4 LTS
    Country    : Germany
    fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda2):
    Read       | 592.97 MB/s (148.2k) | 1.15 GB/s    (18.1k)
    Write      | 594.54 MB/s (148.6k) | 1.16 GB/s    (18.2k)
    Total      | 1.18 GB/s   (296.8k) | 2.32 GB/s    (36.3k)
    Read       | 1.60 GB/s     (3.1k) | 1.64 GB/s     (1.6k)
    Write      | 1.69 GB/s     (3.3k) | 1.75 GB/s     (1.7k)
    Total      | 3.29 GB/s     (6.4k) | 3.40 GB/s     (3.3k)
    Clouvider       | London, UK (10G)          | 926 Mbits/sec   | 925 Mbits/sec   | 17.1 ms
    Eranium         | Amsterdam, NL (10G)       | 930 Mbits/sec   | 929 Mbits/sec   | --
    Telia           | Helsinki, FI (10G)        | busy            | busy            | 32.4 ms
    Uztelecom       | Tashkent, UZ (10G)        | 382 Mbits/sec   | 541 Mbits/sec   | 101 ms
    Leaseweb        | Singapore, SG (10G)       | 278 Mbits/sec   | 553 Mbits/sec   | 251 ms
    Clouvider       | Los Angeles, CA, US (10G) | 780 Mbits/sec   | 415 Mbits/sec   | 151 ms
    Leaseweb        | NYC, NY, US (10G)         | 746 Mbits/sec   | 616 Mbits/sec   | 85.8 ms
    Edgoo           | Sao Paulo, BR (1G)        | 569 Mbits/sec   | 184 Mbits/sec   | 173 ms
    Clouvider       | London, UK (10G)          | 909 Mbits/sec   | 916 Mbits/sec   | 16.6 ms
    Eranium         | Amsterdam, NL (10G)       | busy            | busy            | --
    Uztelecom       | Tashkent, UZ (10G)        | 768 Mbits/sec   | 494 Mbits/sec   | 101 ms
    Leaseweb        | Singapore, SG (10G)       | 411 Mbits/sec   | 415 Mbits/sec   | 251 ms
    Clouvider       | Los Angeles, CA, US (10G) | 718 Mbits/sec   | 463 Mbits/sec   | 151 ms
    Leaseweb        | NYC, NY, US (10G)         | 544 Mbits/sec   | 545 Mbits/sec   | 85.8 ms
    Edgoo           | Sao Paulo, BR (1G)        | 576 Mbits/sec   | 184 Mbits/sec   | 173 ms
    Single Core     | 2745
    Multi Core      | 4935
    Full Test       | https://browser.geekbench.com/v6/cpu/5821145
  • edited April 2024
    @LowHosting
    Running Windows Server 2022 and running YouTube Video at 1080p FHD in RDP
    VPS has 4GB RAM and 2vCore .... yet pretty powerful
    edited April 2024
    @dev_vps said:
    @LowHosting
    Running Windows Server 2022 and running Youtube Video at 1080p FHD in RDP
    VPS has just 2GB RAM and 2vCore .... yet pretty powerful
    Ryzen 9 7950X is a super powerful processor, it amazed me too :)
  • edited April 2024
    Running youtube video at 4k in Windows RDP
