@Neoon said:
Testing the nixOS image currently, since officially its not supported by LXD, but seems to work well.
Should be added soon, hopefully.
Nice, if you need a guinea pig for the NixOS image, give me a ping. It has a bit of a few quirks due to the closure builder sandboxing when running on containers.
Don't know what LXC container backend microLXC is running (e.g., LXD, Proxmox, systemd-nspawn), but you may need to do lxc.apparmor.profileunconfined or this.
Well, yea the Image as said before is not officially supported by LXD.
When I tested it with Incus and partially with LXD, it was working fine.
My best guess is they added apparmor profiles for NixOS to Incus.
Which are missing, hence he said it was not available for LXD.
Incus LTS is available since a few days, so technically I can start upgrading the Nodes.
However, I rather wait a bit, for other people to pentest it.
Well, the new LXD Images include NixOS and it seems to work fine with Nesting enabled.
I will replace it on the Nodes so you can give it a try again.
NixOS has been enabled again, I replaced the current Image with a new one for LXD.
Testing so far was fine, if nesting is enabled, don't forget that to enable it under Settings.
Noice, thanks. I'll give it a spin.
Now works great 🤌
To NixOS friends minmaxing, a few tricks: nix-collect-garbage -d and nix-channel --remove nixos will free you some disk bringing base usage to 300M. You can then just push closures remotely (I doubt you'll be able to get the builder to run and switch on 128M anyway).
Had to Reboot Pakistan and Valdivia, due to the same issue that happend on JP.
The issues just recently appeared, no clue yet, still troubleshooting why this happens.
So I wrote some code to add a simple CPU abuse detection system.
This will notify users via email if the CPU usage is higher than 50% for the last 30 minutes.
The System doesn't stop or suspend anything yet.
However, the idea would be a strike like system.
If you have been notified a bunch of times, your container / virtual machine will be stopped.
@Neoon said:
This week I had a few cases of CPU abuse.
Smol update.
You will be send 3 notifications via email before the System will take action.
Roughly 2 Hours with more than 50% CPU load.
The 4th time you exceed the threshold your virtual machine / container will be stopped and you will be notified via email.
I will post here again once the automatic suspension is enabled, until then, it will just send notifications.
If you notice any bugs, feel free to let me know.
Hey,
The following containers on microLXC have been renewed:
List of ips .... will expire in 60 day(s)
Any questions? You can mail us at: [email protected]
microLXC
Hey,
microLXC
You have to login every 60 days to confirm your activity.
This is just the confirmation email that the listed containers have been extended because you logged in.
OS / Package availability updates
OS
Packages
OS availability updates
- Added Alpine 3.19 (LXC/KVM)
- Added NixOS (LXC)
Alpine is as before available from 64MB, NixOS from 128MB.
NixOS seems to be failing due to the nix-daemon's inability to remount
/nix/store
.Don't know what LXC container backend microLXC is running (e.g., LXD, Proxmox, systemd-nspawn), but you may need to do
unconfined
or this.Well, yea the Image as said before is not officially supported by LXD.
26D7-D40A-F519-5E25
Now works great 🤌
andnix-channel --remove nixos
will free you some disk bringing base usage to 300M. You can then just push closures remotely (I doubt you'll be able to get the builder to run and switch on 128M anyway).Had to Reboot Pakistan and Valdivia, due to the same issue that happend on JP.
- Added Ubuntu Noble Numbat (LXC/KVM)
Reinstalling seems to silently undo Nesting (panel still shows Disable Nesting). Just need to toggle afterwards, no biggie.
Its recreating the container and by default it has nesting not enabled.
Hence its disabled, however it should show it as disabled and not enabled.
Fixed that.
Smol update.
Got this email, what does this mean?
https://microlxc.net/
@Neoon got it.
