Storage server in USA to replace Hetzner in USA
I currently have a 8 by 4TB TB HDD with a 480GB SSD from Hetzner, This server has been good without a fault apart from latency from the USA which i would like to explore options to replace as of now. Storage is the main part but having a decent CPU and network is just as important.
Requirements
~30TB HDD after raid 5, more would be appreciated with at most a $1.4 USD per TB.
Atleast 480GB SSD for OS and cache
128GB RAM DDR4
CPU is largely open but can be atleast 8 core skylake or newer, Intel or AMD. ARM Is an an open option too.
Uplink 1Gbps, 10Gbps option if reasonably priced would be considered. Required 15 TB per month.
Will pay more if upgrades can be offered on the HDD's as requirements expand.
Does Hetzner, OVH or Netcup offer servers in the US?
hetzner to an extent yes, ovh in canda somehat, netcup |
hetzner no, ovs somewhat, netcup not a chance.
I think Crunchbits has the potential to fulfill your requirements in the US.
Free Online DevTools
Yeah, maybe hit up @crunchbits
that's pretty amazing at $1.4 per TB. Was it some kind of special? Isn't it normally around $3/TB in the US?
Shiiiiit. If I could get 30 TB for $45 a month I might donate a kidney
Yeah, this is possible, as long as that $1.4 per TB only applies to the HDD disks, not the RAM or the CPU.
Contact me at: +1 (509) 606-3569 or [email protected]
Will DM you
Hong Kong, United Kingdom, The Netherlands, Lithuania, Switzerland VPS / Dedicated Servers - DDoS Protected, 1 / 10 Gbit Unmetered, NAT and more
