microLXC Public Test
1121314151618»
  • @Neoon said: Does it work now?
    Yes, it does. And maybe it has all the time. My container's IPv6 changed which I didn't notice.
    You have a /64, you can set any IPv6 address within that /64 static if you want.
    By default you get one allocated via DHCP6, which is based on your mac address.
    However I didn't know that upgrading Ubuntu would flip the mac addresses, interesting.
  • OujiOuji OG
    edited May 19
    @Neoon, hi!
    Thank you for the amazing work.
    Do the LXC support VPN (tun devices)?
  • @Ouji said:
    @Neoon, hi!
    I never used OpenVPN on LXC, so no idea.
    Thanked by (1)Ouji
  • @Neoon said: I never used OpenVPN on LXC, so no idea.
    I will try and report back, but on Proxmox you need to passthrough the TUN device for it to work (or have the container privileged).
    Thanks!
    Thanks!
    It works, I have wireguard setup on it.
    Thanked by (1)Ouji
  • @Neoon said:
    Maintenance Announcement
    I mentioned a while ago once Incus becomes LTS, that microLXC will slowly migrate away from LXD.
    Incus is basically a fork from LXD, which has been created a few months after Canonical took over LXD and changed the licenses.
    Technically LXD still has support until 2029, so does Incus, however due to the consistent issues, with LXD and snap, I did choose to migrate to Incus.
    So far my testing has gone without any issues, hence I want to start migrating the first nodes.
    The first batch of Nodes that will be migrated this Weekend are Johannesburg and Valdivia.
    This will be done Sunday, 19th of May, at around 20:00 GMT.
    Downtime should be minimal, expected to be 10 minutes or less, since no reboot is needed.
    Its done, please lemme know if you face any issues.
    Thanked by (1)Ouji
    Thanks!
    Yes, wireguard works because the kernel is new enough to have the kernel module build in.
  • Good news everyone, the prefix for Islamabad has been announced.
    However, still no ETA on JP.
    Thanks to @host_c and Virtury
    Yeeeee!!!
  • Thanks @host_c ;)
    Thanked by (1)host_c
    "He sounds like hearing him say to the liquor merchant: you who sell it what buys you better ?"
    F. De André --- Free NAT KVM
  • offtopic, is this still a "public test"?
    Yes, maybe at some point when everything runs on Incus and the backend is rewritten no more.
    Thanked by (2)Otus9051 host_c
  • NeoonNeoon OG
    edited May 26
    Next batch for migrating to Incus.
    Affected Nodes
    Tokyo, Auckland, Melbourne and Groningen
    Expected downtime roughly 5-10 minutes, per Node.
    Will be carried out at Friday, 31th of May, at around 20:00 GMT.
    Thanked by (2)carlin0 Wonder_Woman
  • Thank you
    Affected Nodes
    Auckland went fine, however there have been complications with Tokyo and Melbourne, the majority of the Containers are back up running however I could not bring back up 4 containers.
    Still have to figure out why, will update once I know more.
  • All contains are up and running.
