microLXC Public Test
11415161820
  • @Neoon said: Does it work now?
    Yes, it does. And maybe it has all the time. My container's IPv6 changed which I didn't notice.
    You have a /64, you can set any IPv6 address within that /64 static if you want.
    By default you get one allocated via DHCP6, which is based on your mac address.
    However I didn't know that upgrading Ubuntu would flip the mac addresses, interesting.
  • OujiOuji OG
    edited May 2024
    @Neoon, hi!
    Thank you for the amazing work.
    Do the LXC support VPN (tun devices)?
    @Ouji said:
    @Neoon, hi!
    I never used OpenVPN on LXC, so no idea.
    Thanked by (1)Ouji
  • @Neoon said: I never used OpenVPN on LXC, so no idea.
    I will try and report back, but on Proxmox you need to passthrough the TUN device for it to work (or have the container privileged).
    Thanks!
    Thanks!
    It works, I have wireguard setup on it.
    Thanked by (1)Ouji
    @Neoon said:
    Maintenance Announcement
    I mentioned a while ago once Incus becomes LTS, that microLXC will slowly migrate away from LXD.
    Incus is basically a fork from LXD, which has been created a few months after Canonical took over LXD and changed the licenses.
    Technically LXD still has support until 2029, so does Incus, however due to the consistent issues, with LXD and snap, I did choose to migrate to Incus.
    So far my testing has gone without any issues, hence I want to start migrating the first nodes.
    The first batch of Nodes that will be migrated this Weekend are Johannesburg and Valdivia.
    This will be done Sunday, 19th of May, at around 20:00 GMT.
    Downtime should be minimal, expected to be 10 minutes or less, since no reboot is needed.
    Its done, please lemme know if you face any issues.
    Thanked by (1)Ouji
    Yes, wireguard works because the kernel is new enough to have the kernel module build in.
    Good news everyone, the prefix for Islamabad has been announced.
    However, still no ETA on JP.
    Thanks to @host_c and Virtury
    Yeeeee!!!
  • carlin0carlin0 Retired
    Thanks @host_c ;)
    Thanked by (1)host_c
    F. Battiato ---
  • offtopic, is this still a "public test"?
    Yes, maybe at some point when everything runs on Incus and the backend is rewritten no more.
    Thanked by (2)Otus9051 host_c
    edited May 2024
    Next batch for migrating to Incus.
    Affected Nodes
    Tokyo, Auckland, Melbourne and Groningen
    Expected downtime roughly 5-10 minutes, per Node.
    Will be carried out at Friday, 31th of May, at around 20:00 GMT.
    Thanked by (2)carlin0 Wonder_Woman
    Affected Nodes
    Auckland went fine, however there have been complications with Tokyo and Melbourne, the majority of the Containers are back up running however I could not bring back up 4 containers.
    Still have to figure out why, will update once I know more.
    All contains are up and running.
    edited June 2024
    Maintenance Announcement For Oradea
    On June 10, 2024, we will perform node security updates and patches. These updates require a reboot of the node/physical server to be applied. The expected downtime is approximately 15 to 25 minutes per node.
    During this time, your VPS will be powered down.
    Operations will begin at 17:00 CET (Central European Time).
    Thanked by (3)carlin0 host_c ElonBezos
  • is this where i post token still
    if so
    39ab-31d4-28d7-735c
    lex.st - Free Shared Hosting in 4 Locations. fk ipv6.
    Forgot to post this Yesterday.
    We will conduct routing Infrastructure Upgrade and optimisations on 20-June-2024 starting at 08:00 AM untill 10:00 AM Romania, Bucharest time.
    During this time, internet conectivity will be interupted ocassionally to your services.
    We estimate a downtime of 10 to 30 minutes for IPV4 and 1 to 2 ours for IPV6.
    Also Regarding Chile.
    There has been a Network outage for roughly 6 hours, this has been resolved however the cause seems to be still unknown.
    Thanked by (1)carlin0
    edited June 2024
    The Deployment issue in Oradea has been fixed.
    For some reason a TLS Certificate wasn't renewed by the cron.
    That moment when CRON does not run
    edited June 2024
    Currently some KVM templates are broken, will look into this when I got time.
    Meanwhile you can still mount netboot.xyz and install Manually if you need that specific OS.
  • I've been meaning to play with this. Things are slow at work, so, why not? Thanks Neoon!
    c803-f6a4-1ce1-9e31
    Thanked by (1)Neoon
    It's pronounced hacker.
    Fixed, please lemme know if you have any issues regarding KVM deployments.
    Vilnius and Milan are now available.
    Thanks to https://www.hosteroid.uk/ and https://synthohosting.net/
    However, there seems to be an issue with the quotas.
    Looks like I have to change the storage driver.
    Please backup your data if you have any, I am gonna wipe the data disk tomorrow and switch the storage driver.
    The Locations will be available shortly afterwards.
    Thanked by (1)Wonder_Woman
    Everyone that has a Container on either Milan or Vilnius has been notified.
    As soon the last container has been removed, I will change the storage driver and the location will be available again shortly.
    Available again, took a bit longer since I waited for the last confirmation.
    Thanked by (2)Wonder_Woman ElonBezos
