Yes, it does. And maybe it has all the time. My container's IPv6 changed which I didn't notice.
You have a /64, you can set any IPv6 address within that /64 static if you want.
By default you get one allocated via DHCP6, which is based on your mac address.
However I didn't know that upgrading Ubuntu would flip the mac addresses, interesting.
I mentioned a while ago once Incus becomes LTS, that microLXC will slowly migrate away from LXD.
Incus is basically a fork from LXD, which has been created a few months after Canonical took over LXD and changed the licenses.
Technically LXD still has support until 2029, so does Incus, however due to the consistent issues, with LXD and snap, I did choose to migrate to Incus.
So far my testing has gone without any issues, hence I want to start migrating the first nodes.
The first batch of Nodes that will be migrated this Weekend are Johannesburg and Valdivia.
This will be done Sunday, 19th of May, at around 20:00 GMT.
Downtime should be minimal, expected to be 10 minutes or less, since no reboot is needed.
Its done, please lemme know if you face any issues.
@Neoon said: Maintenance Announcement
Next batch for migrating to Incus.
Affected Nodes
Tokyo, Auckland, Melbourne and Groningen
Expected downtime roughly 5-10 minutes, per Node.
Will be carried out at Friday, 31th of May, at around 20:00 GMT.
Auckland went fine, however there have been complications with Tokyo and Melbourne, the majority of the Containers are back up running however I could not bring back up 4 containers.
Still have to figure out why, will update once I know more.
On June 10, 2024, we will perform node security updates and patches. These updates require a reboot of the node/physical server to be applied. The expected downtime is approximately 15 to 25 minutes per node.
During this time, your VPS will be powered down.
Operations will begin at 17:00 CET (Central European Time).
Currently some KVM templates are broken, will look into this when I got time.
Meanwhile you can still mount netboot.xyz and install Manually if you need that specific OS.
Fixed, please lemme know if you have any issues regarding KVM deployments.
Everyone that has a Container on either Milan or Vilnius has been notified.
As soon the last container has been removed, I will change the storage driver and the location will be available again shortly.
@Neoon, hi!
Thank you for the amazing work.
Do the LXC support VPN (tun devices)?
I never used OpenVPN on LXC, so no idea.
I will try and report back, but on Proxmox you need to passthrough the TUN device for it to work (or have the container privileged).
Thanks!
It works, I have wireguard setup on it.
Yes, wireguard works because the kernel is new enough to have the kernel module build in.
Good news everyone, the prefix for Islamabad has been announced.
However, still no ETA on JP.
Thanks to @host_c and Virtury
Yeeeee!!!
Thanks @host_c
F. Battiato ---
offtopic, is this still a "public test"?
Yes, maybe at some point when everything runs on Incus and the backend is rewritten no more.
Affected Nodes
Thank you
Mine is up @Neoon
https://microlxc.net/
All contains are up and running.
Maintenance Announcement For Oradea
is this where i post token still
if so
39ab-31d4-28d7-735c
Forgot to post this Yesterday.
We will conduct routing Infrastructure Upgrade and optimisations on 20-June-2024 starting at 08:00 AM untill 10:00 AM Romania, Bucharest time.
During this time, internet conectivity will be interupted ocassionally to your services.
We estimate a downtime of 10 to 30 minutes for IPV4 and 1 to 2 ours for IPV6.
Also Regarding Chile.
There has been a Network outage for roughly 6 hours, this has been resolved however the cause seems to be still unknown.
The Deployment issue in Oradea has been fixed.
For some reason a TLS Certificate wasn't renewed by the cron.
That moment when CRON does not run
I've been meaning to play with this. Things are slow at work, so, why not? Thanks Neoon!
c803-f6a4-1ce1-9e31
It's pronounced hacker.
Vilnius and Milan are now available.
Thanks to https://www.hosteroid.uk/ and https://synthohosting.net/
However, there seems to be an issue with the quotas.
Looks like I have to change the storage driver.
Please backup your data if you have any, I am gonna wipe the data disk tomorrow and switch the storage driver.
The Locations will be available shortly afterwards.
Available again, took a bit longer since I waited for the last confirmation.
