@Neoon said:
No info about Chile though, the prefixes disappeared from the routing table entirely.
Will post here when I know more.
Here's the email Zappie sent yesterday:
At about 5:50am 29th June NZST (About 3 hours prior from this notification being sent) we have noticed that there has been network distributions in our Chile facility.
We are in communication with a datacenter tech (our upstreams) who are investigating the fault. So far we have been told that there has been power related failures in the facility
We are hoping and expect things to come back online within the next hour or so, and will continue to get updates from the upstream datacenter
Yea he send out an email correct, I didn't noticed it because my monitoring was going off and the email went under.
Thanks for posting though.
Bratislava is now available thanks to @Hosteroid
Groningen is not longer available and will be discontinued in a few weeks, replacement Node in Meppel should be up by end of the week.
Meppel is now available as replacement for Groningen, same packages as before.
Everyone that still has a container or virtual-machine on Groningen will be notified, in a bit, to give them enough time to migrate.
Recently there has been made a change to Incus, which requires an additional device.
That by default isn't added, hence some virtual machines refuse to boot.
So far as of my knowledge, it only affects CentOS Stream on Meppel, which is our first Incus kvm node.
If you run into issues, please choose a different OS for now, until a fix is available.
Fixed an issue which would prevent some os templates from booting up successfully when deployed as KVM
There is still an issue though, with the Shell on these os templates, will resolve this later.
Added an option to reconfigure the network
If an IPv6 Prefix is changed or IPv6 connectivity is added, this will update the network configuration on the fly
Upgrades are now available for LXC containers @Fritz
Downgrades will follow (LXC only), same for upgrades for KVM.
Containers that exceed the 50% usage cpu cap for more than 2 hours, will be rebooted automatically, this wasn't enabled before
You will get a bunch of emails as before, if your usage is below 50% its considered fine for now, however keep it reasonable.
Nice!!
One problem, does upgrade mean get a higher plan?
Can I just upgrade a small portion of Memory or disk?
Nice!!
Yeah, No that would be way to much work.
However if you got a suggestion for a Package, lemme know.
Patchnotes
- Renamed Upgrade to Resize
- Fixed a bug that won't list all packages when up/downgrading
- Added Support for Downgrades on LXC containers
As long you have enough free disk space you can downgrade you container all the way to 64MB.
There will be electrical maintenance today through 23:30 to 06:00 CET.
There will be 2 complete blackouts, and partial or most servers might be down for the period depending upon how much load the diesel generator can take.
@Neoon said: Maintenance Announcement for Helsinki
Restocked Vilnius.
IPv6 connectivity issue in Milan has been fixed.
Restocked Milan.
35e7-cea6-f41d-600b
I really want a New Zealand VPS test, but unfortunately my account does not meet the requirements. Thank you anyway
Good luck with it!![o:) o:)](https://lowendspirit.com/plugins/emojiextender/emoji/twitter/innocent.png)
nice services 🤝🏽
Restocked Bratislava.
Hi @Neoon
Can we upgrade the container (Memory / Disk) without terminate it?
or at least by re-install it.
https://microlxc.net/
Not as of right now.
Should be available in a bit.
Patchnotes
Restocked Meppel
Mumbai is now available, Thanks to https://webhorizon.net / @Abdullah
Node was already ready on Monday, however since I had stuff to do a bit delayed.
Node YABS: https://lowendspirit.com/discussion/comment/183825#Comment_183825
Currently 6 Packages are available.
Any suggestions regarding the packages? lemme know.
Patchnotes
Nice!!
Patchnotes
Will post here, when the maintenance is done.
Done, roughly 10 minutes of downtime.
There was a Raid failure on the Italy node, which made the file system read only.
I will post here when I know more.
edit: Resolved.
NZ is back online, Ticket pending.
